S2005ELD
S2005ELD
    SEMITEL(晶讯)
    SOD-923
S2005ELD 数据手册
Semitel Schottky Barrier Diode Engbling your idea Description S2005ELD Planar Maximum Efficiency General Application (MEGA) Reverse Voltage 20 Volts Forward Current 0.5 Ampers schottky barrier diode with an integrated guard ring for stress protection encapsulated in a SOD-923 small package. Feature ■ ■ ■ ■ Small body outline dimensions Very low forward voltage Forward current: 0.5A MLS: Lever 1 – unlimited Schottky Barrier Diode SOD-923 Application ■ ■ ■ ■ ■ ■ Ultra high-speed switching Voltage clamping Protection circuits Low voltage rectification High efficiency DC-to-DC conversion Schematic Diagram Low power consumption applications Typical Applications General purpose use in ac-to-dc bridge full wave rectification for Switching Power Supply, Home Appliances, Office Equipment, Industrial Automation applications Maximum Ratings and Electrical Characteristics ℃ ambient temperature unless otherwise specified. Ratings at 25 Parameter Symbols Continuous reverse voltage VRRM Repetitive peak forward current IFRM Continuous forward current Non-repetitive peak forward current Junction temperature Conditions Min tp≤1ms; δ≤0.25 IF IFSM t=8ms square wave Tj Max Units 20 V 2.5 A 0.5 A 3.0 A 150 Operating ambient temperature Iamb -65 +150 Storage temperature Tstg -65 +150 ℃ ℃ ℃ Notes: For Schottky barrier diodes thermal run-away has to be considered, as in some applications the reverse power losses PR are a significant part of the total power losses. Nomograms for determining the reverse power losses PR and IF(AV) rating will be available on request. 1 Doc.No.SSME/JS-100-0037 @copyright Semitel 2011 www.semiteltech.com Semitel Schottky Barrier Diode Engbling your idea Characteristics Tamb=25 ℃ unless otherwise specified Parameter Symbols Continuous forward voltage Conditions Typ Max Units IF=0.1mA 125 180 mV IF=1mA 185 240 mV IF=10mA 250 290 mV IF=100mA 325 380 mV IF=500mA 450 500 mV VF Continuous reverse current IR VR=10V 4 30 µA Diode capacitance Cd VR=1V;f=1MHz 24 30 pF Schottky Barrier Diode Pulse test:tp≤300µs; δ≤0.02 Typical Performance Curves Fig.1 Forward current as a function of forward Voltage;typical values Fig.2 Reverse current as a function of reverse voltage;typical values 103 IF mA 102 IR mA ( ) ( ) (1) (2) 10 2 10 (1) (2)(3) (4) 1 (3) 10 10-1 1 (4) 10-2 10-3 10-1 0 0.1 ℃ (1) Tj=150 ; 0.2 0.3 0.4 ℃ (2) Tj=125 ; () 0.5 VF V (3) Tj=85 ; 0 ℃ 5 10 ℃ () 15 20 VR V (4) Tj=25 Fig.3Diode capacitance as a function of reverse Voltage;typical values 45 ( ) Cd pF 35 25 15 0 0 5 10 15 ℃ ( )20 VR V f =1 MHz; Tamb=25 Doc.No.SSME/JS-100-0037 @copyright Semitel 2011 2 www.semiteltech.com Semitel Schottky Barrier Diode Engbling your idea Product Dimension millmeters min max Dim I 0.39 0.41 B 0.10 0.26 C 0.08 0.14 D 0.55 0.65 E 0.75 0.85 F 0.90 1.10 G 0.05 0.15 H 0.17 0.27 I 0.90 J 0.40 K 0.30 Schottky Barrier Diode J A K Package Informations D P0 E P2 tmax Top C over Tape F A0 W K0 B0 P A0 B0 K0 D E F W P0 P2 P 0.70 ± 0.05 1.12 ± 0.05 0.48 ± 0.05 1.50 ± 0.10 1.75 ± 0.10 3.50 ± 0.05 8.00 ± 0.20 4.00 ± 0.10 2.00 ± 0.05 2.00 ± 0.05 tmax 0.25 Part Number System S 20 05 ELD Low VF Voltage Current Product Series Marking F5 3 Doc.No.SSME/JS-100-0037 @copyright Semitel 2011 www.semiteltech.com Semitel Schottky Barrier Diode Engbling your idea Order Information Device Package S2005ELD SOD-923 Net Weight 0.0006g Carrier Quantity HSF Status Tape & Reel 5000pcs RoHS compliant Revision history Date Revision Description of changes 13-September-2011 A First issue Schottky Barrier Diode CAUTION / WARNING · Information in this document is believed to be accurate and reliable. However, SEMITEL does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. · Users should independently evaluate the suitability of and test each product selected for their own applications, and SEMITEL assumes no liability whatsoever relating to the choice, selection or use of the SEMITEL products and services described herein. · SEMITEL reserves the right to change or update, without notice, any information contained in this publication; to change, without notice, the design, construction, processing, or specification of any product; and to discontinue or limit production or distribution of any product. · Information in this document supersedes and replaces all information previously supplied. · Products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an SEMITEL product can reasonably be expected to result in personal injury, death or severe property or environmental damage. SEMITEL accepts no liability for inclusion and/or use of SEMITEL products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. · This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. · Resale of SEMITEL products with provisions different from the statements and/or technical features set forth in this document shall immediately void any warranty granted by SEMITEL for the SEMITEL product or service described herein and shall not create or extend in any manner whatsoever, any liability of SEMITEL. · SEMITEL expressly disclaims all implied warranties regarding the information contained herein, including, but not limited to, any implied warranties of merchantability or fitness for a particular purpose. SEMITEL only obligations are those in the SEMITEL Standard Terms and Conditions of Sale and in no case will SEMITEL be liable for any incidental, indirect, or consequential damages arising from the sale, resale, use, or misuse of its products. Specifications are subject to change without notice © Copyright 2005, Semitel Electronics . ® is a registered trademark of Semitel Electronics All rights reserved 4 Doc.No.SSME/JS-100-0037 @copyright Semitel 2011 www.semiteltech.com
S2005ELD 价格&库存
很抱歉,暂时无法提供与“S2005ELD”相匹配的价格&库存,您可以联系我们找货
