JK16-1200
JK16-1200
    JK(金科)
    插件,P=10.2mm
JK16-1200 数据手册
JK16 Series Surface Mount PTC Devices Performance Specification Maximum Time Vmax Model Imax Ihold Itrip Pd Resistance To Trip Typ. Current Time Ri min Ri max R1 max (Vdc) (A) (A) (A) (W) (A) (Sec) () () () JK16-090 16 40 0.90 1.80 0.60 8.00 1.2 0.070 0.1200 0.180 JK16-110 16 40 1.10 2.20 0.70 8.00 2.3 0.050 0.0950 0.140 JK16-135 16 40 1.35 2.70 0.80 8.00 4.5 0.040 0.0740 0.120 JK16-160 16 40 1.60 3.20 0.90 8.00 9.0 0.030 0.0610 0.110 JK16-185 16 40 1.85 3.70 1.00 8.00 10.0 0.030 0.0510 0.090 JK16-250 16 40 2.50 5.00 1.20 12.50 5.0 0.020 0.0350 0.060 JK16-300 16 40 3.00 5.10 2.30 15.00 1.0 0.034 0.0650 0.105 JK16-400 16 40 4.00 6.80 2.40 20.00 1.7 0.020 0.0390 0.063 JK16-500 16 40 5.00 8.50 2.60 25.00 2.0 0.014 0.0230 0.044 JK16-600 16 40 6.00 10.20 2.80 30.00 3.3 0.009 0.0190 0.030 JK16-700 16 40 7.00 11.90 3.00 35.00 3.5 0.006 0.0130 0.021 JK16-800 16 40 8.00 13.60 3.00 40.00 5.0 0.005 0.0110 0.018 JK16-900 16 40 9.00 15.30 3.30 45.00 5.5 0.004 0.0092 0.015 JK16-1000 16 40 10.00 17.00 3.60 50.00 6.0 0.003 0.0071 0.012 JK16-1100 16 40 11.00 18.70 3.70 55.00 7.0 0.003 0.0062 0.010 JK16-200 16 40 12.00 20.40 4.20 60.00 7.5 0.002 0.0060 0.009 JK16-1300 16 40 13.00 23.00 4.40 65.00 8.5 0.002 0.0060 0.009 JK16-1400 16 100 14.00 23.80 4.60 70.00 9.0 0.002 0.0045 0.008 V max = Maximum operating voltage device can withstand without damage at rated current (Imax). I max = Maximum fault current device can withstand without damage at rated voltage (V max). I hold = Hold Current. Maximum current device will not trip in 25°C still air. I trip = Trip Current. Minimum current at which the device will always trip in 25°C still air. Pd = Power dissipation when device is in the tripped state in 25°C still air environment at rated voltage. Ri min/max = Minimum/Maximum device resistance prior to tripping at 25°C. R1max = Maximum device resistance is measured one hour post reflow. CAUTION : Operation beyond the specified ratings may result in damage and possible arcing and flame. Environmental Specifications Test Conditions Resistance change Passive aging +85°C, 1000 hrs. ±5% typical Humidity aging +85°C, 85% R.H. , 168 hours ±5% typical Thermal shock +85°C to -40°C, 20 times ±33% typical Resistance to solvent MIL-STD-202,Method 215 No change Vibration MIL-STD-202,Method 201 No change Ambient operating conditions : - 40 °C to +85 °C Maximum surface temperature of the device in the tripped state is 125 °C http:// www.jksemi.com 2016-12-01 版次: c JK16 Series Surface Mount PTC Devices Agency Approval and Environmental Complianc Agency File Number Regulation Standard UL pending 2002/95/EC TUV pending EN14582 Thermal Derating Curve Derating Curves for R16 Series 1.8 Percentage of Derating Current 1.6 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0.0 -40 -20 0 20 40 60 80 Temperature (C°) Average Time-Current Curve http:// www.jksemi.com 2016-12-01 版次: c JK16 Series Surface Mount PTC Devices Soldering Parameters TP 260 Gradual Cooling Soldering 5Sea.MAX Pre-Heating 1 Minute Min. 100 25 Time WAVE SOLDERING INFORMATIONS Pre-Heating Zone Max. ramping rate should not exceed 4℃/Sec. Soldering Zone Max. solder temperature should not exceed 260℃ Cooling Zone Cooling by natural convection in air. ◎ Specifications are subject to change without notice. Physical Dimensions(mm.) E A A E C B JK 16- 135 B F JK= JKSEMI MARK 16= Radial type 16 Vrms 135 = 1.35A hold current D D C C A B C D E Lead Model Max. Max. Typ. Min. Max. Style JK16-090 7.40 12.20 5.10 7.6 3 Kink JK16-110 7.40 14.20 5.10 7.6 3 Kink JK16-135 8.90 13.50 5.10 7.6 3 Kink JK16-160 8.90 15.20 5.10 7.6 3 Kink JK16-185 10.20 15.70 5.10 7.6 3 Kink JK16-250 10.40 14.30 5.10 7.6 3 Kink JK16-300 7.10 11.00 5.10 7.6 3 Straight JK16-400 8.90 15.20 5.10 7.6 3 Straight JK16-500 10.40 15.70 5.10 7.6 3 Straight JK16-600 10.70 18.30 5.10 7.6 3 Straight JK16-700 12.70 19.70 5.10 7.6 3 Straight JK16-800 13.40 20.10 5.10 7.6 3 Straight JK16-900 14.00 24.90 5.10 7.6 3 Straight JK16-1000 16.50 24.90 5.10 7.6 3 Straight JK16-1100 17.50 24.90 5.10 7.6 3 Straight JK16-200 18.50 26.70 10.20 7.6 3.5 Straight JK16-1300 23.50 27.90 10.20 7.6 3.5 Straight JK16-1400 23.50 27.90 10.20 7.6 3.5 Straight http:// www.jksemi.com 2016-12-01 版次: c JK16 Series Surface Mount PTC Devices PHYSICAL SPECIFICATIONS : Materials : Leads JK16-090~250 : Tin plated copper-clad steel, 24 AWG (0.51mm/0.020" Dia.) JK16-300~1100 : Tin plated copper, 20 AWG (0.81mm/0.032" Dia.) JK16-1200~1400 : Tin plated copper, 18 AWG (1.0mm/0.04" Dia.) Lead Solderability : MIL-STD-202, Method 208E Device Labeling : Device is marked with Logo, amperage rating , voltage rating & date code. Packaging Quantity 16 135 K or S R or U Model Reel Q'ty Bag Q'ty Radial type Hold K= Kink leads R=Tape&reel JK16-090 ~ JK16- 600 3000 500 16V Current S=Straight U= Bulk JK16-700 ~ JK16- 900 1500 500 packaged JK16-1000 ~ JK16-1400 - 500 (A) leads Tape & Reel packaging per EIA468-B standard. Cross Reference Cross Reference Darong Tyco / Raychem Bourns / Multifuse® Polytronics / EVERFUSE® SEA-LAND JK16-090 RUSBF090 MF-RHT070 RLD16P090BF R16-090 JK16-110 RUSBF110 - RLD16P110BF R16-110 JK16-135 RUSBF135 - RLD16P135BF R16-135 JK16-160 RUSBF160 - RLD16P160BF R16-160 JK16-185 RUSBF185 MF-RHT200 RLD16P185BF R16-185 JK16-250 RUSBF250 - RLD16P250BF R16-250 JK16-300 RGEF300 MF-RG300 RLD16P300GF R16-300 JK16-400 RGEF400 MF-RHT450 RLD16P400GF R16-400 JK16-500 RGEF500 MF-RG500 RLD16P500GF R16-500 JK16-600 RGEF600 MF-RHT650 RLD16P600GF R16-600 JK16-700 RGEF700 MF-RHT750 RLD16P700GF R16-700 JK16-800 RGEF800 - RLD16P800GF R16-800 JK16-900 RGEF900 - RLD16P900GF R16-900 JK16-1000 RGEF1000 - RLD16P1000GF R16-1000 JK16-1100 RGEF1100 MF-R1100 RLD16P1100GF R16-1100 JK16-200 RGEF1200 - RLD16P1200GF R16-1200 JK16-1300 - MF-RHT1300 - R16-1300 JK16-1400 RGEF1400 - RLD16P1400GF R16-1400 “Raychem” is a registered trademark of Tyco Electronics. “Multifuse” is a registered trademark of bourns,Inc. “EVERFUSE” is a registered trademark of Polytronics Technology Corp. “SEA-LAND” is a registered trademark of Sea-Land electronic corp. Website: http://www.jksemi.com For additional information, please contact your local Sales Representative. ©Copyright 2016, jk semi 2016-12-01 版次: c is a registered trademark of jk semi All rights are reserved
JK16-1200 价格&库存
很抱歉,暂时无法提供与“JK16-1200”相匹配的价格&库存,您可以联系我们找货
