AT-130V
AT-130V
    HRS(广濑)
    SMA单排模块
    LOW POWER ATTENUATOR 30DB
AT-130V 数据手册
APPLICABLE STANDARD RATING OPERATING TEMPERATURE RANGE -65℃ TO +125℃ POWER 2(AT 25℃) W CW STORAGE TEMPERATURE RANGE CHARACTERISTIC IMPEDANCE -40℃ TO +85℃ 50Ω ( DC TO 8 GHz) Mar.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents. 1(AT 65℃) W CW OPERATING RELATIVE HUMIDITY USED CONNECTOR 95% MAX HRM-P , HRM-J SPECIFICATIONS ITEM TEST METHOD REQUIREMENTS QT AT X X X X X X X X CONSTRUCTION GENERAL EXAMINATION VISUALLY AND BY MEASURING INSTRUMENT. MARKING CONFIRMED VISUALLY. ACCORDING TO DRAWING. ELECTRIC CHARACTERISTICS MUST BE UNDER THE STD.VALUE AT FREQENCY DC TO 4.0 GHz MUST BE UNDER THE STD.VALUE AT FREQENCY 4.0 TO 8.0 GHz MUST BE UNDER THE STD.VALUE AT FREQENCY DC TO 8.0 GHz MUST BE UNDER THE STD.VALUE AT FREQENCY TO GHz V.S.W.R. ATTENUATION ISOLATION INSULATION RESISTANCE MAXIMUM OF 1.15 MAXIMUM OF 1.20 28.8 31.2 dB. MINIIMUM OF MUST BE OVER STANDARD VALUE AT DC V. VOLTAGE PROOF TO - - dB. MINIMUM OF - - MΩ - - - - V AC FOR 1 min.CURRENT LEAKAGE 2mA MAX. NO FLASHOVER OR BREAKDOWN. RESISTANCE VALUE MEASURE THE RESISTANCE VALUE AT DC1V. Ω± % MECHANICAL CHARACTERISTICS ①NO WITHDRAWAL AND BREAKAGE OF CABLE. ②NO BREAKAGE OF CLAMP. APPLYING A PULL FORCE THE CABLE AXIALLY CABLE CLAMP AT N MAX. ROBUSTNESS (AGAINST CABLE PULL) VIBRATION FREQUENCY 10 TO 2000 Hz, SINGLE 2 AMPLITUDE 0.75 mm, 98 m/s AT 4 HOURS, FOR 3 DIRECTIONS. SHOCK 490 m/s 2 AT 10 TIMES FOR 3 DIRECTIONS. - - NO DAMAGE, CRACK, AND LOOSENESS, OF PARTS. X - NO DAMAGE, CRACK, AND LOOSENESS, OF PARTS. X - - - X - X - ENVIRONMENTAL CHARACTERISTICS EXPOSE TO ℃, ~ %, h. ①ELECTRICAL CHARACTERISTIC THEN LEAVE IT FOR ONE HOUR OR TWO IN THE SHALL BE MET. AMBIENT TEMPERATURE AND HUMIDITY. ②NO DAMAGE, CRACK, AND LOOSENESS, OF PARTS. -65 → - → +125 → - ℃ TEMPERATURE NO DAMAGE, CRACK, AND LOOSENESS, TIME 30 → - → 30 → - min TEST 5 CYCLES AND LEAVE IT FOR ONE HOUR OF PARTS. OR TWO. EXPOSE TO 5 % NO CORROSION WHICH AFFECTS THE SALT WATER SPRAY FOR 48 HOURS. OPERATION OF COMPONENT. DAMP HEAT (STEADY STATE) RAPID CHANGE OF TEMPERATURE SALT SPRAY (CORROSION) COUNT DESCRIPTION OF REVISIONS DESIGNED CHECKED DATE △ 0 REMARK RoHS COMPLIANT Unless otherwise specified, refer to IEC 60512. Note QT:Qualification Test AT:Assurance Test X:Applicable Test APPROVED KY.SHIMIZU 15.10.28 CHECKED TO.KATAYAMA 15.10.28 DESIGNED YI.FUNADA 15.10.28 DRAWN YI.FUNADA 15.10.28 DRAWING NO. ELC4-181142-00 SPECIFICATION SHEET PART NO. AT-130V HIROSE ELECTRIC CO., LTD. CODE NO. CL354-0279-6-00 0 △ 1/1 FORM HD0011-2-1
AT-130V 价格&库存
很抱歉,暂时无法提供与“AT-130V”相匹配的价格&库存,您可以联系我们找货
