AT-204(40)
AT-204(40)
    HRS(广濑)
    SMA单排模块
    LOW POWER ATTENUATOR 4DB
AT-204(40) 数据手册
Fixed Attenuators (SMA Type) AT-100, AT-200, and AT-300 Series ■Features 1.Abundant Variations of Attenuators Attenuation amounts are available in abundant variations from 0 to 4 dB in 0.5 dB steps, from 4 to 10 dB in 1 dB steps, and in 12, 13, 14, 15, 20, 26 and 30 dB so that levels can be finely adjusted. 2.SMA Type Feb.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. AT-103(40) The coupling portions are available in all types of plug and jack combinations and stainless steel is used for the external cladding to form a small and durable structure. AT-206(40) 3.High Degree of Matching and High Reliability AT-310(40) The design of the attenuation element uses a distributed constant circuit and metal film resistor. A high degree of matching is achieved as indicated in the V.S.W.R. of the appended tables. Furthermore, these attenuators show stable characteristics for environments of varying temperature, humidity, and gases. ■Product Specifications Ratings Rated frequency range (Note) Characteristic impedance Maximum Input Power DC to 18.0 GHz 50 ohms 1W Operating temperature range Operating relative humidity –10ç to +65ç 95% Max. Note: The frequency range will differ depending on the model. Item Standard 1.Vibration No electrical discontinuity of 1 μs or more No damage, cracks, or parts dislocation 2.Shock 3.Temperature cycle No damage, cracks, or parts dislocation Conditions Frequency of 10 to 2000 Hz, overall amplitude of 1.52 mm, acceleration of 98 m/s2 for 2 hours in each of 3 directions Acceleration of 490 m/s2, sine half-wave waveform, 3 cycles in each of the 3 axis Temperature: -55ç → +15ç to +35ç → +85ç → +15ç to +35ç Time: 30 → 15 max. → 30 → 15 max. (Minutes) 5 cycles ●The test method conforms to MIL-STD-202. ■Materials ■Ordering Information Part Material Finish Connector Body Stainless steel Passivated Insulator PTFE ---------- Male contacts Beryllium copper Gold plating Female contacts Beryllium copper Gold plating Attenuation element Metal film ---------- AT - 1 00-(0) (40) 1 2 3 1 AT: Indicates a fixed attenuator 2 Indicates the Series Name (Coupling Portion) 1: SMA plug - jack 2: SMA plug - plug 3: SMA jack - jack 4 3 Attenuation (Example) 01 : 1dB 06 : 6dB 00-(0) : 0dB (Through) 00-(0.5) : 0.5dB 00-(3.5) : 3.5dB 4 (40): RoHS compliant 69 AT-100, AT-200, and AT-300 Series●Fixed Attenuators (SMA Type) ■Specifications Part Number Attenuation (dB) V.S.W.R.(Max) DC~12.4GHz 12.4~18GHz DC~4GHz Feb.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. AT-100-(0)(40) +0.5 0000 0 +1.0 0000 0 4~12.4GHz 2.4~18GHz Power (W) Connectors Weight (g) 1.15 1.20 1.30 1 HRM-J • P 8 AT-100-(0.5)(40) 0.5±0.5 +1.0 0.5000 _0.5 1.15 1.20 1.30 1 HRM-J • P 8 AT-101(40) 0.1±0.5 1±1.00 1.15 1.20 1.30 1 HRM-J • P 8 AT-100-(1.5)(40) 1.5±0.5 1.5±1.00 1.15 1.20 1.30 1 HRM-J • P 8 AT-102(40) 0.2±0.5 2±1.00 1.15 1.20 1.30 1 HRM-J • P 8 AT-100-(2.5)(40) 2.5±0.5 2.5±1.00 1.15 1.20 1.30 1 HRM-J • P 8 AT-103(40) 0.3±0.5 3±1.00 1.15 1.20 1.30 1 HRM-J • P 8 AT-100-(3.5)(40) 3.5±0.5 3.5±1.00 1.15 1.20 1.30 1 HRM-J • P 8 AT-104(40) 0.4±0.5 4±1.00 1.15 1.20 1.30 1 HRM-J • P 8 AT-105(40) 0.5±0.7 5±1.20 1.15 1.20 1.30 1 HRM-J • P 8 AT-106(40) 0.6±0.7 6±1.20 1.15 1.20 1.30 1 HRM-J • P 8 AT-107(40) 0.7±0.7 7±1.20 1.15 1.20 1.30 1 HRM-J • P 8 AT-108(40) 0.8±0.7 8±1.20 1.15 1.20 1.30 1 HRM-J • P 8 AT-109(40) 0.9±1.0 9±1.25 1.15 1.20 1.30 1 HRM-J • P 8 AT-110(40) 10±1.0 10±1.25 1.15 1.20 1.30 1 HRM-J • P 8 AT-112(40) 12±1.0 12±1.25 1.15 1.20 1.30 1 HRM-J • P 8 AT-113(40) 13±1.0 13±1.25 1.15 1.20 1.30 1 HRM-J • P 8 AT-114(40) 14±1.2 14±1.30 1.15 1.20 1.30 1 HRM-J • P 8 AT-115(40) 15±1.2 15±1.30 1.15 1.20 1.30 1 HRM-J • P 8 AT-120(40) 20±1.2 20±1.30 1.15 1.20 1.30 1 HRM-J • P 8 AT-203(40) 0.3±0.5 3±1.00 1.15 1.20 1.30 1 HRM-P • P 9 AT-206(40) 0.6±0.7 6±1.20 1.15 1.20 1.30 1 HRM-P • P 9 AT-210(40) 10±1.0 10±1.25 1.15 1.20 1.30 1 HRM-P • P 9 AT-220(40) 20±1.2 20±1.30 1.15 1.20 1.30 1 HRM-P • P 9 AT-303(40) 0.3±0.5 3±1.00 1.15 1.20 1.30 1 HRM-J • J 7 AT-306(40) 0.6±0.7 6±1.20 1.15 1.20 1.30 1 HRM-J • J 7 AT-310(40) 10±1.0 10±1.250 1.15 1.20 1.30 1 HRM-J • J 7 AT-320(40) 20±1.2 20±1.30 1.15 1.20 1.30 1 HRM-J • J 7 Power (W) Connectors Weight (g) RoHS YES Part Number Attenuation (dB) V.S.W.R.(Max) DC~8GHz DC~4GHz 4~8GHz AT-126(40) 26±1.0 1.15 1.20 1 HRM-J • P 8 AT-130(40) 30±1.2 1.15 1.20 1 HRM-J • P 8 RoHS YES 70 AT-100, AT-200, and AT-300 Series●Fixed Attenuators (SMA Type) ■External Dimensions Feb.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. AT-100 Type AT-126,130 Type AT-300 Type AT-200 Type ■Typical Data AT-103(40) AT-120(40) AT-130(40) AT-206(40) AT-310(40) Input Power Characteristics 71
AT-204(40) 价格&库存
很抱歉,暂时无法提供与“AT-204(40)”相匹配的价格&库存,您可以联系我们找货
