PHB18NQ10T,118
PHB18NQ10T,118
    NEXPERIA(安世)
    TO-263(D²Pak)
    MOS管 N-Channel VDS=100V VGS=±20V ID=18A RDS(ON)=90mΩ@10V TO263
PHB18NQ10T,118 数据手册
PHB18NQ10T N-channel TrenchMOS standard level FET Rev. 02 — 17 December 2010 Product data sheet 1. Product profile 1.1 General description Standard level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic package using TrenchMOS technology. This product is designed and qualified for use in computing, communications, consumer and industrial applications only. 1.2 Features and benefits  Higher operating power due to low thermal resistance  Low conduction losses due to low on-state resistance  Suitable for high frequency applications due to fast switching characteristics 1.3 Applications  DC-to-DC converters  Switched-mode power supplies 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 100 V ID drain current Tmb = 25 °C; VGS = 10 V - - 18 A Ptot total power dissipation Tmb = 25 °C - - 79 W VGS = 10 V; ID = 9 A; Tj = 25 °C - 80 90 mΩ - 8 - nC Static characteristics RDSon drain-source on-state resistance Dynamic characteristics QGD gate-drain charge VGS = 10 V; ID = 18 A; VDS = 80 V; Tj = 25 °C PHB18NQ10T Nexperia N-channel TrenchMOS standard level FET 2. Pinning information Table 2. Pinning information Pin Symbol Description 1 G gate 2 D drain[1] Simplified outline Graphic symbol mb 3 S source mb D mounting base; connected to drain D G mbb076 S 2 1 3 SOT404 (D2PAK) [1] It is not possible to make connection to pin 2. 3. Ordering information Table 3. Ordering information Type number PHB18NQ10T PHB18NQ10T Product data sheet Package Name Description D2PAK plastic single-ended surface-mounted package (D2PAK); 3 leads SOT404 (one lead cropped) All information provided in this document is subject to legal disclaimers. Rev. 02 — 17 December 2010 Version © Nexperia B.V. 2017. All rights reserved 2 of 12 PHB18NQ10T Nexperia N-channel TrenchMOS standard level FET 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - 100 V VDGR drain-gate voltage Tj ≥ 25 °C; Tj ≤ 175 °C; RGS = 20 kΩ - 100 V VGS gate-source voltage ID drain current -20 20 V VGS = 10 V; Tmb = 100 °C - 13 A VGS = 10 V; Tmb = 25 °C - 18 A - 72 A IDM peak drain current pulsed; Tmb = 25 °C Tmb = 25 °C Ptot total power dissipation - 79 W Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C Source-drain diode IS source current Tmb = 25 °C - 18 A ISM peak source current pulsed; Tmb = 25 °C - 72 A Avalanche ruggedness EDS(AL)S non-repetitive drain-source avalanche energy VGS = 10 V; Tj(init) = 25 °C; ID = 11 A; Vsup ≤ 25 V; unclamped; tp = 100 µs; RGS = 50 Ω - 70 mJ IAS non-repetitive avalanche current Vsup ≤ 25 V; VGS = 10 V; Tj(init) = 25 °C; RGS = 50 Ω; unclamped - 18 A 003aae629 100 PD (%) 80 003aae630 100 ID (%) 80 60 60 40 40 20 20 0 0 0 50 100 150 200 0 50 100 150 Tmb (°C) Fig 1. Normalized total power dissipation as a function of mounting base temperature PHB18NQ10T Product data sheet 200 Tmb (°C) Fig 2. Normalized continuous drain current as a function of mounting base temperature All information provided in this document is subject to legal disclaimers. Rev. 02 — 17 December 2010 © Nexperia B.V. 2017. All rights reserved 3 of 12 PHB18NQ10T Nexperia N-channel TrenchMOS standard level FET 102 003aae631 IDM (A) IAS (A) tp = 10 μs 10 003aae643 102 RDS(on) = VDS / ID 10 100 μs 25 °C D.C. 1 ms 10 ms 100 ms 1 10−1 10 1 Tj prior to avalanche = 150 °C 1 102 10−1 10−3 103 10−2 10−1 1 VDS (V) Tmb = 25 °C; IDM is single pulse Fig 3. 10 tAV (ms) unclamped inductive load Safe operating area; continuous and peak drain currents as a function of drain-source voltage Fig 4. Single-shot avalanche rating; avalanche current as a function of avalanche period 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Rth(j-mb) thermal resistance from junction to mounting base Conditions Rth(j-a) thermal resistance from junction to ambient mounted on printed-circuit board ; minimum footprint Min Typ Max Unit - - 1.9 K/W - 50 - K/W 003aae632 10 Zth(j-mb) (K/W) 1 D = 0.5 0.2 0.1 10−1 0.05 0.02 10−2 10−6 tp T t tp single pulse Fig 5. δ= P T 10−5 10−4 10−3 10−2 10−1 1 tp (s) Transient thermal impedance from junction to mounting base as a function of pulse duration PHB18NQ10T Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 17 December 2010 © Nexperia B.V. 2017. All rights reserved 4 of 12 PHB18NQ10T Nexperia N-channel TrenchMOS standard level FET 6. Characteristics Table 6. Characteristics Symbol Parameter Conditions Min Typ Max Unit ID = 0.25 mA; VGS = 0 V; Tj = -55 °C 89 - - V Static characteristics V(BR)DSS drain-source breakdown voltage VGS(th) gate-source threshold voltage IDSS IGSS RDSon drain leakage current gate leakage current drain-source on-state resistance ID = 0.25 mA; VGS = 0 V; Tj = 25 °C 100 - - V ID = 1 mA; VDS = VGS; Tj = -55 °C - - 6 V ID = 1 mA; VDS = VGS; Tj = 175 °C 1 - - V ID = 1 mA; VDS = VGS; Tj = 25 °C 2 3 4 V VDS = 100 V; VGS = 0 V; Tj = 175 °C - - 500 µA VDS = 100 V; VGS = 0 V; Tj = 25 °C - 0.05 10 µA VGS = 10 V; VDS = 0 V; Tj = 25 °C - 10 100 nA VGS = -10 V; VDS = 0 V; Tj = 25 °C - 10 100 nA VGS = 10 V; ID = 9 A; Tj = 175 °C - - 243 mΩ VGS = 10 V; ID = 9 A; Tj = 25 °C - 80 90 mΩ ID = 18 A; VDS = 80 V; VGS = 10 V; Tj = 25 °C - 21 - nC Dynamic characteristics QG(tot) total gate charge QGS gate-source charge QGD gate-drain charge Ciss input capacitance Coss output capacitance Crss reverse transfer capacitance td(on) turn-on delay time tr rise time td(off) turn-off delay time - 18 - ns tf fall time - 12 - ns LD internal drain inductance measured from tab to centre of die ; Tj = 25 °C - 3.5 - nH LS internal source inductance measured from source lead to source bond pad ; Tj = 25 °C - 7.5 - nH 0.92 1.2 V VDS = 25 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C VDS = 50 V; RL = 2.7 Ω; VGS = 10 V; RG(ext) = 5.6 Ω; Tj = 25 °C - 4 - nC - 8 - nC - 633 - pF - 103 - pF - 61 - pF - 6 - ns - 36 - ns Source-drain diode VSD source-drain voltage IS = 18 A; VGS = 0 V; Tj = 25 °C - trr reverse recovery time 55 - ns recovered charge IS = 18 A; dIS/dt = -100 A/µs; VGS = 0 V; VDS = 25 V; Tj = 25 °C - Qr - 135 - nC PHB18NQ10T Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 17 December 2010 © Nexperia B.V. 2017. All rights reserved 5 of 12 PHB18NQ10T Nexperia N-channel TrenchMOS standard level FET 003aae633 20 ID (A) 16 VGS = 10 V 8V 6V 003aae634 0.20 RDS(on) (Ω) 0.16 4.6 5.4 5 4.8 5.2 6 12 0.12 5.4 V 8 8 0.08 5.2 V VGS (V) = 10 5V 4 4.8 V 4.6 V 4.4 V 0 0 0.4 0.8 1.2 0.04 0 1.6 2.0 VDS (V) 0 8 12 16 20 ID (A) Tj = 25 °C Fig 6. 4 Tj = 25 °C Output characteristics: drain current as a function of drain-source voltage; typical values Fig 7. 003aae635 20 ID (A) 16 gfs (S) Drain-source on-state resistance as a function of drain current; typical values 003aae636 14 Tj = 25 °C 12 10 12 Tj = 175 °C 8 Tj = 175 °C 8 6 Tj = 25 °C 4 4 2 0 0 0 2 4 6 8 10 VGS (V) 0 8 12 16 20 ID (A) VDS > ID x RDSon Fig 8. 4 VDS > ID x RDSon Transfer characteristics: drain current as a function of gate-source voltage; typical values 003aae637 2.9 Fig 9. Forward transconductance as a function of drain current; typical values 003aae638 4.5 VGS(th) (V) RDS(on) (Ω) maximum 3.5 2.1 typical 2.5 minimum 1.3 1.5 0.5 −60 20 100 180 Tj (°C) 0.5 −60 20 100 180 Tj (°C) ID = 1 mA; VDS = VGS Fig 10. Normalized drain-source on-state resistance factor as a function of junction temperature PHB18NQ10T Product data sheet Fig 11. Gate-source threshold voltage as a function of junction temperature All information provided in this document is subject to legal disclaimers. Rev. 02 — 17 December 2010 © Nexperia B.V. 2017. All rights reserved 6 of 12 PHB18NQ10T Nexperia N-channel TrenchMOS standard level FET 003aae639 10−1 ID (A) 003aae640 104 C (pF) 10−2 10−3 minimum 10−4 typical 103 Ciss 102 Coss maximum 10−5 Crss 10−6 0 1 2 3 4 5 10 10−1 1 102 10 VDS (V) VGS (V) Tj = 25 °C; VDS = VGS VGS = 0 V; f = 1 MHz Fig 12. Sub-threshold drain current as a function of gate-source voltage 003aae641 16 VGS (V) 12 VDD = 20 V Fig 13. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values 003aae642 20 IF (A) 16 12 VDD = 80 V Tj = 175 °C 8 Tj = 25 °C 8 4 4 0 0 0 10 20 30 0 0.4 0.8 1.2 QG (nC) VSDS (V) Tj = 25 °C; ID = 18 A VGS = 0 V Fig 14. Gate-source voltage as a function of gate charge; typical values PHB18NQ10T Product data sheet Fig 15. Source (diode forward) current as a function of source-drain (diode forward) voltage; typical values All information provided in this document is subject to legal disclaimers. Rev. 02 — 17 December 2010 © Nexperia B.V. 2017. All rights reserved 7 of 12 PHB18NQ10T Nexperia N-channel TrenchMOS standard level FET 7. Package outline SOT404 Plastic single-ended surface-mounted package (D2PAK); 3 leads (one lead cropped) A A1 E mounting base D1 D HD 2 Lp 1 3 c b e e Q 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 b c D max. D1 E e Lp HD Q mm 4.50 4.10 1.40 1.27 0.85 0.60 0.64 0.46 11 1.60 1.20 10.30 9.70 2.54 2.90 2.10 15.80 14.80 2.60 2.20 OUTLINE VERSION REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 05-02-11 06-03-16 SOT404 Fig 16. Package outline SOT404 (D2PAK) PHB18NQ10T Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 17 December 2010 © Nexperia B.V. 2017. All rights reserved 8 of 12 PHB18NQ10T Nexperia N-channel TrenchMOS standard level FET 8. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes PHB18NQ10T v.2 20101217 Product data sheet - PHB_PHD_PHP18NQ10T v.1 Modifications: • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • • Legal texts have been adapted to the new company name where appropriate. Type number PHB18NQ10T separated from data sheet PHB_PHD_PHP18NQ10T v.1. PHB_PHD_PHP18NQ10T v.1 19990801 PHB18NQ10T Product data sheet Product specification - All information provided in this document is subject to legal disclaimers. Rev. 02 — 17 December 2010 - © Nexperia B.V. 2017. All rights reserved 9 of 12 PHB18NQ10T Nexperia N-channel TrenchMOS standard level FET 9. Legal information 9.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 9.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 9.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective PHB18NQ10T Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 17 December 2010 © Nexperia B.V. 2017. All rights reserved 10 of 12 PHB18NQ10T Nexperia N-channel TrenchMOS standard level FET agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. 9.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the 10. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com PHB18NQ10T Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 17 December 2010 © Nexperia B.V. 2017. All rights reserved 11 of 12 Nexperia PHB18NQ10T N-channel TrenchMOS standard level FET 11. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 9.2 9.3 9.4 10 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3 Thermal characteristics . . . . . . . . . . . . . . . . . . .4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . .8 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . .9 Legal information. . . . . . . . . . . . . . . . . . . . . . . .10 Data sheet status . . . . . . . . . . . . . . . . . . . . . . .10 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .10 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .10 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Contact information. . . . . . . . . . . . . . . . . . . . . . 11 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 17 December 2010
PHB18NQ10T,118 价格&库存
很抱歉,暂时无法提供与“PHB18NQ10T,118”相匹配的价格&库存,您可以联系我们找货
PHB18NQ10T,118
  • 248+12.27774248+1.58813
  • 500+11.06011500+1.43063
  • 1000+10.146891000+1.31250
  • 10000+9.0859310000+1.17527
  • 100000+7.61260100000+0.98469
库存:938
PHB18NQ10T,118
  • 312+4.20214312+0.54355
库存:2384
