IDC
2.5mm
NR CONNECTOR
Emboss Tape
Radial Tape
Disconnectable Insulation displacement connectors
pitch
Features ––––––––––––––––––––––––
• Twin U-slot insulation displacement section
The insulation displacement section connected to each wire
consists of two tin-plated slots (twin U-slot), which ensures
reliable connection.
• Strain relief
The housing has a strain relief feature that supports and
protects the insulation displacement connection from vibration,
shock and bending.
• Interchangeability
The shrouded header is interchangeable with the XH
connectors (crimp style), the NRD connectors (IDC style), and
the JQ connectors (board-to-board style).
The NR connector is our first insulation
displacement connector designed for
printed circuit boards and has a justified
reputation for reliability. The receptacle
accepts both discrete wires and ribbon
cables.
Specifications –––––––––––––––––––
6
JS
T
• Current rating: 2A AC, DC (AWG #24)
• Voltage rating: 250V AC, DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/10m Ω max.
After environmental testing/20m Ω max.
• Insulation resistance: 1,000M Ω min.
• Withstanding voltage: 1,500V AC/minute
• Applicable wire: UL1007(Contact JST for details regarding other UL
wires.)
AWG #28, #26, #24
Conductor/7 strands, tin-coated
Insulation O.D./1.1 to 1.5mm
• Applicable PC board thickness: 1.6mm
* Compliant with RoHS.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
Standards ––––––––––––––––––––––
Recognized E60389
Certified LR20812
1
NR
CONNECTOR
Receptacle –––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––
Model No.
B
A
5.6
7.0
5.2
10.8
JST 10
Q'ty /
box
2.5
7.5
1,000
5.0
10.0
1,000
04NR-E4K
7.5
12.5
1,000
05NR-E6S
05NR-E4K
10.0
15.0
500
06NR-E8M
06NR-E6S
06NR-E4K
12.5
17.5
500
7
07NR-E8M
07NR-E6S
07NR-E4K
15.0
20.0
500
8
08NR-E8M
08NR-E6S
08NR-E4K
17.5
22.5
500
9
09NR-E8M
09NR-E6S
09NR-E4K
20.0
25.0
250
10
10NR-E8M
10NR-E6S
10NR-E4K
22.5
27.5
250
12
12NR-E8M
12NR-E6S
12NR-E4K
27.5
32.5
200
13
13NR-E8M
13NR-E6S
13NR-E4K
30.0
35.0
200
14NR-E6S
32.5
37.5
200
AWG #28
(green)
AWG #26
(natural/white)
AWG #24
(black)
A
2
02NR-E8M
02NR-E6S
02NR-E4K
3
03NR-E8M
03NR-E6S
03NR-E4K
4
04NR-E8M
04NR-E6S
5
05NR-E8M
6
14
4.05
1.5
Dimensions (mm)
B
Circuits
2.5
Material and Finish
Contact: Phosphor bronze, nickel-undercoated, tin-plated
Housing: PA 66, UL94V-0
RoHS compliance This product displays (LF) on a label.
¨ V approved.
Note: 14NR-E6S is not TU
As the color identification,
the following alphabet shall be put in the underlined part.
For availability, delivery and minimum order quantity, contact JST.
ex.
02NR-E8MK…black [standard color for AWG#24]
S…natural (white) [standard color for AWG#26]
M…green [standard color for AWG#28]
Shrouded header –––––––––––––––––––––––––––––––––––––––––––––––––––––––––
The shrouded headers are interchangeable with the XH crimp style connectors, the NRD insulation displacement connectors, and the JQ
board-to-board connectors.
PC board layout (viewed from soldering side) and Assembly layout –––––––––––––––––––
Top entry type
17.6
2.5min.
9.2min.
13.1
3.4min.
2.5±0.05
6.1
7.0
2.5±0.05 2.5min.
φ0.9+0.1
2 circuits:φ1.0±0.05
3 to 13 circuits: φ0.9 +0.1
Top entry type
with boss
7.0
2.5±0.05
13.1
2.0±0.05
1.6±0.05
φ1.1
Note:
1. Tolerances are non-cumulative: ±0.05mm for all centers.
2. Hole dimensions differ according to the kind of PC board and piercing method. If PC boards made of hard material are used, the hole dimensions should be
larger. The dimensions above should serve as a guideline. Contact JST for details.
2
很抱歉,暂时无法提供与“05NR-E4K(LF)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+4.376371+0.56726
- 10+3.1558710+0.40906
- 50+2.6240850+0.34013
- 100+2.26665100+0.29380
- 500+2.19690500+0.28476
- 1000+2.135881000+0.27685
- 2000+2.109722000+0.27346
- 国内价格
- 1+7.11493
- 20+5.58654
- 100+4.65106
- 500+3.74073
- 国内价格
- 1+2.70000
- 10+2.14920
- 30+1.91160
