AT-104V
AT-104V
    HRS(广濑)
    SMA单排模块
    LOW POWER ATTENUATOR 4DB
AT-104V 数据手册
ITS-P-11026W AT Series Fixed Attenuators Up to 2 W Power  Features 1. SMA connector type 2. Excellent high frequency characteristics 3. Stable performance under the conditions of vibration and changes in temperature and humidity 4. Wide varieties of attenuation levels from 1 to 20 dB 5. Conforming to MIL standard 6. RoHS compliant  Dimensions SMA Type (Plug - Jack) AT-100V *All dimensions are in millimeters.  Wide Varieties Series (CL354) Connector Frequency (GHz) Power (W) (at 25 ˚C) Attenuation (dB) AT-100V SMA DC-18 2 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 20  Applicable MIL Standard Vibration Test MIL-STD-202E Method204C Test D Shock Test MIL-STD-202E Method213B Test A Humidity Test MIL-STD-202E Method106D Temperature Shock Test MIL-STD-202E Method107D Test A Salt Splay Test MIL-STD-202E Method101D Test B Specifications herein are subject to change without notice. Contact Hirose for latest specifications, drawings or availabilities. Issued: Dec. 15, 2011
AT-104V 价格&库存
很抱歉,暂时无法提供与“AT-104V”相匹配的价格&库存,您可以联系我们找货
