M1A THRU M7A
1.0A Surface Mount General Purpose
Rectifiers - 50V-1000V
Package outline
Features
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Low reverse leakage
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed:
250 C/10 seconds at terminals
Glass passivated chip junction
Compliant to RoHS Directive 2011/65/EU
SMA
0.108(2.75)
0.096(2.45)
0.067 (1.70)
0.051 (1.30)
0.177(4.50)
0.157(3.99)
0.012(0.305)
0.006(0.152)
0.096(2.42)
0.078(1.98)
Mechanical data
Case: JEDEC SMA molded plastic body
Terminals: Solder plated, solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
0.060(1.52)
0.030(0.76)
0.208(5.28)
0.188(4.80)
Dimensions in inches and (millimeters)
Maximum ratings and Electrical Characteristics (AT
PARAMETER
0.008(0.203)MAX.
T A=25 oC unless otherwise noted)
Symbol
CONDITIONS
MIN.
TYP.
MAX.
UNIT
Forward rectified current
See Fig.2
IO
1.0
A
Forward surge current
8.3ms single half sine-wave (JEDEC methode)
I FSM
30
A
V R = V RRM T A = 25 OC
Reverse current
5.0
IR
O
V R = V RRM T A = 100 C
Thermal resistance
Junction to ambient
NOTE 1
Diode junction capacitance
f=1MHz and applied 4V DC reverse voltage
Storage temperature
R θJA
75
CJ
15
T STG
μA
50
-55
O
C/W
pF
O
+150
C
Note: 1.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
SYMBOLS
*1
V RRM
(V)
V RMS*2
(V)
*3
VR
(V)
M1A
50
35
50
M2A
100
70
100
M3A
200
140
200
M4A
400
280
400
M5A
600
420
600
M6A
800
560
800
M7A
1000
700
1000
www.fuxinsemi.com
*4
VF
(V)
Operating
temperature
T J, ( OC)
*1 Repetitive peak reverse voltage
*2 RMS voltage
*3 Continuous reverse voltage
1.10
-55 to +150
Page 1
*4 Maximum forward voltage@I F=1.0A
Ver2.1
M1A THRU M7A
Rating and characteristic curves
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
FIG. 1- FORWARD CURRENT DERATING CURVE
0.8
0.6
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
0.4
0.2
50
30
£PEAK FORWARD SURGE CURRENT,
AMPERES
1.0
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
75
100
125
150
25
10
175
5.0
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
10
LEAD TEMPERATURE, C
NUMBER OF CYCLES AT 60 Hz
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
1,000
10
1
TJ=25 C
PULSE WIDTH=300 ms
1%DUTY CYCLE
0.1
0.01
0.6
0.8
1.0
1.2
1.4
1.5
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
CURRENT,AMPERES
TJ=100 C
1
0.1
TJ=25 C
0.01
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
TRANSIENT THERMAL IMPEDANCE,
C/W
FIG. 5-TYPICAL JUNCTION CAPACITANCE
200
TJ=25 C
100
TJ=150 C
10
INSTANTANEOUS FORWARD VOLEAGE,
VOLTS
JUNCTION CAPACITANCE, pF
100
10
100
10
1
0.1
0.01
0.1
1
10
100
1
0.1
1.0
10
100
REVERSE VOLTAGE,VOLTS
www.fuxinsemi.com
t,PULSE DURATION,sec.
Page 2
Ver2.1
M1A THRU M7A
Pinning information
Pin
Pin1
Pin2
Simplified outline
cathode
anode
1
Symbol
2
1
2
Marking
Type number
Marking code
Example
M1A
M2A
M3A
M4A
M5A
M6A
M7A
M1
M2
M3
M4
M5
M6
M7
M7
Suggested solder pad layout
C
A
B
www.fuxinsemi.com
PACKAGE
A
B
C
SMA
0.110 (2.80)
0.063 (1.60)
0.087 (2.20)
Page 3
Ver2.1
M1A THRU M7A
Suggested thermal profiles for soldering processes
1.Storage environment: Temperature=5 oC ~40 oC Humidity=55%±25%
2.Reflow soldering of surface-mount devices
Critical Zone
TL to TP
Tp
TP
Ramp-up
TL
TL
Tsmax
Temperature
Tsmin
tS
Preheat
Ramp-down
25
o
t25 C to Peak
Time
3.Reflow soldering
Profile Feature
Soldering Condition
Average ramp-up rate(T L to T P )
o
很抱歉,暂时无法提供与“M7A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.06545
- 500+0.05141
- 1500+0.04364
- 5000+0.03899
- 20000+0.03500
- 50000+0.03284
- 国内价格
- 1+0.15290
- 500+0.05082
- 2500+0.03388
- 5000+0.02783
