Rev 1.6
DIO6809
Ultra
a Low Power Microprocessor Reset Circuit
Features
Descriptions
s
140ms min Reset Pulse Width
DIO6809
6809
series
are
micro
micro-processor(µP)
10µA TypSupply Current @VCC=3V
supervisory circuits used to monitor the power
Guaranteed Reset Valid to VCC = +1.0V
supplies in µP and digital systems. They provide
Power Supply Transient Immunity
excellent circuit reliability and low cost by
Operating Temperature Range
eliminating external components.
-40°C to +85°C
These circuits perform a single function: they
Available in SOT-23 and SOT-23
23-3L
assert a reset signal whenever the VCC supply
voltage
Block Diagram
declines
below
a
preset
threshold,
keeping it asserted for at least 140ms after VCC has
risen above the reset threshold.
GND
1
The DIO6809 has CMOS outputs. The DIO6809 has
DIO6809
3
an active-low
low /RESET output, Thereset
The
comparator
VCC
is designed to ignore fast transients on VCC, and
/RESET
the outputs are guaranteed to be in the correct
2
logic state for VCC down
dow to 1.0V over the
temperature range.
(Top View)
The device is available in 3 pin SOT-23
SOT
and
SOT-23-3L package.
Applications
Computers
Controllers
Intelligent Instruments
Portable/Battery-Powered
Powered Equipment
Ordering Information
Order Part
TA
Number
Package
DIO6809XST3
RoHS
-40 to +85°C
SOT-23
Tape & Reel, 3000
DIO6809XSU3
RoHS
-40 to +85°C
SOT-23-3L
Tape & Reel, 3000
www.dioo.com
© 2016 DIOO MICROCIRCUITS CO., LTD
DIO6809• Rev. 1.6
DIO6809
Ordering Code = Part No. + Package Code
ST3: stands for SOT-23
SU3: stands for SOT-23-3L
X: Refer to Device Function Reference
Table on Page 2
Device Function Reference Table
Part No.
Reset threshold
Reset active Low or High
Output Type
Marking
DIO6809L
4.63V
Low
CMOS
AAAA
DIO6809M
4.38V
Low
CMOS
ABAA
DIO6809J
4.00V
Low
CMOS
CWAA
DIO6809T
3.08V
Low
CMOS
ACAA
DIO6809S
2.93V
Low
CMOS
ADAA
DIO6809R
2.63V
Low
CMOS
AFAA
DIO6809Z
2.32V
Low
CMOS
AEAA
Block Diagram
VCC
OSC
VCC
/RESET
RESET
1.25V
V
COMP
Delay
Generator
GND
www.dioo.com
DIO6809• Rev. 1.6
Ultra Low Power Microprocessor Reset Circuit
Ordering Information Complimentary Note
DIO6809
Pin No.
Symbol
1
GND
2
/RESET
3
VCC
Description
Ground terminal
CMOS output. This output remains low if VCC drops below VRES-VHYST, and for at least 140ms
after VCC rises above VRES.
Analog input. This pin is both the power supply to internal circuit and the voltage to be monitored
Absolute Maximum Ratings
Stresses beyond those listed under “Absolute Maximum Rating” may cause permanent damage to the device. These are stress
ratings only and functional operation of the device at these or any other condition beyond those indicated in the
t operational sections
of the specifications is not implied. Exposure to absolute maxim rating conditions for extended periods may affect device reliability.
rel
Parameter
Rating
VCC
-0.3 to 6.0
/RESET
-0.3 to 6.0
Terminal Voltage (With respect to GND)
V
VCC
/RESET
Input Current
Thermal Resistance
Lead Temperature Range (soldering 10s)
Storage Temperature
ESD HBM, JEDEC: JESD22-A114
www.dioo.com
Units
mA
300
°C/W
-40 to 85
°C
300
°C
-65 to 150
°C
4500
V
DIO6809• Rev. 1.6
Pin Descriptions
DIO6809
Typical value: VCC=3V, TA=25°C, unless otherwise noted.
note
Parameters
Symbol
Maximum input voltage
VCCMAX
Minimum input voltage
VCCMIN
Supply current
Reset Threshold
Temperature coefficient of
reset threshold
Reset Threshold hysteresis
IVCC
VRES
/RESET Output Voltage
High
Reset Pulse Width
Min
Typ
8
Vcc=3.0V
10
Vcc=5.0V
14
5.5
V
uA
DIO6809L
4.51
4.63
4.75
DIO6809M
4.25
4.38
4.5
DIO6809J
3.9
4.00
4.1
DIO6809T
3.0
3.08
3.15
DIO6809S
2.75
2.93
3.05
DIO6809R
2.56
2.63
2.7
DIO6809Z
2.26
2.32
2.38
±100
VCC transitions from VRES+0.1V to
VRES-0.1V
VOH
Unit
V
Vcc=2.0V
VHYST
VOL
Max
1.0
TC
VCC to /RESET Delay
/RESET Output Voltage Low
Test Conditions
V
23
us
ISINK=1.5mA
0.3
VCC=3V, VRES>3V
ISINK=3.2mA
0.3
VCC=4V, VRES>4V
ISINK=5mA
0.3
VCC=3V, VRES
很抱歉,暂时无法提供与“DIO6809SST3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.84543
- 50+0.67954
- 150+0.59660
- 500+0.53439
