YLS-01V
YLS-01V
    JST
    Housings
    定位锁线扣
YLS-01V 数据手册
YL CONNECTOR 4.5mm pitch/Disconnectable Crimp style Wire-to-wire connectors Specifications ––––––––––––––––––– Panel lock • Current rating: 10 A AC, DC max. (7 A when retainers are mounted) • Voltage rating: 300 V AC, DC max. • Temperature range: -25˚C to +90˚C (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 7 mΩ max. After environmental tests/ 10 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 1,500 VAC/minute • Applicable wire: AWG #26 to #16 0.13 to 1.25 mm2 • Applicable panel thickness: 0.7 to 2.0 mm Inner lock Retainer Housing lance Note: The current rating varies depending on the number of circuits and the wire size used in each connector. The table below lists the current rating as a function of the number of circuits and the wire size. Current unit: A Circuits The retainer features added protection against non-insertion or disconnection. • Housing lance • Secondary retainers • Inner-housing lock • Panel lock construction Standards –––––––––––––––––––– 0 Wire size (AWG) #16 #18 #20 #22 #24 #26 1 10 7 5 4 3 2 2 10 7 5 4 3 2 3 9 6 4 4 3 2 4 9 6 4 4 3 2 6 8 5 3 3 2 2 8 7 4 3 3 2 2 9 6 4 3 3 2 2 12 6 3 2 2 2 2 15 5 3 2 2 2 1 16 5 3 2 2 2 1 21 5 3 2 2 2 1 Note: Secondary retainers cannot be used with AWG #16 wires. Recognized E60389 * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. * Compliant with RoHS. 1 2 R9351052 Certified LR20812 Panel Layout and Assembly layout A B 35.1 38.7 (including retainer) 10.8 16.6 20.5 21.8 3.2 9.5 15.3 9.8 A C Single row 2・3 2-row 4・6・8・12・16 3-row 9・12・15・21 Dimensions (mm) A B D Circuits E Type Panel thickness Cir- Receptacle (mm) cuits housing Model No. Dimensions (mm) 2 YLR-02V 3 YLR-03V 4 YLR-04V 6 YLR-06V 8 YLR-08V 9 YLR-09V YLR-12V 12 YLR-12VA 15 YLR-15V 16 YLR-16V 21 YLR-21V 0.7 to 2.0 0.7 to 0.8 0.9 to 1.3 1.4 to 2.0 D±0.1 E±0.1 D±0.1 E±0.1 D±0.1 E±0.1 A B C 10.7 16.8 7.1 4.4 1.35 5.0 1.05 5.6 0.75 15.3 21.3 7.1 4.4 1.35 5.0 1.05 5.6 0.75 10.7 16.8 12.9 7.1 2.9 7.7 2.6 8.3 2.3 15.3 21.3 12.9 7.1 2.9 7.7 2.6 8.3 2.3 19.8 25.8 12.9 7.1 2.9 7.7 2.6 8.3 2.3 15.3 21.3 18.2 7.1 5.55 7.7 5.25 8.3 4.95 19.8 25.8 18.2 7.1 5.55 7.7 5.25 8.3 4.95 28.9 34.8 12.9 7.1 2.9 7.7 2.6 8.3 2.3 24.4 30.3 18.2 7.1 5.55 7.7 5.25 8.3 4.95 37.9 43.8 12.9 7.1 2.9 7.7 2.6 8.3 2.3 33.5 39.3 18.2 7.1 5.55 7.7 5.25 8.3 4.95 Note: 1. Punch holes in the panel according to the figures and table shown above. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. B 1 YL CONNECTOR Contact Applicable wire Model No. 2 Pin contact Pin contact AWG # Insulation O.D. (mm) 26∼20 1.3∼2.5 0.5 ∼1.25 20∼16 2.0∼3.4 *0.3+0.3∼ 0.5+0.5 *22+22∼ 20+20 mm2 Socket contact SYM-01T-P0.5A SYF-01T-P0.5A 0.13∼0.5 Q'ty/ reel 4,000 19.5 SYM-41T-P0.5A SYF-41T-P0.5A 4.4 2 0.5 1.1 SYM-01T-P0.5A (    ) 5,000 *1.5+1.5∼ 2.0+2.0 Material and Finish Phosphor bronze, tin-plated (reflow treatment) RoHS compliance Note: 1. Contact JST for special products. 2. Retainers cannot be used with electric wire whose insulation O.D. exceeds 2.7mm and AWG #16. ¨V . 3. *Marked products are not approved by TU 2.8 Socket contact 4.4 2 SYM-01T-P0.5A 1.1 SYF-01T-P0.5A MKS-L AP-K2N SYM-41T-P0.5A 1.8 Applicator Crimping machine Crimp applicator Contact 14.2 *MKS-SC-YL SC/SYF/M-01-05 APLSC SYF/M01-05 MKS-L SYF-41T-P0.5A Crimp applicator with dies Dies MK/SYF/M-01-05 APLMK SYF/M01-05 MK/SYF/M-41-05 APLMK SYF/M41-05 *MKS-SC-YL SC/SYF/M-41-05 APLSC SYF/M41-05 Note: *Strip-crimp applicator Contact position location numbers Contact position numbers are stamped Retainer Receptacle housing Retainer Plug housing 3 2 2 3 2 1 1 4 4 8 L JST 3 7 12 11 10 L JST 8 9 3 7 6 2 5 21 20 18 17 16 15 19 11 10 9 8 12 13 14 1 7 6 7 15 6 14 5 13 4 12 3 11 2 10 9 L JST 15 14 13 12 11 1 15 14 13 10 9 8 12 1 11 9 7 2 6 10 4 3 3 11 2 4 1 12 7 6 5 4 3 2 1 5 8 16 1 5 1 14 13 12 11 10 9 8 10 9 8 7 6 5 4 10 7 1 8 6 15 14 6 5 4 3 2 1 21 20 19 18 17 16 15 5 4 3 2 1 4 5 11 6 12 16 15 14 13 12 11 10 9 4 1 5 1 8 7 6 5 4 3 2 1 3 2 L JST 7 2 11 10 9 8 7 6 8 7 6 5 4 3 2 1 2 9 12 11 10 9 8 7 1 3 16 L JST 4 17 10 6 5 4 3 2 1 L JST 5 18 11 3 9 6 19 12 15 7 15 14 13 12 11 8 16 3 12 1 4 3 2 1 L JST 4 8 5 9 2 8 7 6 5 13 5 13 L JST 2 9 6 14 3 10 10 7 L JST 11 15 4 8 12 12 11 10 9 16 15 14 13 12 11 10 9 2 6 3 6 2 5 L JST 4 2 L JST 3 3 6 2 5 1 4 2 8 13 L JST 7 20 1 21 14 2 3 1 3 6 9 2 5 8 1 4 7 9 7 8 2 7 8 2 4 1 3 1 3 6 9 9 6 3 8 5 2 7 4 1 4 3 2 1 5 4 8 7 6 5 6 3 5 2 4 1 6 5 4 3 2 1 4 10 L JST 5 1 11 4 7 1 1 6 8 L JST 5 4 12 2 2 6 5 3 3 7 2 6 4 9 8 3 5 L JST L JST 6 12 11 10 9 8 7 L JST 1 1 1 1 1 2 1 L JST 3 1 L JST L JST 2 L JST 1 4 2 3 1 2 4 3 2 1 3 2 2 1 L JST L JST 1 Plug housing L JST Receptacle housing 4 3 2 1 8 7 6 5 4 3 2 1 8 7 6 5 12 11 10 9 7 6 5 4 3 2 1 14 13 12 11 10 9 8 21 20 19 18 17 16 15 YL CONNECTOR Housing Material: Housing...PA 66, UL94V-0, white Retainer...Glass-filled PA 66, UL94V-0, ivory 26.6 3.0 20.9 3.35 500 6.0 YLP-02V Q´ty/ bag YLS-02V Q´ty/ bag L JST 26.6 L JST 500 500 8.5 3.5 20.9 8.3 3.0 1 3.1 YLR-02VF 6.0 1,000 2.9 2 L JST 10.3 1,000 2.9 2 10.3 8.5 500 Q´ty/ bag 6.7 7A (10A) Q´ty/ bag 3.8 L JST 3.0 YLR-02V 300V YLS-01V 1 6.7 2 Retainer Q´ty/ bag 2 (10A) YLP-01V 1 300V Q´ty/ bag L JST 1 7A 5.8 YLR-01VF Plug housing (for socket contact) 5.8 Receptacle housing (for pin contact) 10.3 Voltage Current Circuits rating rating 1 6.7 3.1 26.6 YLR-03V 3.0 Q´ty/ bag YLP-03V Q´ty/ bag 2 YLR-03VF 1 500 12.8 26.6 14.8 3.1 3 6.7 6A (9A) L JST 3.0 1 300V Q´ty/ bag 2 L JST 14.8 3 3 YLS-03V (commonly used for 3-circuit housing and 6-circuit housing) 500 1,000 8.5 3.5 6.0 2.9 2 L JST 14.8 3 20.9 1 6.7 3.1 26.6 RoHS compliance Note: 1. Current rating in parentheses is for use with AWG #16 wire. (Retainers are not mountable.) 2. Contact JST for Glow Wire compliant connectors. 3 YL CONNECTOR Housing Material: Housing...PA 66, UL94V-0, white Voltage Current Circuits rating rating Receptacle housing (for pin contact) YLR-04V 3.0 Q´ty/ bag YLS-02V Q´ty/ bag 2 4 10.3 YLP-04V Retainer L JST 3 1 (9A) 8.3 3 6A 10.3 4 26.6 2 3.1 L JST 3.0 1 300V Plug housing (for socket contact) Q´ty/ bag 12.5 4 Retainer...Glass-filled PA 66, UL94V-0, ivory YLR-04VF 8.5 500 20.9 1,000 2.9 11.8 2 4 L JST 10.3 500 3.5 3 1 12.5 3.1 26.6 YLR-06V YLP-06V Q´ty/ bag 6 3 5 2 L JST 14.8 3.0 Q´ty/ bag YLS-03V (commonly used for 3-circuit housing and 6-circuit housing) Q´ty/ bag 4 3.0 1 3.1 26.6 500 12.8 2 5 YLR-06VF 14.8 (8A) 4 300V 500 1 6 L JST 3 6 12.5 5A 1,000 8.5 6 3 5 2 L JST 14.8 20.9 3.5 2.9 11.8 4 1 L JST 12.5 3.1 26.6 YLR-08V YLP-08V Q´ty/ bag YLS-08V Q´ty/ bag 8 4 7 3 6 2 L JST 19.3 3.0 Q´ty/ bag 5 250 19.0 2 6 5 YLR-08VF 19.3 26.6 L JST 3.1 4A (7A) 500 1 300V 3 7 4 8 3.0 1 12.5 8 1,000 8 4 7 3 6 2 20.9 3.5 11.8 2.9 L JST 19.3 8.5 5 1 12.5 3.1 26.6 YLR-09V YLP-09V Q´ty/ bag 3.5 1 14.8 9 L JST 8 7 6 1 4 7 3.0 3 2 5 5 500 8.5 17.7 3.1 26.6 20.9 RoHS compliance Note: 1. Current rating in parentheses is for use with AWG #16 wire. (Retainers are not mountable.) 4 2 3 8 250 4 6 4A (6A) L JST 300V 9 9 14.8 3.0 Q´ty/ bag 17.0 2. Contact JST for Glow Wire compliant connectors. Q´ty/ bag YL CONNECTOR Housing Material: Housing...PA 66, UL94V-0, white Circuits Voltage Current rating rating Receptacle housing (for pin contact) YLR-12VA Plug housing (for socket contact) Q´ty/ bag YLP-12VA Retainer Q´ty/ bag YLS-12V Q´ty/ bag 3.0 3.1 26.3 L JST 28.3 3 5 11 4 9 4 10 5 10 3 9 6 11 200 1,000 1 1 7 7 2 8 200 2 8 12 6 12 3.5 L JST 28.3 Retainer...Glass-filled PA 66, UL94V-0, ivory 3.0 8.5 2.9 3A (6A) YLR-12V Q´ty/ bag Q´ty/ bag Q´ty/ bag 3.0 3.1 19.3 12 11 L JST 10 5 5 9 200 − 1 200 − Q´ty/ bag Q´ty/ bag 1 9 2 8 3 6 7 4 7 6 8 10 L JST 11 4 3.5 12 19.3 YLP-12V 3 300V 11.8 2 12 20.9 26.6 12.5 3.0 8.5 17.7 26.6 YLR-15V Q´ty/ bag 3.0 23.8 15 14 13 10 9 8 12 6 11 11 7 7 2 12 6 − − 200 1 1 L JST 5 3 4 8 3 4 13 200 2 5 9 23.8 10 L JST 3A (5A) YLP-15V 3.5 14 300V 17.0 3.1 15 15 20.9 Q´ty/ bag 17.0 YLP-16V Q´ty/ bag YLS-16V Q´ty/ bag 11 3 10 2 100 L JST 37.0 200 1,000 1 1 9 9 4 7 15 12 6 14 5 5 13 6 4 12 7 8 16 3.5 2 10 8 13 L JST 14 3A (5A) 15 300V 37.3 3.0 3.1 16 16 20.9 37.3 YLR-16V 26.6 3 11 3.0 8.5 17.7 3.0 8.5 12.5 26.6 20.9 11.8 2.9 RoHS compliance Note: 1. Current rating in parentheses is for use with AWG #16 wire. (Retainers are not mountable.) 2. Contact JST for Glow Wire compliant connectors. 5 YL CONNECTOR Housing Material: Housing...PA 66, UL94V-0, white Receptacle housing (for pin contact) YLR-21V Q´ty/ bag 3.0 2 8 1 3.0 17.7 26.6 20.9 RoHS compliance Note: 1. Current rating in parentheses is for use with AWG #16 wire. (Retainers are not mountable.) 2. Contact JST for Glow Wire compliant connectors. 20 19 17.0 L JST 32.8 18 17 9 16 3 15 10 8.5 6 Q´ty/ bag 21 7 14 6 13 5 12 4 4 11 11 3 5 10 12 15 9 6 16 2 13 17 100 1 7 32.8 14 18 L JST 19 3A (5A) Q´ty/ bag 3.5 20 300V YLP-21V Retainer 3.1 21 21 Plug housing (for socket contact) 8 Circuits Voltage Current rating rating − 200 −
YLS-01V 价格&库存
很抱歉,暂时无法提供与“YLS-01V”相匹配的价格&库存,您可以联系我们找货
