TPSMBJ18A
TPSMBJ18A
    DOWO(东沃电子)
    SMB
    TPSMBJ18A
TPSMBJ18A 数据手册
东沃电子 TPSMBJ Series DOWOSEMI Working Voltage: 11 to 170 V Peak Pulse Power: 600 W Surface Mount Transient Voltage Suppressors Features ● ● ● ● ● ● ● ● Glass passivated chip 600 W peak pulse power capability with a 10/1000 μs waveform, repetitive rate (duty cycle):0.01 % High reliability application and automotive grade AEC Q101 qualified Low leakage Uni and Bidirectional unit Excellent clamping capability Very fast response time RoHS compliant Mechanical Data ● ● ● ● [ ] 0.155 3.94 0.13 3.30 [ ] 0.216 5.50 0.201 [5.10] 0.191 4.85 0.171 4.35 [ ] 0.012 0.30 0.006 0.15 [ ] 0.096 2.44 0.084 2.13 Case: Molded plastic Epoxy: UL 94V-0 rate flame retardant Lead: Solderable per MIL-STD-750, method 2026 [ ] 0.06 1.52 0.03 0.75 [ ] 0.008 0.20 0.001 0.02 Dimensions : inch [ mm ] Polarity: Color band denotes cathode end except Bipolar Mounting position: Any DO ● [ ] 0.087 2.20 0.077 1.96 WO ● SMB/ DO-214AA Maximum Ratings(TA=25℃ unless otherwise noted) Parameter (1) Peak power dissipation with a 10/1000μs waveform Symbol PPP Value 600 UNIT W Peak pulse current wih a 10/1000μs waveform(1) Power dissipation on infinite heatsink at TL = 75 °C Peak forward surge current, 8.3 ms single half sinewave unidirectional only(2) Maximum instantaneous forward voltage at 50 A for unidirectional only(3) Operating junction and storage temperature range IPP PD See Next Table 5.0 A W IFSM 100 A VF 3.5/5.0 V TJ, TSTG –55 to +150 °C Note: (1)Non-repetitive current pulse per Fig.5 and derated above TA= 25 °C per Fig.1 (2)Measured on 8.3 ms single half sine-wave or equivalent square wave, duty cycle = 4 pulses per minute maximum (3)VF
TPSMBJ18A 价格&库存
很抱歉,暂时无法提供与“TPSMBJ18A”相匹配的价格&库存,您可以联系我们找货
