AS7263-BLGM
AS7263-BLGM
    AMSOSRAM(艾迈斯半导体)
    LGA20_4.5X4.7MM
    AS7263-BLGM
AS7263-BLGM 数据手册
AS7263 6-Channel NIR Spectral_ID Device with Electronic Shutter and Smart Interface General Description The AS7263 is a digital 6-channel spectrometer for spectral identification in the near IR (NIR) light wavelengths. AS7263 consists of 6 independent optical filters whose spectral response is defined in the NIR wavelengths from approximately 600nm to 870nm with full-width half-max (FWHM) of 20nm. An integrated LED driver with programmable current is provided for electronic shutter applications. The AS7263 integrates Gaussian filters into standard CMOS silicon via Nano-optic deposited interference filter technology and is packaged an LGA package that provides a built in aperture to control the light entering the sensor array. Control and Spectral data access is implemented through either the I²C register set, or with a high level AT Spectral Command set via a serial UART. Ordering Information and Content Guide appear at end of datasheet. Key Benefits & Features The benefits and features of AS7263, 6-Channel NIR Spectral_ID Device with Electronic Shutter and Smart Interface are listed below: Figure 1: Added Value of Using AS7263 Benefits Features • Compact 6-channel spectrometry solution • 6 near-IR channels: 610nm, 680nm, 730nm, 760nm, 810nm and 860nm, each with 20nm FWHM • Simple text-based command interface via UART, or direct register read and write with interrupt on sensor ready option on I²C • UART or I²C slave digital Interface • Lifetime-calibrated sensing with no drift over time or temperature • NIR filter set realized by silicon interference filters • No additional signal conditioning required • 16-bit ADC with digital access • Electronic shutter control/synchronization • Programmable LED drivers • Low voltage operation • 2.7V to 3.6V with I²C interface • Small, robust package, with built-in aperture • 20-pin LGA package 4.5mm x 4.7mm x 2.5mm, -40°C to 85°C temperature range ams Datasheet [v1-00] 2016-Nov-25 Page 1 Document Feedback AS7263 − General Description Applications The AS7263 applications include: • Product authentication • Bank note/document validation • Chemical analysis • Food/beverage safety Block Diagram The functional blocks of this device are shown below: Figure 2: AS7263 NIR Spectral_ID System 3V 100nF uP 10uF VDD1 VDD2 RX / SCL_S TX / SDA_S LED_IND INT LED_DRV AS7263 Flash Memory MOSI MISO SCK CSN_EE GND Page 2 Document Feedback 6-channel NIR Sensor 3V 3V Light Source Light in Reflective Surface ams Datasheet [v1-00] 2016-Nov-25 AS7263 − Pin Assignment Pin Assignment The device pin assignments are described below. Figure 3: Pin Diagram (Top View) 20 16 1 15 5 11 6 10 Figure 4: Pin Description Pin Number Pin Name 1 NF 2 RESN Reset, Active LOW 3 SCK SPI Serial Clock 4 MOSI SPI Master Out Slave In 5 MISO SPI Master In Slave Out 6 CSN_EE Chip Select for External Serial Flash Memory, Active LOW 7 CSN_SD Chip Select for SD Card Interface, Active LOW 8 I2C_ENB Select UART (Low) or I²C (High) Operation 9 NF Not Functional. Do not connect. 10 NF Not Functional. Do not connect. 11 RX/SCL_S RX (UART) or SCL_S (I²C Slave) Depending on I²C_ENB 12 TX/SDA_S TX (UART) or SDA_S (I²C Slave) Depending on I²C_ENB 13 INT 14 VDD2 ams Datasheet [v1-00] 2016-Nov-25 Description Not Functional. Do not connect. Interrupt, Active LOW Voltage Supply Page 3 Document Feedback AS7263 − Pin Assignment Pin Number Pin Name 15 LED_DRV 16 GND Ground 17 VDD1 Voltage Supply 18 LED_IND 19 NF Not Functional. Do not connect. 20 NF Not Functional. Do not connect. Page 4 Document Feedback Description LED Driver Output for Driving LED, Current Sink LED Driver Output for Indicator LED, Current Sink ams Datasheet [v1-00] 2016-Nov-25 AS7263 − Absolute Maximum Ratings Absolute Maximum Ratings Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated under Electrical Characteristics is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. The device is not designed for high energy UV (ultraviolet) environments, including upward looking outdoor applications, which could affect long term optical performance. Figure 5: Absolute Maximum Ratings Symbol Parameter Min Max Units Comments Electrical Parameters VDD1_MAX Supply Voltage VDD1 -0.3 5 V Pin VDD1 to GND VDD2_MAX Supply Voltage VDD2 -0.3 5 V Pin VDD2 to GND Input/Output Pin Voltage -0.3 VDD+0.3 V Input/Output Pin to GND VDD_IO ISCR Input Current (latch-up immunity) ± 100 mA JESD78D Electrostatic Discharge ESDHBM Electrostatic Discharge HBM ± 1000 V JS-001-2014 ESDCDM Electrostatic Discharge CDM ± 500 V JSD22-C101F Temperature Ranges and Storage Conditions TSTRG Storage Temperature Range TBODY Package Body Temperature RHNC Relative Humidity (non-condensing) MSL Moisture Sensitivity Level ams Datasheet [v1-00] 2016-Nov-25 -40 85 5 3 °C 260 °C 85 % IPC/JEDEC J-STD-020 The reflow peak soldering temperature (body temperature) is specified according to IPC/JEDEC J-STD-020 “Moisture/Reflow Sensitivity Classification for Non-hermetic Solid State Surface Mount Devices.” Maximum floor life time of 168 hours Page 5 Document Feedback AS7263 − Electrical Characteristics Electrical Characteristics All limits are guaranteed with VDD = VDD1 = VDD2 = 3.3V, TAMB=25°C. The parameters with min and max values are guaranteed with production tests or SQC (Statistical Quality Control) methods. Figure 6: Electrical Characteristics of AS7263 Symbol Parameter Conditions Min Typ Max Unit General Operating Conditions VDD1 /VDD2 Voltage Operating Supply UART Interface 2.97 3.3 3.6 V VDD1 /VDD2 Voltage Operating Supply I2C Interface 2.7 3.3 3.6 V TAMB Operating Temperature -40 25 85 °C IVDD Operating Current 5 mA ISTANDBY(1) Standby Current 12 μA Internal RC Oscillator FOSC Internal RC Oscillator Frequency tJITTER(2) Internal Clock Jitter 15.7 16 16.3 MHz 1.2 ns 8.5 °C 8 mA -30 30 % 0.3 VDD V 12.5 100 mA -10 10 % 0.3 VDD V @25°C Temperature Sensor DTEMP Absolute Accuracy of the Temperature Measurement -8.5 Indicator LED IIND LED Current IACC Accuracy of Current VLED Voltage Range of Connected LED 1 Vds of current sink 4 LED_DRV ILED1 LED Current IACC Accuracy of Current VLED Voltage Range of Connected LED Page 6 Document Feedback 12.5, 25, 50 or 100 Vds of current sink ams Datasheet [v1-00] 2016-Nov-25 AS7263 − Electrical Characteristics Symbol Parameter Conditions Min Typ Max Unit Digital Inputs and Outputs IIH, IIL Logic Input Current Vin=0V or VDD -1 1 μA IILRESN Logic Input Current (RESN pin) Vin=0V -1 -0.2 mA VIH CMOS Logic High Input 0.7* VDD VDD V VIL CMOS Logic Low Input 0 0.3* VDD V VOH CMOS Logic High Output I=1mA VDD 0.4 V VOL CMOS Logic Low Output I=1mA 0.4 V tRISE(2) Current Rise Time C(Pad)=30pF 5 ns tFALL(2) Current Fall Time C(Pad)=30pF 5 ns Note(s): 1. 15μA over temperature 2. Guaranteed, not tested in production ams Datasheet [v1-00] 2016-Nov-25 Page 7 Document Feedback AS7263 − Timing Characteristics Timing Characteristics Figure 7: AS7263 I²C Slave Timing Characteristics Symbol Parameter Condition Min Typ Max Unit 400 kHz I²C Interface fSCLK SCL Clock Frequency 0 tBUF Bus Free Time Between a STOP and START 1.3 μs tHS:STA Hold Time (Repeated) START 0.6 μs tLOW LOW Period of SCL Clock 1.3 μs tHIGH HIGH Period of SCL Clock 0.6 μs tSU:STA Setup Time for a Repeated START 0.6 μs tHS:DAT Data Hold Time 0 tSU:DAT Data Setup Time 100 tR Rise Time of Both SDA and SCL 20 300 ns tF Fall Time of Both SDA and SCL 20 300 ns tSU:STO Setup Time for STOP Condition 0.6 CB Capacitive Load for Each Bus Line CI/O I/O Capacitance (SDA, SCL) Page 8 Document Feedback CB — total capacitance of one bus line in pF 0.9 μs ns μs 400 pF 10 pF ams Datasheet [v1-00] 2016-Nov-25 AS7263 − Timing Characteristics Figure 8: I²C Slave Timing Diagram tR tF tLOW SCL P tHIGH S tHD:STA S tSU:DAT tHD:DAT P t SU:STA tSU:STO VIH SDA tBUF Stop VIL Start Figure 9: AS7263 SPI Timing Characteristics Symbol Parameter Conditions Min Typ Max Unit 16 MHz SPI Interface fSCK Clock Frequency 0 tSCK_H Clock High Time 40 ns tSCK_L Clock Low Time 40 ns tSCK_RISE SCK Rise Time 5 ns tSCK_FALL SCK Fall Time 5 ns tCSN_S CSN Setup Time Time between CSN high-low transition to first SCK high transition 50 ns tCSN_H CSN Hold Time Time between last SCK falling edge and CSN low-high transition 100 ns tCSN_DIS CSN Disable Time 100 ns tDO_S Data-Out Setup Time 5 ns tDO_H Data-Out Hold Time 5 ns tDI_V Data-In Valid 10 ns Note(s): 1. Guaranteed, not tested in production ams Datasheet [v1-00] 2016-Nov-25 Page 9 Document Feedback AS7263 − Timing Characteristics Figure 10: SPI Master Write Timing Diagram tCSN_DIS CSN tSCK_RISE tCSN_S tCSN_H tSCK_FALL SCK t DO_S MOSI tDO_H MSB LSB HI-Z HI-Z MISO Figure 11: SPI Master Read Timing Diagram CSN_xx tSCK_H tSCK_L SCK tDI_V Dont care MOSI MISO Page 10 Document Feedback MSB LSB ams Datasheet [v1-00] 2016-Nov-25 AS7263 − Timing Characteristics Optical Characteristics Figure 12: Optical Characteristics of AS7263 (Pass Band)(1) Parameter Test Conditions Channel (nm) R Channel R Incandescent (2), (4) 610 35 (3),(4) counts/ (μW/cm2) S Channel S Incandescent (2), (4) 680 35 (3),(4) counts/ (μW/cm2) T Channel T Incandescent (2), (4) 730 35 (3),(4) counts/ (μW/cm2) U Channel U Incandescent (2), (4) 760 35 (3),(4) counts/ (μW/cm2) V Channel V Incandescent (2), (4) 810 35 (3),(4) counts/ (μW/cm2) W Channel W Incandescent (2), (4) 860 35 (3),(4) counts/ (μW/cm2) FWHM Full Width Half Max 20 20 nm ±5 nm Symbol Wacc Wavelength Accuracy dark Dark Channel Counts GAIN=64, TAMB=25°C f Angle of Incidence On the sensors Min Typ Max 5 Unit counts ±20.0 deg Note(s): 1. Calibration & measurements are made using diffused light. 2. Each channel is tested with GAIN = 16x, Integration Time (INT_T) = 166ms and VDD = VDD1 = VDD2 = 3.3V, TAMB=25°C. 3. The accuracy of the channel counts/μW/cm 2 is ±12%. 4. The light source is an incandescent light with an irradiance of ~1500μW/cm 2 (300-1000nm). The energy at each channel (R, S, T, U, V, W) is calculated with a ±33nm bandwidth around the center wavelengths (610, 680, 730, 760, 810, 860nm). ams Datasheet [v1-00] 2016-Nov-25 Page 11 Document Feedback AS7263 − Typical Operating Characteristics Typical Operating Characteristics Figure 13: Spectral Responsivity AS7263 1 Normalized Responsivity 0.9 0.8 0.7 R 0.6 S 0.5 T 0.4 U 0.3 V 0.2 W 0.1 0 550 600 650 700 750 800 850 900 950 λ - Wavelength (nm) Page 12 Document Feedback ams Datasheet [v1-00] 2016-Nov-25 AS7263 − Detailed Description Detailed Description Figure 14: Internal Block Diagram VDD1 VDD2 INT LED_IND RX / SCL_S 2 UART / I C TX / SDA_S I2C_ENB LED_DRV °C Spectral_ID Engine MISO SPI Master MOSI SCK CSN_SD Multi Spectral Sensor R S T U V W SYNC / RESN RC Osc 16MHz GND 6-Channel NIR Spectral_ID Detector The AS7263 6-channel Spectral_ID is a next-generation digital spectral sensor device. Each channel has a Gaussian filter characteristic with a full width half maximum (FWHM) bandwidth of 20nm. The channels are spaced roughly at 50nm intervals in the NIR spectrum: R, S, T, U, V, W. The sensor contains analog-to-digital converters (16-bit resolution ADC), which integrate the current from each channel’s photodiode. Upon completion of the conversion cycle, the integrated result is transferred to the corresponding data registers. The transfers are double-buffered to ensure that the integrity of the data is maintained. Interference filters enable high temperature stability and eliminate lifetime drift. Filter accuracy will be affected by the angle of incidence, and require 0° angle of incidence ±20.0° for specified accuracy. Angles of light beyond this will shift the spectral response of the filters. The LGA package aperture assists in the control of the light input, helping to maintain the proper angle of incidence at the sensors. ams Datasheet [v1-00] 2016-Nov-25 Page 13 Document Feedback AS7263 − Detailed Description Data Conversion Description AS7263 spectral conversion is implemented via two photodiode banks per device. Bank 1 consists of data from the S, T, U, V photodiodes. Bank 2 consists of data from the R, T, U, W photodiodes. Spectral conversion requires the integration time (IT in ms) set to complete. If both photodiode banks are required to complete the conversion, the 2nd bank requires an additional IT ms. Minimum IT for a single bank conversion is 2.8 ms. If data is required from all 6 photodiodes then the device must perform 2 full conversions (2 x Integration Time). The spectral conversion process is controlled with BANK Mode settings as follows: BANK Mode 0: Data will be available in registers S, T, U & V (R and W registers will be zero) BANK Mode 1: Data will be available in registers R, T, U & W (V and W registers will be zero) BANK Mode 2: Data will be available in registers R, S, T, U, V & W When the bank setting is Mode 0, Mode 1, or Mode 2, the spectral data conversion process operates continuously, with new data available after each IT ms period. In the continuous modes, care should be taken to assure prompt interrupt servicing so that integration values from both banks are all derived from the same spectral conversion cycle. BANK Mode 3: Data will be available in registers R, S, T, U, V & W in One-Shot mode When the bank setting is Mode 3, the device operates in One-Shot mode. Spectral conversion occurs only when bit 0 of the control register (1SHOT) is set to 1. The 1SHOT bit in the control register is subsequently cleared by hardware at the same time the DATA_RDY bit is set to 1 indicating the availability of spectral conversion result data. The One-Shot mode is intended for use when it is critical to ensure that spectral conversion results are obtained contemporaneously. Page 14 Document Feedback ams Datasheet [v1-00] 2016-Nov-25 AS7263 − Detailed Description Figure 15: Photo Diode Array Photo Diode Array T U S R V W Figure 16: Bank Mode and Data Conversion BANK Mode 0 One Conversion S, T, U, V Integration Time BANK Mode 1 One Conversion R, T, U, W Integration Time BANK Mode 2 1st Conversion Integration Time S, T, U, V 2nd Conversion R, T, U, W Integration Time RC Oscillator The timing generation circuit consists of an on-chip 16MHz, temperature compensated oscillator, which provides the master clock for the AS7263. ams Datasheet [v1-00] 2016-Nov-25 Page 15 Document Feedback AS7263 − Detailed Description Temperature Sensor The Temperature Sensor is constantly measuring the on-chip temperature and enables temperature compensation procedures. Reset Pulling down the RESN pin for longer than 100ms resets the AS7263. Figure 17: Reset Circuit RESN CLE Reset AS7263 Push > 100ms Indicator LED The LED, connected to pin LED_IND, can be used to indicate programming progress of the device. While programming the AS7263 via the external SD card the indicator LED starts flashing (500ms pulses). When programming is completed the indicator LED is switched off. The LED (LED0) can be turned ON/OFF via AT commands or via I²C register control. The LED sink current is programmable from 1mA, 2mA, 4mA and 8mA. Electronic Shutter with LED_DRV Driver Control There are two LED driver outputs that can be used to control up to 2 LEDs. This will allow different wavelength light sources to be used in the same system. The LED output sink currents are programmable and can drive external LED sources: LED_IND from 1mA, 2mA, 4mA and 8mA and LED_DRV from 12.5mA, 25mA, 50mA and 100mA. The sources can be turned off and on via I²C registers control or AT commands and provides the device with an electronic shutter. Page 16 Document Feedback ams Datasheet [v1-00] 2016-Nov-25 AS7263 − Detailed Description Interrupt Operation If BANK is set to Mode 0 or Mode 1 then the data is ready after the 1 st integration time. If BANK is set to Mode 2 or Mode 3 then the data is ready after two integration times. If the interrupt is enabled (INT = 1) then when the data is ready, the INT line is pulled low and DATA_RDY is set to 1. The INT line is released (returns high) when the control register is read. DATA_RDY is cleared to 0 when any of the sensor registers R, S, T, U, V, W are read. Since each sensor value is 2 bytes, after the 1 st byte is read the 2 nd byte is shadow-protected in case an integration cycle completes just after the 1 st byte is read. In continuous spectral conversion mode (BANK setting of Mode 0, Mode 1, or Mode 2), the sensors continue to gather information at the rate of the integration time, hence if the sensor registers are not read when the interrupt line goes low, it will stay low and the next cycle’s sensor data will be available in the registers at the end of the next integration cycle. When the control register BANK bits are written with a value of Mode 3, One-Shot Spectral Conversion mode is entered. When a single set of contemporaneous sensor readings is desired, writing BANK Mode 3 to the control register immediately triggers exactly two spectral data conversion cycles. At the end of these two conversion cycles, the DATA_RDY bit is set as for the other BANK modes. To perform a new One-Shot sequence, the control register BANK bits should be written with a value of Mode 3 again. This process may continue until the user writes a different value into the BANK bits. I²C Slave Interface If selected by the I2C_ENB pin setting, interface and control can be accomplished through an I²C compatible slave interface to a set of registers that provide access to device control functions and output data. These registers on the AS7263 are, in reality, implemented as virtual registers in software. The actual I²C slave hardware registers number only three and are described in the table below. The steps necessary to access the virtual registers defined in the following are explained in pseudocode for external I²C master writes and reads below. I²C Feature List • Fast mode (400kHz) and standard mode (100kHz) support. • 7+1-bit addressing mode. • Write format: Byte. • Read format: Byte. • SDA input delay and SCL spike filtering by integrated RC-components. ams Datasheet [v1-00] 2016-Nov-25 Page 17 Document Feedback AS7263 − Detailed Description Figure 18: I²C Slave Device Address and Physical Registers Entity Description Note 8-bit Slave Address Byte = 1001 001x x= 1 for Master Read (byte = 93 hex) x= 0 for Master Write (byte = 92 hex) STATUS Register I²C slave interface STATUS register. Read-only. Register Address = 0x00 Bit 1: TX_VALID 0 -> New data may be written to WRITE register 1 -> WRITE register occupied. Do NOT write. Bit 0: RX_VALID 0 -> No data is ready to be read in READ register. 1 -> Data byte available in READ register. WRITE Register I²C slave interface WRITE register. Write-only. Register Address = 0x01 8-Bits of data written by the I²C Master intended for receipt by the I²C slave. Used for both virtual register addresses and write data. READ Register I²C slave interface READ register. Read-only. Register Address = 0x02 8-Bits of data to be read by the I²C Master. Device Slave Address I²C Virtual Register Write Access Figure 19 shows the pseudocode necessary to write virtual registers on the AS7263. Note that, because the actual registers of interest are realized as virtual registers, a means of indicating whether there is a pending read or write operation of a given virtual register is needed. To convey this information, the most significant bit of the virtual register address is used as a marker. If it is 1, then a write is pending, otherwise the slave is expecting a virtual read operation. The pseudocode illustrates the proper technique for polling of the I²C slave status register to ensure the slave is ready for each transaction. Page 18 Document Feedback ams Datasheet [v1-00] 2016-Nov-25 AS7263 − Detailed Description Figure 19: I²C Virtual Register Byte Write Pseudocode Poll I²C slave STATUS register; If TX_VALID bit is 0, a write can be performed on the interface; Send a virtual register address and set the MSB of the register address to 1 to indicate the pending write; Poll I²C slave STATUS register; If TX_VALID bit is 0, the virtual register address for the write has been received and the data may now be written; Write the data. Sample Code: #define I2C_AS72XX_SLAVE_STATUS_REG0x00 #define I2C_AS72XX_SLAVE_WRITE_REG0x01 #define I2C_AS72XX_SLAVE_READ_REG0x02 #define I2C_AS72XX_SLAVE_TX_VALID0x02 #define I2C_AS72XX_SLAVE_RX_VALID0x01 void i2cm_AS72xx_write(uint8_t virtualReg, uint8_t d) { volatile uint8_tstatus; while (1) { // Read slave I²C status to see if the write buffer is ready. status = i2cm_read(I2C_AS72XX_SLAVE_STATUS_REG); if ((status & I2C_AS72XX_SLAVE_TX_VALID) == 0) // No inbound TX pending at slave. Okay to write now. break ; } // Send the virtual register address (setting bit 7 to indicate a pending write). i2cm_write(I2C_AS72XX_SLAVE_WRITE_REG, (virtualReg | 0x80)) ; while (1) { // Read the slave I2C status to see if the write buffer is ready. status = i2cm_read(I2C_AS72XX_SLAVE_STATUS_REG) ; if ((status & I2C_AS72XX_SLAVE_TX_VALID) == 0) // No inbound TX pending at slave. Okay to write data now. break; } // Send the data to complete the operation. i2cm_write(I2C_AS72XX_SLAVE_WRITE_REG, d); } ams Datasheet [v1-00] 2016-Nov-25 Page 19 Document Feedback AS7263 − Detailed Description I²C Virtual Register Read Access Figure 20 shows the pseudocode necessary to read virtual registers on the AS7263. Note that in this case, reading a virtual register, the register address is not modified. Figure 20: I²C Virtual Register Byte Read Pseudocode Poll I²C slave STATUS register; If TX_VALID bit is 0, the virtual register address for the read may be written; Send a virtual register address; Poll I²C slave STATUS register; If RX_VALID bit is 1, the read data is ready; Read the data. Sample Code: uint8_t i2cm_AS72xx_read(uint8_t virtualReg) { volatile uint8_t status, d ; while (1) { // Read slave I2C status to see if the read buffer is ready. status = i2cm_read(I2C_AS72XX_SLAVE_STATUS_REG) ; if ((status & I2C_AS72XX_SLAVE_TX_VALID) == 0) // No inbound TX pending at slave. Okay to write now. break ; } // Send the virtual register address (setting bit 7 to indicate a pending write). i2cm_write(I2C_AS72XX_SLAVE_WRITE_REG, virtualReg) ; while (1) { // Read the slave I²C status to see if our read data is available. status = i2cm_read(I2C_AS72XX_SLAVE_STATUS_REG) ; if ((status & I2C_AS72XX_SLAVE_RX_VALID) != 0) // Read data is ready. break ; } // Read the data to complete the operation. d = i2cm_read(I2C_AS72XX_SLAVE_READ_REG) ; return d ;s } The details of the i2cm_read() and i2cm_write() functions in previous Figures are dependent upon the nature and implementation of the external I²C master device. Page 20 Document Feedback ams Datasheet [v1-00] 2016-Nov-25 AS7263 − Detailed Description I²C Virtual Register Set The figure below provides a summary of the AS7263 I²C register set. Figures after that provide additional details. All register data is hex or, where noted, 32-bit floating point, and all multi-byte entities are Big Endian (most significant byte is situated at the lowest register address). Figure 21: I²C Register Set Overview Addr Name DATA_ RDY RSVD Version Registers 0x00: 0x01 HW_Version Hardware Version 0x02: 0x03 FW_Version Firmware Version Control Registers 0x04 Control_Setup RST INT 0x05 INT_T Integration Time 0x06 Device_Temp Device Temperature 0x07 LED_Control RSVD GAIN Bank ICL_DRV LED_ DRV ICL_IND LED_IND Sensor Raw Data Registers 0x08 R_High Channel R High Data Byte 0x09 R_Low Channel R Low Data Byte 0x0A S_High Channel S High Data Byte 0x0B S_Low Channel S Low Data Byte 0x0C T_High Channel T High Data Byte 0x0D T_Low Channel T Low Data Byte 0x0E U_High Channel U High Data Byte 0x0F U_Low Channel U Low Data Byte 0x10 V_High Channel V High Data Byte 0x11 V_Low Channel V Low Data Byte 0x12 W_High Channel W High Data Byte 0x13 W_Low Channel W Low Data Byte ams Datasheet [v1-00] 2016-Nov-25 Page 21 Document Feedback AS7263 − Detailed Description Addr Name Sensor Calibrated Data Registers 0x14: 0x17 R_Cal Channel R Calibrated Data (float) 0x18: 0x1B S_Cal Channel S Calibrated Data (float) 0x1C: 0x1F T_Cal Channel T Calibrated Data (float) 0x20: 0x23 U_Cal Channel U Calibrated Data (float) 0x24: 0x27 V_Cal Channel V Calibrated Data (float) 0x28: 0x2B W_Cal Channel W Calibrated Data (float) Detailed Register Description Figure 22: HW Version Registers Addr: 0x00 HW_Version Bit Bit Name Default Access 7:0 Device Type 0100000 R Addr: 0x01 Device type number HW_Version Bit Bit Name Default Access 7:0 HW Version 00111111 R Page 22 Document Feedback Bit Description Bit Description Hardware version ams Datasheet [v1-00] 2016-Nov-25 AS7263 − Detailed Description Figure 23: FW Version Registers Addr: 0x02 FW_Version Bit Bit Name Default Access 7:6 Minor Version R Minor Version [1:0] 5:0 Sub Version R Sub Version Addr: 0x03 Bit Description FW_Version Bit Bit Name Default Access Bit Description 7:4 Major Version R Major Version 3:0 Minor Version R Minor Version [5:2] Figure 24: Control Setup Register Addr: 0x04/0x84 Control_Setup Bit Bit Name Default Access Bit Description 7 RST 0 R/W Soft Reset, Set to 1 for soft reset, goes to 0 automatically after the reset 6 INT 0 R/W Enable interrupt pin output (INT), 1: Enable, 0: Disable 5:4 GAIN 0 R/W Sensor Channel Gain Setting (all channels) ‘b00=1x; ‘b01=3.7x; ‘b10=16x; ‘b11=64x 3:2 BANK 10 R/W Data Conversion Type (continuous) ‘b00=Mode 0; ‘b01=Mode 1; ‘b10=Mode 2; ‘b11=Mode 3 One-Shot 1 DATA_RDY 0 R/W 1: Data Ready to Read, sets INT active if interrupt is enabled. Can be polled if not using INT. 0 RSVD 0 R ams Datasheet [v1-00] 2016-Nov-25 Reserved; Unused Page 23 Document Feedback AS7263 − Detailed Description Figure 25: Integration Time Register Addr: 0x05/0x85 INT_T Bit Bit Name Default Access 7:0 INT_T 0xFF R/W Bit Description Integration time = * 2.8ms Figure 26: Device Temperature Register Addr: 0x06 Bit Bit Name 7:0 Device_Temp Device_Temp Default Access Bit Description Device temperature data byte (°C) R Figure 27: LED Control Register Addr: 0x07/0x87 LED Control Bit Bit Name Default Access 7:6 RSVD 0 R 5:4 ICL_DRV 00 R/W LED_DRV current limit ‘b00=12.5mA; ‘b01=25mA; ‘b10=50mA; ‘b11=100mA 3 LED_DRV 0 R/W Enable LED_DRV 1: Enabled; 0: Disabled 2:1 ICL_IND 00 R/W LED_IND current limit ‘b00=1mA; ‘b01=2mA; ‘b10=4mA; ‘b11=8mA 0 LED_IND 0 R/W Enable LED_IND 1: Enabled; 0: Disabled Page 24 Document Feedback Bit Description Reserved ams Datasheet [v1-00] 2016-Nov-25 AS7263 − Detailed Description Figure 28: Sensor Raw Data Registers Addr: 0x08 Bit Bit Name 7:0 R_High R_High Default Access R Addr: 0x09 Bit Bit Name 7:0 R_Low Bit Name 7:0 S_High Default Access R Bit Name 7:0 S_Low Default Bit Name 7:0 T_High R Bit Name 7:0 T_Low Default Bit Name 7:0 U_High R Bit Name 7:0 U_Low ams Datasheet [v1-00] 2016-Nov-25 Bit Description Channel S Low Data Byte T_High Default Access R Bit Description Channel T High Data Byte T_Low Default Access R Bit Description Channel T Low Data Byte U_High Default Access R Addr: 0x0F Bit Channel S High Data Byte Access Addr: 0x0E Bit Bit Description S_Low Addr: 0x0D Bit Channel R Low Data Byte Access Addr: 0x0C Bit Bit Description S_High Addr: 0x0B Bit Channel R High Data Byte R_Low Addr: 0x0A Bit Bit Description Bit Description Channel U High Data Byte U_Low Default Access R Bit Description Channel U Low Data Byte Page 25 Document Feedback AS7263 − Detailed Description Addr: 0x10 Bit Bit Name 7:0 V_High V_High Default Access R Addr: 0x11 Bit Bit Name 7:0 V_Low Bit Name 7:0 W_High Default Access R Bit Name 7:0 W_Low Bit Description Channel V Low Data Byte W_High Default Access R Addr: 0x13 Bit Channel V High Data Byte V_Low Addr: 0x12 Bit Bit Description Bit Description Channel W High Data Byte W_Low Default Access R Bit Description Channel W Low Data Byte Figure 29: Sensor Calibrated Data Registers Addr: 0x14:0x17 Bit Bit Name 31:0 R_Cal R_Cal Default Access R Addr: 0x18:0x1B Bit Bit Name 31:0 S_Cal Bit Name 31:0 T_Cal Default Access R Bit Name 31:0 U_Cal Page 26 Document Feedback Bit Description Channel S Calibrated Data (float) T_Cal Default Access R Addr: 0x20:0x23 Bit Channel R Calibrated Data (float) S_Cal Addr: 0x1C:0x1F Bit Bit Description Bit Description Channel T Calibrated Data (float) U_Cal Default Access R Bit Description Channel U Calibrated Data (float) ams Datasheet [v1-00] 2016-Nov-25 AS7263 − Detailed Description Addr: 0x24:0x27 Bit Bit Name 31:0 V_Cal V_Cal Default Access R Channel V Calibrated Data (float) Addr: 0x28:0x2B Bit Bit Name 31:0 W_Cal Bit Description W_Cal Default Access Bit Description R Channel W Calibrated Data (float) 4-Byte Floating-Point (FP) Registers Several 4-byte registers (hex) are shown in the tables. Here is an example of how the registers are used to represent floating point data (based on the IEEE 754 standard): Figure 30: Example of the IEEE 754 Standard The floating point (FP) value assumed by 32 bit binary32 data with a biased exponent e (the 8 bit unsigned integer) and a 23 bit fraction is (for the above example). 23  FPvalue = ( – 1 )  –i  ( e – 127 ) 1 + ( b ) ( 2 ) 23 – i    x2   i=1 sign   23  –i ( 124 – 127 ) FPvalue = ( – 1 )  1 +  ( b 23 – i ) ( 2 ) x2   i=1 0 ams Datasheet [v1-00] 2016-Nov-25 Page 27 Document Feedback AS7263 − Detailed Description –2 FPvalue = ( 1 )x ( 1 + 2 )x2 ( –3 ) = 0.15625 UART Interface If selected by the I2C_ENB pin setting, the UART module implements the TX and RX signals as defined in the RS-232 / V.24 standard communication protocol. It has on both, receive and transmit path, a 16 entry deep FIFO. It can generate interrupts as required. UART Feature List 1 • Full Duplex Operation (Independent Serial Receive and Transmit Registers) with FIFO buffer of 8 byte for each. • At a clock rate of 16MHz it supports communication at 115200Baud. • Supports Serial Frames with 8 Data Bits, 1 Parity Bit and 1 Stop Bit. • High Resolution Baud Rate Generator. Theory of Operation Transmission If data is available in the transmit FIFO, it will be moved into the output shift register and the data will be transmitted at the configured Baud Rate, starting with a Start Bit (logic zero) and followed by a Stop Bit (logic one). Reception At any time, with the receiver being idle, if a falling edge of a start bit is detected on the input, a byte will be received and stored in the receive FIFO. The following Stop Bit will be checked to be logic one. 1. With UART operation, min VDD of 2.97V is required as shown in Electrical Characteristics Figures. Page 28 Document Feedback ams Datasheet [v1-00] 2016-Nov-25 AS7263 − Detailed Description Figure 31: UART Protocol Data Bits TX D0 D1 Start Bit D2 D3 D4 D5 D6 D7 D0 Parity Bit Stop Bit Tbit=1/Baude Rate Always Low RX P Next Start Even or odd Always High D0 D1 D2 D3 D4 D5 D6 D7 P D0 Start Bit detected After Tbit/2: Sampling of Start Bit After Tbit: Sampling of Data Sample Points AT Command Interface The microprocessor interface to control the NIR Spectral_ID Sensor is via the UART, using the AT Commands across the UART interface. The 6-channel Spectral _ID sensor provides a text-based serial command interface borrowed from the “AT Command” model used in early Hayes modems. For example: • Read DATA value: ATDATA → OK • Set the gain of the sensor to 1x: ATGAIN =0 → OK The “AT Command Interface Block Diagram”, shown below between the network interface and the core of the system, provides access to the Spectral_ID engine’s control and configuration functions. Figure 32: AT Command Interface Block Diagram RX uP AT Commands TX AT Command Interface Spectral_ID Engine AT Command Interface AS726x ams Datasheet [v1-00] 2016-Nov-25 Page 29 Document Feedback AS7263 − Detailed Description In the Figure below, numeric values may be specified with no leading prefix, in which case they will be interpreted as decimals, or with a leading “0x” to indicate that they are hexadecimal numbers, or with a leading “‘b” to indicate that they are binary numbers. The commands are loosely grouped into functional areas. Texts appearing between angle brackets (‘‘) are commands or response arguments. A carriage return character, a linefeed character, or both may terminate commands and responses. Note that any command that encounters an error will generate the “ERROR” response shown, for example, in the NOP command at the top of the first table, but has been omitted elsewhere in the interest of readability and clarity. Figure 33: AT Commands Command Response Description / Parameters Spectral Data per Channel ATDATA , , , , , OK Read R, S, T, U, V & W data. Returns comma-separated 16-bit integers. ATCDATA , , , , , OK Read calibrated R, S, T, U, V & W data. Returns comma-separated 32-bit floating point values. Sensor Configuration OK Set sensor integration time. Values should be in the range [1... 255], with integration time = * 2.8ms. OK Read sensor integration time, with integration time = * 2.8ms. OK Set sensor gain: 0=1X, 1=3.7x, 2=16x, 3=64x ATGAIN OK Read sensor gain setting, returning 0, 1, 2, or 3 as defined immediately above. ATTEMP OK Read temperature of chip in degree Celsius ATINTTIME= ATINTTIME ATGAIN= Page 30 Document Feedback ams Datasheet [v1-00] 2016-Nov-25 AS7263 − Detailed Description Command ATTCSMD= ATTCSMD ATBURST= Response Description / Parameters OK Set Sensor Mode 0 = BANK Mode 0; 1 = BANK Mode 1; 2 = BANK Mode 2; 3 = BANK Mode 3 One-Shot; 4 = Sensors OFF In One-Shot mode, each ATTCSMD=3 command triggers a One-Shot reading OK Read Sensor Mode, see above OK = # of samples (ATBURST=1 means run until ATBURST=0 is received (a special case for continuous output) LED Driver Controls ATLED0= ATLED0 ATLED1= ATLED1 ATLEDC= ATLEDC OK Sets LED_IND: 100=ON, 0=OFF OK Reads LED_IND setting: 100=ON, 0=OFF OK Sets LED_DRV: 100=ON, 0=OFF OK Reads LED_DRV setting: 100=ON, 0=OFF OK Sets LED_IND and LED_DRV current LED_IND: bits 3:0; LED_DRV: 7:4 bits LED_IND: ‘b00=1mA; ‘b01=2mA; ‘b10=4mA; ‘b11=8ma LED_DRV: ‘b00=12.5mA; ‘b01=25mA; ‘b10=50mA; ‘b11=100mA OK Reads LED_IND and LED_DRV current settings as shown above NOP, Version Access, System Reset OK → Success ERROR → Failure NOP None Software Reset – no response ATVERSW →OK ERROR → Failure Returns the system software version number ATVERHW → OK ERROR → Failure Returns the system hardware revision and product ID, with bits 7:4 containing the part ID, and bits 3:0 yielding the chip revision value. AT ATRST Firmware Update OK = 16-bit checksum. Initial the firmware update process. Bytes that follow is always 56k bytes ATFW= OK Download new firmware Up to 7 Bytes represented as hex chars with no leading or trailing 0x. Repeat command till all 56k bytes of firmware are downloaded ATFWS OK Causes the active image to switch between the two possible current images and then resets the IC ATFWU= ams Datasheet [v1-00] 2016-Nov-25 Page 31 Document Feedback AS7263 − Application Information Application Information Figure 34: AS7263 Typical Application Circuit 3V3 3V3 CSN_SD 7 VDD2 CSN_EE 6 1 2 RESN MISO 5 2 DO 16 GND MOSI 4 5 DI SCK 3 6 8 3 /WP 7 /HOLD 3V3 Vled 15 LED_DRV 18 LED_IND 11 RX/SCL_S 12 TX/SDA_S 13 INT AS7263 I2C_ENB DNP RX TX INT Page 32 Document Feedback NC NC NC NC NC 19 20 1 10 9 /CS 1uF VCC 8 VDD1 14 Flash Memory CLK GND 10K RST 17 4 100nF 10uF 0R ams Datasheet [v1-00] 2016-Nov-25 AS7263 − Package Drawings & Markings Package Drawings & Markings Figure 35: Package Drawing LGA RoHS Green Note(s): 1. XXXXX = tracecode ams Datasheet [v1-00] 2016-Nov-25 Page 33 Document Feedback AS7263 − PCB Pad Layout PCB Pad Layout Suggested PCB pad layout guidelines for the LGA device are shown. Figure 36: Recommended PCB Pad Layout Unit: mm 0.30 1.10 0.65 4.60 1 4.40 Page 34 Document Feedback ams Datasheet [v1-00] 2016-Nov-25 AS7263 − Mechanical Data Mechanical Data Figure 37: Tape & Reel Information Note(s): 1. Each reel contains 2000 parts. 2. Measured from centreline of sprocket hole to centreline of pocket. 3. Cumulative tolerance of 10 sprocket holes is ±0.20. 4. Other material available. 5. All dimensions in millimeters unless otherwise stated. ams Datasheet [v1-00] 2016-Nov-25 Page 35 Document Feedback AS7263 − Storage & Soldering Information Storage & Soldering Information Soldering Information The module has been tested and has demonstrated an ability to be reflow soldered to a PCB substrate. The solder reflow profile describes the expected maximum heat exposure of components during the solder reflow process of product on a PCB. Temperature is measured on top of component. The components should be limited to a maximum of three passes through this solder reflow profile. Figure 38: Solder Reflow Profile Parameter Reference Device Average temperature gradient in preheating 2.5°C/s tsoak 2 to 3 minutes Time above 217°C t1 Max 60 s Time above 230°C t2 Max 50 s Time above Tpeak -10°C t3 Max 10 s Tpeak 260° C Soak time Peak temperature in reflow Temperature gradient in cooling Max -5°C/s Figure 39: Solder Reflow Profile Graph Tpeak Not to scale — for reference only T3 T2 Temperature (5C) T1 Time (s) t3 t2 tsoak t1 Note(s): 1. Not to scale - for reference only. Page 36 Document Feedback ams Datasheet [v1-00] 2016-Nov-25 AS7263 − Storage & Soldering Information Manufacturing Process Considerations The AS7263 package is compatible with standard reflow no-clean and cleaning processes including aqueous, solvent or ultrasonic techniques. However, as an open-aperture device, precautions must be taken to avoid particulate or solvent contamination as a result of any manufacturing processes, including pick and place, reflow, cleaning, integration assembly and/or testing. Temporary covering of the aperture is allowed. To avoid degradation of accuracy or performance in the end product, care should be taken that any temporary covering and associated sealants/debris are thoroughly removed prior to any optical testing or final packaging. Storage Information Moisture Sensitivity Optical characteristics of the device can be adversely affected during the soldering process by the release and vaporization of moisture that has been previously absorbed into the package. To ensure the package contains the smallest amount of absorbed moisture possible, each device is baked prior to being dry packed for shipping. Devices are dry packed in a sealed aluminized envelope called a moisture-barrier bag with silica gel to protect them from ambient moisture during shipping, handling, and storage before use. Shelf Life The calculated shelf life of the device in an unopened moisture barrier bag is 12 months from the date code on the bag when stored under the following conditions: • Shelf Life: 12 months • Ambient Temperature:
AS7263-BLGM 价格&库存
很抱歉,暂时无法提供与“AS7263-BLGM”相匹配的价格&库存,您可以联系我们找货
