FM25F01-DN-T-G
FM25F01-DN-T-G
    FM(富满)
    TDFN8
    FM25F01-DN-T-G
FM25F01-DN-T-G 数据手册
FM25F01 1M-BIT SERIAL FLASH MEMORY Datasheet Oct. 2016 FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 1 INFORMATION IN THIS DOCUMENT IS INTENDED AS A REFERENCE TO ASSIST OUR CUSTOMERS IN THE SELECTION OF SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD PRODUCT BEST SUITED TO THE CUSTOMER'S APPLICATION; THEY DO NOT CONVEY ANY LICENSE UNDER ANY INTELLECTUAL PROPERTY RIGHTS, OR ANY OTHER RIGHTS, BELONGING TO SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD OR A THIRD PARTY. WHEN USING THE INFORMATION CONTAINED IN THIS DOCUMENTS, PLEASE BE SURE TO EVALUATE ALL INFORMATION AS A TOTAL SYSTEM BEFORE MAKING A FINAL DECISION ON THE APPLICABILITY OF THE INFORMATION AND PRODUCTS. PURCHASERS ARE SOLELY RESPONSIBLE FOR THE CHOICE, SELECTION AND USE OF THE SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD PRODUCTS AND SERVICES DESCRIBED HEREIN, AND SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD ASSUMES NO LIABILITY WHATSOEVER RELATING TO THE CHOICE, SELECTION OR USE OF THE SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD PRODUCTS AND SERVICES DESCRIBED HEREIN. UNLESS EXPRESSLY APPROVED IN WRITING BY AN AUTHORIZED SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD REPRESENTATIVE, SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD PRODUCTS ARE NOT RECOMMENDED, AUTHORIZED OR WARRANTED FOR USE IN MILITARY, AIR CRAFT, SPACE, LIFE SAVING, OR LIFE SUSTAINING APPLICATIONS, NOR IN PRODUCTS OR SYSTEMS WHERE FAILURE OR MALFUNCTION MAY RESULT IN PERSONAL INJURY, DEATH, OR SEVERE PROPERTY OR ENVIRONMENTAL DAMAGE. FUTURE ROUTINE REVISIONS WILL OCCUR WHEN APPROPRIATE, WITHOUT NOTICE. CONTACT SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD SALES OFFICE TO OBTAIN THE LATEST SPECIFICATIONS AND BEFORE PLACING YOUR PRODUCT ORDER. PLEASE ALSO PAY ATTENTION TO INFORMATION PUBLISHED BY SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD BY VARIOUS MEANS, INCLUDING SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD HOME PAGE (HTTP://WWW.FMSH.COM/). PLEASE CONTACT SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD LOCAL SALES OFFICE FOR THE SPECIFICATION REGARDING THE INFORMATION IN THIS DOCUMENT OR SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD PRODUCTS. Trademarks Shanghai Fudan Microelectronics Group Co., Ltd name and logo, the “复旦” logo are trademarks or registered trademarks of Shanghai Fudan Microelectronics Group Co., Ltd or its subsidiaries in China. Shanghai Fudan Microelectronics Group Co., Ltd, Printed in the China, All Rights Reserved. FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 2 1. Description The FM25F01 is a 1M-bit (128K-byte) Serial Flash memory, with advanced write protection mechanisms. The FM25F01 supports the standard Serial Peripheral Interface (SPI), and a high performance Dual output as well as Dual I/O. The FM25F01 can be programmed 1 to 256 bytes at a time, using the Page Program instruction. It is designed to allow either single Sector/Block at a time or full chip erase operation. The FM25F01 can be configured to protect part of the memory as the software protected mode. The device can sustain a minimum of 100K program/erase cycles on each sector or block. 2. Features 1Mbit of Flash memory – 32 uniform sectors with 4K-byte each – 2 uniform blocks with 64K-byte each – 4 uniform blocks with 32K-byte each – 256 bytes per programmable page Wide Operation Range – 2.3V~3.6V single voltage supply – Industrial temperature range Serial Interface – Standard SPI: CLK, CS#, DI, DO, WP# – Dual SPI: CLK, CS#, DQ0, DQ1, WP# – Continuous READ mode support High Performance – Max FAST_READ clock frequency: 100MHz – Max READ clock frequency: 50MHz – Typical page program time: 1.5ms – Typical sector erase time: 90ms – Typical block erase time: 500ms – Typical chip erase time: 1.5s Low Power Consumption – Typical standby current: 1µA Security – Software and hardware write protection – Lockable 256-Byte OTP security sectors – Low Voltage Write Inhibit – 64-Bit Unique ID for each device High Reliability – Endurance: 100,000 program/erase cycles – Data retention: 20 years Green Package – 8-pin SOP (150mil) – 8-pin TSSOP – 8-pin TDFN (2x3mm) – All Packages are RoHS Compliant and Halogenfree 3. Packaging Type SOP 8 (150mil) CS# DO(DQ1) 1 2 8 7 VCC WP# VSS 3 4 6 5 CLK DI(DQ0) HOLD# TSSOP8 CS# DO(DQ1) WP# VSS 1 2 3 4 8 7 6 5 VCC HOLD# CLK DI(DQ0) TDFN8 (2x3mm) CS# DO(DQ1) WP# VSS 1 2 3 4 8 VCC 7 HOLD# 6 CLK 5 DI(DQ0) 4. Pin Configurations PIN PIN I/O FUNCTION NO. NAME 1 CS# I Chip Select Input DO Data Output (Data Input Output 2 I/O (1) (DQ1) 1) 3 WP# I Write Protect Input 4 VSS Ground DI Data Input (Data Input Output 5 I/O (1) (DQ0) 0) 6 CLK I Serial Clock Input 7 HOLD# I Hold Input 8 VCC Power Supply Note: 1 DQ0 and DQ1 are used for Dual SPI instructions. FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 3 5. Block Diagram Figure 1 FM25F01 Serial Flash Memory Block Diagram FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 4 6. Pin Descriptions Serial Clock (CLK): The SPI Serial Clock Input (CLK) pin provides the timing for serial input and output operations. Serial Data Input, Output and I/Os (DI, DO and DQ0, DQ1): The FM25F01 supports standard SPI and Dual SPI operation. Standard SPI instructions use the unidirectional DI (input) pin to serially write instructions, addresses or data to the device on the rising edge of the Serial Clock (CLK) input pin. Standard SPI also uses the unidirectional DO (output) to read data or status from the device on the falling edge of CLK. Dual SPI instructions use the bidirectional DQ pins to serially write instructions, addresses or data to the device on the rising edge of CLK and read data or status from the device on the falling edge of CLK. Chip Select (CS#): The SPI Chip Select (CS#) pin enables and disables device operation. When CS# is high, the device is deselected and the Serial Data Output (DO, or DQ0, DQ1) pins are at high impedance. When deselected, the devices power consumption will be at standby levels unless an internal erase, program or write status register cycle is in progress. When CS# is brought low, the device will be selected, power consumption will increase to active levels and instructions can be written to and data read from the device. After power-up, CS# must transition from high to low before a new instruction will be accepted. The CS# input must track the VCC supply level at power-up (see “9 Write Protection” and Figure 25). If needed a pull-up resister on CS# can be used to accomplish this. HOLD (HOLD#): The HOLD# pin allows the device to be paused while it is actively selected. When HOLD# is brought low, while CS# is low, the DO pin will be at high impedance and signals on the DI and CLK pins will be ignored (don’t care). When HOLD# is brought high, device operation can resume. The HOLD# function can be useful when multiple devices are sharing the same SPI signals. The HOLD# pin is active low. Write Protect (WP#): The Write Protect (WP#) pin can be used to prevent the Status Registers from being written. Used in conjunction with the Status Register’s Block Protect (BP2, BP1 and BP0) bits and Status Register Protect (SRP) bits, a portion as small as a 4KB sector or the entire memory array can be hardware protected. The WP# pin is active low. FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 5 7. Memory Organization The FM25F01 array is organized into 512 programmable pages of 256-bytes each. Up to 256 bytes can be programmed (bits are programmed from 1 to 0) at a time. Pages can be erased in groups of 16 (4KB sector erase), groups of 128 (32KB block erase), groups of 256 (64KB block erase) or the entire chip (chip erase). The FM25F01 has 32 erasable sectors , 4 erasable 32-k byte blocks and 2 erasable 64-k byte blocks respectively. The small 4KB sectors allow for greater flexibility in applications that require data and parameter storage. Table 1 Block (64KB) 1 0 Block (32KB) 3 2 1 0 Sector (4KB) 31 : 16 15 : 3 2 1 0 Sector (4KB) 31 : 25 24 23 : 17 16 15 : 9 8 7 : 1 0 FM25F01 1M-BIT SERIAL FLASH MEMORY Memory Organization Address Range 01F000h : 010000h 00F000h : 003000h 002000h 001000h 000000h 01FFFFh : 010FFFh 00FFFFh : 003FFFh 002FFFh 001FFFh 000FFFh Address Range 01F000h : 019000h 018000h 017000h : 011000h 010000h 00F000h : 009000h 008000h 007000h : 001000h 000000h Ver. 1.5 01FFFFh : 019FFFh 018FFFh 017FFFh : 011FFFh 010FFFh 00FFFFh : 009FFFh 008FFFh 007FFFh : 001FFFh 000FFFh Datasheet 6 8. Device Operations 8.1. Standard SPI The FM25F01 is accessed through an SPI compatible bus consisting of four signals: Serial Clock (CLK), Chip Select (CS#), Serial Data Input (DI) and Serial Data Output (DO). Standard SPI instructions use the DI input pin to serially write instructions, addresses or data to the device on the rising edge of CLK. The DO output pin is used to read data or status from the device on the falling edge of CLK. SPI bus operation Mode 0 (0,0) and 3 (1,1) are supported. The primary difference between Mode 0 and Mode 3 concerns the normal state of the CLK signal when the SPI bus master is in standby and data is not being transferred to the Serial Flash. For Mode 0, the CLK signal is normally low on the falling and rising edges of CS#. For Mode 3, the CLK signal is normally high on the falling and rising edges of CS#. Figure 2 The difference between Mode 0 and Mode 3 8.2. Dual SPI The FM25F01 supports Dual SPI operation when using instructions such as “Fast Read Dual Output (3Bh)” and “Fast Read Dual I/O (BBh)”. These instructions allow data to be transferred to or from the device at two to three times the rate of ordinary Serial Flash devices. The Dual SPI Read instructions are ideal for quickly downloading code to RAM upon power-up (codeshadowing) or for executing non-speed- critical code directly from the SPI bus (XIP). When using Dual SPI instructions, the DI and DO pins become bidirectional I/O pins: DQ0 and DQ1. 8.3. Hold For Standard SPI and Dual SPI operations, the HOLD# signal allows the FM25F01 operation to be paused while it is actively selected (when CS# is low). The HOLD# function may be useful in cases where the SPI data and clock signals are shared with other devices. For example, consider if the page buffer was only partially written when a priority interrupt requires use of the SPI bus. In this case the HOLD# function can save the state of the instruction and the data in the buffer so programming can resume where it left off once the bus is available again. To initiate a HOLD# condition, the device must be selected with CS# low. A HOLD# condition will activate on the falling edge of the HOLD# signal if the CLK signal is already low. If the CLK is not already low the HOLD# condition will activate after the next falling edge of CLK. The HOLD# condition will terminate on the rising edge of the HOLD# signal if the CLK signal is already low. If the CLK is not already low the HOLD# condition will terminate after the next falling edge of CLK. During a HOLD# condition, the Serial Data Output (DO) is high impedance, and Serial Data Input (DI) and Serial Clock (CLK) are ignored. The Chip Select (CS#) signal should be kept FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 7 active (low) for the full duration of the HOLD# operation to avoid resetting the internal logic state of the device. Figure 3 Hold Condition Waveform FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 8 9. Write Protection Applications that use non-volatile memory must take into consideration the possibility of noise and other adverse system conditions that may compromise data integrity. To address this concern, the FM25F01 provides several means to protect the data from inadvertent writes. Write Protect Features Device resets when VCC is below threshold Time delay write disable after Power-up Write enable/disable instructions and automatic write disable after erase or program Software and Hardware (WP# pin) write protection using Status Register Write Protection using Power-down instruction Lock Down write protection for Status Register until the next power-up One Time Program (OTP) write protection for array and Security Sectors using Status Register. Upon power-up or at power-down, the FM25F01 will maintain a reset condition while VCC is below the threshold value of VWI, (See “12.3 Power-up Timing” and Figure 25). While reset, all operations are disabled and no instructions are recognized. During power-up and after the VCC voltage exceeds VWI, all program and erase related instructions are further disabled for a time delay of tPUW . This includes the Write Enable, Page Program, Sector Erase, Block Erase, Chip Erase and the Write Status Register instructions. Note that the chip select pin (CS#) must track the VCC supply level at power-up until the VCC-min level and tVSL time delay is reached. If needed a pull-up resister on CS# can be used to accomplish this. After power-up the device is automatically placed in a write-disabled state with the Status Register Write Enable Latch (WEL) set to a 0. A Write Enable instruction must be issued before a Page Program, Sector Erase, Block Erase, Chip Erase or Write Status Register instruction will be accepted. After completing a program, erase or write instruction the Write Enable Latch (WEL) is automatically cleared to a write-disabled state of 0. Software controlled write protection is facilitated using the Write Status Register instruction and setting the Status Register Protect (SRP) and Block Protect (BP2, BP1 and BP0) bits. These settings allow a portion as small as a 4KB sector or the entire memory array to be configured as read only. Used in conjunction with the Write Protect (WP#) pin, changes to the Status Register can be enabled or disabled under hardware control. See Status Register section for further information. Additionally, the Power-down instruction offers an extra level of write protection as all instructions are ignored except for the Release Power-down instruction. FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 9 10. Status Register The Read Status Register instruction can be used to provide status on the availability of the Flash memory array, if the device is write enabled or disabled, the state of write protection, Security Sector lock status. The Write Status Register instruction can be used to configure the device write protection features and Security Sector OTP lock. Write access to the Status Register is controlled by the state of the non-volatile Status Register Protect bit (SRP), the Write Enable instruction, and the WP# pin. Factory default for all Status Register bits are 0. Figure 4 Status Register 10.1. WIP Bit WIP is a read only bit in the status register (S0) that is set to a 1 state when the device is executing a Page Program, Sector Erase, Block Erase, Chip Erase, Write Status Register. During this time the device will ignore further instructions except for the Read Status Register (see tW, tPP, tSE, tBE, and tCE in “12.6 AC Electrical Characteristics”). When the program, erase or write status register (or security sector) instruction has completed, the WIP bit will be cleared to a 0 state indicating the device is ready for further instructions. 10.2. Write Enable Latch bit (WEL) Write Enable Latch (WEL) is a read only bit in the status register (S1) that is set to 1 after executing a Write Enable Instruction. The WEL status bit is cleared to 0 when the device is write disabled. A write disable state occurs upon power-up or after any of the following instructions: Write Disable, Page Program, Sector Erase, Block Erase, Chip Erase, Write Status Register. 10.3. Block Protect Bits (BP2, BP1, BP0) The Block Protect Bits (BP2, BP1, BP0) are non-volatile read/write bits in the status register (S4, S3, and S2) that provide Write Protection control and status. Block Protect bits can be set using FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 10 the Write Status Register Instruction (see tW in “12.6 AC Electrical Characteristics”). All, none or a portion of the memory array can be protected from Program and Erase instructions (see Table 2 Status Register Memory Protection). The factory default setting for the Block Protection Bits is 0, none of the array protected. 10.4. Top/Bottom Block Protect (TB) The non-volatile Top/Bottom bit (TB) controls if the Block Protect Bits (BP2, BP1, BP0) protect from the Top (TB=0) or the Bottom (TB=1) of the array as shown in Table 2 Status Register Memory Protection table. The factory default setting is TB=0. The TB bit can be set with the Write Status Register Instruction depending on the state of the SRP and WEL bits. 10.5. Status Register Protect bit / Lock_bit (SRP/LB) The Status Register Protect (SRP) bit is operated in conjunction with the Write Protect (WP#) signal. The Status Register Write Protect (SRP) bit and Write Protect (WP#) signal allow the device to be put in the Hardware Protected mode (when the Status Register Protect (SRP) bit is set to 1, and Write Protect (WP#) is driven Low). In this mode, the non-volatile bits of the Status Register (SRP, BP2, BP1, BP0) become read-only bits and the Write Status Register (WRSR) instruction is no longer accepted for execution. In OTP mode, this bit is served as Lock_bit (LB), user can read/program/erase security sector as normal sector while LB value is equal 0, after LB is programmed with 1 by WRSR command, the security sector is protected from program and erase operation. The LB can only be programmed once. Note : In OTP mode, the WRSR command will ignore any input data and program LB to 1, user must clear the protect bits before enter OTP mode and program the OTP code, then execute WRSR command to lock the Security sector before leaving OTP mode. 10.6. Status Register Memory Protection Table 2 Status Register Memory Protection Status Register Content TB bit X 0 1 X BP2 bit X X X X BP1 bit 0 0 0 1 BP0 bit 0 1 1 X FM25F01 1M-BIT SERIAL FLASH MEMORY Memory Content Address None 010000h-01FFFFh 000000h-00FFFFh 000000h-01FFFFh Ver. 1.5 Density (KB) None 64KB 64KB 128KB Portion None Upper 1/2 Lower 1/2 All Datasheet 11 11. Instructions The Standard/Dual SPI instruction set of the FM25F01 consists of 17 basic instructions that are fully controlled through the SPI bus (see Table 4~Table 5 Instruction Set). Instructions are initiated with the falling edge of Chip Select (CS#). The first byte of data clocked into the DI input provides the instruction code. Data on the DI input is sampled on the rising edge of clock with most significant bit (MSB) first. Instructions vary in length from a single byte to several bytes and may be followed by address bytes, data bytes, dummy bytes (don’t care), and in some cases, a combination. Instructions are completed with the rising edge of edge CS#. Clock relative timing diagrams for each instruction are included in Figure 5 through Figure 29. All read instructions can be completed after any clocked bit. However, all instructions that Write, Program or Erase must complete on a byte boundary (CS# driven high after a full 8-bits have been clocked) otherwise the instruction will be ignored. This feature further protects the device from inadvertent writes. Additionally, while the memory is being programmed or erased, or when the Status Register is being written, all instructions except for Read Status Register will be ignored until the program or erase cycle has completed. 11.1. Manufacturer and Device Identification Table 3 Manufacturer and Device Identification OP Code MF7-MF0 ABh 90h 9Fh 11.2. ID15-ID0 ID7-ID0 10h 10h A1h A1h 3111h Standard SPI Instructions Set Table 4 INSTRUCTION BYTE 1 NAME CLOCK NUMBER (0-7) Write Enable 06h Write Disable 04h Read Status 05h Register Write Status Register 01h Page Program 02h Sector Erase (4KB) 20h Block Erase (32KB) 52h Block Erase (64KB) D8h Chip Erase C7h/60h Power-down B9h Read Data 03h Fast Read 0Bh Release Powerdown ABh / ID(4) FM25F01 1M-BIT SERIAL FLASH MEMORY Standard SPI Instructions Set (1) BYTE 2 BYTE 3 BYTE 4 BYTE 5 BYTE 6 (8-15) (16-23) (24-31) (32-39) (40-47) (S7-S0) A23-A16 A23-A16 A23-A16 A23-A16 (S15-S8) A15-A8 A15-A8 A15-A8 A15-A8 A7-A0 A7-A0 A7-A0 A7-A0 D7-D0 D7-D0(3) A23-A16 A23-A16 A15-A8 A15-A8 A7-A0 A7-A0 (D7-D0) dummy (S7-S0)(2) dummy dummy Ver. 1.5 dummy (D7-D0) (2) (ID7-ID0) Datasheet 12 INSTRUCTION BYTE 1 NAME Read Unique ID 4Bh Manufacturer/Device 90h ID(4) 11.3. JEDEC ID(4) 9Fh Enter OTP mode 3Ah BYTE 2 BYTE 3 BYTE 4 BYTE 5 BYTE 6 dummy dummy dummy dummy (UID63-UID0) (MF7-MF0) (ID7-ID0) dummy dummy (MF7-MF0) Manufacturer 00h (ID15-ID8) (ID7-ID0) Memory Capacity Type Dual SPI Instructions Set Table 5 INSTRUCTION NAME CLOCK NUMBER Fast Read Dual Output Fast Read Dual I/O Dual SPI Instructions Set BYTE 1 BYTE 2 BYTE 3 BYTE 4 BYTE 5 BYTE 6 (0-7) (8-15) (16-23) (24-31) (32-39) (40-47) 3Bh A23-A16 A15-A8 A7-A0 dummy (D7-D0, R)(6) BBh A23-A8(5) A7-A0, M7M0 (5) (D7D0, R)(6) Notes: 1. Data bytes are shifted with Most Significant Bit first. Byte fields with data in parenthesis “( )” indicate data output from the device on 1 or 2 DQ pins. 2. The Status Register contents and Device ID will repeat continuously until CS# terminates the instruction. 3. At least one byte of data input is required for Page Program and Program Security Sectors, up to 256 bytes of data input. If more than 256 bytes of data are sent to the device, the addressing will wrap to the beginning of the page and overwrite previously sent data. 4. See Table 3 Manufacturer and Device Identification table for device ID information. 5. Dual SPI address input format: DQ0 = A22, A20, A18, A16, A14, A12, A10, A8 A6, A4, A2, A0, M6, M4, M2, M0 DQ1 = A23, A21, A19, A17, A15, A13, A11, A9 A7, A5, A3, A1, M7, M5, M3, M1 6. Dual SPI data output format: DQ0 = (D6, D4, D2, D0) DQ1 = (D7, D5, D3, D1) FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 13 11.4. Write Enable (WREN) (06h) The Write Enable (WREN) instruction (Figure 5) sets the Write Enable Latch (WEL) bit in the Status Register to a 1. The WEL bit must be set prior to every Page Program, Sector Erase, Block Erase, Chip Erase, Write Status Register instruction. The Write Enable (WREN) instruction is entered by driving CS# low, shifting the instruction code “06h” into the Data Input (DI) pin on the rising edge of CLK, and then driving CS# high. Figure 5 Write Enable Instruction 11.5. Write Disable (WRDI) (04h) The Write Disable (WRDI) instruction (Figure 6) resets the Write Enable Latch (WEL) bit in the Status Register to a 0. The Write Disable (WRDI) instruction is entered by driving CS# low, shifting the instruction code “04h” into the DI pin and then driving CS# high. Note that the WEL bit is automatically reset after Power-up and upon completion of the Write Status Register, Page Program, Sector Erase, Block Erase, Chip Erase instructions. Figure 6 Write Disable Instruction FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 14 11.6. Read Status Register (RDSR) (05h) The Read Status Register instructions allow the 8-bit Status Registers to be read. The instruction is entered by driving CS# low and shifting the instruction code “05h” into the DI pin on the rising edge of CLK. The status register bits are then shifted out on the DO pin at the falling edge of CLK with most significant bit (MSB) first as shown in Figure 7. The Status Register bits are shown in Figure 4 and include the WIP, WEL, BP2-BP0 and SRP bits. The Read Status Register instruction may be used at any time, even while a Program, Erase or Write Status Register cycle is in progress. This allows the WIP status bit to be checked to determine when the cycle is complete and if the device can accept another instruction. The Status Register can be read continuously. The instruction is completed by driving CS# high. CS# Mode 3 CLK 0 1 2 3 4 5 6 8 7 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 Mode 0 Instruction (05h) DI (DQ0) Status Register out Status Register out High Impedance D0 (DQ1) 7 6 5 4 3 2 1 0 7 6 5 4 3 2 1 0 7 =MSB Figure 7 Read Status Register Instruction 11.7. Write Status Register (WRSR) (01h) The Write Status Register (WRSR) instruction allows the Status Register to be written. Only nonvolatile Status Register bits SRP, BP2, BP1, BP0 can be written to. All other Status Register bit locations are read-only and will not be affected by the Write Status Register (WRSR) instruction. The Status Register bits are shown in Figure 4, and described in 10 Status Register. To write non-volatile Status Register bits, a standard Write Enable (06h) instruction must previously have been executed for the device to accept the Write Status Register (WRSR) instruction (Status Register bit WEL must equal 1). Once write enabled, the instruction is entered by driving CS# low, sending the instruction code “01h”, and then writing the status register data byte as illustrated in Figure 8. To complete the Write Status Register (WRSR) instruction, the CS# pin must be driven high after the eighth or sixteenth bit of data that is clocked in. If this is not done the Write Status Register (WRSR) instruction will not be executed. During non-volatile Status Register write operation (06h combined with 01h), after CS# is driven high, the self-timed Write Status Register cycle will commence for a time duration of tW (See “12.6 AC Electrical Characteristics”). While the Write Status Register cycle is in progress, the Read Status Register instruction may still be accessed to check the status of the WIP bit. The WIP bit is a 1 during the Write Status Register cycle and a 0 when the cycle is finished and ready to accept other instructions again. After the Write Status Register cycle has finished, the Write Enable Latch (WEL) bit in the Status Register will be cleared to 0. FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 15 CS# Mode 3 CLK 0 1 2 3 4 5 6 8 7 9 10 11 12 13 14 15 1 0 Mode 0 Instruction (01h) DI (DQ0) Status Register in 7 6 5 4 3 2 High Impedance D0 (DQ1) =MSB Figure 8 Write Status Register Instruction 11.8. Read Data (03h) The Read Data instruction allows one or more data bytes to be sequentially read from the memory. The instruction is initiated by driving the CS# pin low and then shifting the instruction code “03h” followed by a 24-bit address A23-A0 into the DI pin. The code and address bits are latched on the rising edge of the CLK pin. After the address is received, the data byte of the addressed memory location will be shifted out on the DO pin at the falling edge of CLK with most significant bit (MSB) first. The address is automatically incremented to the next higher address after each byte of data is shifted out allowing for a continuous stream of data. This means that the entire memory can be accessed with a single instruction as long as the clock continues. The instruction is completed by driving CS# high. The Read Data instruction sequence is shown in Figure 9. If a Read Data instruction is issued while an Erase, Program or Write cycle is in process (WIP =1) the instruction is ignored and will not have any effect on the current cycle. The Read Data instruction allows clock rates from D.C. to a maximum of fR (see “12.6 AC Electrical Characteristics”). The Read Data (03h) instruction is only supported in Standard SPI mode. Figure 9 Read Data Instruction 11.9. Fast Read (0Bh) The Fast Read instruction is similar to the Read Data instruction except that it can operate at the highest possible frequency of FR (see “12.6 AC Electrical Characteristics”). This is accomplished by adding eight “dummy” clocks after the 24-bit address as shown in Figure 10. The dummy clocks allow the devices internal circuits additional time for setting up the initial address. During the dummy clocks the data value on the DI pin is a “don’t care”. FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 16 Figure 10 Fast Read Instruction 11.10. Fast Read Dual Output (3Bh) The Fast Read Dual Output (3Bh) instruction is similar to the standard Fast Read (0Bh) instruction except that data is output on two pins; DQ0 and DQ1. This allows data to be transferred from the FM25F01 at twice the rate of standard SPI devices. The Fast Read Dual Output instruction is ideal for quickly downloading code from Flash to RAM upon power-up or for applications that cache code-segments to RAM for execution. Similar to the Fast Read instruction, the Fast Read Dual Output instruction can operate at the highest possible frequency of FR (see “12.6 AC Electrical Characteristics”). This is accomplished by adding eight “dummy” clocks after the 24-bit address as shown in Figure 11. The dummy clocks allow the device's internal circuits additional time for setting up the initial address. The input data during the dummy clocks is “don’t care”. However, the DQ0 pin should be highimpedance prior to the falling edge of the first data out clock. FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 17 Figure 11 Fast Read Dual Output Instruction 11.11. Fast Read Dual I/O (BBh) The Fast Read Dual I/O (BBh) instruction allows for improved random access while maintaining two I/O pins, DQ0 and DQ1. It is similar to the Fast Read Dual Output (3Bh) instruction but with the capability to input the Address bits A23-A0 two bits per clock. This reduced instruction overhead may allow for code execution (XIP) directly from the Dual SPI in some applications. Fast Read Dual I/O with “Continuous Read Mode” The Fast Read Dual I/O instruction can further reduce instruction overhead through setting the “Continuous Read Mode” bits (M7-0) after the input Address bits A23-A0, as shown in Figure 12. The upper nibble of the (M7-4) controls the length of the next Fast Read Dual I/O instruction through the inclusion or exclusion of the first byte instruction code. The lower nibble bits of the (M3-0) are don’t care (“x”). However, the DQ pins should be high-impedance prior to the falling edge of the first data out clock. If the “Continuous Read Mode” bits M5-4 = (1,0), then the next Fast Read Dual I/O instruction (after CS# is raised and then lowered) does not require the BBh instruction code, as shown in Figure 13. This reduces the instruction sequence by eight clocks and allows the Read address to be immediately entered after CS# is asserted low. If the “Continuous Read Mode” bits M5-4 do not equal to (1,0), the next instruction (after CS# is raised and then lowered) requires the first byte instruction code, thus returning to normal operation. It is recommended to input FFFFh on DQ0 for the next instruction (16 clocks), to ensure M4 = 1 and return the device to normal operation. FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 18 CS# Mode 3 CLK 0 1 2 3 4 5 6 8 7 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 Mode 0 Instruction (BBh) A23-16 DI (DQ0) D0 (DQ1) A15-8 A7-0 M7-0 22 20 18 16 14 12 10 8 6 4 2 0 6 4 2 0 23 21 19 17 15 13 11 9 7 5 3 1 7 5 3 1 33 34 35 36 37 38 39 =MSB CS# 23 24 25 26 27 28 29 30 31 32 CLK IOs switch from Input to Output DI (DQ0) 0 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 6 D0 (DQ1) 1 7 5 3 1 7 5 3 1 7 5 3 1 7 5 3 1 7 Byte 1 Byte 2 Byte 3 Byte 4 Figure 12 Fast Read Dual I/O Instruction (Initial instruction or previous M5-4 ≠ 10) Figure 13 Fast Read Dual I/O Instruction (Previous instruction set M5-4 = 10) FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 19 11.12. Page Program (02h) The Page Program instruction allows from one byte to 256 bytes (a page) of data to be programmed at previously erased (FFh) memory locations. A Write Enable instruction must be executed before the device will accept the Page Program Instruction (Status Register bit WEL= 1). The instruction is initiated by driving the CS# pin low then shifting the instruction code “02h” followed by a 24-bit address A23-A0 and at least one data byte, into the DI pin. The CS# pin must be held low for the entire length of the instruction while data is being sent to the device. The Page Program instruction sequence is shown in Figure 14. If an entire 256 byte page is to be programmed, the last address byte (the 8 least significant address bits) should be set to 0. If the last address byte is not zero, and the number of clocks exceeds the remaining page length, the addressing will wrap to the beginning of the page. In some cases, less than 256 bytes (a partial page) can be programmed without having any effect on other bytes within the same page. One condition to perform a partial page program is that the number of clocks can not exceed the remaining page length. If more than 256 bytes are sent to the device the addressing will wrap to the beginning of the page and overwrite previously sent data. As with the write and erase instructions, the CS# pin must be driven high after the eighth bit of the last byte has been latched. If this is not done the Page Program instruction will not be executed. After CS# is driven high, the self-timed Page Program instruction will commence for a time duration of tPP (See “12.6 AC Electrical Characteristics”). While the Page Program cycle is in progress, the Read Status Register instruction may still be accessed for checking the status of the WIP bit. The WIP bit is a 1 during the Page Program cycle and becomes a 0 when the cycle is finished and the device is ready to accept other instructions again. After the Page Program cycle has finished the Write Enable Latch (WEL) bit in the Status Register is cleared to 0. The Page Program instruction will not be executed if the addressed page is protected by the Block Protect (BP2, BP1, and BP0) bits. Figure 14 Page Program Instruction 11.13. Sector Erase (20h) The Sector Erase instruction sets all memory within a specified sector (4K-bytes) to the erased state of all 1s (FFh). A Write Enable instruction must be executed before the device will accept the Sector Erase Instruction (Status Register bit WEL must equal 1). The instruction is initiated by driving the CS# pin low and shifting the instruction code “20h” followed a 24-bit sector address A23-A0 (see Figure 1). The Sector Erase instruction sequence is shown in Figure 15 . The CS# pin must be driven high after the eighth bit of the last byte has been latched. If this is not FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 20 done the Sector Erase instruction will not be executed. After CS# is driven high, the self-timed Sector Erase instruction will commence for a time duration of tSE (See “12.6 AC Electrical Characteristics”). While the Sector Erase cycle is in progress, the Read Status Register instruction may still be accessed for checking the status of the WIP bit. The WIP bit is a 1 during the Sector Erase cycle and becomes a 0 when the cycle is finished and the device is ready to accept other instructions again. After the Sector Erase cycle has finished the Write Enable Latch (WEL) bit in the Status Register is cleared to 0. The Sector Erase instruction will not be executed if the addressed page is protected by the Block Protect (BP2, BP1, and BP0) bits (see Table 2 Status Register Memory Protection table). Figure 15 Sector Erase Instruction 11.14. 32KB Block Erase (BE32) (52h) The 32KB Block Erase instruction sets all memory within a specified block (32K-bytes) to the erased state of all 1s (FFh). A Write Enable instruction must be executed before the device will accept the Block Erase Instruction (Status Register bit WEL must equal 1). The instruction is initiated by driving the CS# pin low and shifting the instruction code “52h” followed a 24-bit block address A23-A0. The Block Erase instruction sequence is shown in Figure 16. The CS# pin must be driven high after the eighth bit of the last byte has been latched. If this is not done the Block Erase instruction will not be executed. After CS# is driven high, the self-timed Block Erase instruction will commence for a time duration of tBE2 (See 12.6 AC Electrical Characteristics”). While the Block Erase cycle is in progress, the Read Status Register instruction may still be accessed for checking the status of the WIP bit. The WIP bit is a 1 during the Block Erase cycle and becomes a 0 when the cycle is finished and the device is ready to accept other instructions again. After the Block Erase cycle has finished the Write Enable Latch (WEL) bit in the Status Register is cleared to 0. The Block Erase instruction will not be executed if the addressed page is protected by the Block Protect (BP2, BP1, and BP0) bits (see Table 2 Status Register Memory Protection table). FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 21 Figure 16 32KB Block Erase Instruction (SPI Mode) 11.15. 64KB Block Erase (BE) (D8h) The 64KB Block Erase instruction sets all memory within a specified block (64K-bytes) to the erased state of all 1s (FFh). A Write Enable instruction must be executed before the device will accept the Block Erase Instruction (Status Register bit WEL must equal 1). The instruction is initiated by driving the CS# pin low and shifting the instruction code “D8h” followed a 24-bit block address A23-A0. The Block Erase instruction sequence is shown in Figure 17. The CS# pin must be driven high after the eighth bit of the last byte has been latched. If this is not done the Block Erase instruction will not be executed. After CS# is driven high, the self-timed Block Erase instruction will commence for a time duration of tBE1 (See 12.6 AC Electrical Characteristics”). While the Block Erase cycle is in progress, the Read Status Register instruction may still be accessed for checking the status of the WIP bit. The WIP bit is a 1 during the Block Erase cycle and becomes a 0 when the cycle is finished and the device is ready to accept other instructions again. After the Block Erase cycle has finished the Write Enable Latch (WEL) bit in the Status Register is cleared to 0. The Block Erase instruction will not be executed if the addressed page is protected by the Block Protect (BP2, BP1, and BP0) bits (see Table 2 Status Register Memory Protection table). Figure 17 Block Erase Instruction 11.16. Chip Erase (CE) (C7h / 60h) The Chip Erase instruction sets all memory within the device to the erased state of all 1s (FFh). A FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 22 Write Enable instruction must be executed before the device will accept the Chip Erase Instruction (Status Register bit WEL must equal 1). The instruction is initiated by driving the CS# pin low and shifting the instruction code “C7h” or “60h”. The Chip Erase instruction sequence is shown in Figure 18. The CS# pin must be driven high after the eighth bit has been latched. If this is not done the Chip Erase instruction will not be executed. After CS# is driven high, the self-timed Chip Erase instruction will commence for a time duration of tCE (See “12.6 AC Electrical Characteristics”). While the Chip Erase cycle is in progress, the Read Status Register instruction may still be accessed to check the status of the WIP bit. The WIP bit is a 1 during the Chip Erase cycle and becomes a 0 when finished and the device is ready to accept other instructions again. After the Chip Erase cycle has finished the Write Enable Latch (WEL) bit in the Status Register is cleared to 0. The Chip Erase instruction will not be executed if any page is protected by the Block Protect (BP2, BP1, and BP0) bits. Figure 18 Chip Erase Instruction FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 23 11.17. Power-down (B9h) Although the standby current during normal operation is relatively low, standby current can be further reduced with the Power-down instruction. The lower power consumption makes the Power-down instruction especially useful for battery powered applications (See ICC1 and ICC2 in 12.4 DC Electrical Characteristics”). The instruction is initiated by driving the CS# pin low and shifting the instruction code “B9h” as shown in Figure 19. The CS# pin must be driven high after the eighth bit has been latched. If this is not done the Power-down instruction will not be executed. After CS# is driven high, the power-down state will enter within the time duration of tDP (See “12.6 AC Electrical Characteristics”). While in the powerdown state only the Release from Power- down / Device ID instruction, which restores the device to normal operation, will be recognized. All other instructions are ignored. This includes the Read Status Register instruction, which is always available during normal operation. Ignoring all but one instruction makes the Power Down state a useful condition for securing maximum write protection. The device always powers-up in the normal operation with the standby current of ICC1. Figure 19 Deep Power-down Instruction 11.18. Release Power-down / Device ID (ABh) The Release from Power-down / Device ID instruction is a multi-purpose instruction. It can be used to release the device from the power-down state, or obtain the devices electronic identification (ID) number. To release the device from the power-down state, the instruction is issued by driving the CS# pin low, shifting the instruction code “ABh” and driving CS# high as shown in Figure 20. Release from power-down will take the time duration of tRES1 (See “12.6 AC Electrical Characteristics”) before the device will resume normal operation and other instructions are accepted. The CS# pin must remain high during the tRES1 time duration. When used only to obtain the Device ID while not in the power-down state, the instruction is initiated by driving the CS# pin low and shifting the instruction code “ABh” followed by 3-dummy bytes. The Device ID bits are then shifted out on the falling edge of CLK with most significant bit (MSB) first as shown in Figure 20. The Device ID value for the FM25F01 is listed in Table 3 Manufacturer and Device Identification table. The Device ID can be read continuously. The instruction is completed by driving CS# high. When used to release the device from the power-down state and obtain the Device ID, the instruction is the same as previously described, and shown in Figure 21, except that after CS# is driven high it must remain high for a time duration of tRES2 (See “12.6 AC Electrical FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 24 Characteristics”). After this time duration the device will resume normal operation and other instructions will be accepted. If the Release from Power-down / Device ID instruction is issued while an Erase, Program or Write cycle is in process (when WIP equals 1) the instruction is ignored and will not have any effect on the current cycle. Figure 20 Release Power-down Instruction Figure 21 Release Power-down / Device ID Instruction 11.19. Read Manufacturer / Device ID (90h) The Read Manufacturer/Device ID instruction is an alternative to the Release from Power-down / Device ID instruction that provides both the JEDEC assigned manufacturer ID and the specific device ID. The Read Manufacturer/Device ID instruction is very similar to the Release from Power-down / Device ID instruction. The instruction is initiated by driving the CS# pin low and shifting the instruction code “90h” followed by a 24-bit address A23-A0 of 000000h. After which, the Manufacturer ID for Shanghai Fudan Microelectronics Group Co., Ltd (A1h) and the Device ID are shifted out on the falling edge of CLK with most significant bit (MSB) first as shown in Figure 22. The Device ID value for the FM25F01 is listed in Table 3 Manufacturer and Device Identification table. If the 24-bit address is initially set to 000001h the Device ID will be read first and then followed by the Manufacturer ID. The Manufacturer and Device IDs can be read continuously, alternating from one to the other. The instruction is completed by driving CS# high. FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 25 Figure 22 Read Manufacturer / Device ID Instruction 11.20. Read Unique ID Number(4Bh) The Read Unique ID Number instruction accesses a factory-set read-only 64-bit number that is unique to each FM25F01 device. The ID number can be used in conjunction with user software methods to help prevent copying or cloning of a system. The Read Unique ID instruction is initiated by driving the CS# pin low and shifting the instruction code “4Bh” followed by a four bytes of dummy clocks. After which, the 64- bit ID is shifted out on the falling edge of CLK as shown in Figure 23. FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 26 102 101 100 Figure 23 Read Unique ID Number Instruction (SPI Mode only) 11.21. Read JEDEC ID (9Fh) For compatibility reasons, the FM25F01 provides several instructions to electronically determine the identity of the device. The Read JEDEC ID instruction is compatible with the JEDEC standard for SPI compatible serial memories. The instruction is initiated by driving the CS# pin low and shifting the instruction code “9Fh”. The JEDEC assigned Manufacturer ID byte for Shanghai Fudan Microelectronics Group Co., Ltd (A1h) and two Device ID bytes, Memory Type (ID15-ID8) and Capacity ID7-ID0 are then shifted out on the falling edge of CLK with most significant bit (MSB) first as shown in Figure 24. For memory type and capacity values refer to Table 3 Manufacturer and Device Identification table. FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 27 Figure 24 Read JEDEC ID Instruction 11.22. Enter OTP Mode (3Ah) This Flash has an extra 256 bytes security sector, user must issue ENTER OTP MODE command to read, program or erase security sector. After entering OTP mode, the security sector is mapping to sector 31, SRP bit becomes LB and can be read with RDSR command. Program / Erase command will be disabled when LB is ‘1’ WRSR command will ignore the input data and program LB to 1. User must clear the protect bits before enter OTP mode. Security sector can only be program and erase before LB equal ‘1’ and BP[2:0] = ‘000’. In OTP mode, user can read other sectors, but program/erase other sectors only allowed when LB equal ‘0’. User can use WRDI (04h) command to exit OTP mode. Table 6 Security Sector Address Sector Sector Size 31 256 byte Note: The Secruty sector is mapping to sector 31 Address Range 01F000h – 01F0FFh While in OTP mode, user can use Sector Erase (20h) command only to erase OTP data. FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 28 CS# Mode3 CLK Mode0 0 1 2 3 4 5 6 7 Instruction (3Ah) DI DO HIGH IMPEDANCE Figure 23 Enter OTP Mode FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 29 12. Electrical Characteristics 12.1. Absolute Maximum Ratings Operating Temperature Storage Temperature Voltage on I/O Pin with Respect to Ground VCC -40°C to +85°C -65°C to +150°C -0.5V to VCC+0.4V -0.5V to 4.0V *NOTICE: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at these or any other conditions beyond those indicated in the operational sections of this specification are not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. 12.2. Pin Capacitance SYMBOL CIN(1) COUT(1) PARAMETER Input Capacitance Output Capacitance CONDITIONS VIN = 0V; TA = 25°C; f = 5 MHz; VCC = 2.7V VOUT = 0V; TA = 25°C; f = 5 MHz; VCC = 2.7V MAX UNIT 6 pF 8 pF Note: 1. This parameter is characterized and is not 100% tested. 12.3. Power-up Timing Applicable over recommended operating range from: TA = -40°C to 85°C, VCC =2.3V to 3.6V, (unless otherwise noted). SYMBOL tVSL tPUW SPEC PARAMETER VCC (min) to CS# Low Time Delay Before Write Instruction MIN MAX 10 1 10 UNIT µs ms Figure 25 Power-up Timing FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 30 12.4. DC Electrical Characteristics Table 7 DC Characteristics Applicable over recommended operating range from: TA = -40°C to 85°C, VCC = 2.3V to 3.6V, (unless otherwise noted). SYMBOL PARAMETER Vcc ILI ILO Supply Voltage Input Leakage Current Output Leakage Current ICC1 Standby Current ICC2 Deep Power-down Current ICC3(1) Operating Current (READ) ICC4 ICC5 ICC6 ICC7 VIL(2) VIH(2) VOL VOH VWI Operating Current (WRSR) Operating Current (PP) Operating Current (SE) Operating Current (BE) Input Low Voltage Input High Voltage Output Low Voltage Output High Voltage Write Inhibit Threshold Voltage CONDITIONS MIN SPEC TYP 2.3 VCC=3.6V, CS# = VCC, VIN = Vss or VCC VCC=3.6V, CS# = VCC, VIN = Vss or VCC VCC=3.6V, CLK=0.1VCC/0.9VCC, at 100MHz, DQ open MAX UNIT 3.6 ±2 ±2 V µA µA 1 5 µA 1 5 µA 25 mA VCC=3.6V, CS#=VCC 8 12 mA VCC=3.6V, CS#=VCC VCC=3.6V, CS#=VCC VCC=3.6V, CS#=VCC 20 20 20 25 25 25 0.3VCC VCC+0.4 0.4 mA mA mA V V V V 2.2 V -0.5 0.7VCC IOL = 1.6 mA IOH = -100 µA VCC-0.2 1.0 Notes: 1. Checker Board Pattern. 2. VIL min and VIH max are reference only and are not tested. FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 31 12.5. AC Measurement Conditions Table 8 SYMBOL CL TR, TF VIN IN OUT AC Measurement Conditions SPEC PARAMETER MIN Load Capacitance Input Rise and Fall Times Input Pulse Voltages Input Timing Reference Voltages Output Timing Reference Voltages UNIT MAX 20 5 0.2 VCC to 0.8 VCC 0.3 VCC to 0.7 VCC 0.5VCC pF ns V V V Figure 26 AC Measurement I/O Waveform 12.6. AC Electrical Characteristics Table 9 AC Characteristics Applicable over recommended operating range from: TA = -40°C to 85°C, VCC = 2.7V to 3.6V, (unless otherwise noted). SYMBOL FR fR (1) tCH tCL(1) tCLCH(2) tCHCL(2) tSLCH tCHSH tSHCH tCHSL tSHSL tSHQZ(2) tCLQX tDVCH tCHDX tHLCH PARAMETER MIN Serial Clock Frequency for: FAST_READ, PP, SE, BE, DP, RES, WREN, WRDI, WRSR Serial Clock Frequency for READ, RDSR, RDID Serial Clock High Time 4 Serial Clock Low Time 4 Serial Clock Rise Time (Slew Rate) 0.1 Serial Clock Fall Time (Slew Rate) 0.1 CS# Active Setup Time 5 CS# Active Hold Time 5 CS# Not Active Setup Time 5 CS# Not Active Hold Time 5 CS# Deselect Time (for Array Read Array Read/ 10/50 Erase or Program Read Status Register) Output Disable Time Output Hold Time 0 Data In Setup Time 2 Data In Hold Time 5 HOLD# Low Setup Time ( relative to CLK ) 5 FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 SPEC TYP MAX UNIT 100 MHz 50 MHz ns ns V/ns V/ns ns ns ns ns ns 6 ns ns ns ns ns Datasheet 32 SYMBOL PARAMETER tHHCH tCHHH tCHHL HOLD# High Setup Time ( relative to CLK ) HOLD# Low Hold Time ( relative to CLK ) HOLD# High Hold Time ( relative to CLK ) HOLD# Low to High-Z Output HOLD# High to Low-Z Output Output Valid from CLK Write Protect Setup Time before CS# Low Write Protect Hold Time after CS# High CS# High to Deep Power-down Mode CS# High to Standby Mode without Electronic Signature Read CS# High to Standby Mode with Electronic Signature Read Write Status Register Cycle Time Page Programming Time Sector Erase Time Block Erase Time (64KB) Block Erase Time (32KB) Chip Erase Time tHLQZ(2) tHHQX(2) tCLQV tWHSL tSHWL tDP(2) tRES1(2) tRES2(2) MIN SPEC TYP MAX 5 5 5 3 ns ns ns ns ns ns ns ns µs 3 µs 1.8 µs 15 5 0.3 2 1.2 4 ms ms s s s s 6 6 8 20 100 tW tPP tSE tBE1 tBE2 tCE Notes: 1. tCH+tCL >= 1 / FR or 1/fR ; 3. This parameter is characterized and is not 100% tested. 10 1.5 0.09 0.5 0.3 1.5 UNIT Applicable over recommended operating range from: TA = -40°C to 85°C, VCC = 2.3V to 2.7V, (unless otherwise noted). SYMBOL FR fR tPP tSE tBE1 tBE2 tCE PARAMETER MIN Serial Clock Frequency for: FAST_READ, PP, SE, BE, DP, RES, WREN, WRDI, WRSR Serial Clock Frequency for READ, RDSR, RDID Page Programming Time Sector Erase Time Block Erase Time (64KB) Block Erase Time (32KB) Chip Erase Time FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 SPEC TYP 10 0.2 2 1.5 7 MAX UNIT 80 MHz 33 25 0.8 4 3 20 MHz ms s s s s Datasheet 33 Figure 27 Serial Output Timing Figure 28 Serial Input Timing Figure 29 Hold Timing FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 34 13. Ordering Information Note: 1. For SO, TS and DN package, MSL1 package are available, for detail please contact local sales office. 2. For Thinner package please contact local sales office. FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 35 14. Part Marking Scheme 14.1. SOP8 (150mil) 14.2. TSSOP8 14.3. TDFN8 (2x3) FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 36 15. Packaging Information SOP 8 (150mil) Symbol MIN A 1.350 A1 0.050 b 0.330 c 0.150 D 4.700 E1 3.700 E 5.800 e 1.270(BSC) L 0.400 θ 0° NOTE: 1. Dimensions are in Millimeters. FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 MAX 1.750 0.250 0.510 0.260 5.150 4.100 6.200 1.270 8° Datasheet 37 TSSOP8 Symbol MIN D 2.900 E1 4.300 b 0.190 c 0.090 E 6.200 A A1 0.050 e 0.650 (BSC) L 0.450 θ 0° NOTE: 1. Dimensions are in Millimeters. FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 MAX 3.100 4.500 0.300 0.200 6.600 1.200 0.150 0.750 8° Datasheet 38 TDFN8 (2x3mm) Symbol MIN A 0.700 A1 0.000 D 1.900 E 2.900 D2 1.400 E2 1.400 k 0.150(MIN) b 0.200 e 0.500(TYP) L 0.200 NOTE: 1. Dimensions are in Millimeters. FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 MAX 0.800 0.050 2.100 3.100 1.600 1.700 0.300 0.500 Datasheet 39 16. Revision History Version preliminary Publication Pages date Jul. 2012 40 Revise Description Initial Document Release. 1. 2. 3. 4. 1. 2. 3. 4. 1. Added TDFN8 (2x3) offering and parts. Updated packaging information of TSSOP8. Updated Table1. Updated “Pin Capacitance” Corrected the typo Updated the “Ordering Information” Updated “Part Marking Scheme” Updated the “Sales and Service” Updated the Ordering Information and Part Marking Scheme. 2. Updated the Supply Voltage. 1.0 Oct. 2012 41 1.1 Aug. 2013 41 1.2 Dec. 2014 41 1.3 May. 2015 41 Corrected the typo 1.4 Jun. 2015 41 Updated the AC Electrical Characteristics under 2.3V. 1.5 Oct, 2016 41 Updated the packaging information FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 40 Sales and Service Shanghai Fudan Microelectronics Group Co., Ltd. Address: Bldg No. 4, 127 Guotai Rd, Shanghai City China. Postcode: 200433 Tel: (86-021) 6565 5050 Fax: (86-021) 6565 9115 Shanghai Fudan Microelectronics (HK) Co., Ltd. Address: Unit 506, 5/F., East Ocean Centre, 98 Granville Road, Tsimshatsui East, Kowloon, Hong Kong Tel: (852) 2116 3288 2116 3338 Fax: (852) 2116 0882 Beijing Office Address: Room 423, Bldg B, Gehua Building, 1 QingLong Hutong, Dongzhimen Alley north Street, Dongcheng District, Beijing City, China. Postcode: 100007 Tel: (86-010) 8418 6608 Fax: (86-010) 8418 6211 Shenzhen Office Address: Room.1301, Century Bldg, No. 4002, Shengtingyuan Hotel, Huaqiang Rd (North), Shenzhen City, China. Postcode: 518028 Tel: (86-0755) 8335 0911 8335 1011 8335 2011 8335 0611 Fax: (86-0755) 8335 9011 Shanghai Fudan Microelectronics (HK) Ltd Taiwan Representative Office Address: Unit 1225, 12F., No 252, Sec.1 Neihu Rd., Neihu Dist., Taipei City 114, Taiwan Tel : (886-2) 7721 1890 (886-2) 7721 1889 Fax: (886-2) 7722 3888 Shanghai Fudan Microelectronics (HK) Ltd Singapore Representative Office Address : 237, Alexandra Road, #07-01 The Alexcier, Singapore 159929 Tel : (65) 6472 3688 Fax: (65) 6472 3669 Shanghai Fudan Microelectronics Group Co., Ltd NA Office Address: 2490 W. Ray Road Suite#2 Chandler, AZ 85224 USA Tel : (480) 857-6500 ext 18 Web Site: http://www.fmsh.com/ FM25F01 1M-BIT SERIAL FLASH MEMORY Ver. 1.5 Datasheet 41
FM25F01-DN-T-G 价格&库存
很抱歉,暂时无法提供与“FM25F01-DN-T-G”相匹配的价格&库存,您可以联系我们找货
