FN15622
FN15622
    LEDIL(芬兰)
    FN15622
FN15622 数据手册
PRODUCT DATASHEET RONDA-REC-60 RONDA-REC-60 ~60° + 60° rectangular beam with holder A compatible with 3rd party connectors from TE, Bender+Wirth and IDEAL TECHNICAL SPECIFICATIONS: Dimensions Ø 69.9 mm Height 14.6 mm Fastening socket ROHS compliant yes MATERIAL SPECIFICATIONS: Component Type Material Colour F15556_RONDA-REC-60 Single lens PMMA clear F15155_RONDA-HLD-A Holder PC white Finish ORDERING INFORMATION: Quantities for one set: Single lens 1 Holder 1 Last update: 24/05/2018 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/10 PRODUCT DATASHEET RONDA-REC-60 Component Qty in box MOQ MPQ Box weight (kg) F15556_RONDA-REC-60 » Box size: 480 x 280 x 300 mm Single lens 420 120 30 6.7 F15155_RONDA-HLD-A » Box size: 480 x 280 x 300 mm Holder 420 120 30 4.4 Last update: 24/05/2018 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/10 PRODUCT DATASHEET RONDA-REC-60 Last update: 24/05/2018 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/10 PRODUCT DATASHEET RONDA-REC-60 See also our general installation guide: www.ledil.com/installation_guide Last update: 24/05/2018 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/10 PRODUCT DATASHEET RONDA-REC-60 PHOTOMETRIC DATA (MEASURED): LED Vero SE 13 FWHM / FWTM 58.0° / 103.0° Efficiency 90 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: C16402_CLAMP-VEROSE-13-18 LED CLL03x/CLU03x FWHM / FWTM 57.0° / 104.0° Efficiency 89 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: C16791_CLAMP-Z45-A TE Connectivity: 2325807-3 LED CMA1840 FWHM / FWTM 60.0° / 109.0° Efficiency 90 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: C14123_CLAMP-CXA15-18 LED CXA/B 15xx FWHM / FWTM 63.0° / 104.0° Efficiency 91 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: C14123_CLAMP-CXA15-18 Last update: 24/05/2018 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/10 PRODUCT DATASHEET RONDA-REC-60 PHOTOMETRIC DATA (MEASURED): LED CXA/B 1816 & CXA/B 1820 & CXA 1850 FWHM / FWTM 60.0° / 104.0° Efficiency 91 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: C14123_CLAMP-CXA15-18 LED PrevaLED Core G7 L15 H1 FWHM / FWTM 55.0° / 104.0° Efficiency 81 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: C16685_CLAMP-PRV-A Last update: 24/05/2018 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/10 PRODUCT DATASHEET RONDA-REC-60 PHOTOMETRIC DATA (SIMULATED): LED H9 FWHM / FWTM 63.0° Efficiency 91 % LEDs/each optic 1 Light colour White Required components: C13658_CLAMP-VERO13-18 Bender Wirth: 441 Typ L1 LED H9 FWHM / FWTM 63.0° Efficiency 91 % LEDs/each optic 1 Light colour White Required components: C14123_CLAMP-CXA15-18 LED V13 Gen7 FWHM / FWTM 60.0° Efficiency 87 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: C13658_CLAMP-VERO13-18 Bender Wirth: 477 Typ L1 LED CLU700/701/702 FWHM / FWTM 65.0° Efficiency 90 % LEDs/each optic 1 Light colour White Required components: C13658_CLAMP-VERO13-18 Bender Wirth: 434 Typ L1 Last update: 24/05/2018 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/10 PRODUCT DATASHEET RONDA-REC-60 PHOTOMETRIC DATA (SIMULATED): LED CLU710/711 FWHM / FWTM 61.0° Efficiency 90 % LEDs/each optic 1 Light colour White Required components: C13658_CLAMP-VERO13-18 Bender Wirth: 470 Typ L1 LED CXA/B 13xx FWHM / FWTM 65.0° Efficiency 90 % LEDs/each optic 1 Light colour White Required components: C13658_CLAMP-VERO13-18 Bender Wirth: 448 Typ L1 LED CXA/B 15xx FWHM / FWTM 62.0° Efficiency 89 % LEDs/each optic 1 Light colour White Required components: C13658_CLAMP-VERO13-18 Bender Wirth: 441 Typ L1 LED LUXEON CoB 1202s FWHM / FWTM 61.0° Efficiency 90 % LEDs/each optic 1 Light colour White Required components: C13658_CLAMP-VERO13-18 Bender Wirth: 452 Typ L1 Last update: 24/05/2018 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/10 PRODUCT DATASHEET RONDA-REC-60 PHOTOMETRIC DATA (SIMULATED): LED NSCxL036A FWHM / FWTM 58.0° / 88.0 + 94.0° Efficiency 89 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour White Required components: TE Connectivity: 2213382-2 + OPTIC CLIP Z50 TYPE1 2213194-1 LED Mini Zenigata (GW6BM) FWHM / FWTM 60.0° Efficiency % LEDs/each optic 1 Light colour White Required components: C13658_CLAMP-VERO13-18 Bender Wirth: 452 Typ L1 Last update: 24/05/2018 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/10 PRODUCT DATASHEET RONDA-REC-60 GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 24/05/2018 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/10
FN15622
1. 物料型号: - 型号名称:RONDA-REC-60 - 包含组件:单一透镜(Single lens)和支架(Holder)
2. 器件简介: - 描述:RONDA-REC-60是一个具有约60° + 60°矩形光束角度的灯具,配有A型支架,兼容TE、Bender+Wirth和IDEAL的第三方连接器。
3. 引脚分配: - 文档中没有明确提到引脚分配,但提到了与Bender Wirth连接器的兼容性,并且有一个用于对齐的夹子和孔。
4. 参数特性: - 尺寸:直径69.9毫米,高度14.6毫米 - 固定方式:有插座 - 材料:透镜为PMMA,支架为PC - 颜色:透镜透明,支架白色 - 订购信息:每套包含一个透镜和一个支架,最小订购量为120套,最大订购量为30套
5. 功能详解: - 光度数据:文档提供了不同LED(如Bridgelux、CITIZEN、TE Connectivity、CREE、OSRAM等)的光度数据,包括半峰全宽(FWHM)、半高全宽(FWTM)、效率和峰值强度。 - 热设计:由于使用高功率COB,特别推荐注意适当的热设计。
6. 应用信息: - 应用:适用于需要特定光束角度的照明应用,如商业照明、工业照明等。
7. 封装信息: - 封装类型:每盒420个透镜和420个支架 - 盒尺寸:480x280x300毫米 - 重量:透镜盒重6.7公斤,支架盒重4.4公斤
8. 一般信息: - 光束角度可能会因不同的颜色、芯片尺寸和芯片位置公差而变化。 - LEDiL保留在不通知的情况下更改材料等级的权利。 - 产品数据表和机械2D图纸中提供的测量数据仅供参考。
9. 免责声明: - LEDiL不对提供的数据内容和准确性提供任何保证或担保。 - LEDiL保留在不通知的情况下对其产品进行技术更改的权利。
FN15622 价格&库存
很抱歉,暂时无法提供与“FN15622”相匹配的价格&库存,您可以联系我们找货
