KH1(G4)C100-B02
KH1(G4)C100-B02
    KINGHELM(金航标)
    Antenna_D80X16MM
    KH1(G4)C100-B02
KH1(G4)C100-B02 数据手册
A B D C E F G Specifications Item 1 1 GPS1575.42mhz GPS /BD/ GLONASS Antenna Dielectric Frequency Range Antenna Polarization RHCP Gain 2dBi V.S.W.R 1.5 Impendance Gain LNA 2 2 Noise Figure 2dB V.S.W.R Supply Voltage 2.0 3~5V DC Current Consumption 4G Antenna MAIN FrequencyRange 20mA 824~960MHz /1710~2690MHz V.S.W.R 2.0 Polarization 3 Gain 3M(Gules) Linear 2.0dBi 3 Zenith Impendance Mechanical hcat shrink tubing Print:GPS&BD 4 Cable RG174 Connector SMA-J Material ABS Mounting Method Screw Operating Temperature Environmental Relative Humidity Ingress Protection RG174X3000MM SMA-J Vibration Environmentally Friendly 4 Up to 95% IP67 (exclude cable outlet) 10 to 55Hz with 1.5mm amplitude 2hours ROHS Compliant hcat shrink tubing Print:3G 5 5 金航标电子 4G-GPS/BD YG-4G-GPS-BD-RG174-SMA-J-3M 6 2019.03.06 A B C D E F G 6
KH1(G4)C100-B02 价格&库存
很抱歉,暂时无法提供与“KH1(G4)C100-B02”相匹配的价格&库存,您可以联系我们找货
KH1(G4)C100-B02
  • 1+11.61432
  • 10+9.97920
  • 30+8.98344
  • 100+8.14752
库存:3
