AT-430
AT-430
    HRS(广濑)
    LOW POWER ATTENUATOR 30DB
AT-430 数据手册
Fixed Attenuators (N,BNC,TNC) AT-400, AT-500, and AT-600 Series ■Features 1.Connector Coupling Portion Variations Coupling Portion HRS Series Name N Type Plug - Jackπ AT-400 Series BNC Type Plug - Jack AT-500 Series TNC Type Plug - Jack AT-600 Series πCan also be mated with an S type connector. Feb.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2.Small Size and Economical Value engineering has been liberally applied to the design and construction to make these attenuators small and very economical. 3.High Reliability AT-403(40) AT-503(40) AT-603(40) These attenuators show stable characteristics for environments of varying temperature, humidity, and gases. ■Product Specifications Frequency range Ratings Characteristic impedance Maximum Input Power Item AT-400 Series DC ~ 13 GHz AT-500 Series DC ~ 4 GHz Operating temperature range AT-600 Series DC ~ 6 GHz Operating relative humidity 50 ohms 2W Standard Conditions Frequency of 10 to 2000 Hz, overall amplitude of 1.52 mm, acceleration of 98 m/s2 for 2 hours in each of 3 directions 1.Vibration No electrical discontinuity of 1 μs or more 2.Shock –10ç to +65ç 95% Max. No damage, cracks, or parts dislocation Acceleration of 490 m/s2, sine half-wave waveform, 3 cycles in each of the 3 axis Temperature: -55ç → +15ç to +35ç → +85ç → +15ç to +35ç Time: 30 → 15 max. → 30 → 15 max. (Minutes) 100 cycles 3.Temperature cycle No damage, cracks, or parts dislocation ●The test method conforms to MIL-STD-202. ■Materials Part ■Ordering Information Material Finish Connector Body Brass Nickel plating Insulator PTFE ---------- Male contacts Brass Gold plating Female contacts Beryllium copper Gold plating Attenuation element Metal film ---------- AT - 4 01 (40) 1 2 3 4 1 AT: Indicates a fixed attenuator 2 Indicates the Series Name (Coupling Portion) 4: (Example) 01 : 1dB 06 : 6dB N plug - jack 5: BNC plug - jack 6: TNC plug - jack 72 3 Attenuation 4 (40): RoHS compliant AT-400, AT-500, and AT-600 Series●Fixed Attenuators (N,BNC,TNC) ■Specifications Part Number AT-401(40) AT-402(40) Feb.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. AT-403(40) AT-406(40) AT-410(40) AT-420(40) AT-501 AT-503(40) AT-506(40) AT-510(40) AT-520(40) AT-601(40) AT-603(40) AT-606(40) AT-610(40) AT-620(40) Frequency Range V.S.W.R.(Max) (MHz) Attenuation (dB) DC~2000 1.15 01±0.3 2000~4000 1.20 01 +0.5 _0.3 4000~13000 1.25 01 +0.6 _0.3 DC~2000 1.15 02±0.3 2000~4000 1.20 02 +0.5 _0.3 4000~13000 1.25 02 +0.6 _0.3 DC~2000 1.15 03±0.3 2000~4000 1.20 03 +0.5 _0.3 4000~13000 1.25 03 +0.7 _0.3 DC~2000 1.15 06±0.3 2000~4000 1.20 06 +0.5 _0.3 4000~13000 1.25 06 +0.7 _0.3 DC~2000 1.15 10±0.5 2000~4000 1.20 10 +0.8 _0.5 4000~13000 1.25 10 +1.0 _0.5 DC~2000 1.15 20±0.5 2000~4000 1.20 20 +0.8 _0.5 4000~13000 1.25 20 +1.2 _0.7 DC~1000 1.15 01±0.3 1000~2000 1.25 01±0.3 2000~4000 1.25 01 DC~1000 1.15 03±0.3 1000~2000 1.25 03±0.3 2000~4000 1.25 03 DC~1000 1.15 06±0.3 1000~2000 1.25 06±0.3 2000~4000 1.25 06 Power (W)˛ Connectors Weight (g) 2 N-P · J 77 RoHS +0.5 _0.3 +0.5 _0.3 YES 2 BNC-P · J 25 2 TNC-P · J 29 +0.5 _0.3 DC~1000 1.15 10±0.5 1000~2000 1.25 10±0.5 2000~4000 1.25 10 DC~1000 1.15 20±0.5 1000~2000 1.25 20±0.5 2000~4000 1.25 20 +0.8 _0.5 +0.8 _0.5 DC~1000 1.15 01±0.3 1000~2000 1.20 01±0.3 2000~6000 1.35 01 +0.5 _0.3 DC~1000 1.15 03±0.3 1000~2000 1.20 03±0.3 2000~6000 1.35 03 DC~1000 1.15 06±0.3 1000~2000 1.20 06±0.3 2000~6000 1.35 06 +0.5 _0.3 +0.7 _0.3 DC~1000 1.15 10±0.5 1000~2000 1.20 10±0.5 2000~6000 1.35 10 DC~1000 1.15 20±0.5 1000~2000 1.20 20±0.5 2000~6000 1.35 20 +1.0 _0.5 +1.0 _0.5 73 AT-400, AT-500, and AT-600 Series●Fixed Attenuators (N,BNC,TNC) ■External Dimensions Feb.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. AT-400 Type AT-500 Type AT-600 Type ■Typical Data AT-420(40) ATTENUATION(dB) AT-403(40) V.S.W.R. 1.3 -19.0 -19.5 -20.0 -20.5 -21.0 -21.5 1.2 1.1 1.0 0 2 4 6 8 FREQUENCY[GHz] 10 12 0 AT-506(40) 1.1 1.0 1 2 FREQUENCY[GHz] 3 4 ATTENUATION(dB) V.S.W.R. 1.2 2 3 4 FREQUENCY[GHz] 5 6 ATTENUATION(dB) V.S.W.R. 10 12 13 0 2 4 6 8 FREQUENCY[GHz] 10 12 13 AT-406(40) 1.4 1.3 1.2 1.1 1.0 1 6 8 FREQUENCY[GHz] -9.0 -9.5 -10.0 -10.5 -11.0 -11.5 AT-610(40) 0 4 AT-410(40) 1.3 0 2 -5.5 -6.0 -6.5 -7.0 -7.5 -8.0 0 2 4 6 8 FREQUENCY[GHz] 4 6 8 FREQUENCY[GHz] 10 12 13 ATTENUATION(dB) AT-403(40) 74 -2.5 -3.0 -3.5 -4.0 0 2 10 12 13
AT-430 价格&库存
很抱歉,暂时无法提供与“AT-430”相匹配的价格&库存,您可以联系我们找货
