JW5068A
JW5068A
    JOULWATT(杰华特)
    QFN20_3X3MM
    JW5068A
JW5068A 数据手册
JW5068A 23V/8A Sync. Step-Down Converter Parameters Subject to to Change Without Notice DESCRIPTION FEATURES The JW ®5068A is a monolithic buck switching regulator based on I2 architecture for fast transient response. Operating with an input range of 4V~23V, JW5068A delivers 8A of continuous output current with two integrated N-Channel MOSFETs. The internal synchronous power switches provide high efficiency without the use of an external Schottky diode. At light loads, the regulator operates in low frequency to maintain high efficiency and low output ripples. JW5068A guarantees robustness with output short protection, thermal protection, current run-away protection, and input under voltage lockout. JW5068A is available in QFN3X3-20 package, which provide a compact solution with minimal external components.  Company’s Logo is Protected, “JW” and “JOULWATT” are Registered Trademarks of JoulWatt technology Inc.              4V to 23V operating input range 8A continuous / 16A peak output current Up to 95% efficiency High efficiency at light load 500kHz switching frequency External bypass input Programmable valley current limit Power good indicator Input under voltage lockout Output discharge function Output Over Voltage latch off protection Output short protection Thermal protection RoHS Compliant and Halogen Free Available in QFN3X3-20 package APPLICATIONS     Industrial and commercial low power system Notebook LDO monitors and TVs Green Electronics/ Appliances TYPICAL APPLICATION 8A Step-down Regulator JW5068A Rev.0.5 JoulWatt® Proprietary Information. Patent Protected. Unauthorized Photocopy and Duplication Prohibited. 1
JW5068A 价格&库存
很抱歉,暂时无法提供与“JW5068A”相匹配的价格&库存,您可以联系我们找货
