HCS1206FTL300
HCS1206FTL300
    SEI
    HCS1206FTL300
HCS1206FTL300 数据手册
HCS Series Stackpole Electronics, Inc. High Current Metal Element Shunt Resistor Resistive Product Solutions Features: • • • • • • • • • Metal element shunt resistor Available in up to 10W power rating Resistance value from 0.1 to 5mΩ Current handling up to 316A in 5930 size Excellent long-term stability AEC-Q200 qualified 100% RoHS compliant and lead free without exemption Halogen free REACH compliant Applications: • • • • Power modules Frequency converters Current sensor for power hybrid sources High current handling for automotive engine controls and power management Electrical Specifications Type / Code Power Rating (W) @ 100°C Power Rating (W) @ 70°C HCS1206 2 - ±300 ±200 ±150 ±150 ±115 ±115 ±100 ±50 ±50 ±50 ±50 ±200 ±150 ±70 ±50 ±50 ±50 ±50 ±50 ±300 ±100 ±100 ±75 ±50 ±50 ±50 6 3 5 HCS2512 4 3 2.5 2 4 3 2.5 12 10 9 7 6 5 4 3 10 15 7 10 8 9 7 - 2 1.5 5 HCS3920 HCS5930 6 4 3 Rev Date: 5/12/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. TCR (ppm/ºC) 1 Ohmic Range (Ω) and Tolerance 1% and 5% 0.0003 0.0005 0.001 0.0003 0.0005 0.00075 0.001 0.002 0.003 0.004 0.005 0.0002 0.0003 0.0005 0.001 0.002 0.003 0.004 0.005 0.0001 0.0002 0.0003 0.0005 0.001 0.002 0.003 www.seielect.com marketing@seielect.com HCS Series Stackpole Electronics, Inc. High Current Metal Element Shunt Resistor Resistive Product Solutions Mechanical Specifications L Type / Code HCS1206…L300 HCS1206…L500 HCS1206…1L00 HCS2512…L300 HCS2512…L500 HCS2512…L750 HCS2512…1L00 HCS2512…2L00 HCS2512…3L00 HCS2512…4L00 HCS2512…5L00 HCS3920…L200 HCS3920…L300 HCS3920…L500 HCS3920…1L00 HCS3920…2L00 HCS3920…3L00 HCS3920…4L00 HCS3920…5L00 0.126 3.20 0.126 3.20 0.126 3.20 0.256 6.50 0.256 6.50 0.256 6.50 0.256 6.50 0.256 6.50 0.256 6.50 0.256 6.50 0.256 6.50 0.402 10.20 0.402 10.20 0.402 10.20 0.402 10.20 0.402 10.20 0.402 10.20 0.402 10.20 0.402 10.20 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± W 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.065 1.65 0.065 1.65 0.065 1.65 0.128 3.25 0.128 3.25 0.128 3.25 0.128 3.25 0.128 3.25 0.128 3.25 0.128 3.25 0.128 3.25 0.205 5.20 0.205 5.20 0.205 5.20 0.205 5.20 0.205 5.20 0.205 5.20 0.205 5.20 0.205 5.20 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± H 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 T NA NA NA 0.046 1.17 0.042 1.07 0.037 0.95 0.029 0.73 0.038 0.96 0.030 0.76 0.026 0.66 0.026 0.66 0.078 1.98 0.076 1.92 0.054 1.36 0.036 0.92 0.047 1.19 0.037 0.94 0.033 0.85 0.033 0.85 Rev Date: 5/12/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.047 1.20 0.035 0.90 0.035 0.90 0.032 0.82 0.028 0.72 0.024 0.60 0.015 0.38 0.024 0.61 0.016 0.41 0.012 0.31 0.012 0.31 0.058 1.48 0.056 1.42 0.034 0.86 0.017 0.42 0.027 0.69 0.017 0.44 0.014 0.35 0.014 0.35 2 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± A 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.006 0.15 0.031 0.80 0.031 0.80 0.031 0.80 0.035 0.90 0.035 0.90 0.035 0.90 0.035 0.90 0.035 0.90 0.035 0.90 0.035 0.90 0.035 0.90 0.071 1.80 0.071 1.80 0.071 1.80 0.071 1.80 0.071 1.80 0.071 1.80 0.071 1.80 0.071 1.80 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± P C (max.) 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 NA NA NA NA NA NA 0.016 0.40 0.016 0.40 0.016 0.40 0.016 0.40 0.016 0.40 0.016 0.40 0.016 0.40 0.016 0.40 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.024 0.60 0.014 0.35 0.014 0.35 0.014 0.35 0.014 0.35 0.014 0.35 0.014 0.35 0.014 0.35 0.014 0.35 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 0.020 0.50 ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± Unit 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm www.seielect.com marketing@seielect.com HCS Series Stackpole Electronics, Inc. High Current Metal Element Shunt Resistor Resistive Product Solutions Mechanical Specifications (cont.) L Type / Code W H T A P C (max.) Unit HCS5930…L100 0.591 ± 0.008 0.305 ± 0.008 0.098 ± 0.006 0.079 ± 0.006 0.165 ± 0.008 15.00 ± 0.20 7.75 ± 0.20 2.50 ± 0.15 2.00 ± 0.15 4.20 ± 0.20 0.039 1.00 0.020 ± 0.004 inches 0.50 ± 0.10 mm HCS5930…L200 0.591 ± 0.008 0.305 ± 0.008 0.076 ± 0.006 0.056 ± 0.006 0.165 ± 0.008 15.00 ± 0.20 7.75 ± 0.20 1.92 ± 0.15 1.42 ± 0.15 4.20 ± 0.20 0.039 1.00 0.020 ± 0.004 inches 0.50 ± 0.10 mm HCS5930…L300 0.591 ± 0.008 0.305 ± 0.008 0.057 ± 0.006 0.037 ± 0.006 0.165 ± 0.008 15.00 ± 0.20 7.75 ± 0.20 1.44 ± 0.15 0.94 ± 0.15 4.20 ± 0.20 0.039 1.00 0.020 ± 0.004 inches 0.50 ± 0.10 mm HCS5930…L500 0.591 ± 0.008 0.305 ± 0.008 0.043 ± 0.006 0.023 ± 0.006 0.165 ± 0.008 15.00 ± 0.20 7.75 ± 0.20 1.08 ± 0.15 0.58 ± 0.15 4.20 ± 0.20 0.039 1.00 0.020 ± 0.004 inches 0.50 ± 0.10 mm HCS5930…1L00 0.591 ± 0.008 0.305 ± 0.008 0.054 ± 0.006 0.034 ± 0.006 0.165 ± 0.008 15.00 ± 0.20 7.75 ± 0.20 1.37 ± 0.15 0.87 ± 0.15 4.20 ± 0.20 0.039 1.00 0.020 ± 0.004 inches 0.50 ± 0.10 mm HCS5930…2L00 0.591 ± 0.008 0.305 ± 0.008 0.037 ± 0.006 0.018 ± 0.006 0.165 ± 0.008 15.00 ± 0.20 7.75 ± 0.20 0.95 ± 0.15 0.45 ± 0.15 4.20 ± 0.20 0.039 1.00 0.020 ± 0.004 inches 0.50 ± 0.10 mm HCS5930…3L00 0.591 ± 0.008 0.305 ± 0.008 0.035 ± 0.006 0.016 ± 0.006 0.165 ± 0.008 15.00 ± 0.20 7.75 ± 0.20 0.90 ± 0.15 0.40 ± 0.15 4.20 ± 0.20 0.039 1.00 0.020 ± 0.004 inches 0.50 ± 0.10 mm Power Derating Curve: Environmental Performance Characteristics Test Test Specification Test Condition Short Time Overload ΔR: ± (1% + 0.0005Ω) 5 times rated power for 5 seconds Temperature Coefficient of Resistance (TCR) Refer to Electrical Specifications Moisture Resistance ΔR: ± (1% + 0.0005Ω) The specimens shall be placed in a chamber and subjected to a relative humidity of 90 ~ 98% and a temperature of 25ºC / 65ºC, 10 cycles. (MIL-STD-202, Method 106) High Temperature Exposure ΔR: ± (1% + 0.0005Ω) The chip (mounted on board) is exposed in the heat chamber, 125ºC for 1000 hours (JIS-C5202-7.2) Load Life ΔR: ± (1% + 0.0005Ω) Apply rated power for 1000 hours with 1.5 hours ON and 0.5 hour OFF. (JIS-C5202-7.10) +25ºC / +125ºC (JIS-C5202-5.2) Rev Date: 5/12/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 3 www.seielect.com marketing@seielect.com HCS Series Stackpole Electronics, Inc. High Current Metal Element Shunt Resistor Resistive Product Solutions Environmental Performance Characteristics (cont.) Test Test Specification Test Condition The chip (mounted on board) is exposed, - 55 ± 3ºC (30 min) / +125 ± 2ºC (30 minutes) for 5 cycles. The following conditions as the figure below. (JIS_C5202-7.4) Rapid Change of Temperature ΔR: ± (1% + 0.0005Ω) Operating temperature range is -55°C to +170°C Storage condition is 22°C to 28°C, humidity is of 40% to 75%. Function Performance Characteristics Test Test Specification Test Condition Mount the chip to test 90 mm (L)*40 mm (W) FR4 printed circuit board substrate. Apply pressure in direction of arrow unit band width reaches 2 mm (+0.2 / -0 mm) illustrated in the picture below and hold for 10 ± 1 seconds (JIS-C5202-6.1) Bending Strength ΔR: ± (1% + 0.0005Ω) The part shall be immersed into the flux specified in the solder bath 235ºC ± 5ºC for 2 seconds ± 0.5 seconds. It shall be immersed to a point 10 mm from its root. (Sn96.5/Ag3.0/Cu0.5) (JIS-C5 202 6.11) Solderability Solder shall cover 95% or more of the electrode area Note: The terminal temperature of component should be below 100ºC. Rev Date: 5/12/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 4 www.seielect.com marketing@seielect.com HCS Series Stackpole Electronics, Inc. High Current Metal Element Shunt Resistor Resistive Product Solutions Taping Specifications – Embossed Plastic Tape Type / Code HCS1206 HCS2512 (all Ω ranges) HCS3920 (all Ω ranges) HCS5930 (all Ω ranges) A 0.074 1.88 0.140 3.55 0.217 5.50 0.327 8.30 Type / Code HCS1206 HCS2512 (0.0003Ω, 0.0005Ω, 0.00075Ω, 0.002Ω) HCS2512 (0.001Ω, 0.003Ω) HCS2512 (0.004Ω, 0.005Ω) HCS3920 (0.0002Ω, 0.0003Ω, 0.0005Ω, 0.002Ω) HCS3920 (0.001Ω, 0.003Ω, 0.004Ω, 0.005Ω) HCS5930 (0.0001Ω, 0.0002Ω, 0.0003Ω, 0.001Ω) HCS5930 (0.0005Ω, 0.002Ω, 0.003Ω) 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 ± ± ± ± ± ± ± ± B 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.140 3.56 0.266 6.75 0.425 10.80 0.606 15.40 P0 ± 0.004 ± 0.10 ± 0.002 ± 0.05 ± 0.002 ± 0.05 ± 0.002 ± 0.05 ± 0.002 ± 0.05 ± 0.002 ± 0.05 ± 0.004 ± 0.10 ± 0.004 ± 0.10 0.157 4.00 0.157 4.00 0.157 4.00 0.157 4.00 0.315 8.00 0.315 8.00 0.472 12.00 0.472 12.00 ± ± ± ± ± ± ± ± E 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.069 1.75 0.069 1.75 0.069 1.75 0.069 1.75 P1 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 0.079 2.00 ± ± ± ± ± ± ± ± F 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.138 3.50 0.217 5.50 0.295 7.50 0.453 11.50 P2 ± 0.002 ± 0.05 ± 0.002 ± 0.05 ± 0.002 ± 0.05 ± 0.002 ± 0.05 ± 0.002 ± 0.05 ± 0.002 ± 0.05 ± 0.004 ± 0.10 ± 0.004 ± 0.10 0.061 1.55 0.059 1.50 0.059 1.50 0.059 1.50 0.059 1.50 0.059 1.50 0.059 1.50 0.059 1.50 ± ± ± ± ± ± ± ± W Unit 0.002 0.05 0.002 0.05 0.002 0.05 0.004 0.10 0.315 8.00 0.472 12.00 0.630 16.00 0.945 24.00 ± ± ± ± ± ± ± ± 0.004 0.10 0.008 0.20 0.008 0.20 0.012 0.30 inches mm inches mm inches mm inches mm D0 ± 0.002 ± 0.05 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 ± 0.004 ± 0.10 0.055 1.40 0.055 1.40 0.043 1.10 0.031 0.80 0.078 1.97 0.049 1.25 0.094 2.40 0.055 1.40 T ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± ± 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 0.004 0.10 Unit inches mm inches mm inches mm inches mm inches mm inches mm inches mm inches mm Recommended Pad Layouts Type / Code a b c Unit 1206 0.055 1.40 0.067 1.70 0.071 1.80 inches mm 2512 0.150 3.80 0.071 1.80 0.134 3.40 3920 0.220 5.60 0.106 2.70 0.244 6.20 5930 0.220 5.60 0.205 5.20 0.344 8.75 inches mm inches mm inches mm Rev Date: 5/12/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 5 www.seielect.com marketing@seielect.com HCS Series Stackpole Electronics, Inc. High Current Metal Element Shunt Resistor Resistive Product Solutions Soldering Recommendations: • • • Peak reflow temperatures and durations ✓ IR Reflow Peak = 260ºC max for 10 seconds ✓ Not suitable for wave soldering Compatible with lead and lead-free solder reflow processes Recommended IR reflow profile: Pulsed Power Characteristics – HCS1206 Rev Date: 5/12/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 6 www.seielect.com marketing@seielect.com HCS Series Stackpole Electronics, Inc. High Current Metal Element Shunt Resistor Resistive Product Solutions Pulsed Power Characteristics – HCS2512 Pulsed Power Characteristics – HCS3920 Rev Date: 5/12/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 7 www.seielect.com marketing@seielect.com HCS Series Stackpole Electronics, Inc. High Current Metal Element Shunt Resistor Resistive Product Solutions Pulsed Power Characteristics – HCS5930 Rated Power vs. Surface Temperature – HCS1206 Rev Date: 5/12/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 8 www.seielect.com marketing@seielect.com HCS Series Stackpole Electronics, Inc. High Current Metal Element Shunt Resistor Resistive Product Solutions Rated Power vs. Surface Temperature – HCS2512 Rated Power vs. Surface Temperature – HCS3920 Rev Date: 5/12/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 9 www.seielect.com marketing@seielect.com HCS Series Stackpole Electronics, Inc. High Current Metal Element Shunt Resistor Resistive Product Solutions Rated Power vs. Surface Temperature – HCS5930 Temperature rise test boards use aluminum substrate (MCPCB). RoHS Compliance Stackpole Electronics has joined the worldwide effort to reduce the amount of lead in electronic components and to meet the various regulatory requirements now prevalent, such as the European Union’s directive regarding “Restrictions on Hazardous Substances” (RoHS 3). As part of this ongoing program, we periodically update this document with the status regarding the availability of our compliant components. All our standard part numbers are compliant to EU Directive 2011/65/EU of the European Parliament as amended by Directive (EU) 2015/863/EU as regards the list of restricted substances. RoHS Compliance Status Standard Product Series Description Package / Termination Type HCS High Current Shunt Resistor SMD Standard Series RoHS Compliant YES Lead-Free Termination Composition Lead-Free Mfg. Effective Date (Std Product Series) 100% Copper Always Lead-Free Effective Date Code (YY/WW) Always “Conflict Metals” Commitment We at Stackpole Electronics, Inc. are joined with our industry in opposing the use of metals mined in the “conflict region” of the eastern Democratic Republic of the Congo (DRC) in our products. Recognizing that the supply chain for metals used in the electronics industry is very complex, we work closely with our own suppliers to verify to the extent possible that the materials and products we supply do not contain metals sourced from this conflict region. As such, we are in compliance with the requirements of Dodd-Frank Act regarding Conflict Minerals. Rev Date: 5/12/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 10 www.seielect.com marketing@seielect.com HCS Series Stackpole Electronics, Inc. High Current Metal Element Shunt Resistor Resistive Product Solutions Compliance to “REACH” We certify that all passive components supplied by Stackpole Electronics, Inc. are SVHC (Substances of Very High Concern) free and compliant with the requirements of EU Directive 1907/2006/EC, “The Registration, Evaluation, Authorization and Restriction of Chemicals”, otherwise referred to as REACH. Contact us for complete list of REACH Substance Candidate List. Environmental Policy It is the policy of Stackpole Electronics, Inc. (SEI) to protect the environment in all localities in which we operate. We continually strive to improve our effect on the environment. We observe all applicable laws and regulations regarding the protection of our environment and all requests related to the environment to which we have agreed. We are committed to the prevention of all forms of pollution. How to Order 1 2 3 4 5 6 7 8 9 10 11 12 13 H C S 3 9 2 0 F T L 3 0 0 Product Series HCS Size 1206 2512 3920 5930 Tolerance Code Tol F 1% J 5% Code T Packaging Description 7" Reel - Plastic Tape 10" Reel - Plastic Tape 13" Reel - Plastic Tape Resistance Value Size 1206 2512 3920 5930 Quantity 2000 4000 3000 2000 Four characters with "L" used as multiplier of 10-3 for any value under 0.1 ohm 0.0003 ohm = L300 0.0005 ohm = L500 0.00075 ohm = L750 0.001 ohm = 1L00 Rev Date: 5/12/2022 This specification may be changed at any time without prior notice. Please confirm technical specifications before you order and/or use. 11 www.seielect.com marketing@seielect.com
HCS1206FTL300 价格&库存
很抱歉,暂时无法提供与“HCS1206FTL300”相匹配的价格&库存,您可以联系我们找货
HCS1206FTL300
  • 2000+3.514282000+0.45632
  • 4000+3.275644000+0.42533
  • 6000+3.153056000+0.40941
  • 10000+3.0144010000+0.39141
  • 14000+2.9318014000+0.38068
  • 20000+2.8511120000+0.37021
库存:16
HCS1206FTL300
  • 1+11.380971+1.47777
  • 10+7.4355010+0.96547
  • 25+6.3720625+0.82738
  • 50+5.7052150+0.74080
  • 100+5.13712100+0.66703
  • 250+4.51506250+0.58626
  • 500+4.12608500+0.53575
  • 1000+3.795301000+0.49280
库存:16
HCS1206FTL300
    HCS1206FTL300
      库存:2000
