www.msksemi.com
ESD9B5.0ST5G-MS
Semiconductor
Features
Compiance
Pin Description
Capacitance: 15pF(typ.)
Reverse Working Voltage: 5V
IEC 61000-4-2 (ESD Air): ±25KV
IEC 61000-4-2 (ESD Contact): ±25KV
IEC 61000-4-5 (Lightning 8/20µs): 8A
Applications
Schematic Diagram
Smart Phone and Tablet PC
TV and Set Top Box
Wearable Devices
PDA
Limiting Values(TA = 25 °C, unless otherwise specified)
Symbol
Parameter
Conditions
Min
Max
Unit
IEC 61000-4-2; Contact Discharge
±25
kV
IEC 61000-4-2; Air Discharge
±25
kV
VESD
Electrostatic Discharge Voltage
PPP
Peak Pulse Power
tP = 8/20 µs
80
W
IPPM
Rated Peak Pulse Current
tP = 8/20 µs
8
A
TA
Ambient Temperature Range
-55
125
Tstg
Storage Temperature Range
-55
150
Electrical Characteristics(TA = 25 °C, unless otherwise specified)
Symbol
Parameter
Conditions
Min
Typ.
Max
Unit
TA = 25 °C
5.0
V
Breakdown Voltage
IR = 1mA; TA = 25 °C
5.6
6.5
8.4
V
IR
Reverse Leakage Current
VRWM = 5V; TA = 25 °C
0.1
µA
VC
Clamping Voltage
IPP=1A, tP =8/20µs
6
V
IPP=8A, tP =8/20µs
10
V
CJ
Junction Capacitance
VR = 0V, f = 1 MHz
15
18
pF
VRWM
VBR
www.msksemi.com
ESD9B5.0ST5G-MS
Semiconductor
Compiance
PACKAGE MECHANICAL DATA
A
Dim
B
C
R
D
E
MIN
Millimeters
MAX
MIN
MAX
A
0.0125
0.02
0.32
0.52
B
0.000
0.002
0.00
0.05
C
0.037
0.043
0.95
1.080
D
0.022
0.027
0.55
0.680
E
0.016
0.024
0.40
0.60
F
0.008
0.012
0.20
0.30
H
R
F
Inches
0.015Typ.
0.001
0.40Typ.
0.005
0.05
0.15
H
1.20
0.50
0.60
0.70
NOTES:
1. CONTROLLING DIMENSIONS ARE IN MILLIMETERS (ANGLES IN DEGREES).
2. THIS LAND PATTERN IS FOR REFERENCE PURPOSES ONLY.
CONSULT YOUR MANUFACTURING GROUP TO ENSURE YOUR
COMPANY'S MANUFACTURING GUIDELINES ARE MET.
REEL SPECIFICATION
P/N
ESD9B5.0ST5G-MS
PKG
DFN1006-2L
QTY
10000
www.msksemi.com
ESD9B5.0ST5G-MS
Semiconductor
Compiance
Attention
■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications
that can handle applications that require extremely high levels of reliability, such as life-support systems,
aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious
physical and/or material damage. Consult with your MSKSEMI Semiconductor representative
nearest
you
before using any MSKSEMI Semiconductor products described or contained herein in such applications.
■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products
at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or
other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described
orcontained herein.
■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the
performance, characteristics, and functions of the described products in the independent state, and are not
guarantees of the performance, characteristics, and functions of the described products as mounted in the
customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent
device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment.
■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all
semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to
accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause
damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents
or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention
circuitsfor safedesign, redundant design, and structural design.
■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described
or contained herein are controlled under any of applicable local export control laws and regulations, such
products must not be exported without obtaining the export license from theauthorities
concerned
in
accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or
mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise,
without the prior written permission of MSKSEMI Semiconductor.
■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not
guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable,
but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or
other rightsof third parties.
■ Any and all information described or contained herein are subject to change without notice due to
product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the
MSKSEMI Semiconductor productthat you intend to use.
www.msksemi.com
很抱歉,暂时无法提供与“ESD9B5.0ST5G-MS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.16281
- 200+0.12766
- 600+0.10822
- 2000+0.09648
- 10000+0.08635
- 20000+0.08084
