PHP18NQ11T,127
PHP18NQ11T,127
    NEXPERIA(安世)
    TO-220AB
    MOS管 N-Channel VDS=110V VGS=±20V ID=18A RDS(ON)=90mΩ@10V TO220AB
PHP18NQ11T,127 数据手册
PHP18NQ11T N-channel TrenchMOS standard level FET Rev. 02 — 10 March 2010 Product data sheet 1. Product profile 1.1 General description Standard level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic package using TrenchMOS technology. This product is designed and qualified for use in computing, communications, consumer and industrial applications only. 1.2 Features and benefits „ Higher operating power due to low thermal resistance „ Suitable for high frequency applications due to fast switching characteristics 1.3 Applications „ Class-D audio amplifiers „ Inverters „ DC-to-DC convertors „ Switched-mode power supplies 1.4 Quick reference data Table 1. Quick reference Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - - 110 V ID drain current Tmb = 25 °C; VGS = 10 V; see Figure 1 and 3 - - 18 A Ptot total power dissipation Tmb = 25 °C; see Figure 2 - - 79 W VGS = 10 V; ID = 18 A; VDS = 80 V; Tj = 25 °C; see Figure 11 - 8 - nC VGS = 10 V; ID = 9 A; Tj = 25 °C; see Figure 9 and 10 - 80 90 mΩ Dynamic characteristics QGD gate-drain charge Static characteristics RDSon drain-source on-state resistance PHP18NQ11T Nexperia N-channel TrenchMOS standard level FET 2. Pinning information Table 2. Pinning information Pin Symbol Description 1 G gate 2 D drain Simplified outline Graphic symbol mb 3 S source mb D mounting base; connected to drain D G S mbb076 1 2 3 SOT78 (TO-220AB) 3. Ordering information Table 3. Ordering information Type number PHP18NQ11T Package Name Description Version TO-220AB plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead SOT78 TO-220AB 4. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C - 110 V VDGR drain-gate voltage Tj ≥ 25 °C; Tj ≤ 175 °C; RGS = 20 kΩ - 110 V VGS gate-source voltage ID drain current -20 20 V VGS = 10 V; Tmb = 100 °C; see Figure 1 - 13 A VGS = 10 V; Tmb = 25 °C; see Figure 1 and 3 - 18 A - 72 A IDM peak drain current tp ≤ 10 µs; pulsed; Tmb = 25 °C; see Figure 3 Ptot total power dissipation Tmb = 25 °C; see Figure 2 - 79 W Tstg storage temperature -55 175 °C Tj junction temperature -55 175 °C Source-drain diode IS source current Tmb = 25 °C - 18 A ISM peak source current tp ≤ 10 µs; pulsed; Tmb = 25 °C - 72 A - 70 mJ Avalanche ruggedness EDS(AL)S non-repetitive VGS = 10 V; Tj(init) = 25 °C; ID = 11 A; Vsup ≤ 25 V; drain-source avalanche unclamped; tp = 0.1 ms; RGS = 50 Ω energy PHP18NQ11T_2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 10 March 2010 © Nexperia B.V. 2017. All rights reserved 2 of 13 PHP18NQ11T Nexperia N-channel TrenchMOS standard level FET 03aa24 120 03aa16 120 Ider (%) Pder (%) 80 80 40 40 0 0 0 50 100 150 200 0 50 100 150 Tmb (°C) Fig 1. 200 Tmb (°C) Normalized continuous drain current as a function of mounting base temperature Fig 2. Normalized total power dissipation as a function of mounting base temperature 003aaa591 102 Limit RDSon = VDS / ID ID (A) tp = 10 μs 10 100 μs DC 1 ms 10 ms 100 ms 1 10−1 1 Fig 3. 102 10 VDS (V) 103 Safe operating area: continuous and peak currents as a function of drain-source voltage PHP18NQ11T_2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 10 March 2010 © Nexperia B.V. 2017. All rights reserved 3 of 13 PHP18NQ11T Nexperia N-channel TrenchMOS standard level FET 5. Thermal characteristics Table 5. Thermal characteristics Symbol Parameter Rth(j-mb) Rth(j-a) Conditions Min Typ Max Unit thermal resistance from see Figure 4 junction to mounting base - - 1.9 K/W thermal resistance from in free air junction to ambient - 60 - K/W 003aaa592 10 Zth(j-mb) (K/W) δ = 0.5 1 0.2 0.1 0.05 10−1 0.02 δ= P single pulse tp T t tp T 10−2 10−5 Fig 4. 10−4 10−3 10−2 10−1 tp (s) 1 Transient thermal impedance from junction to mounting base as a function of pulse duration PHP18NQ11T_2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 10 March 2010 © Nexperia B.V. 2017. All rights reserved 4 of 13 PHP18NQ11T Nexperia N-channel TrenchMOS standard level FET 6. Characteristics Table 6. Symbol Characteristics Parameter Conditions Min Typ Max Unit ID = 250 µA; VGS = 0 V; Tj = -55 °C 98 - - V ID = 250 µA; VGS = 0 V; Tj = 25 °C 110 - - V ID = 1 mA; VDS = VGS; Tj = 175 °C; see Figure 8 1 - - V ID = 1 mA; VDS = VGS; Tj = 25 °C; see Figure 8 2 3 4 V ID = 1 mA; VDS = VGS; Tj = -55 °C; see Figure 8 - - 4.4 V µA Static characteristics V(BR)DSS drain-source breakdown voltage VGS(th) gate-source threshold voltage IDSS drain leakage current VDS = 110 V; VGS = 0 V; Tj = 25 °C - 0.05 10 VDS = 110 V; VGS = 0 V; Tj = 175 °C - - 500 µA IGSS gate leakage current VGS = 10 V; VDS = 0 V; Tj = 25 °C - 10 100 nA VGS = -10 V; VDS = 0 V; Tj = 25 °C - 10 100 nA VGS = 10 V; ID = 9 A; Tj = 175 °C; see Figure 9 and 10 - - 243 mΩ VGS = 10 V; ID = 9 A; Tj = 25 °C; see Figure 9 and 10 - 80 90 mΩ RDSon drain-source on-state resistance Dynamic characteristics QG(tot) total gate charge QGS gate-source charge ID = 18 A; VDS = 80 V; VGS = 10 V; Tj = 25 °C; see Figure 11 QGD gate-drain charge Ciss input capacitance Coss output capacitance Crss reverse transfer capacitance td(on) turn-on delay time tr rise time - 36 - ns td(off) turn-off delay time - 18 - ns tf fall time - 12 - ns VDS = 25 V; VGS = 0 V; f = 1 MHz; Tj = 25 °C; see Figure 12 VDS = 50 V; RL = 2.7 Ω; VGS = 10 V; RG(ext) = 5.6 Ω; Tj = 25 °C; ID = 18.5 A - 21 - nC - 4 - nC - 8 - nC - 633 - pF - 103 - pF - 61 - pF - 6 - ns Source-drain diode VSD source-drain voltage IS = 18 A; VGS = 0 V; Tj = 25 °C; see Figure 13 - 0.92 1.2 V trr reverse recovery time - 55 - ns Qr recovered charge IS = 18 A; dIS/dt = 100 A/µs; VGS = 0 V; VDS = 25 V; Tj = 25 °C - 135 - nC PHP18NQ11T_2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 10 March 2010 © Nexperia B.V. 2017. All rights reserved 5 of 13 PHP18NQ11T Nexperia N-channel TrenchMOS standard level FET 003aaa593 20 ID 003aaa595 20 VGS = 10 V ID (A) (A) 6V 15 15 10 10 5.4 V Tj = 175 °C 5.2 V 5 Tj = 25 °C 5 5V 4.8 V 4.6 V 0 0 Fig 5. 0 0.5 1 1.5 VDS (V) 2 0 Fig 6. 03aa35 ID (A) 6 8 Transfer characteristics: drain current as a function of gate-source voltage; typical values 03aa32 5 VGS(th) (V) min 10−2 typ max 4 10−3 3 10−4 2 10−5 1 10−6 0 2 4 0 −60 6 VGS (V) Fig 7. 4 VGS (V) Output characteristics: drain current as a function of drain-source voltage; typical values 10−1 2 Sub-threshold drain current as a function of gate-source voltage PHP18NQ11T_2 Product data sheet Fig 8. max typ min 0 60 120 180 Tj (°C) Gate-source threshold voltage as a function of junction temperature All information provided in this document is subject to legal disclaimers. Rev. 02 — 10 March 2010 © Nexperia B.V. 2017. All rights reserved 6 of 13 PHP18NQ11T Nexperia N-channel TrenchMOS standard level FET 03am64 0.2 4.8 5 5.2 5.4 RDSon (Ω) 03aa29 3 Tj = 25 °C VGS (V) = a 0.15 2 0.1 6 1 10 0.05 0 0 Fig 9. 4 8 ID (A) Drain-source on-state resistance as a function of drain current; typical values 003aaa597 10 0 -60 12 VGS 0 60 120 Tj (°C) 180 Fig 10. Normalized drain-source on-state resistance factor as a function of junction temperature 03am67 104 C (pF) (V) 8 20 V VDD = 80 V 103 Ciss 6 4 Coss 102 2 Crss 0 0 10 20 Q G (nC) 30 Fig 11. Gate-source voltage as a function of gate charge; typical values PHP18NQ11T_2 Product data sheet 10 10-1 1 10 VDS (V) 102 Fig 12. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values All information provided in this document is subject to legal disclaimers. Rev. 02 — 10 March 2010 © Nexperia B.V. 2017. All rights reserved 7 of 13 PHP18NQ11T Nexperia N-channel TrenchMOS standard level FET 003aaa596 20 IS (A) 15 Tj = 175 °C 10 25 °C 5 0 0 0.3 0.6 0.9 1.2 VSD (V) Fig 13. Source current as a function of source-drain voltage; typical values PHP18NQ11T_2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 10 March 2010 © Nexperia B.V. 2017. All rights reserved 8 of 13 PHP18NQ11T Nexperia N-channel TrenchMOS standard level FET 7. Package outline Plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead TO-220AB SOT78 E A A1 p q mounting base D1 D L1(1) L2(1) Q L b1(2) (3×) b2(2) (2×) 1 2 3 b(3×) c e e 0 5 10 mm scale DIMENSIONS (mm are the original dimensions) UNIT A A1 b b1(2) b2(2) c D D1 E e L L1(1) L2(1) max. p q Q mm 4.7 4.1 1.40 1.25 0.9 0.6 1.6 1.0 1.3 1.0 0.7 0.4 16.0 15.2 6.6 5.9 10.3 9.7 2.54 15.0 12.8 3.30 2.79 3.0 3.8 3.5 3.0 2.7 2.6 2.2 Notes 1. Lead shoulder designs may vary. 2. Dimension includes excess dambar. OUTLINE VERSION SOT78 REFERENCES IEC JEDEC JEITA 3-lead TO-220AB SC-46 EUROPEAN PROJECTION ISSUE DATE 08-04-23 08-06-13 Fig 14. Package outline SOT78 (TO-220AB) PHP18NQ11T_2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 10 March 2010 © Nexperia B.V. 2017. All rights reserved 9 of 13 PHP18NQ11T Nexperia N-channel TrenchMOS standard level FET 8. Revision history Table 7. Revision history Document ID Release date Data sheet status Change notice Supersedes PHP18NQ11T_2 20100310 Product data sheet - PHP18NQ11T-01 Modifications: PHP18NQ11T-01 (9397 750 12305) PHP18NQ11T_2 Product data sheet • The format of this data sheet has been redesigned to comply with the new identity guidelines of NXP Semiconductors. • Legal texts have been adapted to the new company name where appropriate. 20031113 Product data - All information provided in this document is subject to legal disclaimers. Rev. 02 — 10 March 2010 - © Nexperia B.V. 2017. All rights reserved 10 of 13 PHP18NQ11T Nexperia N-channel TrenchMOS standard level FET 9. Legal information 9.1 Data sheet status Document status [1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term 'short data sheet' is explained in section "Definitions". [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 9.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 9.3 Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on a weakness or default in the customer application/use or the application/use of customer’s third party customer(s) (hereinafter both referred to as “Application”). It is customer’s sole responsibility to check whether the Nexperia product is suitable and fit for the Application planned. Customer has to do all necessary testing for the Application in order to avoid a default of the Application and the product. Nexperia does not accept any liability in this respect. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. PHP18NQ11T_2 Product data sheet Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 02 — 10 March 2010 © Nexperia B.V. 2017. All rights reserved 11 of 13 PHP18NQ11T Nexperia N-channel TrenchMOS standard level FET Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. 9.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 10. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com PHP18NQ11T_2 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 02 — 10 March 2010 © Nexperia B.V. 2017. All rights reserved 12 of 13 Nexperia PHP18NQ11T N-channel TrenchMOS standard level FET 11. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 9 9.1 9.2 9.3 9.4 10 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1 General description . . . . . . . . . . . . . . . . . . . . . .1 Features and benefits . . . . . . . . . . . . . . . . . . . . .1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1 Quick reference data . . . . . . . . . . . . . . . . . . . . .1 Pinning information . . . . . . . . . . . . . . . . . . . . . . .2 Ordering information . . . . . . . . . . . . . . . . . . . . . .2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .2 Thermal characteristics . . . . . . . . . . . . . . . . . . .4 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . .9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . .10 Legal information. . . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . .12 Contact information. . . . . . . . . . . . . . . . . . . . . .12 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 10 March 2010
PHP18NQ11T,127 价格&库存
很抱歉,暂时无法提供与“PHP18NQ11T,127”相匹配的价格&库存,您可以联系我们找货
PHP18NQ11T,127
  • 1+21.675961+2.80037
  • 10+13.8975510+1.79546
  • 100+9.45878100+1.22200
  • 500+7.55852500+0.97650
库存:533
