IW657P-18-70B
IW657P-18-70B
    DIALOGSEMICONDUCTOR(戴乐格)
    TDFN14
    IW657P-18-70B
IW657P-18-70B 数据手册
iW657P USB Power Delivery 3.0 Controller with Integrated Current Sense Supports Qualcomm Quick Charge 4+ 1 Description The iW657P is a USB Power Delivery (USB PD) interface controller which handles the communication between a Power Adapter and Mobile Device (MD). The controller enables the mobile device to alter the VBUS voltage from the default 5V and/or maximum current limitation (e.g. 3A) for higher power output or better efficiency. The iW657P supports USB PD 3.0, including Programmable Power Supply (PPS) support, while being backwards compatible with USB PD 2.0. The device also supports Qualcomm® Quick ChargeTM 4+ technology. The iW657P enables the use of advanced USB Type-CTM connector technology with CC1/CC2 pins for MD attach/detach detection and VCONN support for Electronically Marked Cable (EMC) rated current reading. The iW657P also integrates a high current charge-pump circuit to drive an external NFET VBUS disconnect switch. The iW657P resides on the secondary side of an AC/DC power supply and negotiates voltage and current settings with the primary-side controller, depending on the requests from the MD. The iW657P uses Dialog’s proprietary secondary-toprimary digital communication technology and when paired with one of Dialog’s primary-side RapidCharge™ controllers, such as the iW1781, iW1791 or iW1799, the iW657P eliminates the need for a discrete decoder on the primary side by using one optocoupler to transmit all necessary information for rapid charging to the primary side. This includes output voltage requests, output current limits, output voltage undershoot, output over-voltage, and fault and reset signals. The iW657P incorporates Dialog’s proven and reliable DLNK technology to communicate from the secondary to the primary and also has a built-in optocoupler LED driver to minimize the bill of material cost. The power supply designed with the iW657P is fully protected. Using over-voltage protection on the D+/D-/CC1/CC2 pins, the iW657P helps to address soft short issues in cables and connectors caused by poor or loose connections between the cable connector and the socket, contamination in the USB connector, or a worn out cable. Additionally, proprietary short circuit protection on the VBUS NFET ensures safe operation in the event of a short on the output, while the SD pin can be used with an external NTC resistor for protection from over-temeperature faults. The iW657P also integrates a secondary-side current sensing circuit that provides additional over-current protection for the power adapter. 2 Features ●● USB-IF PD certified: USB PD 3.0 + Programmable Power Supply (PPS) ●● ●● ●● ●● ●● ●● Proprietary VBUS NFET protection to protect VBUS switch from damage due to an output short circuit xx Maximum power limit in PPS to minimize power ●● Proprietary secondary-to-primary digital communication eliminates discrete decoders on the adapter size primary side and simplifies system designs xx Integrated CC transmitter/receiver supports BMC ●● D+/D-/CC1/CC2 over-voltage protection (OVP) address communication soft short issues in the output cables and connectors xx Backwards-compatible with USB PD 2.0 ●● Optional secondary-side current sensing circuit Supports Qualcomm Quick Charge 4+ Technology provides additional protection for over-load fault Supports up to 7 Power Data Objects (PDOs) ●● Uses external NTC for power adapter temperature sensing Supports wide output voltage range from 3.3 to 21V ●● Programmable active fast discharge from a high voltage VBUS level to 5V at MD unplug or upon Compatible with USB Type-C specification Rev 1.2 request with built-in switch or external switch for MD attach/detach detection and VCONN support for smart cables ●● Intelligent circuits helps achieve < 20mW system noload power at 5V steady-state operation. Integrated charge pump supports single NFET VBUS switch ●● 9-bit ADC provides accurate current (optional) and voltage sensing ●● 14-pin 4x3mm TDFN package 3 Applications ●● Rapid-charging AC/DC adapters for smart phones, tablets and other portable devices Qualcomm® Quick Charge™ is a product of Qualcomm Technologies, Inc. Product Summary www.dialog-semiconductor.com Rev. 0.6 Preliminary 1 of 7 14-Aug-2018 © 2018 Dialog Semiconductor iW657P USB Power Delivery 3.0 Controller with Integrated Current Sense Supports Qualcomm Quick Charge 4+ L + + + + VBUS N - GND U3 iW676 U1 iW1791 1 DRAIN 2 SOURCE VCC 5 3 OUT GND 4 VIN 6 + VCC 8 1 GND 2 DLNK GATE 7 3 VSENSE SOURCE 6 4 CFG ISENSE 5 U2 iW657P D+ 14 GND 13 VCC D- 12 DET SD 11 5 VBUS IS+ 10 6 VBUS_G IS- 9 7 CC2 CC1 8 1 DIS 2 DRV 3 4 D+ D- CC1 CC2 USB Type-C Socket Figure 3.1 : iW657P Typical Application Circuit with Secondary-Side Current Sensing (with iW1791 as the Primary-Side Controller and the iW676 as the Synchronous Rectifier Controller) L + + + + VBUS N - GND U3 iW676 U1 iW1791 1 DRAIN 2 SOURCE VCC 5 3 OUT GND 4 VIN 6 + VCC 8 1 GND 2 DLNK GATE 7 3 VSENSE SOURCE 6 4 CFG ISENSE 5 U2 iW657P D+ 14 GND 13 VCC D- 12 DET SD 11 5 VBUS IS+ 10 6 VBUS_G IS- 9 7 CC2 CC1 8 1 DIS 2 DRV 3 4 D+ D- CC1 CC2 USB Type-C Socket Figure 3.2 : iW657P Typical Application Circuit without Secondary-Side Current Sensing (with iW1791 as the Primary-Side Controller and the iW676 as the Synchronous Rectifier Controller) Product Summary www.dialog-semiconductor.com Rev. 0.6 Preliminary 2 of 7 14-Aug-2018 © 2018 Dialog Semiconductor iW657P USB Power Delivery 3.0 Controller with Integrated Current Sense Supports Qualcomm Quick Charge 4+ + + + - U1 iW1799 NTC DRAIN VIN 6 DET 8 2 SOURCE VCC 5 CS/CDC 7 3 OUT VSENSE 2 DLNK 3 SD GATE 6 4 VCC GND 5 GND U3 iW676 1 1 VBUS + GND 4 U2 iW657P 1 DIS 2 DRV 3 VCC D- 12 4 DET SD 11 5 VBUS IS+ 10 6 VBUS_G 7 CC2 D+ D+ 14 GND 13 D- IS- 9 CC1 8 CC1 CC2 USB Type-C Socket Figure 3.3 : iW657P Typical Application Circuit with Secondary-Side Current Sensing (with iW1799 as the Primary-Side Controller and the iW676 as the Synchronous Rectifier Controller) Product Summary www.dialog-semiconductor.com Rev. 0.6 Preliminary 3 of 7 14-Aug-2018 © 2018 Dialog Semiconductor iW657P USB Power Delivery 3.0 Controller with Integrated Current Sense Supports Qualcomm Quick Charge 4+ 4 Pinout Description iW657P DIS 1 14 D+ DRV 2 13 GND VCC 3 12 D- DET 4 11 SD VBUS 5 10 IS+ VBUS_G 6 9 IS- CC2 7 8 CC1 Figure 4.1 : 14-Lead TDFN 4x3mm Package (Top View, Transparent) Pin Number DFN-14 Pin Name Type 1 DIS Analog Output Discharging circuit. Used for fast discharging of output capacitor. 2 DRV Analog Output External circuit drive. Can be used to drive optocoupler LED with automatic current limiting for transmitting signals to primary side. 3 VCC Power Supply IC power supply. 4 DET Analog Input AC unplug detect. 5 VBUS Analog Input/ Output Monitor VBUS voltage after N-FET switch. 6 VBUS_G Analog Input/ Output Connect to external N-FET gate pin for gate-source voltage control. 7 CC2 Analog Input/ Output Configuration Channel 2. 8 CC1 Analog Input/ Output Configuration Channel 1. 9 IS- Analog Input Output current sensing terminal - (for current sensing resistor). 10 IS+ Analog Input Output current sensing terminal + (for current sensing resistor). 11 SD Analog Input/ Output Connect to an external NTC resistor to measure the power adapter temperature. 12 D- Analog Input/ Output USB D- signal. 13 GND Ground 14 D+ Analog Input/ Output Product Summary www.dialog-semiconductor.com Pin Description Ground. USB D+ signal. Rev. 0.6 Preliminary 4 of 7 14-Aug-2018 © 2018 Dialog Semiconductor iW657P USB Power Delivery 3.0 Controller with Integrated Current Sense Supports Qualcomm Quick Charge 4+ 5 Absolute Maximum Ratings Absolute maximum ratings are the parameter values or ranges which can cause permanent damage if exceeded. Parameter Symbol Value Units VCC voltage VCC -0.3 to 30 V DIS voltage VDIS -0.3 to 30 V DRV voltage VDRV -0.3 to 30 V VSD voltage VSD -0.3 to 7 V D- voltage VD- -0.3 to 7 V D+ voltage VD+ -0.3 to 7 V CC1 voltage VCC1 -0.3 to 30 V CC2 voltage VCC2 -0.3 to 30 V VBUS voltage (IVBUS < 10mA) VBUS -0.7 to 30 V VBUS_G -0.7 to 35 V DET voltage VDET -0.7 to 30 V Peak current at DIS pin (VDIS= 12V) IDIS 600 mA IS+ voltage VIS+ -0.3 to 7 V IS- voltage VIS- -0.3 to 7 V Maximum junction temperature TJMAX 150 °C Operating junction temperature TJOPT -40 to 150 °C Storage temperature TSTG -65 to 150 °C ESD rating per JEDEC JESD22-A114 (D+, D-, CC1, CC2) ±8,000 V ESD rating per JEDEC JESD22-A114 (all other pins) ±2,000 V VBUS_G voltage Notes: Note 1. Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only, so functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specification are not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Product Summary www.dialog-semiconductor.com Rev. 0.6 Preliminary 5 of 7 14-Aug-2018 © 2018 Dialog Semiconductor iW657P USB Power Delivery 3.0 Controller with Integrated Current Sense Supports Qualcomm Quick Charge 4+ 6 Physical Dimensions Figure 6.1 : 14-Lead TDFN 4x3mm Package 7 Part Number Code Description iW657P-XX-YYY Base Part Number Travel Adapter Maximum Output Power (W) Product Option Product Summary www.dialog-semiconductor.com Rev. 0.6 Preliminary 6 of 7 14-Aug-2018 © 2018 Dialog Semiconductor iW657P USB Power Delivery 3.0 Controller with Integrated Current Sense Supports Qualcomm Quick Charge 4+ Disclaimer Information in this document is believed to be accurate and reliable. However, Dialog Semiconductor does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information. Dialog Semiconductor furthermore takes no responsibility whatsoever for the content in this document if provided by any information source outside of Dialog Semiconductor. Dialog Semiconductor reserves the right to change without notice the information published in this document, including without limitation the specification and the design of the related semiconductor products, software and applications. Applications, software, and semiconductor products described in this document are for illustrative purposes only. Dialog Semiconductor makes no representation or warranty that such applications, software and semiconductor products will be suitable for the specified use without further testing or modification. Unless otherwise agreed in writing, such testing or modification is the sole responsibility of the customer and Dialog Semiconductor excludes all liability in this respect. Customer notes that nothing in this document may be construed as a license for customer to use the Dialog Semiconductor products, software and applications referred to in this document. Such license must be separately sought by customer with Dialog Semiconductor. All use of Dialog Semiconductor products, software and applications referred to in this document are subject to Dialog Semiconductor’s Standard Terms and Conditions of Sale, available on the company website (www.dialog-semiconductor.com) unless otherwise stated. Dialog and the Dialog logo are trademarks of Dialog Semiconductor plc or its subsidiaries. All other product or service names are the property of their respective owners. Qualcomm is a trademark of Qualcomm Incorporated, registered in the United States and other countries. Quick Charge is a trademark of Qualcomm Incorporated. All Qualcomm Incorporated trademarks are used with permission. © 2018 Dialog Semiconductor. All rights reserved. RoHS Compliance Dialog Semiconductor’s suppliers certify that its products are in compliance with the requirements of Directive 2011/65/EU of the European Parliament on the restriction of the use of certain hazardous substances in electrical and electronic equipment. RoHS certificates from our suppliers are available on request. Contacting Dialog Semiconductor United Kingdom (Headquarters) Dialog Semiconductor (UK) LTD Phone: +44 1793 757700 North America Dialog Semiconductor Inc. Phone: +1 408 845 8500 Hong Kong Dialog Semiconductor Hong Kong Phone: +852 2607 4271 China (Shenzhen) Dialog Semiconductor China Phone: +86 755 2981 3669 Germany Dialog Semiconductor GmbH Phone: +49 7021 805-0 Japan Dialog Semiconductor K. K. Phone: +81 3 5769 5100 Korea Dialog Semiconductor Korea Phone: +82 2 3469 8200 China (Shanghai) Dialog Semiconductor China Phone: +86 21 5424 9058 The Netherlands Dialog Semiconductor B.V. Phone: +31 73 640 8822 Taiwan Dialog Semiconductor Taiwan Phone: +886 281 786 222 Email info_pcbg@diasemi.com Web site: www.dialog-semiconductor.com Product Summary www.dialog-semiconductor.com Rev. 0.6 Preliminary 7 of 7 14-Aug-2018 © 2018 Dialog Semiconductor
IW657P-18-70B 价格&库存
很抱歉,暂时无法提供与“IW657P-18-70B”相匹配的价格&库存,您可以联系我们找货
