PA0603-R-070RL
PA0603-R-070RL
    YAGEO(国巨)
PA0603-R-070RL 数据手册
DATA SHEET METAL LOW OHMIC JUMPER PA series sizes 0201/ 0402/ 0603/ 0805 Product specification – October 05, 2018 V.0 RoHS compliant & Halogen free - Product specification Chip Resistor Surface Mount SERIES PA 2 10 0201 / 0402 / 0603 / 0805 SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER This specification describes PA0201/0402/0603/0805 series current sensor - low TCR with metal alloy layer. Global part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. APPLICATIONS  Consumer goods  Computer  Telecom / Datacom  Industrial / Power supply  Alternative Energy  Car electronics GLOBAL PART NUMBER PA XXXX X X X XX XXXX L (1) (2) (3) (4) (5) (6) (7) (1) SIZE 0201 / 0402 / 0603 / 0805 (2) TOLERANCE - (3) PACKAGING TYPE R = Paper taping reel FEATURES  AEC-Q200 qualified  Halogen-free Epoxy  RoHS compliant  Reduce environmentally hazardous wastes  High component and equipment reliability  Non-forbidden materials used in products/production  Low resistances applied to current sensing  Moisture sensitivity level: MSL 1 (4) TEMPERATURE COEFFICIENT OF RESISTANCE - (5) TAPING REEL 07 = 7 inch dia. Reel 7W = 7 inch dia. Reel, (0402 only) 47= 7 inch dia. Reel, (0805 only) (6) RESISTANCE VALUE 0Ω (7) DEFAULT CODE Letter L is the system default code for ordering only. (Note) Resistance rule of global part number Resistance code rule Example 0R (0 Ω) 0R = 0 Ω ORDERING EXAMPLE The ordering code for a PA0603 chip resistor, value 0 Ω, supplied in 7-inch tape reel with 5Kpcs quantify is: PA0603-R-070RL. NOTE 1. All our RChip products are RoHS compliant. "LFP" of the internal 2D reel label mentions "Lead-Free Process" www.yageo.com Oct. 05, 2018 V0 - Product specification Chip Resistor Surface Mount SERIES PA 0201 / 0402 / 0603 / 0805 3 10 MARKING PA0201 No Marking Fig. 1 Value = 0 Ω PA0402 / 0603 / 0805 Fig. 2 Value = 0 Ω No Marking CONSTRUCTION The resistors are constructed using outstanding TCR level material, which makes Yageo P A resistors excellent for current sensing application in battery charger circuit & DC -DC converter. The composition of the resistive material is adjusted to give the approxi mate required resistance and is covered with a protective coating. Marking is printed on the top side of the resistor. Finally, the three external terminations (Cu / Ni / matte Tin) are added, as shown in Fig. 3. Outlines L W H I1 I1 Fig. 3 Chip resistor outlines www.yageo.com Oct. 05, 2018 V0 - Product specification Chip Resistor Surface Mount SERIES PA 4 10 0201 / 0402 / 0603 / 0805 DIMENSION Table 1 For outlines, please refer to Fig. 4 TYPE L (mm) W (mm) H (mm) I1 (mm) PA0201 0.60± 0.03 0.31± 0.04 Max. 0.35 0.15± 0.06 PA0402 1.00± 0.10 0.55± 0.10 Max. 0.35 0.25± 0.10 PA0603 1.60± 0.20 0.8+0.10/-0.20 0.45± 0.15 0.38± 0.12 PA0805 2.00± 0.15 1.20± 0.15 Max. 0.40 0.35± 0.25 Note: 1. For relevant physical dimensions, please refer to construction outlines. 2. Please contact with sales offices, distributors and representatives in your region before ordering. ELECTRICAL CHARACTERISTICS Table 2 PA0201 Jumper Criteria Fig. 4 Maximum Resistance Maximum Current PA0603 PA0805
PA0603-R-070RL 价格&库存
很抱歉,暂时无法提供与“PA0603-R-070RL”相匹配的价格&库存,您可以联系我们找货
PA0603-R-070RL
  • 1+2.802901+0.36280
  • 10+1.7727010+0.22950
  • 25+1.3296025+0.17210
  • 100+1.18340100+0.15320
  • 250+1.01690250+0.13170
  • 500+0.92110500+0.11930
  • 1000+0.832501000+0.10780
  • 5000+0.754605000+0.09770
库存:45148
PA0603-R-070RL
    库存:45000
    PA0603-R-070RL
    • 1+5.84320
    • 100+3.96240
    • 1000+2.68600
    • 2500+1.91260
    • 5000+1.38270
    库存:37577
    PA0603-R-070RL
      PA0603-R-070RL
        库存:5000
