A3961WR-2P
A3961WR-2P
    CJT(长江连接器)
    DIP,P=3.96mm
    A3961WR-2P
A3961WR-2P 数据手册
A3961 SERIES 3.96~7.92mm pitch wire to board connector Specifications Current rating:7A AC,DC Voltage rating:250V AC,DC Temperature range:-40°C~+105°C Contact resistance:10m Max. Insulation resistance:1000M Min. Withstanding voltage:1500V AC/minute *Compliant with RoHS and REACH* *Meet the HF/Halogen Free,GWT/Glow wire Test (IEC60335-1) request,need to customize* *Contact CJT for details* Standards E326732 10.20 REF. 2.00 1.60 24.60 REF. 10.20 REF. 1.60 2.00 16.57 REF. 10.30 REF. 2.00 1.60 1.60 2.00 19.20 REF. 6.30 19.20 REF. E326732 CHANGJIANG CONNECTORS TEL:86-755-29959119 29959129 FAX:86-755-29959139 Http://www.CJT.cn A-330 A3961 SERIES A3961-T 3.96mm pitch wire to board connector 3.96mm pitch Crimp Terminal Reference Informations: *Used in CJT A3961 series Housing Ø1.90 3.16±0.25 0.25 2.40±0.20 7.00±0.20 3.45±0.25 A SEC:A-A 2.85±0.10 2.10±0.25 6.20±0.20 B 5.50±0.20 13.60±0.25 B 2.30 A 2.55±0.25 SEC:B-B 1.85±0.10 5.00±0.20 Ordering information & Specifications: Part NO. A3961-TB A3961-TP A3961-GB A3961-GP Wire Range AWG#18-#24 AWG#18-#24 AWG#18-#24 AWG#18-#24 Unit:mm Material Brass Phosphor Bronze Brass Phosphor Bronze Insulation O.D. 2.80mm(max) 2.80mm(max) 2.80mm(max) 2.80mm(max) Finish Tin over Nickel Tin over Nickel Gold over Nickel Gold over Nickel Qty/reel 6,000 PCS 6,000 PCS 6,000 PCS 6,000 PCS Optional Gold plating available but MOQ requested A3961-T-1 Reference Informations: *Used in CJT A3961 series Housing 0.25 3.50±0.25 3.96mm pitch Crimp Terminal 3.70±0.25 2.70±0.15 1.42±0.10 2.30 0.80 2.30±0.25 B SEC:A-A 6.00±0.25 B 13.40±0.25 A 2.20 A 2.30±0.25 SEC:B-B Ordering information & Specifications: Part NO. A3961-TB-1 A3961-TP-1 A3961-GB-1 A3961-GP-1 Wire Range AWG#18-#24 AWG#18-#24 AWG#18-#24 AWG#18-#24 Insulation O.D. 2.80mm(max) 2.80mm(max) 2.80mm(max) 2.80mm(max) Unit:mm Material Brass Phosphor Bronze Brass Phosphor Bronze Finish Tin over Nickel Tin over Nickel Gold over Nickel Gold over Nickel Qty/reel 6,000 PCS 6,000 PCS 6,000 PCS 6,000 PCS Optional Gold plating available but MOQ requested CHANGJIANG CONNECTORS TEL:86-755-29959119 29959129 FAX:86-755-29959139 Http://www.CJT.cn A3961 SERIES A3961H Reference Informations: *Material:Nylon 66,UL94V-2 *Suitable CJT A3961 series Terminal *Mates with CJT A3961 series Wafer *Color:Natual Circuit 1 3.96mm pitch wire to board connector 3.96mm pitch Housing Ordering Information: A3961H-XP - * 1 2 1.Part No. 2.Material: (blank)-UL94V-2 V0-UL94V-0 Ordering Information & Dimensions: PART NO. 3.96±0.10 A±0.20 B±0.25 16.00±0.25 7.70 6.30 A3961H-2P A3961H-3P A3961H-4P A3961H-5P A3961H-6P A3961H-7P A3961H-8P A3961H-9P A3961H-10P A3961H-11P A3961H-12P A3961H-13P A3961H-14P A3961H-15P A3961H-16P A3961H-17P A3961H-18P A3961H-19P A3961H-20P A3961H-21P A3961H-22P A3961H-23P A3961H-24P Dimensions A B 3.96 7.92 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 51.48 55.44 59.40 63.36 67.32 71.28 75.24 79.20 83.16 87.12 91.08 8.43 12.39 16.35 20.31 24.27 28.23 32.19 36.15 40.11 44.07 48.03 51.99 55.95 59.91 63.87 67.83 71.79 75.75 79.71 83.67 87.63 91.59 95.55 Unit: mm A3961H-2 Reference Informations: *Material:Nylon 66,UL94V-2 *Suitable CJT A3961 series Terminal *Mates with CJT A3961 series Wafer *Color:Natual 3.96mm pitch Housing Ordering Information: A3961H-XP-2 - * 1 2 1.Part No. 2.Material: (blank)-UL94V-2 V0-UL94V-0 Ordering Information & Dimensions: PART NO. Circuit 1 3.96±0.10 A±0.20 6.30 16.00±0.25 B±0.25 A3961H-2P-2 A3961H-3P-2 A3961H-4P-2 A3961H-5P-2 A3961H-6P-2 A3961H-7P-2 A3961H-8P-2 A3961H-9P-2 A3961H-10P-2 A3961H-11P-2 A3961H-12P-2 A3961H-13P-2 A3961H-14P-2 A3961H-15P-2 A3961H-16P-2 A3961H-17P-2 A3961H-18P-2 A3961H-19P-2 A3961H-20P-2 A3961H-21P-2 A3961H-22P-2 A3961H-23P-2 A3961H-24P-2 Dimensions A B 3.96 7.92 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 51.48 55.44 59.40 63.36 67.32 71.28 75.24 79.20 83.16 87.12 91.08 8.43 12.39 16.35 20.31 24.27 28.23 32.19 36.15 40.11 44.07 48.03 51.99 55.95 59.91 63.87 67.83 71.79 75.75 79.71 83.67 87.63 91.59 95.55 Unit: mm CHANGJIANG CONNECTORS TEL:86-755-29959119 29959129 FAX:86-755-29959139 Http://www.CJT.cn A3961 SERIES A3961H-3 3.96mm pitch wire to board connector 3.96mm pitch Housing Reference Informations: *Material:Nylon 66,UL94V-2 *Suitable CJT A3961 series Terminal *Mates with CJT D3961WV D3961WR series Wafer *Color:Natual Ordering Information: A3961H-XP-3 - * 1 2 1.Part No. 2.Material: (blank)-UL94V-2 V0-UL94V-0 Circuit 1 3.96±0.10 A±0.20 8.30 16.00±0.25 B±0.25 6.30 A3961WV PART NO. A3961H-2P-3 A3961H-3P-3 A3961H-4P-3 A3961H-5P-3 A3961H-6P-3 A3961H-7P-3 A3961H-8P-3 A3961H-9P-3 A3961H-10P-3 A3961H-11P-3 A3961H-12P-3 A3961H-13P-3 A3961H-14P-3 A3961H-15P-3 A3961H-16P-3 A3961H-17P-3 A3961H-18P-3 A3961H-19P-3 A3961H-20P-3 A3961H-21P-3 A3961H-22P-3 A3961H-23P-3 A3961H-24P-3 Dimensions A B 3.96 7.92 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 51.48 55.44 59.40 63.36 67.32 71.28 75.24 79.20 83.16 87.12 91.08 8.43 12.39 16.35 20.31 24.27 28.23 32.19 36.15 40.11 44.07 48.03 51.99 55.95 59.91 63.87 67.83 71.79 75.75 79.71 83.67 87.63 91.59 95.55 Unit: mm 3.96mm pitch 180° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A3961 or A3964 series Housing *Color:Natual Ordering Information & Dimensions: PART NO. Circuit 1 3.96±0.10 Ø1.80±0.05 3.96±0.10 P.C.B LAYOUT A±0.20 3.20±0.20 3.60 11.30±0.20 17.50±0.25 5.60±0.20 B±0.25 PIN 1.14 SQ Ordering Information & Dimensions: 10.20±0.20 A3961WV-2P A3961WV-3P A3961WV-4P A3961WV-5P A3961WV-6P A3961WV-7P A3961WV-8P A3961WV-9P A3961WV-10P A3961WV-11P A3961WV-12P A3961WV-13P A3961WV-14P A3961WV-15P A3961WV-16P A3961WV-17P A3961WV-18P A3961WV-19P A3961WV-20P A3961WV-21P A3961WV-22P A3961WV-23P A3961WV-24P Dimensions A B 3.96 7.92 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 51.48 55.44 59.40 63.36 67.32 71.28 75.24 79.20 83.16 87.12 91.08 7.92 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 51.48 55.44 59.40 63.36 67.32 71.28 75.24 79.20 83.16 87.12 91.08 95.04 Unit: mm CHANGJIANG CONNECTORS TEL:86-755-29959119 29959129 FAX:86-755-29959139 Http://www.CJT.cn A3961 SERIES A3961WR-B 3.96mm pitch wire to board connector 3.96mm pitch 90° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A3961 or A3964 series Housing *Color:Natual Circuit 1 20 Ordering Information & Dimensions: PART NO. 3.96±0.10 Ø1.80±0.05 3.96±0.10 P.C.B LAYOUT A±0.20 5.60 3.20±0.20 3.60 PIN 1.14 SQ A3961WVA 5.40±0.20 11.30±0.20 22.20±0.25 B±0.25 10.20±0.20 3.96 7.92 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 51.48 55.44 59.40 63.36 67.32 71.28 75.24 79.20 83.16 87.12 91.08 7.92 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 51.48 55.44 59.40 63.36 67.32 71.28 75.24 79.20 83.16 87.12 91.08 95.04 Unit: mm 3.96mm pitch 180° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A3961 or A3964 series Housing *Color:Natual Ordering Information & Dimensions: 6.35±0.25 PART NO. 3.96±0.10 3.96±0.10 A±0.20 Ø1.80±0.05 P.C.B LAYOUT 3.20±0.20 3.60±0.20 17.50±0.25 B±0.25 PIN 1.14 SQ A3961WR-2P-B A3961WR-3P-B A3961WR-4P-B A3961WR-5P-B A3961WR-6P-B A3961WR-7P-B A3961WR-8P-B A3961WR-9P-B A3961WR-10P-B A3961WR-11P-B A3961WR-12P-B A3961WR-13P-B A3961WR-14P-B A3961WR-15P-B A3961WR-16P-B A3961WR-17P-B A3961WR-18P-B A3961WR-19P-B A3961WR-20P-B A3961WR-21P-B A3961WR-22P-B A3961WR-23P-B A3961WR-24P-B Dimensions A B A3961WVA-2P A3961WVA-3P A3961WVA-4P A3961WVA-5P A3961WVA-6P A3961WVA-7P A3961WVA-8P A3961WVA-9P A3961WVA-10P A3961WVA-11P A3961WVA-12P A3961WVA-13P A3961WVA-14P A3961WVA-15P A3961WVA-16P A3961WVA-17P A3961WVA-18P A3961WVA-19P A3961WVA-20P A3961WVA-21P A3961WVA-22P A3961WVA-23P A3961WVA-24P Dimensions A B 3.96 7.92 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 51.48 55.44 59.40 63.36 67.32 71.28 75.24 79.20 83.16 87.12 91.08 7.92 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 51.48 55.44 59.40 63.36 67.32 71.28 75.24 79.20 83.16 87.12 91.08 95.04 Unit: mm CHANGJIANG CONNECTORS TEL:86-755-29959119 29959129 FAX:86-755-29959139 Http://www.CJT.cn A3961 SERIES A3961WRA 3.96mm pitch wire to board connector 3.96mm pitch 90° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A3961 or A3964 series Housing *Color:Natual Ordering Information & Dimensions: 6.35±0.20 PART NO. 3.96±0.10 Ø1.80±0.25 P.C.B LAYOUT 3.96±0.10 A±0.20 8.50±0.20 3.60 8.10±0.20 3.20±0.20 B±0.25 PIN 1.14 SQ A3961WRA-2P A3961WRA-3P A3961WRA-4P A3961WRA-5P A3961WRA-6P A3961WRA-7P A3961WRA-8P A3961WRA-9P A3961WRA-10P A3961WRA-11P A3961WRA-12P A3961WRA-13P A3961WRA-14P A3961WRA-15P A3961WRA-16P A3961WRA-17P A3961WRA-18P A3961WRA-19P A3961WRA-20P A3961WRA-21P A3961WRA-22P A3961WRA-23P A3961WRA-24P Dimensions A B 3.96 7.92 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 51.48 55.44 59.40 63.36 67.32 71.28 75.24 79.20 83.16 87.12 91.08 7.92 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 51.48 55.44 59.40 63.36 67.32 71.28 75.24 79.20 83.16 87.12 91.08 95.04 Unit: mm A3961WV-R 3.96mm pitch 180° Wafer, Round PIN Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A3961 or A3964 series Housing *Color:Natual Ordering Information & Dimensions: PART NO. Circuit 1 3.96±0.10 Ø1.57±0.05 3.96±0.10 P.C.B LAYOUT A±0.20 3.20±0.20 17.50±0.25 11.30±0.25 PIN 1.14 ROUND 3.60±0.20 5.60±0.20 B±0.25 10.20±0.20 A3961WV-2P-R A3961WV-3P-R A3961WV-4P-R A3961WV-5P-R A3961WV-6P-R A3961WV-7P-R A3961WV-8P-R A3961WV-9P-R A3961WV-10P-R A3961WV-11P-R A3961WV-12P-R A3961WV-13P-R A3961WV-14P-R A3961WV-15P-R A3961WV-16P-R A3961WV-17P-R A3961WV-18P-R A3961WV-19P-R A3961WV-20P-R A3961WV-21P-R A3961WV-22P-R A3961WV-23P-R A3961WV-24P-R Dimensions A B 3.96 7.92 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 51.48 55.44 59.40 63.36 67.32 71.28 75.24 79.20 83.16 87.12 91.08 7.92 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 51.48 55.44 59.40 63.36 67.32 71.28 75.24 79.20 83.16 87.12 91.08 95.04 Unit: mm CHANGJIANG CONNECTORS TEL:86-755-29959119 29959129 FAX:86-755-29959139 Http://www.CJT.cn A3961 SERIES A3961WVA-R 3.96mm pitch wire to board connector 3.96mm pitch 180° Wafer, Round PIN Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A3961 or A3964 series Housing *Color:Natual Ordering Information & Dimensions: 6.35±0.20 PART NO. 3.96±0.10 3.96±0.10 A±0.20 Ø1.57±0.05 3.60±0.20 17.50±0.25 PIN 1.14 ROUND 3.20±0.20 P.C.B LAYOUT B±0.25 A3961WVA-2P-R A3961WVA-3P-R A3961WVA-4P-R A3961WVA-5P-R A3961WVA-6P-R A3961WVA-7P-R A3961WVA-8P-R A3961WVA-9P-R A3961WVA-10P-R A3961WVA-11P-R A3961WVA-12P-R A3961WVA-13P-R A3961WVA-14P-R A3961WVA-15P-R A3961WVA-16P-R A3961WVA-17P-R A3961WVA-18P-R A3961WVA-19P-R A3961WVA-20P-R A3961WVA-21P-R A3961WVA-22P-R A3961WVA-23P-R A3961WVA-24P-R Dimensions A B 3.96 7.92 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 51.48 55.44 59.40 63.36 67.32 71.28 75.24 79.20 83.16 87.12 91.08 7.92 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 51.48 55.44 59.40 63.36 67.32 71.28 75.24 79.20 83.16 87.12 91.08 95.04 Unit: mm CHANGJIANG CONNECTORS TEL:86-755-29959119 29959129 FAX:86-755-29959139 Http://www.CJT.cn A3961 SERIES A3961WV-A 7.92mm pitch wire to board connector 7.92mm pitch 180° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A3961 or A3964 series Housing *Color:Natual Circuit 1 7.92±0.10 Ø1.80±0.05 7.92±0.10 P.C.B LAYOUT A±0.20 5.60±0.20 Ordering Information & Dimensions: B±0.25 3.20±0.20 3.60±0.20 17.50±0.25 11.30±0.20 PART NO. PIN 1.14 SQ 10.20±0.20 A3961WV-3P-A A3961WV-5P-A A3961WV-7P-A A3961WV-9P-A A3961WV-11P-A A3961WV-13P-A A3961WV-15P-A A3961WV-17P-A A3961WV-19P-A Dimensions A B 7.92 15.84 23.76 31.68 39.60 47.52 55.44 63.36 71.28 11.88 19.80 27.72 35.64 43.56 51.48 59.40 67.32 75.24 Unit: mm A3961WR-B-A 7.92mm pitch 90° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A3961 or A3964 series Housing *Color:Natual Circuit 1 7.92±0.10 20 Ø1.80±0.05 P.C.B LAYOUT 7.92±0.10 A±0.20 5.60 B±0.25 Ordering Information & Dimensions: PIN 1.14 SQ 3.60 3.20±0.20 5.40±0.20 22.20±0.25 11.30±0.20 PART NO. 10.20±0.20 A3961WR-3P-B-A A3961WR-5P-B-A A3961WR-7P-B-A A3961WR-9P-B-A A3961WR-11P-B-A A3961WR-13P-B-A A3961WR-15P-B-A A3961WR-17P-B-A A3961WR-19P-B-A Dimensions A B 7.92 15.84 23.76 31.68 39.60 47.52 55.44 63.36 71.28 11.88 19.80 27.72 35.64 43.56 51.48 59.40 67.32 75.24 Unit: mm CHANGJIANG CONNECTORS TEL:86-755-29959119 29959129 FAX:86-755-29959139 Http://www.CJT.cn A-337 A3961 SERIES A3961WVA-A 7.92mm pitch wire to board connector 7.92mm pitch 180° Wafer 6.35±0.25 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A3961 or A3964 series Housing *Color:Natual 7.92±0.10 7.92±0.10 Ø1.80±0.05 A±0.20 P.C.B LAYOUT B±0.25 Ordering Information & Dimensions: 3.20±0.20 3.60±0.20 17.50±0.25 PART NO. A3961WVA-3P-A A3961WVA-5P-A A3961WVA-7P-A A3961WVA-9P-A A3961WVA-11P-A A3961WVA-13P-A A3961WVA-15P-A A3961WVA-17P-A A3961WVA-19P-A PIN 1.14 SQ Dimensions A B 7.92 15.84 23.76 31.68 39.60 47.52 55.44 63.36 71.28 11.88 19.80 27.72 35.64 43.56 51.48 59.40 67.32 75.24 Unit: mm A3961WRA-A 7.92mm pitch 90° Wafer 6.35±0.20 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A3961 or A3964 series Housing *Color:Natual 7.92±0.10 Ø1.80±0.05 P.C.B LAYOUT 7.92±0.10 A±0.20 Ordering Information & Dimensions: 8.50±0.20 PART NO. 3.20±0.20 8.10±0.20 3.60±0.20 B±0.25 PIN 1.14 SQ A3961WRA-3P-A A3961WRA-5P-A A3961WRA-7P-A A3961WRA-9P-A A3961WRA-11P-A A3961WRA-13P-A A3961WRA-15P-A A3961WRA-17P-A A3961WRA-19P-A Dimensions A B 7.92 15.84 23.76 31.68 39.60 47.52 55.44 63.36 71.28 11.88 19.80 27.72 35.64 43.56 51.48 59.40 67.32 75.24 Unit: mm CHANGJIANG CONNECTORS TEL:86-755-29959119 29959129 FAX:86-755-29959139 Http://www.CJT.cn A-338 A3961 SERIES A3961WV-R-A 7.92mm pitch wire to board connector 7.92mm pitch 180° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A3961 or A3964 series Housing *Color:Natual Circuit 1 7.92±0.10 Ø1.57±0.05 7.92±0.10 A±0.20 P.C.B LAYOUT B±0.25 5.60±0.20 Ordering Information & Dimensions: 3.20±0.20 3.60±0.20 17.50±0.25 11.30±0.25 PART NO. 10.20±0.20 PIN 1.14 ROUND A3961WVA-R-A A3961WV-3P-R-A A3961WV-5P-R-A A3961WV-7P-R-A A3961WV-9P-R-A A3961WV-11P-R-A A3961WV-13P-R-A A3961WV-15P-R-A A3961WV-17P-R-A A3961WV-19P-R-A Dimensions A B 7.92 15.84 23.76 31.68 39.60 47.52 55.44 63.36 71.28 11.88 19.80 27.72 35.64 43.56 51.48 59.40 67.32 75.24 Unit: mm 7.92mm pitch 180° Wafer 6.35±0.20 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-2 *Mates with CJT A3961 or A3964 series Housing *Color:Natual 7.92±0.10 7.92±0.10 A±0.20 Ø1.80±0.05 P.C.B LAYOUT B±0.25 Ordering Information & Dimensions: PIN 1.14 ROUND 3.20±0.20 3.60±0.20 17.50±0.25 PART NO. A3961WVA-3P-R-A A3961WVA-5P-R-A A3961WVA-7P-R-A A3961WVA-9P-R-A A3961WVA-11P-R-A A3961WVA-13P-R-A A3961WVA-15P-R-A A3961WVA-17P-R-A A3961WVA-19P-R-A Dimensions A B 7.92 15.84 23.76 31.68 39.60 47.52 55.44 63.36 71.28 11.88 19.80 27.72 35.64 43.56 51.48 59.40 67.32 75.24 Unit: mm CHANGJIANG CONNECTORS TEL:86-755-29959119 29959129 FAX:86-755-29959139 Http://www.CJT.cn A-339 A3961 SERIES A3961WVB 7.92mm pitch wire to board connector 3.96mm pitch 180° Wafer Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A3961 or A3964 series Housing *Color:White 7.20±0.20 10.20±0.20 3.96±0.10 Ø1.80±0.05 Ordering Information & Dimensions: PART NO. A3961WVB-2P A3961WVB-3P A3961WVB-4P A3961WVB-5P A3961WVB-6P A3961WVB-7P A3961WVB-8P A3961WVB-9P A3961WVB-10P A3961WVB-11P A3961WVB-12P A3961WVB-13P A3961WVB-14P A3961WVB-15P A3961WVB-16P A3961WVB-17P A3961WVB-18P A3961WVB-19P A3961WVB-20P P.C.B LAYOUT 3.96±0.10 A±0.20 5.60±0.20 B±0.25 3.56±0.20 3.20±0.20 11.43±0.40 1.60±0.20 Dimensions A B 3.96 7.92 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 51.48 55.44 59.40 63.36 67.32 71.28 75.24 7.92 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 51.48 55.44 59.40 63.36 67.32 71.28 75.24 79.20 Unit: mm A3961WVB-F 3.96mm pitch 180° Wafer 4.24±0.10 10.20±0.20 7.20±0.20 Reference Informations: *Material:Pin:Brass/Tin over Nickel Insulator:Nylon 66,UL94V-0 *Mates with CJT A3961 or A3964 series Housing *Color:White 3.96±0.10 Ø1.80±0.05 Ordering Information & Dimensions: PART NO. 1.98±0.05 3.96±0.10 Ø1.63±0.05 P.C.B LAYOUT A±0.20 5.60±0.20 B±0.25 3.56±0.20 11.43±0.40 2.60±0.20 3.20±0.20 1.60±0.20 4.20±0.20 A3961WVB-F-2P A3961WVB-F-3P A3961WVB-F-4P A3961WVB-F-5P A3961WVB-F-6P A3961WVB-F-7P A3961WVB-F-8P A3961WVB-F-9P A3961WVB-F-10P A3961WVB-F-11P A3961WVB-F-12P A3961WVB-F-13P A3961WVB-F-14P A3961WVB-F-15P A3961WVB-F-16P A3961WVB-F-17P A3961WVB-F-18P A3961WVB-F-19P A3961WVB-F-20P Dimensions A B 3.96 7.92 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 51.48 55.44 59.40 63.36 67.32 71.28 75.24 7.92 11.88 15.84 19.80 23.76 27.72 31.68 35.64 39.60 43.56 47.52 51.48 55.44 59.40 63.36 67.32 71.28 75.24 79.20 Unit: mm CHANGJIANG CONNECTORS TEL:86-755-29959119 29959129 FAX:86-755-29959139 Http://www.CJT.cn
A3961WR-2P 价格&库存
很抱歉,暂时无法提供与“A3961WR-2P”相匹配的价格&库存,您可以联系我们找货
