MMBT3904
NPN Plastic-Encapsulate Transistor
» Features
V
= 40V
IC
= 0.2A
CE
»Pin Configurations
3 COLLECTOR
f T =300MHZ @VCE=20V, IC=10mA,f=100MHz
1 BASE
2 EMITTER
»General Description
As complementary type the PNP transistor
MMBT3906 is recommended
Epitaxial planar die constructio
SOT-23 Plastic Package.
»Absolute Maximum Ratings @T =25℃ unless otherwise noted
A
Symbol
Parameter
Value
Units
VCBO
Collector-Base Voltage
60
V
VCEO
Collector-Emitter Voltage
40
V
VEBO
Emitter-Base Voltage
6
V
IC
Collector Current -Continuous
200
mA
PC
Total Device Dissipation
200
mW
RθJA
Thermal Resistance Junction to Ambient
625
℃/W
TJ
Junction Temperature
150
Tstg
Storage Temperature
-55 to +150
Revision 2018
www.born-tw.com
1/4
MMBT3904
»Electrical Characteristics @T =25℃ unless otherwise noted
A
Parameter
Symbol
Test
conditions
MIN
MAX
UNIT
Collector-base breakdown voltage
VCBO
IC= 10μA, IE=0
60
V
Collector-emitter breakdown voltage
VCEO
IC= 1mA, IB=0
40
V
Emitter-base breakdown voltage
VEBO
IE=10μA, IC=0
6
V
Collector cut-off
current
ICBO
VCB=60V, IE=0
0.1
μA
Collector cut-off
current
ICEX
VCE=30V,VBE(off)=3V
50
nA
IEBO
VEB=5V, IC=0
0.1
μA
hFE(1)
VCE=1V, IC=10mA
100
hFE(2)
VCE=1V, IC= 50mA
60
hFE(3)
VCE=1V, IC= 100mA
30
Collector-emitter saturation voltage
VCE(sat)
IC=50mA, IB= 5mA
0.3
V
Base-emitter saturation voltage
VBE(sat)
IC= 50mA, IB= 5mA
0.95
V
Emitter cut-off
current
DC current gain
400
Transition frequency
fT
Delay Time
td
VCC=3V,VBE=-0.5V
35
nS
Rise Time
tr
IC=10mA, IB1=-IB2=1.0mA
35
nS
Storage Time
ts
VCC=3V,IC=10mA,
200
nS
Fall Time
tf
IB1=-IB2=1mA
50
nS
CLASSIFICATION OF
Range
Revision 2018
300
MHz
hFE(1)
100-300
www.born-tw.com
2/4
MMBT3904
»Typical Performance Characteristics((TJ = 25 °C, unless otherwise noted))
Revision 2018
www.born-tw.com
3/4
MMBT3904
»Package Information
SOT-23
»Ordering information
Order code
MMBT3904
Revision 2018
Package
SOT-23
Marking
1AM
www.born-tw.com
Base qty
Delivery mode
3K
Tape and reel
4/4
很抱歉,暂时无法提供与“MMBT3904”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.06782
- 600+0.05445
- 1200+0.05363
- 3000+0.04386
- 15000+0.03940
- 国内价格
- 50+0.07398
- 500+0.05940
- 3000+0.04785
- 6000+0.04299
- 24000+0.03878
- 51000+0.03651
- 国内价格
- 1+0.21010
- 200+0.06996
- 1500+0.04378
- 3000+0.03465
- 国内价格
- 50+0.07390
- 500+0.05900
- 3000+0.04750
- 6000+0.04260
- 24000+0.03840
- 51000+0.03620
