Approval sheet
RFBLN 2012 (0805) Series – RoHS Compliance
MULTILAYER CERAMIC BALUN TRANSFORMER
Halogens Free Product
2.4 GHz ISM Band Working Frequency
P/N: RFBLN2012090A1T
*Contents in this sheet are subject to change without prior notice.
Page 1 of 7
ASC_RFBLN2012090A1T_V02
May. 2012
Approval sheet
FEATURES
1.
Multilayer LTCC ( Low Temperature Cofired Ceramics ) Technology
2.
Miniatured Size 2.00 x 1.25 x 0.95 mm
3.
Low Insertion Loss reduces power consumption
4.
Low inband Amplitude and Phase imbalance enable high performance wireless system operation.
5.
Enable for DC Biasing of PA or Mixer
6.
Suitable for 2.45 GHz Working Frequency Operation
7.
Special Balance/ Unbalance impedance is upon requested.
3
APPLICATIONS
1.
2.4GHz ISM Band RF Application
2.
Bluetooth, Wireless LAN, HomeRF
CONSTRUCTION
P1
P2
P3
P6
PIN
Connection
PIN
Connection
P1
Unbalance Port
P4
Balance Port
P2
DC or GND
P5
GND
P3
Balance Port
P6
NC
P5
P4
Fig 1. Outline of 2.4GHz Balun
DESCRIPTION
Walsin Technology Corporation develops a new ceramic Balun Transformer specified for 2.45 GHz ISM Band application,
TM
as shown in fig-1. Both of Wireless LAN IEEE 802.11b, and Bluetooth typically located on this unlicensed frequency band
which range covers from 2.4GHz to 2.5GHz (2.4835GHz). To fulfil the in-band and out-band frequency requirements, this
ceramic Balun has been designed to a low Amplitude imbalance and Phase imbalance, wide bandwidth (-10dB) as well as
low insertion loss characteristics through Walsin’s advanced LTCC (Low Temperature Co-fired Ceramic) technology and
superior product design via 3D EM Simulation Skill.
3
This ceramic Balun has a rectangular ceramic body with a tiny dimension of 2.00 x 1.25 x 0.95 mm future meet the SMT
automation and miniaturization requirements on modern portable devices.
DIMENSIONS
Figure
Page 2 of 7
Symbol
Dimension
L
2.00 ± 0.15 mm
W
1.25 ± 0.15 mm
T
0.95 ± 0.10 mm
A
0.20 ± 0.20 mm
B
0.30 ± 0.20 mm
C
0.35 ± 0.20 mm
D
0.65 ± 0.20 mm
E
0.25 ± 0.15 mm
May. 2012
Approval sheet
ELECTRICAL CHARACTERISTICS
RFBLN2012090A1T
Specification
Frequency range
2450 ± 50 MHz
Insertion Loss (dB)
1.0
Impedance ( Ω ) Unbalanced
50
Impedance ( Ω ) Balanced
100
Return Loss (dB) Min.
10
Inband Amplitude imbalance (dB) Max.
2.0
Inband Phase imbalance (degree)
180˚ ± 10˚
Operation Temperature Range
-40°C ~ +85°C
Typical Electrical Chart
(1). Amplitude balance
Remark: -4.1dB which should include 0.4dB microstrip line loss
(2). Phase balance
SOLDER LAND PATTERN
Figure
Symbol
Dimension (mm)
A
1.00 ± 0.10
B
0.35 ± 0.10
C
0.30 ± 0.10
D
0.65 ± 0.10
E
0.80 ± 0.10
Line width to be design to match 50Ω
Ω characteristic impedance, depending on PCB
material and thickness
Page 3 of 7
May. 2012
Approval sheet
RELIABILITY TEST
Test item
Solderability
JIS C 0050-4.6
JESD22-B102D
Test condition / Test method
Specification
*Solder bath temperature:235 ± 5°C
At least 95% of a surface of each terminal
*Immersion time:2 ± 0.5 sec
electrode must be covered by fresh solder.
*Solder:Sn3Ag0.5Cu for lead-free
Leaching
*Solder bath temperature:260 ± 5°C
Loss of metallization on the edges of each
of metallization)
*Leaching immersion time:30 ± 0.5 sec
electrode shall not exceed 25%.
IEC 60068-2-58
*Solder : SN63A
(Resistance to dissolution
Resistance to soldering heat
*Preheating temperature:120~150℃,
No mechanical damage.
JIS C 0050-5.4
1 minute.
Samples shall satisfy electrical specification
*Solder temperature:270±5°C
after test.
*Immersion time:10±1 sec
Measurement to be made after keeping at
room temperature for 24±2 hrs
Drop Test
JIS C 0044
*Height:75 cm
*Test Surface:Rigid surface of concrete
after test.
or steel.
*Times:6 surfaces for each units;2
times for each side.
Adhesive Strength
of Termination
JIS C 0051- 7.4.3
Bending test
JIS C 0051- 7.4.1
*Pressurizing force:
5N(≦0603);10N(>0603)
No remarkable damage or removal of the
termination.
*Test time:10±1 sec
The middle part of substrate shall be
pressurized by means of the pressurizing
rod at a rate of about 1 mm/s per second
after test.
until the deflection becomes 1mm/s and
then pressure shall be maintained for 5±1
sec.
room temperature for 24±2 hours
Page 4 of 7
May. 2012
Approval sheet
Temperature cycle
JIS C 0025
1.
30±3 minutes at -40°C±3°C,
2.
10~15 minutes at room temperature,
3.
30±3 minutes at +85°C±3°C,
4.
specification after test.
Total 100 continuous cycles
Vibration
JIS C 0040
*Frequency:10Hz~55Hz~10Hz(1min)
*Total amplitude:1.5mm
*Test times:6hrs.(Two hrs each in three
after test.
mutually perpendicular directions)
High temperature
JIS C 0021
*Temperature:85°C±2°C
*Test duration:1000+24/-0 hours
after test.
Humidity
(steady conditions)
*Humidity:90% to 95% R.H.
*Temperature:40±2°C
JIS C 0022
*Time:1000+24/-0 hrs.
after test.
※ 500hrs measuring the first data then
1000hrs data
Low temperature
JIS C 0020
*Temperature:-40°C±2°C
after test.
Page 5 of 7
May. 2012
Approval sheet
SOLDERING CONDITION
Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 2,
Fig 2. Infrared soldering profile
ORDERING CODE
RF
Walsin
RF device
BLN
Product
Code
BLN : BALUN
201209
Dimension code
Unit of
dimension
Per 2 digits of
Length, Width,
Thickness :
0 : 0.1 mm
A
1
T
Application
Specification
Packing
A : 2.4GHZ ISM
Band
Design Code
T : 7” Reeled
X = 1: 50/ 100
1 : 1.0 mm
e.g. :
201209 =
Length 20,
Width 12,
Thickness 09
Minimum Ordering Quantity: 2000 pcs per reel.
PACKAGING
Plastic Tape specifications (unit :mm)
Index
Dimension (mm)
Index
Dimension (mm)
Page 6 of 7
Ao
Bo
ΦD
T
W
1.52 ± 0.10
2.35 ± 0.10
1.55 ± 0.10
1.12 ± 0.10
8.0 ± 0.30
E
F
Po
P1
P2
1.75 ± 0.10
3.50 ± 0.05
4.00 ± 0.10
4.00 ± 0.10
2.00 ± 0.10
May. 2012
Approval sheet
Reel dimensions
C
Index
Dimension (mm)
B
A
A
B
C
Φ178
Φ60.0
Φ13.5
Typing Quantity: 2000 pieces per 7” reel
CAUTION OF HANDLING
Limitation of Applications
Please contact us before using our products for the applications listed below which require especially high reliability for
the prevention of defects, which might directly cause damage to the third party’s life, body or property.
(1)
Aircraft equipment
(2)
Aerospace equipment
(3)
Undersea equipment
(4)
Medical equipment
(5)
Disaster prevention / crime prevention equipment
(6)
Traffic signal equipment
(7)
Transportation equipment (vehicles, trains, ships, etc.)
(8)
Applications of similar complexity and /or reliability requirements to the applications listed in the above.
Storage condition
(1)
Products should be used in 6 months from the day of WALSIN outgoing inspection, which can be
confirmed.
(2)
Storage environment condition.
Products should be storage in the warehouse on the following conditions.
Temperature
: -10 to +40°C
Humidity
: 30 to 70% relative humidity
Don’t keep products in corrosive gases such as sulfur. Chlorine gas or acid or it may cause oxidization of
electrode, resulting in poor solderability.
Products should be storage on the palette for the prevention of the influence from humidity, dust and son on.
Products should be storage in the warehouse without heat shock, vibration, direct sunlight and so on.
Products should be storage under the airtight packaged condition.
Page 7 of 7
May. 2012
