AS260-M
AS260-M
    ANBON(安邦)
    SOD123
    AS260-M
AS260-M 数据手册
AS220-M THRU AS2200-M 2.0A Surface Mount Schottky Barrier Rectifiers - 20V-200V Package outline Features • Batch process design, excellent power dissipation offers SOD-123 better reverse leakage current and thermal resistance • Low profile surface mounted application in order to optimize board space 0.154(3.9) 0.138(3.5) • Tiny plastic SMD package • Low power loss, high efficiency • High current capability, l ow forward voltage drop • High surge capability • Guardring for overvoltage protection • Ultra high-speed switching • Silicon epitaxial planar chip, metal silicon junction • Lead-free parts meet RoHS requirements • Suffix "-H" indicates Halogen free parts, ex. AS220-M-H 0.012(0.3) Typ. 0.075(1.9) 0.060(1.5) 0.067(1.7) 0.051(1.3) Mechanical data • Epoxy : UL94-V0 rated flame retardant • Case : Molded plastic, SOD-123 / MINI SMA • Terminals :Plated terminals, solderable per MIL-STD-750, 0.028(0.7) Typ. 0.028(0.7) Typ. Dimensions in inches and (millimeters) Method 2026 • Polarity : Indicated by cathode band • Mounting Position : Any • Weight : Approximated 0.018 gram Maximum ratings and Electrical characteristics (AT PARAMETER T A =25 o C unless otherwise noted) Symbol CONDITIONS Forward rectified current See Fig.1 Forward surge current 8.3ms single half sine-wave (JEDEC methode) MIN. TYP. V R = V R R M T J = 100 O C Thermal resistance Diode junction capacitance UNIT IO 2.0 A IFSM 50 A O V R = V R R M T J = 25 C Reverse current MAX. 0.5 IR mA 10 Junction to ambient RθJA 88 O C/W Junction to case RθJC 44 O C/W CJ 160 f=1MHz and applied 4V DC reverse voltage Storage temperature SYMBOLS *1 VRRM (V) V R M S*2 (V) *3 VR (V) AS220-M 20 14 20 AS230-M 30 21 30 *4 VF (V) Operating temperature T J , ( O C) 0.50 -55 to +125 AS240-M 40 28 40 AS250-M 50 35 50 AS260-M 60 42 60 AS280-M 80 56 80 AS2100-M 100 70 100 AS2150-M 150 105 150 0.90 AS2200-M 200 140 200 0.92 +175 -65 TSTG pF O C *1 Repetitive peak reverse voltage *2 RMS voltage *3 Continuous reverse voltage 0.70 *4 Maximum forward voltage@I F =2.0A 0.85 -55 to +150 Page 1 Document ID Issued Date AS-121620 2008/02/10 Revised Date 2011/09/27 Revision E Page. 3 Rating and characteristic curves (AS220-M THRU AS2200-M) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL FORWARD AVERAGE FORWARD CURRENT,(A) CHARACTERISTICS 2.4 50 AS 1.6 INSTANTANEOUS FORWARD CURRENT,(A) 2.0 25 22 0-M AS ~A 0-M 1.2 S2 40 -M 0-M S2 20 ~A 0.8 0.4 0 0 20 40 60 80 100 120 140 160 180 200 LEAD TEMPERATURE,(°C) FIG.3-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT 20V ~ 40V 10 50V ~ 60V 80V ~ 100V 3.0 150V~200V 1.0 0.1 TJ=25 C Pulse Width 300μs 1% Duty Cycle PEAK FORWARD SURGE CURRENT,(A) 50 .01 40 .1 .3 .5 .7 .9 1.1 1.3 1.5 FORWARD VOLTAGE,(V) 30 8.3ms Single Half TJ=25 C Sine Wave 20 JEDEC method 10 FIG.5 - TYPICAL REVERSE 0 1 5 50 10 CHARACTERISTICS 100 100 20V~40V 50V~200V NUMBER OF CYCLES AT 60Hz 10 REVERSE LEAKAGE CURRENT, (mA) FIG.4-TYPICAL JUNCTION CAPACITANCE JUNCTION CAPACITANCE,(pF) 700 600 500 400 300 200 TJ=100°C 1.0 0.1 TJ=25°C 0.01 100 0 .01 .05 .1 .5 1 5 10 50 100 REVERSE VOLTAGE,(V) 0.001 0 20 40 60 80 100 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) Page 2 Document ID Issued Date AS-121620 2008/02/10 Revised Date 2011/09/27 Revision E Page. 3 AS220-M THRU AS2200-M 2.0A Surface Mount Schottky Barrier Rectifiers - 20V-200V Pinning information Pin Pin1 Pin2 Simplified outline cathode anode 1 Symbol 2 1 2 Marking Type number Marking code AS220-M AS230-M AS240-M AS250-M AS260-M AS280-M AS2100-M AS2150-M AS2200-M 22 23 24 25 26 28 20 215 220 Suggested solder pad layout C A B Dimensions in inches and (millimeters) PACKAGE A B C SOD-123 0.075 (1.90) 0.055 (1.40) 0.075 (1.90) Page 3 Document ID Issued Date AS-121620 2008/02/10 Revised Date 2011/09/27 Revision E Page. 3
AS260-M 价格&库存
很抱歉,暂时无法提供与“AS260-M”相匹配的价格&库存,您可以联系我们找货
