UMW
R
UMW AO3403A
30V P-Channel MOSFET
General Description
SOT–23
The AO3403 uses advanced trench technology to provide
excellent RDS(ON) and low gate charge. This device is
suitable for use as a load switch or in PWM applications.
Product Summary
VDS
ID (at VGS=-10V)
-30V
-2.6A
RDS(ON) (at VGS=-10V)
< 115mΩ
RDS(ON) (at VGS =-4.5V)
< 150mΩ
RDS(ON) (at VGS =-2.5V)
< 200mΩ
1. GATE
2. SOURCE
3. DRAIN
D
G
S
Absolute Maximum Ratings TA=25°C unless otherwise noted
Parameter
Symbol
Drain-Source Voltage
VDS
Gate-Source Voltage
VGS
TA=25°C
Continuous Drain
Current
Pulsed Drain Current
Power Dissipation
Junction and Storage Temperature Range
Thermal Characteristics
Parameter
Maximum Junction-to-Ambient A
Maximum Junction-to-Ambient A D
Maximum Junction-to-Lead
www.umw-ic.com
Steady-State
Steady-State
A
1.4
W
0.9
TJ, TSTG
°C
-55 to 150
Symbol
t ≤ 10s
V
-13
PD
TA=70°C
±12
-2.2
IDM
TA=25°C
B
Units
V
-2.6
ID
TA=70°C
C
Maximum
-30
Typ
70
100
63
RθJA
RθJL
1
Max
90
125
80
Units
°C/W
°C/W
°C/W
友台半导体有限公司
UMW
R
UMW AO3403A
Electrical Characteristics (TJ=25°C unless otherwise noted)
Parameter
Symbol
STATIC PARAMETERS
BVDSS
Drain-Source Breakdown Voltage
IDSS
Zero Gate Voltage Drain Current
Conditions
Min
ID=-250µA, VGS=0V
-30
-1
TJ=55°C
-5
Gate-Body leakage current
VDS=0V, VGS= ±12V
VGS(th)
Gate Threshold Voltage
VDS=VGS ID=-250µA
-0.6
ID(ON)
On state drain current
VGS=-10V, VDS=-5V
-13
VGS=-10V, ID=-2.6A
Static Drain-Source On-Resistance
TJ=125°C
88
115
143
200
A
mΩ
150
mΩ
mΩ
-1
V
-1.5
A
315
pF
VDS=-5V, ID=-2.6A
IS
Maximum Body-Diode Continuous Current
8
-0.78
DYNAMIC PARAMETERS
Ciss
Input Capacitance
Gate resistance
V
200
IS=-1A,VGS=0V
Rg
nA
-1.4
103
Diode Forward Voltage
Output Capacitance
±100
-1
139
Forward Transconductance
Reverse Transfer Capacitance
µA
VGS=-2.5V, ID=-1A
VSD
Coss
Units
VGS=-4.5V, ID=-2A
gFS
Crss
Max
V
VDS=-30V, VGS=0V
IGSS
RDS(ON)
Typ
260
VGS=0V, VDS=-15V, f=1MHz
S
37
pF
pF
8
12
Ω
SWITCHING PARAMETERS
Qg(10V) Total Gate Charge
5.9
7.2
nC
Qg(4.5V) Total Gate Charge
2.8
3.5
nC
Qgs
Gate Source Charge
VGS=0V, VDS=0V, f=1MHz
VGS=-10V, VDS=-15V, ID=-2.6A
4
0.7
nC
nC
Qgd
Gate Drain Charge
1
tD(on)
Turn-On DelayTime
6
ns
tr
Turn-On Rise Time
3.5
ns
tD(off)
Turn-Off DelayTime
ns
tf
Turn-Off Fall Time
5
ns
trr
Qrr
VGS=-10V, VDS=-15V,
RL=5.76Ω, RGEN=3Ω
IF=-2.6A, dI/dt=100A/µs
Body Diode Reverse Recovery Time
Body Diode Reverse Recovery Charge IF=-2.6A, dI/dt=100A/µs
11.5
4.5
15
ns
nC
A. The value of RθJA is measured with the device mounted on 1in2 FR-4 board with 2oz. Copper, in a still air environment with TA =25°C. The
value in any given application depends on the user's specific board design.
B. The power dissipation PD is based on TJ(MAX)=150°C, using ≤ 10s junction-to-ambient thermal resistance.
C. Repetitive rating, pulse width limited by junction temperature TJ(MAX)=150°C. Ratings are based on low frequency and duty cycles to keep
initialTJ=25°C.
D. The RθJA is the sum of the thermal impedence from junction to lead RθJL and lead to ambient.
E. The static characteristics in Figures 1 to 6 are obtained using
很抱歉,暂时无法提供与“AO3403A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.28383
- 100+0.22346
- 300+0.19327
- 3000+0.16070
- 6000+0.14257
- 9000+0.13352
