PHPT60603NYX
PHPT60603NYX
    NEXPERIA(安世)
    SOT669
    60V,3A NPN高功率双极晶体管
PHPT60603NYX 数据手册
PHPT60603NY 60V, 3 A NPN high power bipolar transistor 10 January 2014 Product data sheet 1. General description NPN high power bipolar transistor in a SOT669 (LFPAK56) Surface-Mounted Device (SMD) power plastic package. PNP complement: PHPT60603PY 2. Features and benefits • • • • • High thermal power dissipation capability High temperature applications up to 175 °C Reduced Printed Circuit Board (PCB) requirements comparing to transistors in DPAK High energy efficiency due to less heat generation AECQ-101 qualified. 3. Applications • • • • Power management Load switch Linear mode voltage regulator Backlighting apllications 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VCEO collector-emitter voltage open base - - 60 V IC collector current - - 3 A ICM peak collector current single pulse; tp ≤ 1 ms - - 8 A RCEsat collector-emitter saturation resistance IC = 3 A; IB = 300 mA; pulsed; - 60 90 mΩ tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C PHPT60603NY Nexperia 60V, 3 A NPN high power bipolar transistor 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 E emitter 2 E emitter 3 E emitter 4 B base mb C collector Simplified outline Graphic symbol C mb B E 1 2 3 4 sym123 LFPAK56; PowerSO8 (SOT669) 6. Ordering information Table 3. Ordering information Type number PHPT60603NY Package Name Description Version LFPAK56; Power-SO8 Plastic single-ended surface-mounted package (LFPAK56; Power-SO8); 4 leads SOT669 7. Marking Table 4. Marking codes Type number Marking code PHPT60603NY 0603NAB PHPT60603NY Product data sheet All information provided in this document is subject to legal disclaimers. 10 January 2014 © Nexperia B.V. 2017. All rights reserved 2 / 15 PHPT60603NY Nexperia 60V, 3 A NPN high power bipolar transistor 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage open emitter - 60 V VCEO collector-emitter voltage open base - 60 V VEBO emitter-base voltage open collector - 7 V IC collector current - 3 A ICM peak collector current - 8 A IB base current - 0.5 A Ptot total power dissipation [1] - 1.25 W [2] - 3 W [3] - 5 W [4] - 25 W single pulse; tp ≤ 1 ms Tamb ≤ 25 °C Tj junction temperature - 175 °C Tamb ambient temperature -55 175 °C Tstg storage temperature -65 175 °C [1] [2] [3] [4] Device mounted on an FR4 Printed-Circuit Board (PCB); single-sided copper; tin-plated and standard footprint. 2 Device mounted on an FR4 PCB; single-sided copper; tin-plated and mounting pad for collector 6 cm . Device mounted on an ceramic PCB; Al2O3, standard footprint. Power dissipation from junction to mounting base. aaa-010424 8 Ptot (W) 6 (1) 4 (2) 2 (3) 0 -75 25 125 Tamb (°C) 225 (1) Ceramic PCB, Al2O3, standard footprint (2) FR4 PCB, mounting pad for collector 6 cm (3) FR4 PCB, standard footprint Fig. 1. 2 Power derating curves PHPT60603NY Product data sheet All information provided in this document is subject to legal disclaimers. 10 January 2014 © Nexperia B.V. 2017. All rights reserved 3 / 15 PHPT60603NY Nexperia 60V, 3 A NPN high power bipolar transistor 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Rth(j-a) thermal resistance from junction to ambient Rth(j-sp) Conditions in free air Min Typ Max Unit [1] - - 115 K/W [2] - - 50 K/W [3] - - 30 K/W - - 6 K/W thermal resistance from junction to solder point [1] [2] [3] Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. aaa-010427 103 Zth(j-a) (K/W) 102 duty cycle = 1 0.75 0.33 0.2 10 1 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated mounting pad for collector 6 cm . Device mounted on an ceramic Printed-Circuit Board (PCB), Al2O3, standard footprint. 0.05 0.01 10-1 10-5 0.5 0.1 0.02 0.25 0 10-4 10-3 10-2 10-1 1 10 102 tp (s) 103 FR4 PCB, standard footprint Fig. 2. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PHPT60603NY Product data sheet All information provided in this document is subject to legal disclaimers. 10 January 2014 © Nexperia B.V. 2017. All rights reserved 4 / 15 PHPT60603NY Nexperia 60V, 3 A NPN high power bipolar transistor aaa-010428 102 duty cycle = 1 Zth(j-a) (K/W) 0.75 10 0.33 0.5 0.2 0.1 0.05 1 0.01 10-2 10-5 0.02 0.25 0 10-4 10-3 10-2 FR4 PCB, mounting pad for collector 6 cm Fig. 3. 10-1 1 10 102 tp (s) 103 2 Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PHPT60603NY Product data sheet All information provided in this document is subject to legal disclaimers. 10 January 2014 © Nexperia B.V. 2017. All rights reserved 5 / 15 PHPT60603NY Nexperia 60V, 3 A NPN high power bipolar transistor 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit ICBO collector-base cut-off current VCB = 48 V; IE = 0 A; Tamb = 25 °C - - 100 nA VCB = 48 V; IE = 0 A; Tj = 150 °C - - 50 µA ICES collector-emitter cut-off VCE = 48 V; VBE = 0 V; Tamb = 25 °C current - - 100 nA IEBO emitter-base cut-off current VEB = 7 V; IC = 0 A; Tamb = 25 °C - - 100 nA hFE DC current gain VCE = 2 V; IC = 500 mA; Tamb = 25 °C 200 400 - VCE = 2 V; IC = 1 A; tp ≤ 300 µs; 200 330 - 100 180 - 50 100 - - 70 120 mV IC = 3 A; IB = 300 mA; pulsed; - 180 270 mV δ ≤ 0.02 ; Tamb = 25 °C VCE = 2 V; IC = 2 A; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C VCE = 2 V; IC = 3 A; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C; pulsed VCEsat collector-emitter saturation voltage IC = 1 A; IB = 50 mA; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C; pulsed RCEsat collector-emitter saturation resistance tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C - 60 90 mΩ VBEsat base-emitter saturation IC = 1 A; IB = 100 mA; pulsed; voltage tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C - 0.86 1 V - 1 1.2 V VCE = 2 V; IC = 0.1 A; Tamb = 25 °C - 0.65 0.85 V IC = 2 A; IB = 200 mA; pulsed; tp ≤ 300 µs; δ ≤ 0.02 ; Tamb = 25 °C VBEon base-emitter turn-on voltage td delay time VCC = 12.5 V; IC = 1 A; IBon = 0.05 A; - 15 - ns tr rise time IBoff = -0.05 A; Tamb = 25 °C - 120 - ns ton turn-on time - 135 - ns ts storage time - 800 - ns tf fall time - 300 - ns toff turn-off time - 1100 - ns fT transition frequency - 140 - MHz - 17 - pF VCE = 10 V; IC = 100 mA; f = 100 MHz; Tamb = 25 °C Cc collector capacitance VCB = 10 V; IE = 0 A; ie = 0 A; f = 1 MHz; Tamb = 25 °C PHPT60603NY Product data sheet All information provided in this document is subject to legal disclaimers. 10 January 2014 © Nexperia B.V. 2017. All rights reserved 6 / 15 PHPT60603NY Nexperia 60V, 3 A NPN high power bipolar transistor aaa-010143 600 aaa-010176 5 IB = 50 mA IC (A) (1) hFE 45 40 4 35 (2) 400 30 3 25 20 15 (3) 200 10 2 5 1 0 10-1 1 10 102 0 103 104 IC (mA) 1 2 3 4 VCE (V) 5 Tamb = 25 °C VCE = 1 V (1) Tamb = 100 °C Fig. 5. (2) Tamb = 25 °C Collector current as a function of collectoremitter voltage; typical values (3) Tamb = −55 °C Fig. 4. 0 DC current gain as a function of collector current; typical values aaa-010144 1.6 aaa-010174 1.4 VBE (V) VBEsat (V) 1.2 1 0.8 (1) (1) (2) 0.6 (2) 0.4 (3) (3) 0 10-1 Fig. 6. 1 10 102 0.2 10-1 103 104 IC (mA) 1 10 VCE = −2 V IC/IB = 20 (1) Tamb = −55 °C (1) Tamb = −55 °C (2) Tamb = 25 °C (2) Tamb = 25 °C (3) Tamb = 100 °C (3) Tamb = 100 °C Base-emitter voltage as a function of collector current; typical values PHPT60603NY Product data sheet Fig. 7. 103 104 IC (mA) Base-emitter saturation voltage as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. 10 January 2014 102 © Nexperia B.V. 2017. All rights reserved 7 / 15 PHPT60603NY Nexperia 60V, 3 A NPN high power bipolar transistor aaa-010145 1 aaa-010173 10 VCEsat (V) VCEsat (V) (1) 10-1 1 (2) (1) (3) (2) 10-1 (3) 10-2 10-2 10-3 10-1 Fig. 8. 1 10 102 10-3 10-1 103 104 IC (mA) 1 10 IC/IB = 20 Tamb = 25 °C (1) Tamb = 100 °C (1) IC/IB = 50 (2) Tamb = 25 °C (2) IC/IB = 20 (3) Tamb = −55 °C (3) IC/IB = 10 Collector-emitter saturation resistance as a function of collector current; typical values aaa-010175 103 Fig. 9. 102 103 104 IC (mA) Collector-emitter saturation resistance as a function of collector current; typical values aaa-010177 103 RCEsat (Ω) RCEsat (Ω) 102 102 10 10 1 1 (1) 10-1 (2) 10-1 (1) (3) (2) 10-2 10-1 (3) 1 10 102 10-2 10-1 103 104 IC (mA) IC/IB = 20 1 (1) IC/IB = 50 (2) Tamb = 25 °C (2) IC/IB = 20 (3) Tamb = −55 °C (3) IC/IB = 10 Fig. 10. Collector-emitter saturation voltage as a function of collector current; typical values Product data sheet 102 103 104 IC (mA) Tamb = 25 °C (1) Tamb = 100 °C PHPT60603NY 10 Fig. 11. Collector-emitter saturation voltage as a function of collector current; typical values All information provided in this document is subject to legal disclaimers. 10 January 2014 © Nexperia B.V. 2017. All rights reserved 8 / 15 PHPT60603NY Nexperia 60V, 3 A NPN high power bipolar transistor 11. Test information - IB input pulse (idealized waveform) 90 % - I Bon (100 %) 10 % - I Boff output pulse (idealized waveform) - IC 90 % - I C (100 %) 10 % t td ts tr t on tf t off 006aaa266 Fig. 12. BISS transistor switching time definition VBB RB VCC RC Vo (probe) oscilloscope 450 Ω (probe) 450 Ω R2 VI oscilloscope DUT R1 mgd624 Fig. 13. Test circuit for switching times 11.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. PHPT60603NY Product data sheet All information provided in this document is subject to legal disclaimers. 10 January 2014 © Nexperia B.V. 2017. All rights reserved 9 / 15 PHPT60603NY Nexperia 60V, 3 A NPN high power bipolar transistor 12. Package outline Plastic single-ended surface-mounted package (LFPAK56; Power-SO8); 4 leads E A2 A SOT669 C c2 b2 E1 b3 L1 mounting base b4 D1 D H L2 1 2 3 e 4 w b A X c 1/2 e A (A3) A1 C q L detail X 0 y C θ 5 mm 8° scale 0° Dimensions (mm are the original dimensions) Unit(1) A A1 A2 A3 b b2 max 1.20 0.15 1.10 0.50 4.41 nom 0.25 min 1.01 0.00 0.95 0.35 3.62 mm c c2 D(1) D1(1) E(1) E1(1) b3 b4 2.2 0.9 0.25 0.30 4.10 4.20 5.0 3.3 2.0 0.7 0.19 0.24 3.80 4.8 3.1 e 1.27 H L L1 L2 6.2 0.85 1.3 1.3 5.8 0.40 0.8 0.8 Note 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. Outline version SOT669 References IEC JEDEC JEITA w y 0.25 0.1 sot669_po European projection Issue date 11-03-25 13-02-27 MO-235 Fig. 14. Package outline LFPAK56; Power-SO8 (SOT669) PHPT60603NY Product data sheet All information provided in this document is subject to legal disclaimers. 10 January 2014 © Nexperia B.V. 2017. All rights reserved 10 / 15 PHPT60603NY Nexperia 60V, 3 A NPN high power bipolar transistor 13. Soldering Footprint information for reflow soldering SOT669 4.7 4.2 0.9 (3×) 0.25 (2×) 0.25 (2×) 0.6 (4×) 3.45 0.6 (3×) 2 3.5 2.55 0.25 (2×) SR opening = Cu + 0.075 1.1 2.15 3.3 SP opening = Cu - 0.050 0.7 (4×) 1.27 3.81 solder lands solder paste 125 µm stencil solder resist occupied area Dimensions in mm sot669_fr Fig. 15. Reflow soldering footprint for LFPAK56; Power-SO8 (SOT669) PHPT60603NY Product data sheet All information provided in this document is subject to legal disclaimers. 10 January 2014 © Nexperia B.V. 2017. All rights reserved 11 / 15 PHPT60603NY Nexperia 60V, 3 A NPN high power bipolar transistor 14. Revision history Table 8. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes PHPT60603NY v.1 20131213 Product data sheet - - Modifications: • PHPT60603NY v.2 20140110 Product data sheet - PHPT60603NY v.1 PHPT60603NY Product data sheet editorial update All information provided in this document is subject to legal disclaimers. 10 January 2014 © Nexperia B.V. 2017. All rights reserved 12 / 15 PHPT60603NY Nexperia 60V, 3 A NPN high power bipolar transistor In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. 15. Legal information 15.1 Data sheet status Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. PHPT60603NY Product data sheet Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. 10 January 2014 © Nexperia B.V. 2017. All rights reserved 13 / 15 PHPT60603NY Nexperia 60V, 3 A NPN high power bipolar transistor No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. PHPT60603NY Product data sheet All information provided in this document is subject to legal disclaimers. 10 January 2014 © Nexperia B.V. 2017. All rights reserved 14 / 15 PHPT60603NY Nexperia 60V, 3 A NPN high power bipolar transistor 16. Contents 1 General description ............................................... 1 2 Features and benefits ............................................1 3 Applications ........................................................... 1 4 Quick reference data ............................................. 1 5 Pinning information ............................................... 2 6 Ordering information ............................................. 2 7 Marking ................................................................... 2 8 Limiting values .......................................................3 9 Thermal characteristics .........................................4 10 Characteristics ....................................................... 6 11 11.1 Test information ..................................................... 9 Quality information ............................................... 9 12 Package outline ................................................... 10 13 Soldering .............................................................. 11 14 Revision history ................................................... 12 15 15.1 15.2 15.3 15.4 Legal information .................................................13 Data sheet status ............................................... 13 Definitions ...........................................................13 Disclaimers .........................................................13 Trademarks ........................................................ 14 © Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 10 January 2014 PHPT60603NY Product data sheet All information provided in this document is subject to legal disclaimers. 10 January 2014 © Nexperia B.V. 2017. All rights reserved 15 / 15
PHPT60603NYX
物料型号:PHPT60603NY
器件简介: - 该晶体管是一款NPN高功率双极型晶体管,采用SOT669(LFPAK56)表面贴装器件(SMD)塑料封装。 - PNP互补型号为PHPT60603PY。
特点和优势: - 高热耗散能力,适用于高达175°C的高温应用。 - 与DPAK封装的晶体管相比,减少了印刷电路板(PCB)的要求。 - 由于产生的热量较少,因此具有高能效。 - 符合AECQ-101标准的认证。
应用: - 电源管理 - 负载开关 - 线性模式电压调节器 - 背光应用
引脚分配: - 引脚1、2、3:发射极(E) - 引脚4:基极(B) - 集电极(C)未单独列出,但通常与封装的中央部分连接。
参数特性: - 集电极-发射极电压(VCEO):最大60V - 集电极电流(Ic):最大3A - 峰值集电极电流(ICM):单脉冲,tp ≤ 1ms时,最大8A - 集电极-发射极饱和电阻(RcEsat):在Ic = 3A,Ib = 300mA,脉冲,ts ≤ 300us,Tamb = 25°C条件下,最小60mΩ,典型值90mΩ
功能详解: - 该晶体管具有高热耗散能力,适用于高温应用,并且由于其封装设计,可以减少PCB的要求。 - 它还具有高能效,因为它产生的热量较少,并且已经通过了AECQ-101认证,适合汽车应用。
应用信息: - 该晶体管适用于需要高功率和高温性能的应用,如电源管理、负载开关、线性模式电压调节器和背光应用。
封装信息: - 封装类型:LFPAK56;Power-SO8(SOT669) - 引脚数:4 - 封装材料:塑料
订购信息: - 型号:PHPT60603NY - 描述:LFPAK56;Power-SO8塑料单端表面贴装封装(LFPAK56;Power-SO8);4引脚 - 版本:SOT669
标记代码: - 型号:PHPT60603NY - 标记代码:0603NAB
限制值: - 集电极-基极电压(VCBO):最大60V - 集电极-发射极电压(VCEO):最大60V - 发射极-基极电压(VEBO):最大7V - 集电极电流(Ic):最大3A - 峰值集电极电流(ICM):单脉冲,tp ≤ 1ms时,最大8A - 基极电流(Ib):最大0.5A - 总功耗(Ptot):在Tamb ≤ 25°C时,最大1.25W(单面铜PCB,锡镀和标准足迹),最大3W(单面铜PCB,锡镀和集电极安装垫6cm²),最大5W(陶瓷PCB,Al2O3,标准足迹),最大25W(从结到安装基座的功耗) - 结温(Tj):最大175°C - 环境温度(Tamb):-55°C至175°C - 存储温度(Tstg):-65°C至175°C
热特性: - 从结到环境的热阻(Rth(-a)):在自由空气中,最小115K/W,典型值50K/W(单面铜PCB,锡镀和集电极安装垫6cm²),典型值30K/W(陶瓷PCB,Al2O3,标准足迹) - 从结到焊点的热阻(Rthj-sp):6K/W
特性: - 集电极-基极截止电流(CBO):在VcB = 48V,I=0A,Tamb = 25°C条件下,最大100nA - 发射极-基极截止电流(ICES):在VcE=48V,VBE=0V,Tamb=25°C条件下,最大100nA - 发射极-基极截止电流(lEBO):在VEB =7V,Ic=0A,Tamb = 25°C条件下,最大100nA - DC电流增益(hFE):在VcE=2V,Ic= 500 mA,Tamb = 25°C条件下,最小200,典型值400 - 集电极-发射极饱和电压(VcEsat):在Ic = 1A,Ib = 50 mA,ts ≤ 300us,Tamb=25°C,脉冲条件下,最小70mV,典型值120mV - 集电极-发射极饱和电阻(RcEsat):最小60mΩ,典型值90mΩ - 基极-发射极饱和电压(VBEsat):在Ic=1A,Ib=100 mA,脉冲,ts ≤ 300us,Tamb = 25°C条件下,最小0.86V,典型值1V - 基极-发射极开启电压(VBEon):在VcE=2V,Ic=0.1A,Tamb=25°C条件下,最小0.65V,典型值0.85V - 延迟时间(t):在Vcc= 12.5V,Ic=1A,Ib on =0.05 A,Ib off =-0.05A,Tamb=25°C条件下,最小15ns - 上升时间(tr):最小120ns - 存储时间(ts):最小800ns - 下降时间(tf):最小300ns - 关闭时间(toff):最小1100ns - 过渡频率(fT):在Vce=10V,Ic=100mA,f=100MHz,Tamb=25°C条件下,最小140MHz - 集电极电容(Cc):在Vc8=10V,e=0A,i=0A,f=1 MHz,Tamb=25°C条件下,最小17pF
测试信息: - 提供了BISS晶体管开关时间定义的图表和测试电路。
质量信息: - 该产品已根据汽车电子委员会(AEC)标准Q101进行资格认证,适用于汽车应用。
封装轮廓: - 提供了LFPAK56;Power-SO8(SOT669)的封装轮廓图。
焊接: - 提供了LFPAK56;Power-SO8(SOT669)的回流焊接足迹信息。
修订历史: - 提供了数据表的修订历史。
法律信息: - 提供了数据表状态、定义、免责声明、出口控制、翻译和商标等法律信息。
PHPT60603NYX 价格&库存
很抱歉,暂时无法提供与“PHPT60603NYX”相匹配的价格&库存,您可以联系我们找货
PHPT60603NYX
  • 10+19.21420
  • 200+11.46160
  • 500+8.02310
  • 1500+5.73080
  • 3000+5.44420
  • 15000+5.04310
库存:508
PHPT60603NYX
