BUK7618-55
N-channel TrenchMOS standard level FET
Rev. 2 — 26 April 2011
Product data sheet
1. Product profile
1.1 General description
Standard level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic
package using TrenchMOS technology. This product has been designed and qualified to
the appropriate AEC standard for use in automotive critical applications.
1.2 Features and benefits
AEC Q101 compliant
Low conduction losses due to low
on-state resistance
Electrostatically robust due to
integrated protection diodes
1.3 Applications
Automotive and general purpose
power switching
1.4 Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min Typ Max Unit
VDS
drain-source voltage
Tj ≥ 25 °C; Tj ≤ 175 °C
55
V
ID
drain current
Tmb = 25 °C
57
A
Ptot
total power dissipation
125 W
VGS = 10 V; ID = 25 A;
Tj = 25 °C
15
18
ID = 50 A; Vsup ≤ 25 V;
RGS = 50 Ω; VGS = 10 V;
Tj(init) = 25 °C; unclamped
125 mJ
Static characteristics
RDSon
drain-source on-state
resistance
mΩ
Avalanche ruggedness
EDS(AL)S
non-repetitive
drain-source
avalanche energy
BUK7618-55
Nexperia
2. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
1
G
gate
2
D
drain
3
S
source
mb
D
mounting base;
connected to drain
Simplified outline
Graphic symbol
mb
D
G
mbb076
S
2
1
3
SOT404 (D2PAK)
3. Ordering information
Table 3.
Type number
BUK7618-55
BUK7618-55
Product data sheet
Package
Name
Description
Version
D2PAK
plastic single-ended surface-mounted package (D2PAK);
3 leads (one lead cropped)
SOT404
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 12
BUK7618-55
Nexperia
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
55
V
VDGR
drain-gate voltage
RGS = 20 kΩ
55
V
VGS
gate-source voltage
ID
drain current
-16
16
V
Tmb = 25 °C
57
A
Tmb = 100 °C
40
A
228
A
IDM
peak drain current
Tmb = 25 °C; pulsed
Tmb = 25 °C
Ptot
125
W
Tstg
storage temperature
-55
175
°C
Tj
junction temperature
-55
175
°C
Source-drain diode
IS
source current
Tmb = 25 °C
57
A
ISM
peak source current
pulsed; Tmb = 25 °C
200
A
ID = 50 A; Vsup ≤ 25 V; RGS = 50 Ω;
VGS = 10 V; Tj(init) = 25 °C; unclamped
125
mJ
HBM; C = 100 pF; R = 1.5 kΩ; (all pins)
2
kV
non-repetitive drain-source
avalanche energy
EDS(AL)S
Electrostatic discharge
Vesd
electrostatic discharge voltage
003aaf190
100
Pder
80
003aaf191
100
ID
80
60
60
40
40
80
120
200
Tmb (°C)
40
80
120
160
200
Tmb (°C)
VGS ≥ 5 V
Fig 1.
Normalized total power dissipation as a
function of mounting base temperature
BUK7618-55
Product data sheet
Fig 2.
Normalized continuous drain current as a
3 of 12
BUK7618-55
Nexperia
003aaf192
103
IDM
(A)
WDSS
RDS(on) = VDS / ID
tp = 1 μs
102
003aaf204
120
80
10 μs
100 μs
D.C.
10
1 ms
40
10 ms
100 ms
1
1
10
100
140
180
T(mb) (°C)
VDS (V)
Tmb = 25 °C; IDM is single pulse
Fig 3.
ID = 75 A
Safe operating area; continuous and peak drain
currents as a function of drain-source voltage
Fig 4.
Normalised drain-source avalanche energy as a
function of mounting-base temperature.
5. Thermal characteristics
Table 5.
Symbol
Parameter
Rth(j-mb)
thermal resistance from
junction to mounting base
Conditions
Rth(j-a)
junction to ambient
minimum footprint; FR4 board
Min
Typ
Max
Unit
1.2
K/W
50
K/W
003aaf193
10
Zth(j-mb)
(K/W)
1
δ = 0.5
0.2
10−1
10−2
0.1
0.05
0.02
δ=
P
t
tp
10−3
10−6
Fig 5.
tp
T
T
10−5
10−4
10−3
10−2
10−1
1
10
tp (s)
Transient thermal impedance from junction to mounting base as a function of pulse duration
BUK7618-55
Product data sheet
4 of 12
BUK7618-55
Nexperia
6. Characteristics
Table 6.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
V(BR)DSS
drain-source
breakdown voltage
ID = 0.25 mA; VGS = 0 V; Tj = 25 °C
55
V
ID = 0.25 mA; VGS = 0 V; Tj = -55 °C
50
V
VGS(th)
gate-source threshold
voltage
ID = 1 mA; VDS = VGS; Tj = 25 °C
2
3
4
V
ID = 1 mA; VDS = VGS; Tj = 175 °C
1
V
ID = 1 mA; VDS = VGS; Tj = -55 °C
4.4
V
VDS = 55 V; VGS = 0 V; Tj = 175 °C
500
µA
VDS = 55 V; VGS = 0 V; Tj = 25 °C
0.05
10
µA
VGS = 10 V; VDS = 0 V; Tj = 25 °C
0.02
1
µA
VGS = -10 V; VDS = 0 V; Tj = 25 °C
0.02
1
µA
IDSS
IGSS
RDSon
V(BR)GSS
drain leakage current
gate leakage current
VGS = 10 V; VDS = 0 V; Tj = 175 °C
µA
VGS = -10 V; VDS = 0 V; Tj = 175 °C
µA
resistance
VGS = 10 V; ID = 25 A; Tj = 175 °C
38
mΩ
VGS = 10 V; ID = 25 A; Tj = 25 °C
15
18
mΩ
gate-source
breakdown voltage
VDS = 0 V; Tj = 25 °C; IG = 1 mA
16
V
VDS = 0 V; Tj = 25 °C; IG = -1 mA
16
V
VGS = 0 V; VDS = 25 V; f = 1 MHz;
Tj = 25 °C
1500
2000
pF
370
470
pF
170
250
pF
15
22
ns
Dynamic characteristics
Ciss
input capacitance
Coss
output capacitance
Crss
reverse transfer
capacitance
td(on)
turn-on delay time
VDS = 30 V; RL = 1.2 Ω; VGS = 10 V;
RG(ext) = 10 Ω; ID = 25 A; Tj = 25 °C
tr
rise time
30
60
ns
td(off)
turn-off delay time
35
50
ns
tf
fall time
25
38
ns
LD
internal drain
inductance
measured from upper edge of drain
mounting base to centre of die;
Tj = 25 °C
2.5
nH
LS
internal source
inductance
measured from source lead soldering
point to source bond pad; Tj = 25 °C
7.5
nH
gfs
transfer conductance
VDS = 25 V; ID = 25 A; Tj = 25 °C
6
30
S
IS = 50 A; VGS = 0 V; Tj = 25 °C
1
V
IS = 25 A; VGS = 0 V; Tj = 25 °C
0.95
1.2
V
IS = 50 A; dIS/dt = -100 A/µs;
VGS = -10 V; VDS = 30 V; Tj = 25 °C
48
ns
0.1
µC
Source-drain diode
VSD
source-drain voltage
trr
reverse recovery time
Qr
recovered charge
BUK7618-55
Product data sheet
5 of 12
BUK7618-55
Nexperia
003aaf194
100
16.0
ID
10.0
(A)
80 8.0
7.5
6.0
RDS(on)
(mΩ)
VGS (V) = 7.0
6.5
25
6.5
60
003aaf195
30
7.0
8.0
6.0
40
15
VGS (V) = 10
5.5
5.0
4.0
4
6
8
10
10
VDS (V)
5
45
65
85
105
ID (A)
Tj = 25 °C
Fig 6.
25
Tj = 25 °C
Output characteristics: drain current as a
function of drain-source voltage; typical values
Fig 7.
003aaf196
100
ID
(A)
80
Drain-source on-state resistance as a function
of drain current; typical values
003aaf197
30
gfs
(S)
40
10
Tj = 175 °C
Tj = 25 °C
4
6
8
10
VGS (V)
60
80
100
ID (A)
VDS > ID x RDSon
Fig 8.
VDS > ID x RDSon
Transfer characteristics: drain current as a
function of gate-source voltage; typical values
003aaf198
2.5
Fig 9.
Forward transconductance as a function of
003aaf199
5
VGS(th)
(V)
4
a
2.0
maximum
3
typical
2
minimum
1.5
1.0
0.5
−100
1
200
Tmb (°C)
−100
200
Tj (°C)
Fig 10. Normalized drain-source on-state resistance
factor as a function of junction temperature
BUK7618-55
Product data sheet
Fig 11. Gate-source threshold voltage as a function of
6 of 12
BUK7618-55
Nexperia
003aaf200
10−1
ID
(A)
10−2
003aaf201
3
Ciss
C
(nF)
Coss
2
10−3
2%
10−4
Crss
98 %
typical
1
10−5
10−6
2
3
4
5
10−2
10−1
1
VDS (V)
Tj = 25 °C; VDS = VGS
VGS = 0 V; f = 1 MHz
Fig 12. Sub-threshold drain current as a function of
gate-source voltage
003aaf202
12
VGS
(V)
102
10
VGS (V)
Fig 13. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
003aaf203
100
IF
(A)
80
VDS = 14 V
8
60
VDS = 44 V
40
4
Tj = 175 °C
Tj = 25 °C
40
0.8
1.2
QG (nC)
VSDS (V)
Tj = 25 °C; ID = 50 A
VGS = 0 V
Fig 14. Gate-source voltage as a function of gate
charge; typical values
BUK7618-55
Product data sheet
Fig 15. Source (diode forward) current as a function of
source-drain (diode forward) voltage; typical
values
7 of 12
BUK7618-55
Nexperia
7. Package outline
SOT404
Plastic single-ended surface-mounted package (D2PAK); 3 leads (one lead cropped)
A
A1
E
mounting
base
D1
D
HD
2
Lp
1
3
c
b
e
e
Q
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
b
c
D
max.
D1
E
e
Lp
HD
Q
mm
4.50
4.10
1.40
1.27
0.85
0.60
0.64
0.46
11
1.60
1.20
10.30
9.70
2.54
2.90
2.10
15.80
14.80
2.60
2.20
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
05-02-11
06-03-16
SOT404
Fig 16. Package outline SOT404 (D2PAK)
BUK7618-55
Product data sheet
8 of 12
BUK7618-55
Nexperia
8. Revision history
Table 7.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
BUK7618-55 v.2
20110426
Product data sheet
BUK7618-55_1
Modifications:
BUK7618-55_1
BUK7618-55
Product data sheet
The format of this data sheet has been redesigned to comply with the new identity guidelines
of NXP.
Legal texts have been adapted to the new company name where appropriate.
19980401
Product specification
9 of 12
BUK7618-55
Nexperia
9. Legal information
9.1
Data sheet status
Document status [1] [2]
Product status [3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term 'short data sheet' is explained in section "Definitions".
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product
status information is available on the Internet at URL http://www.nexperia.com.
9.2
Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
Nexperia does not give any representations or warranties as to
the accuracy or completeness of information included herein and shall have
no liability for the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
9.3
Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
BUK7618-55
Product data sheet
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. The product is not designed, authorized or warranted to be
suitable for use in medical, military, aircraft, space or life support equipment,
nor in applications where failure or malfunction of a Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia accepts no
liability for inclusion and/or use of Nexperia products in such
equipment or applications and therefore such inclusion and/or use is at the
customer’s own risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
10 of 12
BUK7618-55
Nexperia
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
Export control — This document as well as the item(s) described herein may
be subject to export control regulations. Export might require a prior
authorization from national authorities.
9.4
Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
10. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
BUK7618-55
Product data sheet
11 of 12
Nexperia
BUK7618-55
11. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
9.1
9.2
9.3
9.4
10
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1
General description . . . . . . . . . . . . . . . . . . . . . .1
Features and benefits . . . . . . . . . . . . . . . . . . . . .1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1
Quick reference data . . . . . . . . . . . . . . . . . . . . .1
Pinning information . . . . . . . . . . . . . . . . . . . . . . .2
Ordering information . . . . . . . . . . . . . . . . . . . . . .2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3
Thermal characteristics . . . . . . . . . . . . . . . . . . .4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . .8
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . .9
Legal information. . . . . . . . . . . . . . . . . . . . . . . .10
Data sheet status . . . . . . . . . . . . . . . . . . . . . . .10
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .10
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .10
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Contact information. . . . . . . . . . . . . . . . . . . . . . 11
Date of release: 26 April 2011
很抱歉,暂时无法提供与“BUK7618-55,118”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 4800+4.667724800+0.60464
