ESD15V32D-C
ESD15V32D-C
    SOCAY(硕凯)
    SOD323
    ESD15V32D-C
ESD15V32D-C 数据手册
Transient Voltage Suppressors for ESD Protection ESDXXV32D-C Series Description SOD-323 The ESDXXV32D-C is designed to protect voltage sensitive components from ESD and transient voltage events. Excellent clamping capability, low leakage, and fast response time, make these parts ideal for ESD protection on designs where board space is at a premium. Because of its small size, it is suited for use in cellular phones, MP3 players, digital cameras and many other portable applications where board space is at a premium. Feature Functional Diagram  320 Watts Peak Pulse Power per Line (tp=8/20μs)  Protects one I/O line or power line  Low clamping voltage  Working voltages : 3V, 5V, 8V, 12V, 15V, 18V, 24V, 36V and 48V  Low leakage current  IEC61000-4-2 (ESD) ±15kV (air), ±8kV (contact)  IEC61000-4-4 (EFT) 40A (5/50ns)  IEC61000-4-5 (Lightning) 24A (8/20μs) Applications  Cell Phone Handsets and Accessories  Microprocessor based equipment  Personal Digital Assistants (PDA’s)  Notebooks, Desktops, and Servers  Portable Instrumentation  Peripherals  Pagers Mechanical Characteristics  JEDEC SOD-323 Package  Molding Compound Flammability Rating : UL 94V-0  Weight 5 Milligrams (Approximate)  Quantity Per Reel : 3,000pcs  Reel Size : 7 inch  Lead Finish : Lead Free Mechanical Characteristics Symbol Parameter Value Units 320 W PPP Peak Pulse Power (tp=8/20μs waveform) TL Lead Soldering Temperature 260 (10sec) ºC TSTG Storage Temperature Range -55 to +150 ºC TOP Operating Temperature Range -55 to +150 ºC IEC61000-4-2 (ESD) Air Discharge ±15 Contact Discharge ±8 IEC61000-4-4 (EFT) 40 A IEC61000-4-5 ( Lightning ) 24 A SOCAY Electronics Co., Ltd. Revision January 06, 2014 KV www.socay.com 1/3 @ SOCAY Electronics Co., Ltd. 2014 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Transient Voltage Suppressors for ESD Protection ESDXXV32D-C Series I-V Curve Characteristics Symbol Parameter Bi-directional IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP VRWM I IPP Working Peak Reverse Voltage IR Maximum Reverse leakage Current @ VRWM IT Test Current VB Breakdown Voltage @ IT VC VB VRWM R IR IT IT V IR VRWM VB VC IPP Electrical Characteristics (@ 25℃ Unless Otherwise Specified ) VC @1A (Max.) 7.5 25 IR (μA) (Max.) 200 C (pF) (Typ.) 350 (Max.) (@A) 16 1 9.8 1 13.4 17 24 10 260 20 18 5 120 13.3 1 16.7 1 19 25 13 1 110 24 30 6 1 100 18 19.0 1 28 35 8 1 90 ESD24V32D-C 24 ESD36V32D-C 36 26.7 1 43 52 6 1 75 40 1 60 75 4 1 35 ESD48V32D-C 48 50 1 65 85 3 1 25 Part Number VRWM (V) (Max.) VB (V) (Min.) IT (mA) ESD03V32D-C 3.3 4.0 1 ESD05V32D-C 5 6.0 ESD08V32D-C 8 8.5 ESD12V32D-C 12 ESD15V32D-C 15 ESD18V32D-C VC Characteristic Curves Fig1. 8/20μs Pulse Waveform Fig2. ESD Pulse Waveform (according to IEC 61000-4-2) tr 100 Peak Value IPP 80 100% TEST WAVEFORM PARAMETERS tr=8μs td=20μs Percent of Peak Pulse Current % IPP - Peak Pulse Current - % of IPP 120 60 40 td=t IPP/2 20 0 0 5 10 15 20 25 10% tr = 0.7~1ns Time (ns) 30ns 30 60ns t - Time (μs) SOCAY Electronics Co., Ltd. Revision January 06, 2014 90% www.socay.com 2/3 @ SOCAY Electronics Co., Ltd. 2014 Specifications are subject to change without notice. Please refer to www.socay.com for current information. Transient Voltage Suppressors for ESD Protection ESDXXV32D-C Series Characteristic Curves Fig3. ESD Clamping (+8KV Contac per IEC61000-4-2) Fig4. ESD Clamping (-8KV Contac per IEC61000-4-2) SOD-323 Package Outline & Dimensions Millimeters Symbol Min. Nom. Max. Min. Nom. Max. A 0.80 0.90 1.00 0.031 0.035 0.040 A1 0.00 0.05 0.10 0.000 0.002 0.004 A3 Soldering Footprint 0.15 REF 0.006 REF b 0.25 0.32 0.40 0.010 0.012 0.016 C 0.089 0.12 0.177 0.003 0.005 0.007 D 1.60 1.70 1.80 0.062 0.066 0.070 E 1.15 1.25 1.35 0.045 0.049 0.053 L 0.08 HE 2.30 0.098 0.105 0.003 2.50 2.70 0.090 Symbol Millimeters Inches F 1.60 0.063 G 2.85 0.112 J 0.83 0.033 K 0.63 0.025 SOCAY Electronics Co., Ltd. Revision January 06, 2014 Inches www.socay.com 3/3 @ SOCAY Electronics Co., Ltd. 2014 Specifications are subject to change without notice. Please refer to www.socay.com for current information.
ESD15V32D-C 价格&库存
很抱歉,暂时无法提供与“ESD15V32D-C”相匹配的价格&库存,您可以联系我们找货
