CD4066BE
CD4066BE
    HGSEMI(华冠)
    DIP-14
    CMOS四双边开关
CD4066BE 数据手册
CD4066B CMOS Quad Bilateral Switch FEATURES • Wide Operating Voltage Range of 3.0V to 18.0V • Maximum Input Current of 1µA at 18V over Full Package-Temperature range, 100nA at 18V and 25°C • Standardized Symmetrical Output Characteristics • Noise Margin 1.0V min @ 5.0V supply 2.0V min @ 10.0V supply 2.5V min @ 15.0V supply SOP-14 DESCRIPTION The CD4066B device is a quad bilateral switch intended for the transmission or multiplexing of analog or digital signals. In addition, the on-state resistance is relatively constant over the full signal input range. The CD4066B device consists of four bilateral switches, each with independent controls. Both the p and the n devices in a given switch are biased on or off switch is tied to either the input (when the switch is on) or to VSS (when the switch is off). This configuration eliminates the variation of the switch-transistor threshold voltage with input signal and, thus, keeps the on-state resistance low over the full operating-signal range. The advantages over single-channel switches include peak input-signal voltage swings equal to the full supply voltage and more constant on-state impedance over the input-signal range. DIP-14 ORDERING INFORMATION DEVICE Package Type MARKING Packing Packing Qty CD4066BE DIP14 CD4066B TUBE 1000/box CD4066BM/TR SOP14 CD4066B REEL 2500/reel http://www.hgsemi.com.cn 1 2019 OCT V1.0 CD4066B BLOCK DIAGRAM 1Y 1Z 1E 2Y 2Z 2E 3Y 3Z 3E 4Y 4Z 4E ABSOLUTE MAXIMUM RATINGS (Note 1) CHARACTERISTIC SYMBOL MIN. MAX. UNIT DC Supply Voltage (Referenced to VSS) VDD −0.5 20 V Digital Input Voltage (Referenced to VSS) VIN −0.5 VDD + 0.5 V Analog Input Voltage (Referenced to VSS) VIS −0.5 VDD + 0.5 V Analog Output Voltage (Referenced to VSS) VOS −0.5 VDD + 0.5 V IIN - ±10 mA TSTG −65 150 °C DC Input Current Storage Temperature Note1. Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only and functional operation of the device at these or any other conditions beyond those indicated under Recommended Operating Conditions is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. RECOMMENDED OPERATING CONDITIONS (Note 2) CHARACTERISTIC SYMBOL MIN. MAX. UNIT Supply Voltage (Referenced to VSS) VDD 3 18 V Digital Input Voltage (Referenced to VSS) VIN 0 VDD V Analog Input Voltage (Referenced to VSS) VIS 0 VDD V Operating Free-Air Temperature Range TA −40 85 °C Note 2. The device is not guaranteed to function outside its operating ratings. http://www.hgsemi.com.cn 2 2019 OCT V1.0 CD4066B PIN CONFIGURATION SOP-14 DIP-14 1Y 1 14 VDD 1Y 1 14 VDD 1Z 2 13 1E 1Z 2 13 1E 2Z 3 12 4E 2Z 3 12 4E 2Y 4 11 4Y 2Y 4 11 4Y 2E 5 10 4Z 2E 5 10 4Z 3E 6 9 3Z 3E 6 9 3Z VSS 7 8 3Y VSS 7 8 3Y PIN DESCRIPTION Pin No. Pin Name Pin Function SOP-14 DIP-14 1 1 1Y Analog Input/Output for Switch 1 2 2 1Z Analog Output/Input for Switch 1 3 3 2Z Analog Output/Input for Switch 2 4 4 2Y Analog Input/Output for Switch 2 5 5 2E ON/OFF (Enable) Control for Switch 2 6 6 3E ON/OFF (Enable) Control for Switch 3 7 7 VSS 8 8 3Y Analog Input/Output for Switch 3 9 9 3Z Analog Output/Input for Switch 3 10 10 4Z Analog Output/Input for Switch 4 11 11 4Y Analog Input/Output for Switch 4 12 12 4E ON/OFF (Enable) Control for Switch 4 13 13 1E ON/OFF (Enable) Control for Switch 1 14 14 VDD http://www.hgsemi.com.cn Low Power Supply Power Supply 3 2019 OCT V1.0 CD4066B DC ELECTRICAL CHARACTERISTICS Voltages referenced to VSS. Limit SYMBOL VIH VIL IIN IDD RON PARAMETER Minimum High-Level Input Voltage, ON/OFF Control Inputs TEST CONDITION RON = Per Spec Maximum Low-Level Input Voltage, ON/OFF Control Inputs RON = Per Spec Maximum Input Leakage Current, On/Off Control Inputs VIN = VDD or VSS Maximum Quiescent Supply Current (Per Package) Maximum On-State Resistance VIN = VDD or VSS VIN = VDD, RL = 10kΩ returned to (VDD−VSS)/2, VIS = VSS to VDD VDD UNIT −40°C 25°C 85°C 5V 3.5 3.5 3.5 10 V 7 7 7 15 V 11 11 11 5V 1 1 1 10 V 2 2 2 15 V 2 2 2 18 V ±0.1 ±0.1 ±1.0 5V 0.25 0.25 7.5 10 V 0.5 0.5 15 15 V 1.0 1.0 30 20 V 5.0 5.0 150 5V 800 1050 1300 10 V 310 400 550 15 V 200 240 320 5V - 15 - 10 V - 10 - 15 V - 5 - V V µA µA Ω Maximum Difference in OnState Resistance between Any Two Channels VIN = VDD, RL = 10 kΩ IOFF Maximum Off-Channel Leakage Current VIN = VSS, |VIS – VOS| = VDD − VSS 18 V ±0.1 ±0.1 ±1.0 µA ION Maximum On-Channel Leakage Current VIN = VDD, VIS = VDD or VSS 18 V ±0.1 ±0.1 ±1.0 µA 5V - - 0.4 10 V - - 0.5 15 V - - 1.5 5V 4.6 - - 10 V 9.5 - - 15 V 13.5 - - 5V 0.64 0.51 0.36 10 V 1.6 1.3 0.9 15 V 4.2 3.4 2.4 5V −0.64 −0.51 −0.36 10 V −1.6 −1.3 −0.9 15 V −4.2 −3.4 −2.4 ΔRON VOS Switch Output Voltage VIS = VSS VIS = VDD IIS Switch Input Current VIS = VSS VIS = VDD http://www.hgsemi.com.cn 4 Ω V V mA mA 2019 OCT V1.0 CD4066B AC ELECTRICAL CHARACTERISTICS Voltages referenced to VSS, CL = 50 pF, RL = 200kΩ, Input tr = tf = 20 ns Limit SYMBOL tPLH, tPHL tPLZ, tPHZ, tPZL, tPZH CIO PARAMETER VDD 25°C 85°C 5V 40 40 80 10 V 20 20 40 15 V 15 15 30 5V 70 70 140 10 V 40 40 80 15 V 30 30 60 ON/OFF Control Input - - 15 - Analog I/O (Control Input = VSS) - - 7.5 - Feedthrough (Control Input = VSS) - - 0.6 - Maximum Propagation Delay, Analog Input to Analog Output (Figure 1) Maximum Propagation Delay, ON/OFF Control to Analog Output (Figure 2) Capacitance UNIT −40°C ns ns pF ADDITIONAL DYNAMIC CHARACTERISTICS Voltages referenced to GND and TA=25°C unless otherwise noted. Guaranteed by design. SYMBOL TEST CONDITION VDD TYP UNIT Total Harmonic Distortion VIN = VDD, VSS = −5V, RL = 10kΩ, fIS = 1kHz sine wave 5V 0.4 % - −3dB Cutoff Frequency (Switch On) VIN = VDD, VSS = −5V, RL = 1kΩ 5V 40 MHz - −50dB Feedthrough Frequency (Switch Off) VIN = GND, VIS = 5V, RL = 1kΩ 10 V 1 MHz - −50dB Crosstalk Frequency VIN(A) = VDD = 5V, VIN(B) = VSS = −5V, VIS(A) = 5Vp-p, 50Ω source, RL = 1kΩ 5V 8 MHz - Crosstalk (Control Input to Signal Output) VIN = 10V (square wave), RL = 10kΩ, tr, tf = 20ns 10 V 50 mV 6 - VIS = VDD, VSS = GND, RL = 1kΩ, CL = 50pF, VIN = 10V (square wave centered on 5V), tr, tf = 20ns, VOS = 1/2 VOS at 1kHz 5V Maximum Control Input Repetition Rate 10 V 9 15 V 9.5 THD PARAMETER http://www.hgsemi.com.cn 5 MHz 2019 OCT V1.0 CD4066B FUNCTION TABLE ON/OFF Control Switch L OFF (Hi-Z) H ON SWITCHING CHARACTERISTICS tr tf VDD 90% VIN 50% 10% VIS VSS 50 % tPZL tPLH tPLZ t PHL VOS Hi-Z 50% 10% VOS 50% tPZH tPHZ 90% VOS Fig. 1. Analog In to Analog Out http://www.hgsemi.com.cn Hi-Z 50% Fig. 2. ON/OFF Control to Analog Out 6 2019 OCT V1.0 CD4066B Important statement: Huaguan Semiconductor Co,Ltd. reserves the right to change the products and services provided without notice. Customers should obtain the latest relevant information before ordering, and verify the timeliness and accuracy of this information. Customers are responsible for complying with safety standards and taking safety measures when using our products for system design and machine manufacturing to avoid potential risks that may result in personal injury or property damage. Our products are not licensed for applications in life support, military, aerospace, etc., so we do not bear the consequences of the application of these products in these fields. Our documentation is only permitted to be copied without any tampering with the content, so we do not accept any responsibility or liability for the altered documents. http://www.hgsemi.com.cn 7 2019 OCT V1.0
CD4066BE 价格&库存
很抱歉,暂时无法提供与“CD4066BE”相匹配的价格&库存,您可以联系我们找货
