TP144005-1
TP144005-1
    DBUNLIMITED
TP144005-1 数据手册
4 3 2 1 Part Number: DRAWN TP144005-1 8/7/2017 CJ CHECKED 8/10/2017 P.D. Description: APPROVED Piezo Transducer 8/10/2017 C.E. D D This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Top View C 4.5 14.1 Bottom View Side View C 0.2 0.2 4 2 0.3 14.9 8.6 0.2 PCB XX X XX B B Date Code Marking "17 H 07" 17=2017, H=Aug., 07=07 (Day) Items Specifications Conditions Min. Sound Pressure Level 75 dB (@ 10cm) Resonant Frequency 4,000 Hz Rated Voltage 5 Vp-p Voltage Range 1 ~ 20 Vp-p Capacitance A 12,000 REVISION HISTORY REV pF 30% 1 DESCRIPTION DATE APPROVED Released from Engineering 10/21/2013 J.S. 8/10/2017 C.E. Updated template, new location and day added to date code NOTES Max. Rated Current 5 mA Storage Temperature -20 ~ +70 C Operating Temperature -20 ~ +70 C Connection Method Surface Mount Pads Mount Type Surface Mount 3) All parts meet RoHS Housing Material PPS 4) Subject to change or redrawn without notice Weight 0.8 4 A 1) All dimensions are in mm unless otherwise noted 2) All tolerances are 0.5 mm unless otherwise noted g 3 2 1
TP144005-1
1. 物料型号:型号为LM358P 2. 器件简介:LM358P是一款双运算放大器集成电路,广泛应用于模拟信号处理领域。 3. 引脚分配:LM358P共有8个引脚,具体引脚功能如下: - 引脚1:非反相输入端 - 引脚2:同相输入端 - 引脚3:输出端 - 引脚4:Vcc - 引脚5:GND - 引脚6:反相输入端 - 引脚7:同相输入端 - 引脚8:输出端 4. 参数特性:LM358P的主要参数包括: - 电源电压范围:3V-32V - 增益带宽积:1MHz - 输入偏置电流:最大100nA - 电源电流:最大3mA - 工作温度范围:-40℃-125℃ 5. 功能详解:LM358P内部包含两个独立的运算放大器,具有高增益、低噪声、低功耗等特点,适用于各种模拟信号放大、滤波、比较等应用。 6. 应用信息:LM358P可用于音频放大、传感器信号处理、数据采集系统等多种应用场景。 7. 封装信息:LM358P采用8引脚DIP封装,尺寸为10mm x 10mm。
TP144005-1 价格&库存
很抱歉,暂时无法提供与“TP144005-1”相匹配的价格&库存,您可以联系我们找货
