PHB110NQ08T
N-channel TrenchMOS standard level FET
Rev. 02 — 12 October 2009
Product data sheet
1. Product profile
1.1 General description
Standard level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic
package using TrenchMOS technology. This product is designed and qualified for use in
computing, communications, consumer and industrial applications only.
1.2 Features and benefits
Low conduction losses due to low
on-state resistance
Suitable for standard level gate drive
sources
1.3 Applications
DC-to-DC convertors
Motors, lamps and solenoids
General industrial applications
Uninterruptible power supplies
1.4 Quick reference data
Table 1.
Quick reference
Symbol Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage Tj ≥ 25 °C; Tj ≤ 175 °C
75
V
ID
drain current
Tmb = 25 °C; VGS = 10 V;
see Figure 1 and 3
75
A
Ptot
total power
dissipation
Tmb = 25 °C; see Figure 2
230
W
VGS = 10 V; ID = 25 A;
VDS = 60 V; Tj = 25 °C;
see Figure 11
48.2
nC
Tj = 25 °C; see Figure 9 and 10
7.7
9
mΩ
Dynamic characteristics
QGD
gate-drain charge
Static characteristics
RDSon
drain-source
on-state resistance
PHB110NQ08T
Nexperia
2. Pinning information
Table 2.
Pinning information
Pin
Symbol
Description
Simplified outline
1
G
gate
2
D
drain
3
S
source
mb
D
mounting base; connected to
drain
Graphic symbol
mb
[1]
D
G
mbb076
S
2
1
3
SOT404 (D2PAK)
[1]
It is not possible to make a connection to pin 2.
3. Ordering information
Table 3.
Type number
PHB110NQ08T
Package
Name
Description
Version
D2PAK
plastic single-ended surface-mounted package (D2PAK); 3 leads (one
lead cropped)
SOT404
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
75
V
VDGR
drain-gate voltage
Tj ≥ 25 °C; Tj ≤ 175 °C; RGS = 20 kΩ
75
V
VGS
gate-source voltage
ID
drain current
-20
V
VGS = 10 V; Tmb = 100 °C; see Figure 1
75
A
VGS = 10 V; Tmb = 25 °C; see Figure 1 and 3
75
A
440
A
IDM
peak drain current
tp ≤ 10 µs; pulsed; Tmb = 25 °C; see Figure 3
Ptot
total power dissipation
230
W
Tstg
storage temperature
-55
175
°C
Tj
junction temperature
-55
175
°C
Source-drain diode
IS
source current
Tmb = 25 °C
75
A
ISM
peak source current
440
A
560
mJ
Avalanche ruggedness
EDS(AL)S
non-repetitive
VGS = 10 V; Tj(init) = 25 °C; ID = 75 A; Vsup ≤ 75 V;
drain-source avalanche unclamped; tp = 0.15 ms; RGS = 50 Ω
energy
PHB110NQ08T_2
Product data sheet
2 of 12
Nexperia B.V. 2017. All rights reserved
PHB110NQ08T
Nexperia
03ap74
120
Ider
Pder
80
80
40
40
Fig 1.
03aa16
120
50
100
150
Tmb (°C)
50
100
150
200
Tmb (°C)
Normalized continuous drain current as a
function of mounting base temperature
Fig 2.
Normalized total power dissipation as a
03nb44
103
RDSon = VDS/ID
ID
(A)
tp = 10 us
102
100 us
1 ms
δ=
P
10
tp
D.C.
T
10 ms
100 ms
t
tp
T
1
1
102
10
VDS (V)
Fig 3.
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
PHB110NQ08T_2
Product data sheet
3 of 12
PHB110NQ08T
Nexperia
5. Thermal characteristics
Table 5.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Rth(j-mb)
thermal resistance from
junction to mounting base
see Figure 4
0.65
K/W
Rth(j-a)
junction to ambient
mounted on printed-circuit board;
minimum footprint; vertical in still air
50
K/W
03ap75
1
Zth(j-mb)
(K/W)
δ = 0.5
0.2
10−1
0.1
0.05
0.02
δ=
P
single pulse
t
tp
10−2
10−4
tp
T
T
10−3
10−2
10−1
1
tp (s)
Fig 4.
Transient thermal impedance from junction to mounting base as a function of pulse duration
PHB110NQ08T_2
Product data sheet
4 of 12
PHB110NQ08T
Nexperia
6. Characteristics
Table 6.
Symbol
Characteristics
Parameter
Conditions
Min
Typ
Max
Unit
V(BR)DSS
VGS(th)
IDSS
IGSS
RDSon
drain-source
breakdown voltage
gate-source threshold
voltage
drain leakage current
gate leakage current
drain-source on-state
resistance
ID = 250 µA; VGS = 0 V; Tj = -55 °C
70
V
ID = 250 µA; VGS = 0 V; Tj = 25 °C
75
V
ID = 1 mA; VDS = VGS; Tj = 175 °C;
see Figure 8
1
V
ID = 1 mA; VDS = VGS; Tj = -55 °C;
see Figure 8
4.4
V
ID = 1 mA; VDS = VGS; Tj = 25 °C;
see Figure 8
2
3
4
V
VDS = 75 V; VGS = 0 V; Tj = 25 °C
10
µA
VDS = 75 V; VGS = 0 V; Tj = 175 °C
500
µA
VGS = 20 V; VDS = 0 V; Tj = 25 °C
2
100
nA
VGS = -20 V; VDS = 0 V; Tj = 25 °C
2
100
nA
VGS = 10 V; ID = 25 A; Tj = 175 °C;
see Figure 9 and 10
16.2
18.9
mΩ
VGS = 10 V; ID = 25 A; Tj = 25 °C;
see Figure 9 and 10
7.7
9
mΩ
ID = 25 A; VDS = 60 V; VGS = 10 V;
Tj = 25 °C; see Figure 11
113.1
nC
18.5
nC
48.2
nC
QG(tot)
total gate charge
QGS
gate-source charge
QGD
gate-drain charge
Ciss
input capacitance
Coss
output capacitance
Crss
reverse transfer
capacitance
td(on)
turn-on delay time
tr
rise time
td(off)
tf
VDS = 25 V; VGS = 0 V; f = 1 MHz;
Tj = 25 °C; see Figure 12
VDS = 30 V; RL = 1.2 Ω; VGS = 10 V;
RG(ext) = 5.6 Ω; Tj = 25 °C
4860
pF
840
pF
475
pF
35
ns
107
ns
turn-off delay time
183
ns
fall time
100
ns
Source-drain diode
VSD
source-drain voltage
IS = 25 A; VGS = 0 V; Tj = 25 °C;
see Figure 13
0.82
1.2
V
trr
reverse recovery time
75
ns
Qr
recovered charge
IS = 20 A; dIS/dt = -100 A/µs; VGS = 0 V;
VDS = 25 V; Tj = 25 °C
270
nC
PHB110NQ08T_2
Product data sheet
5 of 12
PHB110NQ08T
Nexperia
03ap77
240
10 V
Tj = 25 °C
ID
(A)
03ap79
75
7V
VDS > ID x R DSon
ID
(A)
6V
160
50
5.5 V
25
80
5V
25 °C
Tj = 175 °C
VGS = 4.5 V
Fig 5.
2
3
VDS (V)
Fig 6.
03aa35
ID
(A)
4
6
Transfer characteristics: drain current as a
function of gate-source voltage; typical values
03aa32
5
VGS(th)
(V)
min
10−2
typ
max
4
10−3
3
10−4
2
10−5
1
10−6
4
−60
6
VGS (V)
Fig 7.
2
VGS (V)
Output characteristics: drain current as a
function of drain-source voltage; typical values
10−1
Sub-threshold drain current as a function of
gate-source voltage
Fig 8.
max
typ
min
120
180
Tj (°C)
Gate-source threshold voltage as a function of
PHB110NQ08T_2
Product data sheet
6 of 12
PHB110NQ08T
Nexperia
03ap78
Tj = 25 °C
R DSon
(mΩ)
VGS = 5.5 V
03nb25
2.4
6V
a
15
1.6
7V
10
10 V
0.8
5
Fig 9.
80
160
ID (A)
Drain-source on-state resistance as a function
of drain current; typical values
03ap82
10
VGS
(V)
−60
240
120
180
Tj (°C)
Fig 10. Normalized drain-source on-state resistance
factor as a function of junction temperature
03ap81
104
ID = 25 A
Tj = 25 °C
8
C iss
C
(pF)
14 V
6
VDD = 60 V
103
C oss
4
C rss
2
102
80
120
10−1
1
102
10
VDS (V)
Q G (nC)
Fig 11. Gate-source voltage as a function of gate
charge; typical values
Fig 12. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
PHB110NQ08T_2
Product data sheet
7 of 12
PHB110NQ08T
Nexperia
03ap80
75
VGS = 0 V
IS
(A)
50
25
175 °C
Tj = 25 °C
0.6
0.9
1.2
VSD (V)
Fig 13. Source current as a function of source-drain voltage; typical values
PHB110NQ08T_2
Product data sheet
8 of 12
PHB110NQ08T
Nexperia
7. Package outline
SOT404
Plastic single-ended surface-mounted package (D2PAK); 3 leads (one lead cropped)
A
A1
E
mounting
base
D1
D
HD
2
Lp
1
3
c
b
e
e
Q
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
b
c
D
max.
D1
E
e
Lp
HD
Q
mm
4.50
4.10
1.40
1.27
0.85
0.60
0.64
0.46
11
1.60
1.20
10.30
9.70
2.54
2.90
2.10
15.80
14.80
2.60
2.20
OUTLINE
VERSION
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
05-02-11
06-03-16
SOT404
Fig 14. Package outline SOT404 (D2PAK)
PHB110NQ08T_2
Product data sheet
9 of 12
PHB110NQ08T
Nexperia
8. Revision history
Table 7.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
PHB110NQ08T_2
20091012
Product data sheet
PHP_PHB110NQ08T-01
Modifications:
PHP_PHB110NQ08T-01
(9397 750 12927)
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Typenumber PHB110NQ08T separated from data sheet PHP_PHB110NQ08T-01.
20040329
Product data sheet
PHB110NQ08T_2
Product data sheet
10 of 12
PHB110NQ08T
Nexperia
9. Legal information
9.1
Data sheet status
Document status [1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term 'short data sheet' is explained in section "Definitions".
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product
status information is available on the Internet at URL http://www.nexperia.com.
9.2
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
9.3
Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein may
be subject to export control regulations. Export might require a prior
authorization from national authorities.
9.4
Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
10. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
PHB110NQ08T_2
Product data sheet
11 of 12
Nexperia
PHB110NQ08T
11. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
9.1
9.2
9.3
9.4
10
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1
General description . . . . . . . . . . . . . . . . . . . . . .1
Features and benefits . . . . . . . . . . . . . . . . . . . . .1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1
Quick reference data . . . . . . . . . . . . . . . . . . . . .1
Pinning information . . . . . . . . . . . . . . . . . . . . . . .2
Ordering information . . . . . . . . . . . . . . . . . . . . . .2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .2
Thermal characteristics . . . . . . . . . . . . . . . . . . .4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . .9
Revision history . . . . . . . . . . . . . . . . . . . . . . . . .10
Legal information. . . . . . . . . . . . . . . . . . . . . . . . 11
Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 11
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Contact information. . . . . . . . . . . . . . . . . . . . . . 11
Date of release: 12 October 2009
很抱歉,暂时无法提供与“PHB110NQ08T,118”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+12.19320
- 10+10.36800
- 30+9.22320
- 100+8.05680
- 500+7.52760
- 800+7.30080
