JD222M2GY5VS9.5
JD222M2GY5VS9.5
    JEC(智旭)
    插件
    等级:Y1 2.2NF ±20% 400V
JD222M2GY5VS9.5 数据手册
JYH HSU(JEC)ELECTRONICS LTD., Approved/Recognized Type Related Standard Certificate NO CQC (China) IEC 60384-14 CQC13001103540 KC (Korea) K60384 SU03044-9001 UL(usa) CSA(Canada) IEC UL 60384 E356696 ENEC (EU) EN 60384-14 ENEC-00982-A1 VDE (Germany) EN 60384-14 40038642 IEC CB IEC 60384-14 US-33637-UL APProved Monogram Specifications Operating Temp.Range -40℃ to +85℃ Use temperature range -40℃ to +125℃ Applicable Standards UL, CSA, CQC, ENEC, VDE Dielectric Withstanding Voltage Dissipation Factor (D.F) Capacitance(C) Y1 400VAC 400VAC Rted Voltage Test Voltage 400VAC 4000 VAC for 1 min. Y5P,Y5U TANδ(DF) ≦2.5%,measured at 1KHz±10%,1.0 - 5.0 Vrms,25℃ Y5V TANδ(DF) ≦5.0%,measured at 1KHz±10%,1.0 - 5.0 Vrms,25℃ Range 10 pF to 10000 pF. measured at 1KHz±10%, 1.0 - 5.0 Vrms, 25℃ Tolerance ±10% Y5P ±10% ±20% Y5U ±20% Y5V InsulationResiatance(IR) Temperature Characteristics X1 10000 MΩ , 1 min , 100 VDC Type Code Y5P Temp. Coeff. Temp. Range ±10% -40℃ to +85℃, -40℃ to +125℃ Y5V +30%~-89% -40℃ to +85℃, -40℃ to +125℃ Y5U +22%~-65% -40℃ to +85℃, -40℃ to +125℃ -1- JYH HSU(JEC)ELECTRONICS LTD., Part Number Configuration: JD 102 M (1) (2) 2G (3) (4) Y5V (5) S T 10 (6) (编带) L (7) (8) (1) AC capacitors, safety (5) Type code: (B)Y5P, (F)Y5V, (E)Y5U (2) Rated capacitance (6) Lead shape:S(直角), I(内弯), O(外弯), X(前后弯) (3) Tolerance on rated capacitance (7) Pin pitch : 7.5or9.5or10.0 (4) Rated Voltage (8) Lead length: 3-25mm Dimensions and Tolerance B=3.0mm max for AA L=3-27mm 编带详细参数看 P11. 承认规格详细参数 (Approved Spec. Data) 品名规格 D(MAX) F±0.8 L(MIN)mm T±0.5mm -2- d±0.05mm B DF A 备注 JYH HSU(JEC)ELECTRONICS LTD., Marking: a. Trademark or Company name JEC b. Product Type JD Series c. Nominal Capacitance & Tolerance 471=470pF, K= ±10%, M= ±20% d. Safety Class such as Y1 e. Recognized Type f. Rated Voltage JEC JD 102K Y1 1. Packing Quantity: Safety High Voltage Ceramic Capacitor Capacitor(Y1, Y2) Capacitor DC Bulk 1000pcs 1000pcs 1000pcs Tape Ammo 2000pcs 1500pcs 2000pcs Packing ROHS Compliance , SVHC 2. Packing information 2.1 the number of plastic bags in each bag is 1000 PCS. Internal label and ROHS qualification label. 2.2 the quantity of each small box is 10k-30k. 1K is a bag. It depends on the product volume. 2.3 each large box can hold two small boxes. Packing box schematic -3- JYH HSU(JEC)ELECTRONICS LTD., 料號編碼規定如下: 成品之編碼原則上以十五碼完成,亦以阿拉伯數字與英文字母混合編成,第二碼至第十一碼與瓷片相同。 第一碼以J代表自製(取 JEC 商標第一字) The coding of the finished product is in principle 15 codes, which are mixed with Arabic numerals and English letters Sizes 2 to 11 are the same as the tiles The first code is represented by J (take the first word of JEC trademark)。 2 345 J□ □□□ 6 78 □ 9 10 11 □□ 12 13 14 □ □ □ □ □ □ 小分类码 Small category codes D - Y1 Y - Y2 特性代码 Feature code Y5P -Y5P(B) 容量 capacity 05R 010 100 101 Y5V -Y5V (F) -0.5PF - 1PF - 10PF - 100PF Y5U -Y5U (E) 脚长,Feet long 3 代表脚长 3 mm 5 代表脚长 5 mm 8 代表脚长 8 mm 0 代表脚长 10mm L 代表长脚 25mm 102 - 1000PF 脚距, Foot distance 7 代表脚距 7.52 mm 9 代表脚距 9.52 mm 10 代表脚距 10.0 mm T 代表编带(Taping) CAP 误差 K-± 10% M-± 20% 额定电压 The rated voltage 2G-400V 脚型, Foot type 直脚S表示 弯脚O表示外弯 弯脚I表示内弯 弯脚 X 表示前后弯 2E-250V 2F-300V 2H-500V -4- JYH HSU(JEC)ELECTRONICS LTD., Capacitance and Dimensions: CAP. Part Number TOL. T.C. Dimension(mm) D max JD10K2GY5P To JD82K2GY5P 10pF To 82PF JD101K2GY5P 100PF 6.8 JD151K2GY5P 150PF 6.8 JD221K2GY5P 220PF 6.8 JD331K2GY5P 330PF 7.2 JD471K2GY5P JD561K2GY5P ±10% (Y5P) 470PF 560PF K ±10% JD102K2GY5P 1000PF 10.2 JD471K2GY5U 470PF 6.8 JD561K2GY5U 560PF 7.8 JD681K2GY5U 680PF 7.2 1000PF 7.8 1500PF 9.3 JD222M2GY5U 2200PF M±20% 3300PF JD392M2GY5U 3900PF 15.0 JD472M2GY5U 4700PF 15.0 JD102M2GY5V 1000PF 6.8 JD152M2GY5V 1500PF 7.8 JD222M2GY5V 2200PF 8.5 3300PF 10.2 JD392M2GY5V JD472M2GY5V JD103M2GY5V +30 ~-89% (Y5V) 3900PF M±20% 9.5 10.0 10.7 JD332M2GY5U JD332M2GY5V 6 0.55 8.8 9.8 JD152M2GY5U Φ d(±0.05) 8.8 680PF +22 ~-65% (Y5U) T max 6.8 JD681K2GY5P JD102M2GY5U F±0.8MM 13.0 11.4 4700PF 11.4/12.0 10000PF 16.5 注:本规格仅作参考,在没有告知的情况下,有可能变更或改进,如有需求请咨询我司。 -5- JYH HSU(JEC)ELECTRONICS LTD., Firs Digit is low Temperature X:﹣55℃ Y:﹣25℃ Z: + 10℃ EIA TEMPERATURE CHARACTERISTIC CHART Last Digit is Capacitance Change Over Second Temperature Range From ﹢25 C Reading Digit is High Temperature 4:﹢65℃ 5:﹢85℃ 6:﹢105℃ 7:﹢125℃ 8:﹢150℃ A B C D E F P R S T U V ± 1.0 ﹪ ± 1.5 ﹪ ± 2.2 ﹪ ± 3.3 ﹪ ± 4.7 ﹪ ± 7.5 ﹪ ± 10 ﹪ ± 15 ﹪ ± 22 ﹪ ﹢22 ﹪ ﹣33 ﹪ ﹢22 ﹪ ﹣56 ﹪ ﹢22 ﹪ ﹣82 ﹪ Capacitance Temperature Characteristics -6- JYH HSU(JEC)ELECTRONICS LTD., Performance & Tests, draw up by IEC 60384-14:2005 and GB/T 6346 "Note: (1) Is was defined according with IEC 60384-14:2005, when for qualification approval and periodic tests, the withstanding test must last to 1 minute, and it belong to destroyed test domain, therefore, after the test, capacitors should be scrap. Withstand voltage test should rise slowly at 150V/s, and test time is counted from when the voltage reaches to experiment requirement." (2) The test time is more than 1 second at production period, and the rated test voltage is applied. Capacitors may cause to damage when withstand voltage test repeated." Item Characteristic Appearance and Dimensions Please refer to figures and tables on page 2, 3 and 4. NO. 1 Test Method 1~1 1~2 2 Marks Must be clean and clear. 2~1 Label need to be able endure wiping with Isopropanol 3~1 Rated voltage: 300VAC for Y2, test voltage 2000 VAC or 2600 VAC, time 60s, frequency: 50Hz/60Hz. Rated voltage: 400VAC for Y1, test voltage 4000 VAC, Approval and period test: 60s, Lot inspection 100% and time 2s, dicharge current must ≦50 mA." Can not have exceptions. 3~2 Use metal foil test method: use metal foil wrap around the capacitor body, each end extending at least 5mm, and keep 1mm/1kV distance minimum, between metal foil and terminals. for Y2, test voltage 2300VAC; for Y1, test voltage 4000VAC, test time 60s. Withstand voltage test(Ⅲ) (For safety symbol A2) (1)Gauze shall not ignite. (2)Capacitors shall not in burned. 4~1 Withstand voltage test (Ⅳ)(For safety symbol B2) (3)Elements and coating must 3 Withstand voltage test (Ⅰ) 4 5 "Production line visual inspection must be done in full and remove the defective products." "Dimensions measurement by micrometer and Caliper Between terminal Between terminal and coating. Can not have exceptions. not scattered. (4)Terminals can not be moved away from 5~1 According to IEC 60384-14 and GB/T6346 requirements. According to IEC 60384-14 and GB/T6346 requirements. the mounting position than 3mm. 6 Between terminals More than 10000MΩ. I R Between terminals and coating. 7 6~1 More than 10000MΩ. Within specified tolerance 7~1 The Capacitance shall be measured at 25℃, with 1±0.1kHz and 5Vrms max Dissipation B(Y5P) tan ≦2.5% 8~1 "The Dissipation Factor shall be measured at 25℃ with Factor(D.F) E(Y5U) tan ≦2.5% Capacitance 8 Measured voltage is 500 ± 15V within 1 minute, and IR keeps within the specified value. 1±0.1kHz and 5Vrms max F(Y5V) tan ≦5.0% -7- JYH HSU(JEC)ELECTRONICS LTD., NO Item 9 Characteristic Test Method Temperature Coefficient 9~1 Temperature applicable): 9~2 PPM/℃=(Ct2- Ct1) /Ct1*(t2-t1) Ct2:the capacitance of t2 Ct1:the capacitance of t1 t2:85℃±3℃ t1:20℃±2℃ (T.C. category applicable): TYPE 20~85℃ Type Type Type Robustness of terminations Vibratio nresista nce ﹣800~ -1000pp -5800 m∕℃ ppm∕℃ B Within ±10% E Within +22% -56% F Within +30% -80% 9~3 Lead wires not be snapped 10~1 Tensile Capacitors not be damaged 10~2 Bending Lead wires not be fractured Capacitors not be damaged Appearance No significant abnormal Cap. Within specification 10~3 Soldering Heat Resistance Appearance (T.C. category Temperature phase 1) 20±2℃ → 2) -25±2℃ → 3) 20±2℃ →4) 85±2℃ →5) 20±2℃ Capacitance change: (High Dielectric Category applicable) C .C(%)=(Ctx-Ct20)/Ct20*100 Ctx : Except Temp. phase 1 、 3 、 5, The capacitance of any temperature between phase 2 to phase 4. Ct20: The capacitance of phase 3 temp. Diameter(mm) Load(kgs) Time(sec) 0.5Φ 0.5 10 0.6Φ~0.8Φ 1 10 Fix the capacitor's body and apply a tensile weight gradually to each lead wire in the radial direction Diameter(mm) Load(kgs) 0.5Φ 0.25 0.6Φ~0.8Φ 0.5 Bending angle is 90 more than twice. 11~1 Vibration frequency from 10Hz to 55Hz and back to 10Hz, amplitude 1.5mm, period time within 1 minute。 12~1 Solder temperature 350±10℃ Change Q or DF 12 ﹢350~ Temperature characteristics: (High Dielectric applicable) Capacitance change rate within the range: Characteristic 11 YN Temp.Range Temperature 10 SL Coefficient within initial specification No significant abnormal Immersion time 3.0± 0.5sec Dielectric StrengthⅠ Capacitance change rate compliance with characteristic as No.3 B: within ±10% E: within ±15% F: within ±20% the 12~2 Placed at room condition for 4~24 hours, and then to measure. 12~3 -8- JYH HSU(JEC)ELECTRONICS LTD., No 13 Item Solder ability 14 Test Method Solder temperature 275±10℃ Immersion time 2.0± 0.5sec Appearance No significant abnormal 14~1 Temperature:40±2℃ Dielectric StrengthⅠ Must meet requirements of No.3 14~2 Humidity:90~95%RH 14~3 Time:500±12 Hrs 14~4 Remove & placed at room condition for 1~2 hours, and then to measure. 15~1 Temperature:40±2℃ 15~2 Humidity:90~95%RH 15~3 Time:500±12 Hrs 15~4 Voltage: AC 180Vrms 15~5 Current:Less than 50mA 15~6 Remove & placed at room condition for 1~2 hours, and then to measure. Between terminals R Damp heat loading The round surface of lead wires, there 13~1 must be 3/4 area welding with the 13~2 solder.。 I Humidity (Under Steady State) 15 Characteristic Between terminal & coating the More than the 1/2 value of No.6 requirements. Capacitance change rate Type B within ±15% Type E within ±20% Type F within ±30% Dissipation Factor (D.F) Type B & E, under 5%. Type F, under 7.5% Appearance No significant abnormal Dielectric StrengthⅠ IR Between terminals Between terminal & coating Must meet requirements of No.3 the More than the 1/2 value of No.6 requirements. Capacitance change rate Type B within ±15% Type E within ±20% Type F within ±30% Dissipation Factor (D.F) Type B & E, under 5% Type F, under 7.5%. -9- JYH HSU(JEC)ELECTRONICS LTD., No Item 16 Characteristic Test Method Endurance Appearance No significant abnormal 16~1 Temperature:85±3℃; 125±5℃ Dielectric StrengthⅠ "Must meet the requirements of No.3 16~2 Time:1000±12 Hrs I R Between terminals Between terminal&coating Capacitance change rate Dissipation Factor (D.F) More than the 1/2 value of No.6 requirements. 16~3 16~4 Type B within ±15% Type E within ±20% Type F within ±30% 18 Solvent Resistance (Body) Applicable safety symbols A2, B2. After the test must meet the standards of its electrical properties 19 Solvent Resistance (Mark) Current:less than 50mA 16~5 Remove & placed at room condition for 1~2 hours, and then to measure. Type B & E, under 5% Type F, under 7.5% 17 Flame Test Voltage: rated voltage of 1.7UR Marks should be legible - 10 - The capacitor should be subjected to applied flame for 15 sec, and then removed for 15 sec, until 3 cycles are completed. And then continued to flame a minute and never to explode. The capacitor should be immersed into a isopropyl alcohol for 5±0.5 minutes, then removed and placed for 48 hrs. at room condition before post measurements. Use cotton yarn dips isopropyl alcohol, by force 5±0.5 N/1 cm^2, 1 second round trip twice to wipe mark on the body, and run 5 cycles. JYH HSU(JEC)ELECTRONICS LTD., TAPING SPECIFICATIONS Taping (Radial)--Lead Spacing F=7.5±0.8 or 10.0±0.8 Item Code Dimensions (mm) Taping Pitch P 12.7±1.0 Guide Pitch Po Lead Spacing Item Code Dimensions (mm) Lead Protrusion l +0.5~1.0 12.7±1.0 Diameter of Feed Hole Do 4.0±0.3 F 7.5±0.8 9.5±0.8 Diameter of Lead d Feed Hole Position Capacitor Body P2 6.35±1.3 Total Thickness of Tape t 0.7±0.2 Feed Hole Position Capacitor Lead P1 3.85±0.7 Thickness of Capacitor Body T Differ in each product Diameter Of ISO D See table of each series Alignment to FR. Direction Δh 0±2.0 Length of snipped Lead L 11.0 +0 0.55+0.06 -0.05 -1.0 Width Of Base Tape W 18.0±0.5 Width of Hold-down Tape Wo 12.5 Feed Hole Vertical Position W1 9.0 +0.75 -0.05 Hold-down Tape Position W2 1.5±1.5 Taping Height For Straight Ho 16.0±0.5 Coating Extention e 3.0 以下 For Crimp H 20 +1.5 e1 up to center of crimp -1.0 AMMO PACK Acceptable to standard radial type cartridge. REE Acceptable to standard radial type cartridge with a few extra accessories. Reeled axials are also acceptable to standard axial type cartridge with a few accessories. - 11 -
JD222M2GY5VS9.5 价格&库存
很抱歉,暂时无法提供与“JD222M2GY5VS9.5”相匹配的价格&库存,您可以联系我们找货
