FM25Q04-TS-T-G
FM25Q04-TS-T-G
    FM(富满)
    TSSOP8
    FM25Q04-TS-T-G
FM25Q04-TS-T-G 数据手册
FM25Q04 4M-BIT SERIAL FLASH MEMORY Datasheet Sep. 2017 FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 1 INFORMATION IN THIS DOCUMENT IS INTENDED AS A REFERENCE TO ASSIST OUR CUSTOMERS IN THE SELECTION OF SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD PRODUCT BEST SUITED TO THE CUSTOMER'S APPLICATION; THEY DO NOT CONVEY ANY LICENSE UNDER ANY INTELLECTUAL PROPERTY RIGHTS, OR ANY OTHER RIGHTS, BELONGING TO SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD OR A THIRD PARTY. WHEN USING THE INFORMATION CONTAINED IN THIS DOCUMENTS, PLEASE BE SURE TO EVALUATE ALL INFORMATION AS A TOTAL SYSTEM BEFORE MAKING A FINAL DECISION ON THE APPLICABILITY OF THE INFORMATION AND PRODUCTS. PURCHASERS ARE SOLELY RESPONSIBLE FOR THE CHOICE, SELECTION AND USE OF THE SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD PRODUCTS AND SERVICES DESCRIBED HEREIN, AND SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD ASSUMES NO LIABILITY WHATSOEVER RELATING TO THE CHOICE, SELECTION OR USE OF THE SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD PRODUCTS AND SERVICES DESCRIBED HEREIN.UNLESS EXPRESSLY APPROVED IN WRITING BY AN AUTHORIZED SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD REPRESENTATIVE, SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD PRODUCTS ARE NOT RECOMMENDED, AUTHORIZED OR WARRANTED FOR USE IN MILITARY, AIR CRAFT, SPACE, LIFE SAVING, OR LIFE SUSTAINING APPLICATIONS, NOR IN PRODUCTS OR SYSTEMS WHERE FAILURE OR MALFUNCTION MAY RESULT IN PERSONAL INJURY, DEATH, OR SEVERE PROPERTY OR ENVIRONMENTAL DAMAGE. FUTURE ROUTINE REVISIONS WILL OCCUR WHEN APPROPRIATE, WITHOUT NOTICE. CONTACT SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD SALES OFFICE TO OBTAIN THE LATEST SPECIFICATIONS AND BEFORE PLACING YOUR PRODUCT ORDER. PLEASE ALSO PAY ATTENTION TO INFORMATION PUBLISHED BY SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD BY VARIOUS MEANS, INCLUDING SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD HOME PAGE (HTTP://WWW.FMSH.COM/). PLEASE CONTACT SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD LOCAL SALES OFFICE FOR THE SPECIFICATION REGARDING THE INFORMATION IN THIS DOCUMENT OR SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD PRODUCTS. Trademarks Shanghai Fudan Microelectronics Group Co., Ltd name and logo, the “复旦” logo are trademarks or registered trademarks of Shanghai Fudan Microelectronics Group Co., Ltd or its subsidiaries in China. Shanghai Fudan Microelectronics Group Co., Ltd, Printed in the China, All Rights Reserved. FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 2 1. Description The FM25Q04 is a 4M-bit (512K-byte) Serial Flash memory, with advanced write protection mechanisms. The FM25Q04 supports the standard Serial Peripheral Interface (SPI), Dual/Quad I/O as well as 2-clock instruction cycle Quad Peripheral Interface (QPI). They are ideal for code shadowing to RAM, executing code directly from Dual/Quad SPI (XIP) and storing voice, text and data. The FM25Q04 can be programmed 1 to 256 bytes at a time, using the Page Program instruction. It is designed to allow either single Sector/Block at a time or full chip erase operation. The FM25Q04 can be configured to protect part of the memory as the software protected mode. The device can sustain a minimum of 100K program/erase cycles on each sector or block. 2. Features  4Mbit of Flash memory – 128 uniform sectors with 4K-byte each – 8 uniform blocks with 64K-byte each – 16 uniform blocks with 32K-byte each – 256 bytes per programmable page  Wide Operation Range – 2.3V~3.6Vsingle voltage supply – Industrial temperature range  Serial Interface – Standard SPI: CLK, CS#, DI, DO, WP# – Dual SPI: CLK, CS#, DQ0, DQ1, WP# – Quad SPI: CLK, CS#, DQ0, DQ1, DQ2, DQ3 – QPI: CLK, CS#, DQ0, DQ1, DQ2, DQ3 – Continuous READ mode support – Allow true XIP (execute in place) operation  High Performance – Max FAST_READ clock frequency: 104MHz – Dual I/O Data transfer up to 208Mbits/s – Quad I/O I/O Data transfer up to 416Mbits/s – Typical page program time: 1.5ms – Typical sector erase time: 80ms – Typical block erase time: 120/150ms – Typical chip erase time: 1.2s  Low Power Consumption – Typical standby current: 1μA  Security – Software and hardware write protection – Lockable 2X512-Byte OTP security sectors – 64-Bit Unique ID for each device(1) – Discoverable Parameters (SFDP) Register FM25Q044M-BITSERIAL FLASH MEMORY  High Reliability – Endurance: 100,000 program/erase cycles – Data retention: 20 years  Green Package – 8-pin SOP (150mil) – 8-pin SOP (208mil) – 8-pin TSSOP8 – 8-pin TDFN(2×3mm) – All Packages are RoHS Compliant and Halogenfree Note 1.This feature is available upon special order. Please contact Shanghai Fudan Microelectronics Group Co., Ltd for details. 3. Packaging Type SOP 8 (150mil) CS# DO(DQ1) 1 2 8 7 VCC HOLD#(DQ3) WP#(DQ2) VSS 3 4 6 5 CLK DI(DQ0) CS# DO(DQ1) WP#(DQ2) VSS 1 2 3 4 TDFN8 (2x3mm) CS# DO(DQ1) WP#(DQ2) VSS VCC HOLD#(DQ3) CLK DI(DQ0) 8 2 7 3 6 4 5 VCC HOLD#(DQ3) CLK DI(DQ0) TSSOP8 SOP 8 (208mil) 8 7 6 5 1 CS# DO(DQ1) WP#(DQ2) VSS 1 2 3 4 8 7 6 5 VCC HOLD#(DQ3) CLK DI(DQ0) 4. Pin Configurations PIN PIN NO. NAME 1 CS# DO 2 (DQ1) WP# 3 (DQ2) 4 VSS DI 5 (DQ0) 6 CLK HOLD# 7 (DQ3) 8 VCC I/O FUNCTION I Chip Select Input Data Output (Data Input Output I/O (1) 1) Write Protect Input (Data Input I/O Output 2)(2) Ground Data Input (Data Input Output I/O (1) 0) I Serial Clock Input Hold Input (Data Input Output I/O (2) 3) Power Supply Note: 1 DQ0 and DQ1 are used for Dual SPI instructions. 2 DQ0 – DQ3 are used for Quad SPI and QPI instructions. Ver. 1.4 Datasheet 3 5. Block Diagram X Y Decoder Decoder Address Generator HV Generator Memory Array HOLD(DQ3) Y-Gating Serial Output logic WP CS DI DO Serial Input Logic CLK SRAM Sense Amplifier WP(DQ2) DO(DQ1) DI(DQ0) HOLD Clock Generator State Machine Figure 1 FM25Q04 Serial Flash Memory Block Diagram FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 4 6. Pin Descriptions Serial Clock (CLK): The SPI Serial Clock Input (CLK) pin provides the timing for serial input and output operations. Serial Data Input, Output and I/Os (DI, DO and DQ0, DQ1, DQ2, DQ3): The FM25Q04 supports standard SPI, Dual SPI, Quad SPI and QPI operation. Standard SPI instructions use the unidirectional DI (input) pin to serially write instructions, addresses or data to the device on the rising edge of the Serial Clock (CLK) input pin. Standard SPI also uses the unidirectional DO (output) to read data or status from the device on the falling edge of CLK. Dual/Quad SPI and QPI instructions use the bidirectional DQ pins to serially write instructions, addresses or data to the device on the rising edge of CLK and read data or status from the device on the falling edge of CLK. Quad SPI and QPI instructions require the non-volatile Quad Enable bit (QE) in Status Register-2 to be set. When QE=1, the WP# pin becomes DQ2 and HOLD# pin becomes DQ3. Chip Select (CS#): The SPI Chip Select (CS#) pin enables and disables device operation. When CS# is high, the device is deselected and the Serial Data Output (DO, or DQ0, DQ1, DQ2, DQ3) pins are at high impedance. When deselected, the devices power consumption will be at standby levels unless an internal erase, program or write status register cycle is in progress. When CS# is brought low, the device will be selected, power consumption will increase to active levels and instructions can be written to and data read from the device. After power-up, CS# must transition from high to low before a new instruction will be accepted. The CS# input must track the VCC supply level at power-up (see “9 Write Protection” and Figure 72). If needed a pullup resister on CS# can be used to accomplish this. HOLD (HOLD#): The HOLD# pin allows the device to be paused while it is actively selected. When HOLD# is brought low, while CS# is low, the DO pin will be at high impedance and signals on the DI and CLK pins will be ignored (don’t care). When HOLD# is brought high, device operation can resume. The HOLD# function can be useful when multiple devices are sharing the same SPI signals. The HOLD# pin is active low. When the QE bit of Status Register-2 is set for Quad I/O, the HOLD# pin function is not available since this pin is used for DQ3. Write Protect (WP#): The Write Protect (WP#) pin can be used to prevent the Status Registers from being written. Used in conjunction with the Status Register’s Block Protect (CMP, TB, BP2, BP1 and BP0) bits and Status Register Protect (SRP) bits, a portion as small as a 4KB sector or the entire memory array can be hardware protected. The WP# pin is active low. However, when the QE bit of Status Register-2 is set for Quad I/O, the WP# pin function is not available since this pin is used for DQ2. FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 5 7. Memory Organization The FM25Q04 array is organized into 2,048 programmable pages of 256-bytes each. Up to 256 bytes can be programmed (bits are programmed from 1 to 0) at a time. Pages can be erased in groups of 16 (4KB sector erase), groups of128 (32KB block erase), groups of 256 (64KB block erase) or the entire chip (chip erase).TheFM25Q04 has 128 erasable sectors, 16 erasable 32-k byte blocks and 8 erasable 64-k byte blocks respectively. The small 4KB sectors allow for greater flexibility in applications that require data and parameter storage. Table 1 Block (64KB) 7 Block (32KB) 15 | 14 6 13 | 12 5 11 | 10 4 9 | 8 3 7 | 6 2 5 | 4 1 3 | 2 0 1 | 0 FM25Q044M-BITSERIAL FLASH MEMORY Memory Organization Sector (4KB) 127 … 112 111 … 96 95 … 80 79 … 64 63 … 48 47 … 32 31 … 16 15 … 2 1 0 Ver. 1.4 Address Range 07F000h … 070000h 06F000h … 060000h 05F000h … 050000h 04F000h … 040000h 03F000h … 030000h 02F000h … 020000h 01F000h … 010000h 00F000h … 002000h 001000h 000000h 07FFFFh … 070FFFh 06FFFFh … 060FFFh 05FFFFh … 050FFFh 04FFFFh … 040FFFh 03FFFFh … 030FFFh 02FFFFh … 020FFFh 01FFFFh … 010FFFh 00FFFFh … 002FFFh 001FFFh 000FFFh Datasheet 6 8. Device Operations Power On Reset (66h + 99h) Reset (66h + 99h) Device Initialization Standard SPI Dual SPI Quad SPI operations Enable QPI (38h) Disable QPI (FFh) QPI operations Figure 2 FM25Q04 Serial Flash Memory Operation Diagram 8.1. Standard SPI The FM25Q04 is accessed through an SPI compatible bus consisting of four signals: Serial Clock (CLK), Chip Select (CS#), Serial Data Input (DI) and Serial Data Output (DO). Standard SPI instructions use the DI input pin to serially write instructions, addresses or data to the device on the rising edge of CLK. The DO output pin is used to read data or status from the device on the falling edge of CLK. SPI bus operation Mode 0 (0,0) and 3 (1,1) are supported. The primary difference between Mode 0 and Mode 3 concerns the normal state of the CLK signal when the SPI bus master is in standby and data is not being transferred to the Serial Flash. For Mode 0, the CLK signal is normally low on the falling and rising edges of CS#. For Mode 3, the CLK signal is normally high on the falling and rising edges of CS#. CS# CLK MODE3 MODE3 MODE0 MODE0 DI DO DONT CARE Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 MSB HIGH IMPEDANCE Bit7 Bit6 Bit5 Bit4 Bit3 Bit2 Bit1 Bit0 MSB Figure 3 The difference between Mode 0 and Mode 3 8.2. Dual SPI The FM25Q04 supports Dual SPI operation when using instructions such as “Fast Read Dual Output (3Bh)” and “Fast Read Dual I/O (BBh)”. These instructions allow data to be transferred to or from the device at two to three times the rate of ordinary Serial Flash devices. The Dual SPI Read instructions are ideal for quickly downloading code to RAM upon power-up (codeshadowing) or for executing non-speed- critical code directly from the SPI bus (XIP). When using Dual SPI instructions, the DI and DO pins become bidirectional I/O pins: DQ0 and DQ1. FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 7 8.3. Quad SPI The FM25Q04 supports Quad SPI operation when using instructions such as “Fast Read Quad Output (6Bh)”, “Fast Read Quad I/O (EBh)”, “Word Read Quad I/O (E7h)” and “Octal Word Read Quad I/O (E3h)”. These instructions allow data to be transferred to or from the device four to six times the rate of ordinary Serial Flash. The Quad Read instructions offer a significant improvement in continuous and random access transfer rates allowing fast code-shadowing to RAM or execution directly from the SPI bus (XIP). When using Quad SPI instructions the DI and DO pins become bidirectional DQ0 and DQ1 and the WP # and HOLD# pins become DQ2 and DQ3 respectively. Quad SPI instructions require the non-volatile Quad Enable bit (QE) in Status Register-2 to be set. 8.4. QPI The FM25Q04 supports Quad Peripheral Interface (QPI) operations only when the device is switched from Standard/Dual/Quad SPI mode to QPI mode using the “Enable QPI (38h)” instruction. The typical SPI protocol requires that the byte-long instruction code being shifted into the device only via DI pin in eight serial clocks. The QPI mode utilizes all four DQ pins to input the instruction code, thus only two serial clocks are required. This can significantly reduce the SPI instruction overhead and improve system performance in an XIP environment. Standard/Dual/Quad SPI mode and QPI mode are exclusive. Only one mode can be active at any given time. “Enable QPI (38h)” and “Disable QPI (FFh)” instructions are used to switch between these two modes. Upon power-up or after a software reset using “Reset (99h)” instruction, the default state of the device is Standard/Dual/Quad SPI mode. To enable QPI mode, the non-volatile Quad Enable bit (QE) in Status Register-2 is required to be set. When using QPI instructions, the DI and DO pins become bidirectional DQ0 and DQ1, and the WP# and HOLD# pins become DQ2 and DQ3 respectively. See Figure 2 for the device operation modes. 8.5. Hold For Standard SPI and Dual SPI operations, the HOLD# signal allows the FM25Q04 operation to be paused while it is actively selected (when CS# is low). The HOLD# function may be useful in cases where the SPI data and clock signals are shared with other devices. For example, consider if the page buffer was only partially written when a priority interrupt requires use of the SPI bus. In this case the HOLD# function can save the state of the instruction and the data in the buffer so programming can resume where it left off once the bus is available again. The HOLD# function is only available for standard SPI and Dual SPI operation, not during Quad SPI or QPI. To initiate a HOLD# condition, the device must be selected with CS# low. A HOLD# condition will activate on the falling edge of the HOLD# signal if the CLK signal is already low. If the CLK is not already low the HOLD# condition will activate after the next falling edge of CLK. The HOLD# condition will terminate on the rising edge of the HOLD# signal if the CLK signal is already low. If the CLK is not already low the HOLD# condition will terminate after the next falling edge of CLK. During a HOLD# condition, the Serial Data Output (DO) is high impedance, and Serial Data Input (DI) and Serial Clock (CLK) are ignored. The Chip Select (CS#) signal should be kept active (low) for the full duration of the HOLD# operation to avoid resetting the internal logic state of the device. Active Hold Active Hold Active Figure 4 HoldCondition Waveform FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 8 9. Write Protection Applications that use non-volatile memory must take into consideration the possibility of noise and other adverse system conditions that may compromise data integrity. To address this concern, the FM25Q04 provides several means to protect the data from inadvertent writes. Write Protect Features        Device resets when VCC is below threshold Time delay write disable after Power-up Write enable/disable instructions and automatic write disable after erase or program Software and Hardware (WP# pin) write protection using Status Register Write Protection using Power-down instruction Lock Down write protection for Status Register until the next power-up One Time Program (OTP) write protection for array and Security Sectors using Status Register. Upon power-up or at power-down, the FM25Q04 will maintain a reset condition while VCC is below the threshold value of VWI, (See “12.3Power-up Timing” and Figure 72). While reset, all operations are disabled and no instructions are recognized. During power-up and after the VCC voltage exceeds VWI, all program and erase related instructions are further disabled for a time delay of tPUW . This includes the Write Enable, Page Program, Sector Erase, Block Erase, Chip Erase and the Write Status Register instructions. Note that the chip select pin (CS#) must track the VCC supply level at power-up until the VCC-min level and tVSL time delay is reached. If needed a pull-up resister on CS# can be used to accomplish this. After power-up the device is automatically placed in a write-disabled state with the Status Register Write Enable Latch (WEL) set to a 0. A Write Enable instruction must be issued before a Page Program, Sector Erase, Block Erase, Chip Erase or Write Status Register instruction will be accepted. After completing a program, erase or write instruction the Write Enable Latch (WEL) is automatically cleared to a write-disabled state of 0. Software controlled write protection is facilitated using the Write Status Register instruction and setting the Status Register Protect (SRP0, SRP1) and Block Protect (CMP, TB, BP2, BP1 and BP0) bits. These settings allow a portion as small as a 4KB sector or the entire memory array to be configured as read only. Used in conjunction with the Write Protect (WP#) pin, changes to the Status Register can be enabled or disabled under hardware control. See Status Register section for further information. Additionally, the Power-down instruction offers an extra level of write protection as all instructions are ignored except for the Release Power-down instruction. FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 9 10. Status Register The Read Status Register instructions can be used to provide status on the availability of the Flash memory array, if the device is write enabled or disabled, the state of write protection, Quad SPI setting, Security Sector lock status. The Write Status Register instruction can be used to configure the device write protection features, Quad SPI setting and Security Sector OTP lock. Write access to the Status Register is controlled by the state of the non-volatile Status Register Protect bits (SRP0, SRP1), the Write Enable instruction, and during Standard/Dual SPI operations, the WP# pin. Factory default for all Status Register bits are 0. S7 S6 SRP0 RFU S5 S4 S3 S2 S1 S0 TB BP2 BP1 BP0 WEL WIP STATUS REGISTER PROTECT 0 (non-volatile) Reserved (non-volatile) TOP/BOTTOM PROTECT (non-volatile) BLOCK PROTECT BITS (non-volatile) WRITE ENABLE LATCH ERASE/WRITE IN PROGRESS Figure 5 Status Register-1 FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 10 S15 S14 S13 S12 RFU ERR WPS CMP S11 S10 S9 S8 LB1 LB0 QE SRP1 Reserved Error Status (volatile, Read only) Write Protect Selection (non-volatile) COMPLEMENT PROTECT (non-volatile) SECURITY REGISTER LOCK BIT (non-Volatile) QUAD ENABLE (non-volatile) STATUS REGISTER PROTECT 1 (non-volatile) Figure 6 Status Register-2 S23 S22 S21 S20 S19 RFU RFU RFU RFU RFU S18 S17 S16 RFU DRV1 DRV0 Reserved Output Driver Strength (Volatile/Non-Volatile Writable) Figure 7 Status Register-3 10.1. WIP Bit WIP is a read only bit in the status register (S0) that is set to a 1 state when the device is executing a Page Program, Quad Page Program, Sector Erase, Block Erase, Chip Erase, Write Status Register or Erase/Program Security Sectorinstruction. During this time the device will ignore further instructions except for the Read Status Register instruction (see tW , tPP, tSE,tBE, and tCE in “12.6AC Electrical Characteristics”). When the program, erase or write status register(or security sector)instruction has completed, the WIP bit will be cleared to a 0 state indicating the device is ready for further instructions. 10.2. Write Enable Latch (WEL) Write Enable Latch (WEL) is a read only bit in the status register (S1) that is set to 1 after executing a Write Enable Instruction. The WEL status bit is cleared to 0 when the device is write disabled. A write disable state occurs upon power-up or after any of the following instructions: FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 11 Write Disable, Page Program, Quad Page Program, Sector Erase, Block Erase, Chip Erase, Write Status Register, Erase Security Sector and Program Security Sector. 10.3. Block Protect Bits (BP2, BP1, BP0) The Block Protect Bits (BP2, BP1, BP0) are non-volatile read/write bits in the status register (S4, S3, and S2) that provide Write Protection control and status. Block Protect bits can be set using the Write Status Register Instruction (see tW in “12.6AC Electrical Characteristics”). All, none or a portion of the memory array can be protected from Program and Erase instructions (see Table 3Status Register Memory Protection). The factory default setting for the Block Protection Bits is 0, none of the array protected. 10.4. Top/Bottom Block Protect (TB) The non-volatile Top/Bottom bit (TB) controls if the Block Protect Bits (BP2, BP1, BP0) protect from the Top (TB=0) or the Bottom (TB=1) of the array as shown in Table 3Status Register Memory Protection table. The factory default setting is TB=0. The TB bit can be set with the Write Status Register Instruction depending on the state of the SRP0, SRP1 and WEL bits. 10.5. Complement Protect (CMP) The Complement Protect bit (CMP) is a non-volatile read/write bit in the status register (S14). It is used in conjunction with TB, BP2, BP1 and BP0 bits to provide more flexibility for the array protection. Once CMP is set to 1, previous array protection set by TB, BP2, BP1 and BP0 will be reversed. For instance, when CMP=0, a top 4KB sector can be protected while the rest of the array is not; when CMP=1, the top 4KB sector will become unprotected while the rest of the array become read-only. Please refer to Table 3Status Register Memory Protection table for details. The default setting is CMP=0. FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 12 10.6. Status Register Protect (SRP1, SRP0) The Status Register Protect bits (SRP1 and SRP0) are non-volatile read/write bits in the status register (S8 and S7). The SRP bits control the method of write protection: software protection, hardware protection, power supply lock-down or one time programmable (OTP) protection. Table 2 Status Register SRP1 SRP0 WP# 0 0 X 0 1 0 0 1 1 1 0 X 1 1 X Status Register Protect bits Description WP# pin has no control. The Status register can be written to after a Write Enable instruction, WEL=1. (Factory Default) Hardware When WP# pin is low the Status Register locked and can Protected not be written to. Hardware When WP# pin is high the Status register is unlocked and Unprotected can be written to after a Write Enable instruction, WEL=1. Power Supply Status Register is protected and can not be written to Lock-Down again until the next power-down, power-up cycle.(1) One Time Status Register is permanently protected and can not be Program written to. Software Protection Note: 1. When SRP1, SRP0 = (1, 0), a power-down, power-up cycle will change SRP1, SRP0 to (0, 0) state. 10.7. Error Bit (ERR) The Error bit is a status flag, which shows the status of last Program/Erase operation. It will be set to "1", if the Program/Erase operation fails. It will be set to “0”, after reset or WREN instruction. 10.8. Security Sector Lock Bits (LB1, LB0) The Security Register Lock Bit (LB1-0) are non-volatile One Time Program (OTP) bits in Status Register (S12,S11) that provide the write protect control and status to the Security Registers. The default state of LB1-0 is 0, Security Registers are unlocked. LB1-0 can be set to 1 individually using the Write Status Register instruction. LB1-0 are One Time Programmable (OTP), once it’s set to 1, the corresponding 512-Bytes Security Register will become read-only permanently. 10.9. Quad Enable (QE) The Quad Enable (QE) bit is a non-volatile read/write bit in the status register (S9) that allows Quad SPI and QPI operation. When the QE bit is set to a 0 state (factory default), the WP# pin and HOLD# are enabled. When the QE bit is set to a 1, the Quad DQ2 and DQ3 pins are enabled, and WP# and HOLD# functions are disabled. QE bit is required to be set to a 1 before issuing an “Enable QPI (38h)” to switch the device from Standard/Dual/Quad SPI to QPI, otherwise the command will be ignored. When the device is in QPI mode, QE bit will remain to be 1. A “Write Status Register” command in QPI mode cannot change QE bit from a “1” to a “0”. WARNING: If the WP# or HOLD# pins are tied directly to the power supply or ground during standard SPI or Dual SPI operation, the QE bit should never be set to a 1. FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 13 10.10. Write Protect Selection (WPS) The WPS bit is used to select which Write Protect scheme should be used. When WPS=0, the device will use the combination of CMP, TB, BP[2:0] to protect a specific area of the memory array. When WPS=1, the device will utilize the Individual Sector Locks to protect any individual sector. The default value for all Individual Sector Lock bits is 1 upon device power on or after reset. 10.11. Reserved Bits (RFU) There are a few reserved Status Register bits that may be read out as a “0” or “1”.It is recommended to ignore the values of those bits. During a “Write Status Register” instruction, the Reserved Bits can be written as “0”, but there will not be any effects. 10.12. Output driver strength (DRV1, DRV0) The DRV1 & DRV0 bits are used to determine the output driver strength. DRV1, DRV0 Driver Strength 0,0 0,1 1,0 1,1 FM25Q044M-BITSERIAL FLASH MEMORY 100% 75% 50% 25% Ver. 1.4 Datasheet 14 10.13. Status Register Memory Protection (WPS=0, CMP=0) Table 3 Status Register Memory Protection (CMP=0) STATUS REGISTER FM25Q04 (4M-BIT) MEMORY PROTECTION TB BP2 BP1 BP0 X 0 0 0 1 1 1 X 0 0 0 0 0 0 0 1 0 0 1 1 0 1 1 X 0 1 0 1 1 0 1 X PROTECTED BLOCK(S) NONE 7 6 and 7 4 thru 7 0 0 and 1 0 thru 3 0 thru 7 PROTECTED ADDRESSES NONE 070000h – 07FFFFh 060000h – 07FFFFh 040000h – 07FFFFh 000000h – 00FFFFh 000000h – 01FFFFh 000000h – 03FFFFh 000000h – 07FFFFh PROTECTED DENSITY NONE 64KB 128KB 256KB 64KB 128KB 256KB 512KB PROTECTED PORTION NONE Upper 1/8 Upper 1/4 Upper 1/2 Lower 1/8 Lower 1/4 Lower 1/2 ALL 10.14. Status Register Memory Protection (WPS=0, CMP=1) Table 4 Status Register Memory Protection (CMP=1) STATUS REGISTER FM25Q04 (4M-BIT) MEMORY PROTECTION TB BP2 BP1 BP0 X 0 0 0 1 1 1 X 0 0 0 0 0 0 0 1 0 0 1 1 0 1 1 X 0 1 0 1 1 0 1 X PROTECTED BLOCK(S) 0 thru 7 0 thru 6 0 thru 5 0 thru 3 1 thru 7 2 thru 7 4 thru 7 NONE PROTECTED ADDRESSES 000000h – 07FFFFh 000000h – 06FFFFh 000000h – 05FFFFh 000000h – 03FFFFh 010000h – 07FFFFh 020000h – 07FFFFh 040000h – 07FFFFh NONE PROTECTED DENSITY 512KB 448KB 384KB 256KB 448KB 384KB 256KB NONE PROTECTED PORTION All Lower7/8 Lower3/4 Lower1/2 Upper 1/8 Upper 1/4 Upper 1/2 NONE 10.15. Status Register Memory Protection (WPS=1) FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 15 Individual Sector Locks: 128 Sectors(Top/Bottom) Sector 127(4KB) Sector 126(4KB) Individual Sector Lock: 36h + Address ..... } Individual Sector Unlock: 39h + Address Read Sector Lock: 3Dh + Address Global Sector Lock: 7Eh Sector 1(4KB) Sector 0(4KB) Global Sector Unlock: 98h Figure 8 Individual Sector Locks FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 16 11. Instructions The Standard/Dual/Quad SPI instruction set of the FM25Q04 consists of 39 basic instructions that are fully controlled through the SPI bus (see Table 6~Table 8Instruction Set). Instructions are initiated with the falling edge of Chip Select (CS#). The first byte of data clocked into the DI input provides the instruction code. Data on the DI input is sampled on the rising edge of clock with most significant bit (MSB) first. The QPI instruction set of the FM25Q04 consists of 25 basic instructions that are fully controlled through the SPI bus (see Table 9 Instruction Set). Instructions are initiated with the falling edge of Chip Select (CS#). The first byte of data clocked through DQ[3:0] pins provides the instruction code. Data on all four DQ pins are sampled on the rising edge of clock with most significant bit (MSB) first. All QPI instructions, addresses, data and dummy bytes are using all four DQ pins to transfer every byte of data with every two serial clocks (CLK). Instructions vary in length from a single byte to several bytes and may be followed by address bytes, data bytes, dummy bytes (don’t care), and in some cases, a combination. Instructions are completed with the rising edge of edge CS#. Clock relative timing diagrams for each instruction are included in Figure 9 through Figure 76. All read instructions can be completed after any clocked bit. However, all instructions that Write, Program or Erase must complete on a byte boundary (CS# driven high after a full 8-bits have been clocked) otherwise the instruction will be ignored. This feature further protects the device from inadvertent writes. Additionally, while the memory is being programmed or erased, or when the Status Register is being written, all instructions except for Read Status Register will be ignored until the program or erase cycle has completed. 11.1. Manufacturer and Device Identification Table 5 OP Code ABh 90h,92h,94h 9Fh FM25Q044M-BITSERIAL FLASH MEMORY Manufacturer and Device Identification MF7-MF0 ID15-ID0 ID7-ID0 12h 12h A1h A1h 4013h Ver. 1.4 Datasheet 17 11.2. Standard SPI Instructions Set Table 6 Standard SPI Instructions Set (1) INSTRUCTION NAME BYTE 1 BYTE 2 BYTE 3 BYTE 4 BYTE 5 BYTE 6 CLOCK NUMBER Write Enable Volatile SR Write Enable Write Disable Read Status Register-1 Write Status Register-1 (0-7) 06h 50h 04h 05h 01h (8-15) (16-23) (24-31) (32-39) (40-47) (S7-S0)(2) S7-S0 Read Status Register-2 35h (S15-S8)(2) Write Status Register-2 31h S15-S8 Read Status Register-3 15h (S23-S16)(2) Write Status Register-3 11h S23-S16 Page Program 02h A23-A16 Sector Erase (4KB) 20h A23-A16 Block Erase (32KB) 52h A23-A16 Block Erase (64KB) D8h A23-A16 Chip Erase C7h/60h Power-down B9h Read Data 03h A23-A16 Fast Read 0Bh A23-A16 Release Powerdown / ID(4) ABh dummy (4) Manufacturer/Device ID 90h dummy JEDEC ID(4) 9Fh Read SFDP Register Read Unique ID 5Ah (5) (6) Erase Security Sectors Program Security Sectors(6) Read Security Sectors(6) Individual Sector Lock Individual Sector Unlock Read Sector Unlock Global Sector Lock Global Sector Unlock Enable QPI Enable Reset Reset 01h can be used to program Status Register1&2 A15-A8 A15-A8 A15-A8 A15-A8 A7-A0 A7-A0 A7-A0 A7-A0 A15-A8 A7-A0 (D7-D0) A15-A8 A7-A0 dummy dummy dummy (ID7-ID0)(2) dummy 00h (MF7-MF0) (ID15(MF7ID8) (ID7-ID0) MF0)Manufa Memory Capacity cturer Type 00h 00h A7-A0 dummy 4Bh dummy dummy dummy 44h 42h 48h 36h 39h 3Dh 7Eh 98h 38h 66h 99h A23-A16 A23-A16 A23-A16 A23-A16 A23-A16 A23-A16 A15-A8 A15-A8 A15-A8 A15-A8 A15-A8 A15-A8 A7-A0 A7-A0 A7-A0 A7-A0 A7-A0 A7-A0 FM25Q044M-BITSERIAL FLASH MEMORY D7-D0 Ver. 1.4 dummy D7-D0 dummy D7-D0(3) (D7-D0) (ID7-ID0) (D7-D0) (UID63UID0) D7-D0(3) (D7-D0) Datasheet 18 11.3. Dual SPI Instructions Set Table 7 INSTRUCTION NAME CLOCK NUMBER Fast Read Dual Output 11.4. BYTE 1 BYTE 2 BYTE 3 BYTE 4 BYTE 5 BYTE 6 (0-7) (8-15) (16-23) (24-31) (32-39) (40-47) 3Bh A23-A16 A15-A8 A7-A0 dummy (D7-D0, …)(8) Fast Read Dual I/O BBh A23-A8(7) A7-A0, M7M0 (7) (D7D0, …)(8) Manufacturer/Device ID by Dual I/O(4) 92h A23-A8(7) A7-A0, M7M0(7) (MF7-MF0, ID7-ID0) Quad SPI Instructions Set Table 8 INSTRUCTION NAME CLOCK NUMBER Quad SPI Instructions Set BYTE 1 BYTE 2 BYTE 3 BYTE 4 BYTE 5 BYTE 6 (0-7) (8-15) (16-23) (24-31) (40-47) Quad Page Program 32h A23-A16 A15-A8 A7-A0 (32-39) D7D0, …(10) Fast Read Quad Output 6Bh A23-A16 A15-A8 A7-A0 Fast Read Quad I/O EBh A23-A0, M7-M0(9) A23-A0, M7-M0(9) A23-A0, M7-M0(9) xxxxxx, W6-W4(9) (xxxx, D7D0)(11) (xx, D7D0)(12) (D7D0, …)(10) (D7D0, …)(10) (D7D0, …)(10) Word Read Quad I/O(13) Octal Word Read Quad I/O(14) 11.5. Dual SPI Instructions Set E7h E3h Set Burst with Wrap 77h Manufacture/Device ID by Quad I/O(4) 94h A23-A0, M7-M0(9) D7-D0, …(3) dummy (D7-D0, …)(10) xxxx, (MF7(MF7-MF0, MF0, ID7ID7-ID0, …) ID0) QPI Instructions Set Table 9 INSTRUCTION NAME BYTE 1 CLOCK NUMBER Write Enable Volatile SR Write Enable Write Disable Read Status Register-1 Write Status Register-1 Read Status Register-2 Write Status Register-2 Read Status Register-3 (0,1) 06h QPI Instructions Set (15) BYTE 2 BYTE 3 BYTE 4 BYTE 5 BYTE 6 (2,3) (4,5) (6,7) (8,9) (10,11) 50h 04h 05h 01h 35h 31h 15h FM25Q044M-BITSERIAL FLASH MEMORY (S7-S0)(2) S7-S0 01h can be used to program Status Register-1&2 (2) (S15-S8) S15-S8 (S23- Ver. 1.4 Datasheet 19 INSTRUCTION NAME BYTE 1 Write Status Register-3 Page Program Sector Erase (4KB) Block Erase (32KB) Block Erase (64KB) Chip Erase Power-down Set Read Parameters Fast Read Burst Read with Wrap(17) Fast Read Quad I/O Release Powerdown / ID(4) Manufacturer/Device ID(4) JEDEC ID (4) 11h 02h 20h 52h D8h C7h/60 h B9h C0h 0Bh BYTE 2 S16)(2) S23-S16 A23-A16 A23-A16 A23-A16 A23-A16 P7-P0 A23-A16 BYTE 3 BYTE 4 BYTE 5 BYTE 6 A15-A8 A15-A8 A15-A8 A15-A8 A7-A0 A7-A0 A7-A0 A7-A0 D7-D0(10) D7-D0(3) A7-A0 dummy(16) (D7-D0) (16) A15-A8 0Ch A23-A16 A15-A8 A7-A0 dummy (D7-D0) EBh A23-A16 A15-A8 A7-A0 M7-M0(16) (D7-D0) ABh dummy dummy dummy (ID7-ID0)(2) 90h dummy dummy 00h (MF7-MF0) 9Fh (MF7-MF0) Manufacture r (ID15ID8) Memory Type (ID7ID0) Capacity (ID7-ID0) Disable QPI FFh Enable Reset 66h Reset 99h Notes: 1. Data bytes are shifted with Most Significant Bit first. Byte fields with data in parenthesis “( )” indicate data output from the device on either 1, 2 or 4 DQ pins. 2. The Status Register contents and Device ID will repeat continuously until CS# terminates the instruction. 3. At least one byte of data input is required for Page Program, Quad Page Program and Program Security Sectors, up to 256 bytes of data input. If more than 256 bytes of data are sent to the device, the addressing will wrap to the beginning of the page and overwrite previously sent data. 4. See Table 5Manufacturer and Device Identification table for device ID information. 5. This feature is available upon special order. Please contact Shanghai Fudan Microelectronics Group Co., Ltd for details. 6. Security Sector Address: Security Sector 1: A23-A12 = 000h; A11-A8=00~01h; A7-A0 = byte address Security Sector 2: A23-A12 = 001h; A11-A8=00~01h; A7-A0 = byte address 7. Dual SPI address input format: DQ0 = A22, A20, A18, A16, A14, A12, A10, A8 A6, A4, A2, A0, M6, M4, M2, M0 DQ1 = A23, A21, A19, A17, A15, A13, A11, A9 A7, A5, A3, A1, M7, M5, M3, M1 8. Dual SPI data output format: DQ0 = (D6, D4, D2, D0) DQ1 = (D7, D5, D3, D1) 9. Quad SPI address input format: Set Burst with Wrap input format: DQ0 = A20, A16, A12, A8, A4, A0, M4, M0 DQ0 = x, x, x, x, x, x, W4, x DQ1 = A21, A17, A13, A9, A5, A1, M5, M1 DQ1 = x, x, x, x, x, x, W5, x DQ2 = A22, A18, A14, A10, A6, A2, M6, M2 DQ2 = x, x, x, x, x, x, W6, x DQ3 = A23, A19, A15, A11, A7, A3, M7, M3 DQ3 = x, x, x, x, x, x, x, x 10. Quad SPI data input/output format: DQ0 = (D4, D0, …) FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 20 11. 12. 13. 14. 15. DQ1 = (D5, D1, …..) DQ2 = (D6, D2, …..) DQ3 = (D7, D3, …..) Fast Read Quad I/O data output format: DQ0 = (x, x, x, x, D4, D0, D4, D0) DQ1 = (x, x, x, x, D5, D1, D5, D1) DQ2 = (x, x, x, x, D6, D2, D6, D2) DQ3 = (x, x, x, x, D7, D3, D7, D3) Word Read Quad I/O data output format: DQ0 = (x, x, D4, D0, D4, D0, D4, D0) DQ1 = (x, x, D5, D1, D5, D1, D5, D1) DQ2 = (x, x, D6, D2, D6, D2, D6, D2) DQ3 = (x, x, D7, D3, D7, D3, D7, D3) For Word Read Quad I/O, the lowest address bit must be 0. (A0 = 0) For Octal Word Read Quad I/O, the lowest four address bits must be 0. (A3, A2, A1, A0 = 0) QPI Command Address, Data input/output format: CLK# 0 1 2 3 4 5 6 7 8 9 10 11 DQ0 C4 C0 A20 A16 A12 A8 A4 A0 D4 D0 D4 D0 DQ1 C5 C1 A21 A17 A13 A9 A5 A1 D5 D1 D5 D1 DQ2 C6 C2 A22 A18 A14 A10 A6 A2 D6 D2 D6 D2 DQ3 C7 C3 A23 A19 A15 A11 A7 A3 D7 D3 D7 D3 16. The number of dummy clocks for QPI Fast Read, QPI Fast Read Quad I/O & QPI Burst Read with Wrap is controlled by read parameter P7 ~ P4. 17. The wrap around length for QPI Burst Read with Wrap is controlled by read parameter P3 ~ P0. FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 21 11.6. Write Enable (WREN) (06h) The Write Enable (WREN) instruction (Figure 9) sets the Write Enable Latch (WEL) bit in the Status Register to a 1. The WEL bit must be set prior to every Page Program, Quad Page Program, Sector Erase, Block Erase, Chip Erase, Write Status Register and Erase/Program Security Sectors instruction. The Write Enable (WREN)instruction is entered by driving CS# low, shifting the instruction code “06h” into the Data Input (DI) pin on the rising edge of CLK, and then driving CS# high. CS# CS# Mode 3 CLK Mode 3 CLK 0 1 2 3 4 5 6 7 Mode 0 Mode 3 0 1 Mode 0 Mode 3 Mode 0 Instruction (06h) Mode 0 DQ0 Instruction (06h) DI (DQ0) DQ1 DQ2 High Impedance D0 (DQ1) DQ3 Figure 9 Write Enable Instruction for SPI Mode (left) or QPI Mode (right) 11.7. Write Enable for Volatile Status Register (50h) The non-volatile Status Register bits described in section 10.1 can also be written to as volatile bits. This gives more flexibility to change the system configuration and memory protection schemes quickly without waiting for the typical non-volatile bit write cycles or affecting the endurance of the Status Register non-volatile bits. To write the volatile values into the Status Register bits, the Write Enable for Volatile Status Register (50h) instruction must be issued prior to a Write Status Register (01h/31h/11h) instruction. Write Enable for Volatile Status Register instruction (Figure 10) will not set the Write Enable Latch (WEL) bit, it is only valid for the Write Status Register instruction to change the volatile Status Register bit values. CS# CS# Mode 3 CLK Mode 3 CLK 0 1 2 3 4 5 Mode 0 6 7 Mode 3 Mode 0 0 1 Mode 0 Mode 3 Mode 0 Instruction( 50h) DQ0 Instruction (50h) DI (DQ0) DQ1 DQ2 D0 (DQ1) High Impedance DQ3 Figure 10 Write Enable for Volatile Status Register Instruction for SPI Mode (left) or QPI Mode (right) FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 22 11.8. Write Disable(WRDI) (04h) The Write Disable (WRDI) instruction (Figure 11) resets the Write Enable Latch (WEL) bit in the Status Register to a 0. The Write Disable(WRDI) instruction is entered by driving CS# low, shifting the instruction code “04h” into the DI pin and then driving CS# high. Note that the WEL bit is automatically reset after Power-up and upon completion of the Write Status Register, Erase/Program Security Sectors, Page Program, Quad Page Program, Sector Erase, Block Erase, Chip Erase and Reset instructions. CS# CS# Mode 3 CLK Mode 3 CLK 0 1 2 3 4 5 6 7 Mode 3 1 Mode 0 Mode 3 Mode 0 0 Mode 0 Instruction (04h) Mode 0 DQ0 Instruction (04h) DI (DQ0) DQ1 DQ2 High Impedance D0 (DQ1) DQ3 Figure 11 Write Disable Instruction for SPI Mode (left) or QPI Mode (right) 11.9. Read Status Register-1(RDSR1) (05h) , Status Register-2 (RDSR2) (35h)& Status Register-3 (RDSR3) (15h) The Read Status Register instructions allow the 8-bit Status Registers to be read. The instruction is entered by driving CS# low and shifting the instruction code “05h” for Status Register-1, “35h” for Status Register-2 or “15h” for Status Register-3 into the DI pin on the rising edge of CLK. The status register bits are then shifted out on the DO pin at the falling edge of CLK with most significant bit (MSB) first as shown in Figure 12. The Status Register bits are shown in Figure 5 ,Figure 6 and Figure 7. The Read Status Register instruction may be used at any time, even while a Program, Erase or Write Status Register cycle is in progress. This allows the WIP status bit to be checked to determine when the cycle is complete and if the device can accept another instruction. The Status Register can be read continuously, as shown in Figure 13. The instruction is completed by driving CS# high. CS# Mode 3 CLK 0 1 2 3 4 5 6 8 7 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 1 0 Mode 0 Instruction (05h/35h/15h) DI (DQ0) Status Register 1/2/3 out D0 (DQ1) Status Register 1/2/3 out High Impedance 7 «=MSB 6 5 4 « 3 2 1 0 7 6 5 4 3 2 7 « Figure 12 Read Status Register Instruction (SPI Mode) FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 23 CS# Mode 3 CLK 0 1 2 4 3 5 Mode 0 Instruction 05h/35h/15h DQ0 4 0 4 0 4 DQ1 5 1 5 1 5 DQ2 6 2 6 2 6 DQ3 7 3 7 3 7 SR1/2/3 out SR1/2/3 out Figure 13 Read Status Register Instruction (QPI Mode) 11.10. Write Status Register-1(WRSR)(01h), Status Register-2 (31h) & Status Register-3 (11h) The Write Status Register (WRSR)instruction allows the Status Register to be written. Only nonvolatile Status Register bits SRP0, TB, BP2, BP1, BP0 (bits 7 thru 2 of Status Register-1) , WPS, CMP, LB1, LB0 QE, SRP1 (bits 5 thru 0 of Status Register-2) , DRV0, DRV1(bits 2 thru 1 of Status Register-3) can be written to. All other Status Register bit locations are read-only and will not be affected by the Write Status Register (WRSR)instruction. LB1-0are non-volatile OTP bits, once it is set to 1, it cannot be cleared to 0. The Status Register bits are shown in shown in Figure 5 ,Figure 6 and Figure 7 and described in 10Status Register. To write non-volatile Status Register bits, a standard Write Enable (06h) instruction must previously have been executed for the device to accept the Write Status Register (WRSR) instruction (Status Register bit WEL must equal 1). Once write enabled, the instruction is entered by driving CS# low, sending the instruction code “01h”, and then writing the status register data byte as illustrated in Figure 14 and Figure 15. To write volatile Status Register bits, a Write Enable for Volatile Status Register (50h) instruction must have been executed prior to the Write Status Register (WRSR)instruction (Status Register bit WEL remains 0). However, SRP1 and LB1-0, cannot be changed from “1” to “0” because of the OTP protection for these bits. Upon power off or the execution of a “Reset (99h)” instruction, the volatile Status Register bit values will be lost, and the non-volatile Status Register bit values will be restored. To complete the Write Status Register (WRSR)instruction, the CS# pin must be driven high after the eighth or sixteenth bit of data that is clocked in. If this is not done the Write Status Register (WRSR)instruction will not be executed. If CS# is driven high after the eighth clock the CMP, QE and SRP1 bits will be cleared to 0. During non-volatile Status Register write operation (06h combined with 01h), after CS# is driven high, the self-timed Write Status Register cycle will commence for a time duration of tW (See “12.6AC Electrical Characteristics”). While the Write Status Register cycle is in progress, the Read Status Register instruction may still be accessed to check the status of the WIP bit. The WIP bit is a 1 during the Write Status Register cycle and a 0 when the cycle is finished and ready to accept other instructions again. After the Write Status Register cycle has finished, the FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 24 Write Enable Latch (WEL) bit in the Status Register will be cleared to 0. During volatile Status Register write operation (50h combined with 01h), after CS# is driven high, the Status Register bits will be refreshed to the new values within the time period of tSHSL2 (See “12.6AC Electrical Characteristics”). WIP bit will remain 0 during the Status Register bit refresh period. The Write Status Register (WRSR) instruction can be used in both SPI mode and QPI mode. However, the QE bit cannot be written to when the device is in the QPI mode, because QE=1 is required for the device to enter and operate in the QPI mode. CS# 0 Mode 3 CLK 1 2 3 4 5 6 8 7 10 11 12 13 14 15 Mode 0 Mode 3 Mode 0 Instruction (01h/31h/11h) Status Register 1/2/3 in DI (DQ0) D0 (DQ1) 9 7 6 5 4 3 2 1 0 « High Impedance «=MSB Figure 14 Write Status Register Instruction (SPI Mode) CS# Mode 3 CLK 0 1 2 3 Mode 3 Mode 0 Mode 0 Instruction 01h/31h/11h SR 1/2/3 in DQ0 4 0 4 0 DQ1 5 1 5 1 DQ2 6 2 6 2 DQ3 7 3 7 3 Figure 15 Write Status Register Instruction (QPI Mode) The FM25Q02 is also backward compatible to FMSH’s previous generations of serial flash memories, in which the Status Register-1&2 can be written using a single “Write Register-1(01h)” command. To complete the Write Status Register1&2, the CS# pin must be driven high after the sixteenth bit of data that is clocked in as shown in Figure 16&Figure 17 . If CS# is driven high after the eighth clock, the Write Status Register (WRSR)instruction will only program the Status Register-1, the Status Register-2 will not be affected. FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 25 CS# Mode 3 CLK 0 1 2 3 4 5 6 8 7 9 11 12 13 14 15 16 17 18 19 20 21 22 23 Mode 3 Mode 0 Instruction (01h) Status Register 1 in DI (DQ0) D0 (DQ1) 10 Mode 0 7 6 5 4 3 2 Status Register 2 in 1 0 « 15 14 13 12 11 10 9 8 « High Impedance «=MSB Figure 16 Write Status Register-1/2 Instruction (backward compatible, SPI Mode) CS# Mode 3 CLK 0 1 2 3 4 5 Mode 3 Mode 0 Mode 0 Instruction 01h SR1 in SR2 in DQ0 4 0 12 8 DQ1 5 1 13 9 DQ2 6 2 14 10 DQ3 7 3 15 11 Figure 17 Write Status Register-1/2 Instruction (backward compatible, QPI Mode) 11.11. Read Data (03h) The Read Data instruction allows one or more data bytes to be sequentially read from the memory. The instruction is initiated by driving the CS# pin low and then shifting the instruction code “03h” followed by a 24-bit address A23-A0 into the DI pin. The code and address bits are latched on the rising edge of the CLK pin. After the address is received, the data byte of the addressed memory location will be shifted out on the DO pin at the falling edge of CLK with most significant bit (MSB) first. The address is automatically incremented to the next higher address after each byte of data is shifted out allowing for a continuous stream of data. This means that the entire memory can be accessed with a single instruction as long as the clock continues. The instruction is completed by driving CS# high. The Read Data instruction sequence is shown in Figure 18. If a Read Data instruction is issued while an Erase, Program or Write cycle is in process (WIP =1) the instruction is ignored and will not have any effect on the current cycle. The Read Data instruction allows clock rates from D.C. to a maximum of fR (see“12.6AC Electrical Characteristics”). The Read Data (03h) instruction is only supported in Standard SPI mode. FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 26 CS# 0 1 Mode3 CLK Mode0 2 4 3 5 6 8 9 10 7 28 29 30 31 32 33 34 35 36 37 38 39 24-Bit Addess Instruction (03h) DI (DQ0) 23 22 21 ▲ DO (DQ1) 2 3 1 0 Data Out1 HIGH IMPEDANCE 5 6 7 ▲ 4 3 Data Out2 2 1 0 7 ▲ = MSB Figure 18 Read Data Instruction (SPI Mode only) 11.12. Fast Read (0Bh) The Fast Read instruction is similar to the Read Data instruction except that it can operate at the highest possible frequency of FR (see “12.6AC Electrical Characteristics”). This is accomplished by adding eight “dummy” clocks after the 24-bit address as shown in Figure 19. The dummy clocks allow the devices internal circuits additional time for setting up the initial address. During the dummy clocks the data value on the DI pin is a “don’t care”. CS# Mode 3 CLK 0 1 Mode 0 2 3 4 5 6 8 7 9 10 Instruction (0Bh) 28 29 30 31 3 2 1 0 45 46 47 48 49 50 0 7 6 5 24-Bit Address DI (DQ0) 23 22 21 42 43 « High Impedance D0 (DQ1) «=MSB CS# 31 32 33 34 35 36 37 38 39 40 41 44 51 52 53 54 55 2 1 0 CLK Dummy Clocks DI (DQ0) 0 Data Out 2 Data Out 1 D0 (DQ1) High Impedance 7 6 5 4 3 2 1 4 3 7 « « Figure 19 Fast Read Instruction (SPI Mode) Fast Read (0Bh) in QPI Mode The Fast Read instruction is also supported in QPI mode. When QPI mode is enabled, the number of dummy clocks is configured by the “Set Read Parameters (C0h)” instruction to accommodate wide range applications with different needs for either maximum Fast Read frequency or minimum data access latency. Depending on the Read Parameter Bits P[5:4] setting, the number of dummy clocks can be configured as either 2, 4, 6 or 8. The default number of dummy clocks upon power up or after a Reset instruction is 2. FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 27 CS# Mode 3 CLK 0 1 2 3 4 5 6 7 8 9 10 11 12 13 Mode 0 Instruction IOs switch from Input to Output A23-16 A15-8 A7-0 DQ0 20 16 12 8 4 0 4 0 4 0 4 0 4 DQ1 21 17 13 9 5 1 5 1 5 1 5 1 5 DQ2 22 18 14 10 6 2 6 2 6 2 6 2 6 DQ3 23 19 15 11 7 3 7 3 7 3 7 3 7 0Bh Dummy« Byte1 Byte2 * "Set Read Parameters" instruction (C0h) can set the number of dummy clocks. Figure 20 Fast Read Instruction (QPI Mode) 11.13. Fast Read Dual Output (3Bh) The Fast Read Dual Output (3Bh) instruction is similar to the standard Fast Read (0Bh) instruction except that data is output on two pins; DQ0 and DQ1. This allows data to be transferred from the FM25Q04 at twice the rate of standard SPI devices. The Fast Read Dual Output instruction is ideal for quickly downloading code from Flash to RAM upon power-up or for applications that cache code-segments to RAM for execution. Similar to the Fast Read instruction, the Fast Read Dual Output instruction can operate at the highest possible frequency of FR (see “12.6AC Electrical Characteristics”). This is accomplished by adding eight “dummy” clocks after the 24-bit address as shown in Figure 21. The dummy clocks allow the device's internal circuits additional time for setting up the initial address. The input data during the dummy clocks is “don’t care”. However, the DQ0 pin should be highimpedance prior to the falling edge of the first data out clock. FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 28 CS# 0 Mode 3 CLK 1 2 3 4 5 6 8 7 9 10 29 30 31 2 1 0 Mode 0 Instruction (3Bh) 24-Bit Address DI (DQ0) D0 (DQ1) 28 23 22 21 3 « High Impedance «=MSB CS# 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 CLK IO0 switches from Input to Output Dummy Clocks DI (DQ0) 0 6 4 2 0 5 3 1 6 4 2 0 7 5 3 1 6 4 2 0 7 5 3 1 6 4 2 0 6 7 5 3 1 7 « High Impedance D0 (DQ1) 7 « « Data Out 1 Figure 21 « Data Out 2 « Data Out 3 Data Out 4 Fast Read Dual Output Instruction (SPI Mode only) 11.14. Fast Read Quad Output (6Bh) The Fast Read Quad Output (6Bh) instruction is similar to the Fast Read Dual Output (3Bh) instruction except that data is output on four pins, DQ0, DQ1, DQ2, and DQ3. A Quad enable of Status Register-2 must be executed before the device will accept the Fast Read Quad Output Instruction (Status Register bit QE must equal 1). The Fast Read Quad Output Instruction allows data to be transferred from the FM25Q04 at four times the rate of standard SPI devices. The Fast Read Quad Output instruction can operate at the highest possible frequency of FR (see “12.6AC Electrical Characteristics”). This is accomplished by adding eight “dummy” clocks after the 24-bit address as shown in Figure 22. The dummy clocks allow the device's internal circuits additional time for setting up the initial address. The input data during the dummy clocks is “don’t care”. However, the DQ pins should be high-impedance prior to the falling edge of the first data out clock. FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 29 CS# 0 Mode 3 CLK 1 2 3 4 5 6 7 8 9 10 28 29 30 31 2 1 0 Mode 0 Instruction (6Bh) 24-Bit Address DQ0 23 22 21 3 « High Impedance DQ1 High Impedance DQ2 High Impedance DQ3 «=MSB CS# 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 CLK IO0 switches from Input to Output Dummy Clocks DQ0 DQ1 DQ2 DQ3 0 High Impedance High Impedance High Impedance 4 0 4 0 4 0 4 0 4 5 1 5 1 5 1 5 1 5 6 2 6 2 6 2 6 2 6 7 3 7 3 7 3 7 3 7 Byte1 Byte2 Byte3 Byte4 Figure 22 Fast Read Quad Output Instruction (SPI Mode only) 11.15. Fast Read Dual I/O (BBh) The Fast Read Dual I/O (BBh) instruction allows for improved random access while maintaining two I/O pins, DQ0 and DQ1. It is similar to the Fast Read Dual Output (3Bh) instruction but with the capability to input the Address bits A23-A0 two bits per clock. This reduced instruction overhead may allow for code execution (XIP) directly from the Dual SPI in some applications. Fast Read Dual I/O with “Continuous Read Mode” The Fast Read Dual I/O instruction can further reduce instruction overhead through setting the “Continuous Read Mode” bits (M7-0) after the input Address bits A23-A0, as shown in Figure 23. The upper nibble of the (M7-4) controls the length of the next Fast Read Dual I/O instruction through the inclusion or exclusion of the first byte instruction code. The lower nibble bits of the (M3-0) are don’t care (“x”). However, the DQ pins should be high-impedance prior to the falling edge of the first data out clock. If the “Continuous Read Mode” bits M5-4 = (1,0), then the next Fast Read Dual I/O instruction (after CS# is raised and then lowered) does not require the BBh instruction code, as shown in Figure 24. This reduces the instruction sequence by eight clocks and allows the Read address to FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 30 be immediately entered after CS# is asserted low. If the “Continuous Read Mode” bits M5-4 do not equal to (1,0), the next instruction (after CS# is raised and then lowered) requires the first byte instruction code, thus returning to normal operation. It is recommended to input FFFFh on DQ0 for the next CS# Mode 3 CLK 0 1 2 3 4 5 6 8 7 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 Mode 0 Instruction (BBh) A23-16 DI (DQ0) D0 (DQ1) A15-8 A7-0 22 20 18 16 14 12 10 8 6 4 2 0 23 21 19 17 15 13 11 9 7 5 3 1 6 4 2 0 7 5 3 1 « « «=MSB M7-0 CS# 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 CLK IOs switch from Input to Output DI (DQ0) 0 D0 (DQ1) 1 6 4 2 0 7 5 3 1 « 6 4 2 0 7 5 3 1 « Byte 1 6 4 2 0 7 5 3 1 « Byte 2 6 4 2 0 6 7 5 3 1 7 « Byte 3 Byte 4 Figure 23 Fast Read Dual I/O Instruction (Initial instruction or previous M5-4 ≠ 10, SPI Mode only) FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 31 CS# Mode 3 CLK 0 1 2 3 4 5 6 8 7 9 10 11 12 13 14 15 Mode 0 A23-16 A15-8 A7-0 M7-0 DI (DQ0) 22 20 18 16 14 12 10 8 6 4 2 0 D0 (DQ1) 23 21 19 17 15 13 11 9 7 5 3 1 6 4 2 0 7 5 3 1 30 31 « « «=MSB CS# 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 CLK IOs switch from Input to Output DI (DQ0) 0 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 D0 (DQ1) 1 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 « « Byte 1 « Byte 2 « Byte 3 Byte 4 Figure 24 Fast Read Dual I/O Instruction (Previous instruction set M5-4 = 10, SPI Mode only) 11.16. Fast Read Quad I/O (EBh) The Fast Read Quad I/O (EBh) instruction is similar to the Fast Read Dual I/O (BBh) instruction except that address and data bits are input and output through four pins DQ0, DQ1, DQ2 and DQ3 and four Dummy clocks are required in SPI mode prior to the data output. The Quad I/O dramatically reduces instruction overhead allowing faster random access for code execution (XIP) directly from the Quad SPI. The Quad Enable bit (QE) of Status Register-2 must be set to enable the Fast Read Quad I/O Instruction. Fast Read Quad I/O with “Continuous Read Mode” The Fast Read Quad I/O instruction can further reduce instruction overhead through setting the “Continuous Read Mode” bits (M7-0) after the input Address bits A23-A0, as shown in Figure 25. The upper nibble of the (M7-4) controls the length of the next Fast Read Quad I/O instruction through the inclusion or exclusion of the first byte instruction code. The lower nibble bits of the (M3-0) are don’t care (“x”). However, the DQ pins should be high-impedance prior to the falling edge of the first data out clock. If the “Continuous Read Mode” bits M5-4 = (1,0), then the next Fast Read Quad I/O instruction (after CS# is raised and then lowered) does not require the EBh instruction code, as shown in Figure 26. This reduces the instruction sequence by eight clocks and allows the Read address to be immediately entered after CS# is asserted low. If the “Continuous Read Mode” bits M5-4 do not equal to (1,0), the next instruction (after CS# is raised and then lowered) requires the first byte instruction code, thus returning to normal operation. It is recommended to input FFh on DQ0 for the next instruction (8 clocks), to ensure M4 = 1 and return the device to normal operation. FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 32 CS# Mode 3 CLK 0 1 2 3 4 5 6 8 7 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 Mode 0 Instruction (EBh) IOs switch from Input to Output A23-16 A15-8 A7-0 M7-0 Dummy Dummy DQ0 20 16 12 8 4 0 4 0 4 0 4 0 4 DQ1 21 17 13 9 5 1 5 1 5 1 5 1 5 DQ2 22 18 14 10 6 2 6 2 6 2 6 2 6 Dq3 23 19 15 11 7 3 7 3 7 3 7 3 7 Byte1 Byte2 Byte3 Figure 25 Fast Read Quad I/O Instruction (Initial instruction or previous M5-4≠10, SPI Mode) CS# Mode 3 CLK 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 Mode 0 IOs switch from Input to Output A23-16 A15-8 A7-0 M7-0 Dummy Dummy DQ0 20 16 12 8 4 0 4 0 4 0 4 0 4 DQ1 21 17 13 9 5 1 5 1 5 1 5 1 5 DQ2 22 18 14 10 6 2 6 2 6 2 6 2 6 DQ3 23 19 15 11 7 3 7 3 7 3 7 3 7 Byte1 Byte2 Byte3 Figure 26 Fast Read Quad I/O Instruction (Previous instruction set M5-4 = 10, SPI Mode) Fast Read Quad I/O with “8/16/32/64-Byte Wrap Around” in Standard SPI mode The Fast Read Quad I/O instruction can also be used to access a specific portion within a page by issuing a “Set Burst with Wrap” (77h) command prior to EBh. The “Set Burst with Wrap” (77h) command can either enable or disable the “Wrap Around” feature for the following EBh commands. When “Wrap Around” is enabled, the data being accessed can be limited to either a 8, 16, 32 or 64-byte section of a 256-byte page. The output data starts at the initial address specified in the instruction, once it reaches the ending boundary of the 8/16/32/64-byte section, the output will wrap around to the beginning boundary automatically until CS# is pulled high to terminate the command. The Burst with Wrap feature allows applications that use cache to quickly fetch a critical address and then fill the cache afterwards within a fixed length (8/16/32/64-byte) of data without issuing multiple read commands. The “Set Burst with Wrap” instruction allows three “Wrap Bits”, W6-4 to be set. The W4 bit is used to enable or disable the “Wrap Around” operation while W6-5 are used to specify the length of the wrap around section within a page. See “11.19Set Burst with Wrap (77h)” for detail descriptions. FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 33 Fast Read Quad I/O (EBh) in QPI Mode The Fast Read Quad I/O instruction is also supported in QPI mode, as shown in Figure 27. When QPI mode is enabled, the number of dummy clocks is configured by the “Set Read Parameters (C0h)” instruction to accommodate a wide range application with different needs for either maximum Fast Read frequency or minimum data access latency. Depending on the Read Parameter Bits P[5:4] setting, the number of dummy clocks can be configured as either 2, 4, 6 or 8. The default number of dummy clocks upon power up or after a Reset instruction is 2. In QPI mode, the “Continuous Read Mode” bits M7-0 are also considered as dummy clocks. In the default setting, the data output will follow the Continuous Read Mode bits immediately. “Continuous Read Mode” feature is also available in QPI mode for Fast Read Quad I/O instruction. Please refer to the description on previous pages. “Wrap Around” feature is not available in QPI mode for Fast Read Quad I/O instruction. To perform a read operation with fixed data length wrap around in QPI mode, a dedicated “Burst Read with Wrap” (0Ch) instruction must be used. Please refer to “11.38Burst Read with Wrap (0Ch)” for details. CS# Mode 3 CLK 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 Mode 0 Instruction IOs switch from Input to Output A23-16 A15-8 A7-0 M7-0« DQ0 20 16 12 8 4 0 4 0 4 0 4 0 4 DQ1 21 17 13 9 5 1 5 1 5 1 5 1 5 DQ2 22 18 14 10 6 2 6 2 6 2 6 2 6 DQ3 23 19 15 11 7 3 7 3 7 3 7 3 7 EBh Byte1 Byte2 Byte3 * "Set Read Parameters" instruction (C0h) can set the number of dummy clocks. Figure 27 Fast Read Quad I/O Instruction (Initial instruction or previous M5-4≠10, QPI Mode) 11.17. Word Read Quad I/O (E7h) The Word Read Quad I/O (E7h) instruction is similar to the Fast Read Quad I/O (EBh) instruction except that the lowest Address bit (A0) must equal 0 and only two Dummy clock are required prior to the data output. The Quad I/O dramatically reduces instruction overhead allowing faster random access for code execution (XIP) directly from the Quad SPI. The Quad Enable bit (QE) of Status Register-2 must be set to enable the Word Read Quad I/O Instruction. Word Read Quad I/O with “Continuous Read Mode” The Word Read Quad I/O instruction can further reduce instruction overhead through setting the “Continuous Read Mode” bits (M7-0) after the input Address bits A23-A0, as shown in Figure 28. FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 34 The upper nibble of the (M7-4) controls the length of the next Fast Read Quad I/O instruction through the inclusion or exclusion of the first byte instruction code. The lower nibble bits of the (M3-0) are don’t care (“x”). However, the DQ pins should be high-impedance prior to the falling edge of the first data out clock. If the “Continuous Read Mode” bits M5-4 = (1,0), then the next Fast Read Quad I/O instruction (after CS# is raised and then lowered) does not require the E7h instruction code, as shown in Figure 29. This reduces the instruction sequence by eight clocks and allows the Read address to be immediately entered after CS# is asserted low. If the “Continuous Read Mode” bits M5-4 do not equal to (1,0), the next instruction (after CS# is raised and then lowered) requires the first byte instruction code, thus returning to normal operation. It is recommended to input FFh on DQ0 for the next instruction (8 clocks), to ensure M4 = 1 and return the device to normal operation. CS# Mode 3 CLK 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 Mode 0 Instruction (E7h) IOs switch from Input to Output A23-16 A15-8 A7-0 M7-0 Dummy DQ0 20 16 12 8 4 0 4 0 4 0 4 0 4 DQ1 21 17 13 9 5 1 5 1 5 1 5 1 5 DQ2 22 18 14 10 6 2 6 2 6 2 6 2 6 DQ3 23 19 15 11 7 3 7 3 7 3 7 3 7 Byte1 Byte2 Byte3 Figure 28 Word Read Quad I/O Instruction (Initial instruction or previous M5-4 ≠ 10, SPI Mode only) CS# Mode 3 CLK 0 1 2 3 4 5 6 7 8 9 10 11 12 13 Mode 0 IOs switch from Input to Output A23-16 A15-8 A7-0 M7-0 Dummy DQ0 20 16 12 8 4 0 4 0 4 0 4 0 4 DQ1 21 17 13 9 5 1 5 1 5 1 5 1 5 DQ2 22 18 14 10 6 2 6 2 6 2 6 2 6 DQ3 23 19 15 11 7 3 7 3 7 3 7 3 7 Byte1 Byte2 Byte3 Figure 29 Word Read Quad I/O Instruction (Previous instruction set M5-4 = 10, SPI Mode only) Word Read Quad I/O with “8/16/32/64-Byte Wrap Around” in Standard SPI mode The Word Read Quad I/O instruction can also be used to access a specific portion within a page by issuing a “Set Burst with Wrap” (77h) command prior to E7h. The “Set Burst with Wrap” (77h) FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 35 command can either enable or disable the “Wrap Around” feature for the following E7h commands. When “Wrap Around” is enabled, the data being accessed can be limited to either a 8, 16, 32 or 64-byte section of a 256-byte page. The output data starts at the initial address specified in the instruction, once it reaches the ending boundary of the 8/16/32/64-byte section, the output will wrap around to the beginning boundary automatically until CS# is pulled high to terminate the command. The Burst with Wrap feature allows applications that use cache to quickly fetch a critical address and then fill the cache afterwards within a fixed length (8/16/32/64-byte) of data without issuing multiple read commands. The “Set Burst with Wrap” instruction allows three “Wrap Bits”, W6-4 to be set. The W4 bit is used to enable or disable the “Wrap Around” operation while W6-5 are used to specify the length of the wrap around section within a page. See “11.19Set Burst with Wrap (77h)”for detail descriptions. 11.18. Octal Word Read Quad I/O (E3h) The Octal Word Read Quad I/O (E3h) instruction is similar to the Fast Read Quad I/O (EBh) instruction except that the lower four Address bits (A0, A1, A2, A3) must equal 0. As a result, the dummy clocks are not required, which further reduces the instruction overhead allowing even faster random access for code execution (XIP). The Quad Enable bit (QE) of Status Register-2 must be set to enable the Octal Word Read Quad I/O Instruction. Octal Word Read Quad I/O with “Continuous Read Mode” The Octal Word Read Quad I/O instruction can further reduce instruction overhead through setting the “Continuous Read Mode” bits M7-M0 after the input Address bits A23-A0, as shown in Figure 30. The upper nibble of the (M7-4) controls the length of the next Octal Word Read Quad I/O instruction through the inclusion or exclusion of the first byte instruction code. The lower nibble bits of the (M3-0) are don’t care (“x”). However, the DQ pins should be high-impedance prior to the falling edge of the first data out clock. If the “Continuous Read Mode” bits M5-4 = (1,0), then the next Fast Read Quad I/O instruction (after CS# is raised and then lowered) does not require the E3h instruction code, as shown in Figure 31. This reduces the instruction sequence by eight clocks and allows the Read address to be immediately entered after CS# is asserted low. If the “Continuous Read Mode” bits M5-4 do not equal to (1, 0), the next instruction (after CS# is raised and then lowered) requires the first byte instruction code, thus returning to normal operation. It is recommended to input FFh on DQ0 for the next instruction (8 clocks), to ensure M4 = 1 and return the device to normal operation. CS# Mode 3 CLK 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 Mode 0 IOs switch from Input to Output A23-16 A15-8 A7-0 M7-0 DQ0 20 16 12 8 4 0 4 0 4 0 4 0 4 0 4 DQ1 21 17 13 9 5 1 5 1 5 1 5 1 5 1 5 DQ2 22 18 14 10 6 2 6 2 6 2 6 2 6 2 6 DQ3 23 19 15 11 7 3 7 3 7 3 7 3 7 3 7 Instruction (E3h) Byte1 Byte2 Byte3 Byte4 Figure 30 Octal Word Read Quad I/O Instruction (Initial instruction or previous M5-4 ≠ 10, SPI Mode only) FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 36 CS# Mode 3 CLK 0 1 2 3 4 5 6 8 7 9 10 11 12 13 Mode 0 IOs switch from Input to Output A23-16 A15-8 A7-0 M7-0 DQ0 20 16 12 8 4 0 4 0 4 0 4 0 4 0 4 DQ1 21 17 13 9 5 1 5 1 5 1 5 1 5 1 5 DQ2 22 18 14 10 6 2 6 2 6 2 6 2 6 2 6 DQ3 23 19 15 11 7 3 7 3 7 3 7 3 7 3 7 Byte1 Byte2 Byte3 Byte4 Figure 31 Octal Word Read Quad I/O Instruction (Previous instruction set M5-4 = 10, SPI Mode only) 11.19. Set Burst with Wrap (77h) In Standard SPI mode, the Set Burst with Wrap (77h) instruction is used in conjunction with “Fast Read Quad I/O” and “Word Read Quad I/O” instructions to access a fixed length of 8/16/32/64byte section within a 256-byte page. Certain applications can benefit from this feature and improve the overall system code execution performance. Similar to a Quad I/O instruction, the Set Burst with Wrap instruction is initiated by driving the CS# pin low and then shifting the instruction code “77h” followed by 24 dummy bits and 8 “Wrap Bits”, W7-0. The instruction sequence is shown in Figure 32. Wrap bit W7 and the lower nibble W3-0 are not used. W6, W5 00 01 10 11 W4 = 0 Wrap Around Wrap Length Yes Yes Yes Yes 8-byte 16-byte 32-byte 64-byte W4 =1 (default) Wrap Around Wrap Length No No No No N/A N/A N/A N/A Once W6-4 is set by a Set Burst with Wrap instruction, all the following “Fast Read Quad I/O” and “Word Read Quad I/O” instructions will use the W6-4 setting to access the 8/16/32/64-byte section within any page. To exit the “Wrap Around” function and return to normal read operation, another Set Burst with Wrap instruction should be issued to set W4 = 1. The default value of W4 upon power on is 1. In the case of a system Reset while W4 = 0, it is recommended that the controller issues a Set Burst with Wrap instruction to reset W4 = 1 prior to any normal Read instructions since FM25Q04 does not have a hardware Reset Pin. In QPI mode, the “Burst Read with Wrap (0Ch)” instruction should be used to perform the Read operation with “Wrap Around” feature. The Wrap Length set by W5-4 in Standard SPI mode is still FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 37 valid in QPI mode and can also be re-configured by “Set Read Parameters (C0h)” instruction. Refer to “11.37Set Read Parameters (C0h)” and “11.38Burst Read with Wrap (0Ch)” for details. CS# Mode 3 CLK 0 1 2 3 4 5 6 8 7 9 10 11 12 13 14 15 Mode 3 Mode 0 Mode 0 don’t care Instruction (77h) don’t care DQ0 X X X X DQ1 X X X X DQ2 X X X DQ3 X X X don’t care X Wrap Bit X W4 X X X W5 X X X X W6 X X X X X X Figure 32 Set Burst with Wrap Instruction (SPI Mode only) 11.20. Page Program (02h) The Page Program instruction allows from one byte to 256 bytes (a page) of data to be programmed at previously erased (FFh) memory locations. A Write Enable instruction must be executed before the device will accept the Page Program Instruction (Status Register bit WEL= 1). The instruction is initiated by driving the CS# pin low then shifting the instruction code “02h” followed by a 24-bit address A23-A0 and at least one data byte, into the DI pin. The CS# pin must be held low for the entire length of the instruction while data is being sent to the device. The Page Program instruction sequence is shown in Figure 33 and Figure 34. If an entire 256 byte page is to be programmed, the last address byte (the 8 least significant address bits) should be set to 0. If the last address byte is not zero, and the number of clocks exceeds the remaining page length, the addressing will wrap to the beginning of the page. In some cases, less than 256 bytes (a partial page) can be programmed without having any effect on other bytes within the same page. One condition to perform a partial page program is that the number of clocks can not exceed the remaining page length. If more than 256 bytes are sent to the device the addressing will wrap to the beginning of the page and overwrite previously sent data. As with the write and erase instructions, the CS# pin must be driven high after the eighth bit of the last byte has been latched. If this is not done the Page Program instruction will not be executed. After CS# is driven high, the self-timed Page Program instruction will commence for a time duration of tPP (See “12.6AC Electrical Characteristics”). While the Page Program cycle is in progress, the Read Status Register instruction may still be accessed for checking the status of the WIP bit. The WIP bit is a 1 during the Page Program cycle and becomes a 0 when the cycle is finished and the device is ready to accept other instructions again. After the Page Program cycle has finished the Write Enable Latch (WEL) bit in the Status Register is cleared to 0. The Page Program instruction will not be executed if the addressed page is protected by the Block Protect (CMP, TB, BP2, BP1, and BP0) bits. FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 38 CS# 0 Mode 3 CLK 1 2 3 4 5 6 7 8 9 10 28 29 30 31 32 33 34 35 36 37 38 39 2 1 0 Mode 0 Instruction (02h) Data Byte 1 24-Bit Address DI (DQ0) 23 22 21 3 2 1 7 0 6 5 4 3 « « «=MSB 46 47 48 49 50 51 52 53 54 55 2079 45 2078 44 2077 43 2076 42 2075 41 2074 40 2073 39 2072 CS# CLK Mode 0 Data Byte 2 DI (DQ0) Mode 3 0 7 6 5 4 3 Data Byte 3 2 1 0 7 « 6 5 4 3 Data Byte 256 2 1 0 7 6 5 4 3 2 1 0 « « Figure 33 Page Program Instruction (SPI Mode) 2 3 4 5 6 7 8 9 10 11 12 13 519 1 518 0 517 Mode 3 CLK 516 CS# Mode 0 Mode 3 Mode 0 Instruction A23-16 02h A15-8 A7-0 Byte1 Byte2 Byte3 Byte 255 Byte 256 DQ0 20 16 12 8 4 0 4 0 4 0 4 0 4 0 4 0 DQ1 21 17 13 9 5 1 5 1 5 1 5 1 5 1 5 1 DQ2 22 18 14 10 6 2 6 2 6 2 6 2 6 2 6 2 DQ3 23 19 15 11 7 3 7 3 7 3 7 3 7 3 7 3 Figure 34 Page Program Instruction (QPI Mode) 11.21. Quad Input Page Program (32h) The Quad Page Program instruction allows up to 256 bytes of data to be programmed at previously erased (FFh) memory locations using four pins: DQ0, DQ1, DQ2, and DQ3. The Quad Page Program can improve performance for PROM Programmer and applications that have slow clock speeds = 1 / FR or 1/fR ; 2. This parameter is characterized and is not 100% tested. Table13 MAX AC Characteristics (VCC = 2.3V to 2.7V) Applicable over recommended operating range from: TA = -40°C to 85°C, VCC = 2.3V to 2.7V, (unless otherwise noted). SYMBOL FR fR tCLQV tPP tSE tBE1 tBE2 tCE PARAMETER Serial Clock Frequency for: FAST_READ, PP, SE, BE, DP, RES, WREN, WRDI, WRSR Serial Clock Frequency for READ, RDSR, RDID Output Valid from CLK Page Programming Time Sector Erase Time Block Erase Time (32KB) Block Erase Time (64KB) Chip Erase Time FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 MIN SPEC TYP 10 100 800 1000 3 MAX UNIT 80 MHz 33 9 35 1200 3000 5000 30 MHz ns ms ms ms ms s Datasheet 69 CS# tCH CLK I/O OUTPUT tCLQX tCLQV tCLQX tCLQV tCL tSHQZ LSB OUT tQLQH tQHQL Figure 74 Serial Output Timing tSHSL CS# tCHSL tCHSH tSLCH tSHCH CLK tDVCH I/O INPUT I/O OUTPUT tCHDX tCLCH MSB IN tCHCL LSB IN (High Impedance) Figure 75 Serial Input Timing CS# tHLCH tCHHL tHHCH CLK tCHHH tHLQZ tHHQX I/O OUTPUT I/O INPUT HOLD# Figure 76 Hold Timing FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 70 13. Ordering Information FM 25Q 04 -XXX -C -H Company Prefix FM = Fudan Microelectronics Group Co.,ltd Product Family 25Q = 2.3~3.6V Serial Flash with 4KB Uniform-Sector, Dual/Quad SPI & QPI Product Density 04= 4M-bit Package Type (1) SO = 8-pin SOP(150mil) SOB = 8-pin SOP(208mil) TS = 8-pin TSSOP8 DN = 8-pin TDFN (2mm x 3mm) (2) Product Carrier U = Tube T = Tape and Reel HSF ID Code G = RoHS Compliant, Halogen-free, Antimony-free Note: 1. For SO, TS, DN package, MSL1 package are available, for detail please contact local sales office. 2. For Thinner package please contact local sales office. FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 71 14. Part Marking Scheme 14.1. SOP8 (150mil) FM25Q04 YYWWALHM Moisture Sensitivity Level 1 = MSL1 Blank=MSL3 HSF ID Code G = RoHS Compliant, Halogen-free, Antimony-free Lot Number(just with 0~9、A~Z) Assembly’s Code Work week during which the product was molded (eg..week 12) The last two digits of the year In which the product was sealed / molded. 14.2. SOP8 (208mil) FM25Q04 YYWWALHM Moisture Sensitivity Level 1 = MSL1 Blank=MSL3 HSF ID Code G = RoHS Compliant, Halogen-free, Antimony-free Lot Number(just with 0~9、A~Z) Assembly’s Code Work week during which the product was molded (eg..week 12) The last two digits of the year In which the product was sealed / molded. 14.3. TSSOP8 FM25Q04 YYWWALHM MSL Code Blank = MSL3 1 = MSL1 HSF ID Code G = RoHS Compliant, Halogen-free, Antimony-free Lot Number(just with 0~9、A~Z) Assembly’s Code Work week during which the product was molded (eg..week 12) The last two digits of the year In which the product was sealed / molded. FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 72 14.4. TDFN8(2x3mm) 5 Q 2 Y M A L H Product Density Code The month (hexadecimal digit) in which the product was molded. The last one digit of the year In which the product was sealed / molded. HSF ID Code M G = RoHS Compliant, Halogen-free, Antimony-free Moisture Sensitivity Level 1 = MSL1 Blank=MSL3 Lot Number(just with 0~9、A~Z) Assembly’s Code FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 73 15. Packaging Information SOP 8 (150mil) Symbol MIN A 1.350 A1 0.050 b 0.330 c 0.150 D 4.700 E1 3.700 E 5.800 e 1.270(BSC) L 0.400 θ 0° NOTE: 1. Dimensions are in Millimeters. FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 MAX 1.750 0.250 0.510 0.260 5.150 4.100 6.200 1.270 8° Datasheet 74 SOP 8 (208mil) Symbol MIN A –– A1 0.050 b 0.350 c 0.100 D 5.130 E1 5.180 E 7.700 e L 0.500 θ 0° NOTE: 1. Dimensions are in Millimeters. FM25Q044M-BITSERIAL FLASH MEMORY MAX 2.100 0.250 0.500 0.250 5.330 5.380 8.100 1.270(BSC) Ver. 1.4 0.850 8° Datasheet 75 TSSOP8 Symbol MIN D 2.900 E1 4.300 b 0.190 c 0.090 E 6.200 A A1 0.050 e 0.650 (BSC) L 0.450 θ 0° NOTE: 1. Dimensions are in Millimeters. FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 MAX 3.100 4.500 0.300 0.200 6.600 1.200 0.150 0.750 8° Datasheet 76 TDFN8(2x3mm) Symbol MIN A 0.700 A1 0.000 D 1.900 E 2.900 D2 1.400 E2 1.400 k 0.150(MIN) b 0.200 e 0.500(TYP) L 0.200 NOTE: 1. Dimensions are in Millimeters. FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 MAX 0.800 0.050 2.100 3.100 1.600 1.700 0.300 0.500 Datasheet 77 16. Revision History Publication Pages Revise Description date preliminary Sep. 2015 79 Initial Document Release. 0.1 Oct. 2015 79 Updated the Supply Voltage. 1.0 Jul. 2016 79 Updated the AC characteristics. 1.1 Oct.2016 79 Updated the DC/AC Electrical Characteristics 1.2 Jan. 2017 79 Updated the DC/AC Electrical Characteristics 1.3 May.2017 79 Corrected some typo 1.4 Aug. 2017 79 Corrected some typo Version FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 78 Sales and Service Shanghai Fudan Microelectronics Group Co., Ltd. Address: Bldg No. 4, 127 Guotai Rd, Shanghai City China. Postcode: 200433 Tel: (86-021) 6565 5050 Fax: (86-021) 6565 9115 Shanghai Fudan Microelectronics (HK) Co., Ltd. Address: Unit 506, 5/F., East Ocean Centre, 98 Granville Road, Tsimshatsui East, Kowloon, Hong Kong Tel: (852) 2116 3288 2116 3338 Fax: (852) 2116 0882 Beijing Office Address: Room 423, Bldg B,Gehua Building, 1 QingLongHutong, Dongzhimen Alley north Street, Dongcheng District, Beijing City, China. Postcode: 100007 Tel: (86-010) 8418 6608 Fax: (86-010) 8418 6211 Shenzhen Office Address: Room.1301, Century Bldg, No. 4002, Shengtingyuan Hotel, Huaqiang Rd (North), Shenzhen City, China. Postcode: 518028 Tel: (86-0755) 8335 0911 8335 1011 8335 2011 8335 0611 Fax: (86-0755) 8335 9011 Shanghai Fudan Microelectronics (HK) Ltd Taiwan Representative Office Address: Unit 1225, 12F., No 252, Sec.1 Neihu Rd., Neihu Dist., Taipei City 114, Taiwan Tel : (886-2) 7721 1890 (886-2) 7721 1889 Fax: (886-2) 7722 3888 Shanghai Fudan Microelectronics (HK) Ltd Singapore Representative Office Address : 237, Alexandra Road, #07-01 The Alexcier, Singapore 159929 Tel : (65) 6472 3688 Fax: (65) 6472 3669 Shanghai Fudan Microelectronics Group Co., Ltd NA Office Address: 2490 W. Ray Road Suite#2 Chandler, AZ 85224 USA Tel : (480) 857-6500 ext 18 Web Site: http://www.fmsh.com/ FM25Q044M-BITSERIAL FLASH MEMORY Ver. 1.4 Datasheet 79
FM25Q04-TS-T-G 价格&库存
很抱歉,暂时无法提供与“FM25Q04-TS-T-G”相匹配的价格&库存,您可以联系我们找货
