AT-110(40)
AT-110(40)
    HRS(广濑)
    SMA单排模块
    LOW POWER ATTENUATOR 10DB
AT-110(40) 数据手册
MKT-E-11026F_1 AT Series Fixed Attenuators Up to 2W Power  Features 1. SMA, N, BNC, TNC, connector types are available. 2. Excellent high frequency characteristics 3. Stable performance under the conditions of vibration and changes in temperature and humidity 4. Wide varieties of attenuation levels from 0.5-30dB 5. Conforming to MIL standard 6. RoHS compliant  Dimensions BNC Type AT-500 N Type AT-400 TNC Type AT-600 26.3 (28.3)* SMA Type (Plug - Jack) AT-100V *() indicates dimension for AT-130V. All dimensions are in millimeters.  Wide Varieties Plug - Jack Series (CL354) Connector Frequency (GHz) Power (W) (at 25˚C) AT-100V SMA DC-18 2 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 20, 30 AT-400 N DC-13 2 0.5, 1, 2, 3, 5, 6, 10, 13, 20, 30 AT-500 BNC DC-4 2 1, 2, 3, 5, 6, 9, 10, 14, 20 AT-600 TNC DC-6 2 1, 3, 4, 6, 7, 10, 20 SMA DC-18 2 3, 6, 10, 20 SMA DC-18 2 3, 6, 10, 20 Attenuation (dB) Plug – Plug AT-200 Jack – Jack AT-300 Specifications herein are subject to change without notice. Contact Hirose for the latest specifications, drawings and availabilities. Issued: Jun. 15 , 2016 © 2016 HIROSE ELECTRIC CO., LTD. All rights reserved.
AT-110(40)
物料型号:HRS AT系列
器件简介:该系列衰减器提供高达2W功率的固定衰减,适用于SMA、N型、BNC、TNC等连接器类型。
引脚分配:文档中未提供引脚分配信息。
参数特性: - 频率范围:DC至18GHz(AT-100V、AT-200、AT-300)、DC至13GHz(AT-400)、DC至4GHz(AT-500)、DC至6GHz(AT-600)。 - 功率容量:所有型号均支持2W功率。 - 衰减级别:提供从0.5dB至30dB的多种衰减级别。
功能详解:文档中未提供详细的功能解释。
应用信息:文档中未提供应用信息
封装信息:提供了SMA、N型、BNC、TNC型衰减器的尺寸信息,例如SMA型(插头-插座)的尺寸为26.3(28.3)mm等。
AT-110(40) 价格&库存
很抱歉,暂时无法提供与“AT-110(40)”相匹配的价格&库存,您可以联系我们找货
AT-110(40)
  • 1+1898.680901+246.60810
  • 20+1237.5383020+160.73630
  • 60+1200.3718060+155.90900
  • 100+1140.44260100+148.12520
库存:13
