HV-AT(6)-PJ
HV-AT(6)-PJ
    HRS(广濑)
    V连接器直插式模块
    CONN HV ATTENUATOR FIXED 6 DB
HV-AT(6)-PJ 数据手册
IEC Standard Compliant 1.85mm coaxial connectors 1.85mm Series Compatible with 67GHz configurations Features 1. IEC Standard Compliant 1.85mm coaxial connector (IEC 61169-32) 2. Compatible with the frequency range of up to 67GHz Feb.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3. RoHS2 compliant Applications Optical transmission devices, Measuring for data transmission, Radio communication equipment, Measuring instruments etc. Product Specifications Nominal characteristic impedance Ratings Rated frequency Items Operating Temperature -55ç to +105ç (95% RH or less) Range Storage Temperature DC to 65GHz -55ç to +50ç (95% RH or less) Range 50ø Measured at less than 100mA 2. Insulation resistance Specifications Center : Less than 4mø External : Less than 4mø 500Mø min. 3. Withstanding voltage No flashover or breakdown 300V AC for 1 minute 4. Voltage standing wave ratio V.S.W.R. : Less than 1.5 DC to 65GHz 1. Contact resistance Conditions Measured at 250V DC Contact resistance at center : Less than 6mø External : Less than 6mø No broken, cracked, or loose parts No electrical discontinuity for more than 6. Vibration resistance 1µs. No broken, cracked, or loose parts No electrical discontinuity for more than 7. Shock resistance 1µs. No broken, cracked, or loose parts Insulation resistance : More than 100Mø 8. Moisture resistance of (in a high humidity environment) temperature/humidity Insulation resistance : More than 500Mø cycle (in a dry environment) No broken, cracked or loose parts 5. Mating Cycles 9. Temperature cycle No broken, cracked or loose parts 10. Salt spray No considerable corrosion 500 cycles Frequency : 10 to 2000Hz, half amplitude : 0.75mm, Acceleration : 196m/s2, 12 cycles in each of 3 axis directions Acceleration : 980m/s2, duration : 6ms, Wave form : half-sine wave, 3 times in each of 3 directions Left for 10 cycles (240 hours) in an environment with the temperature ranging from -10 to 65°C and the humidity ranging from 90 to 98%. Temperature : 5 cycles for a series of time periods : _55ç for 30 minutes → 3 minutes → +105ç for 30 minutes → 3 minutes Continuous 48 hour cycle in 5% salt water solution *Measurement of voltage standing wave ratio (V.S.W.R.) The specified values of the voltage standing wave ratio (V.S.W.R.) noted above, are taken with the test set up shown in the figure below: Network Analyzer HV-P-SF085 measurement system D.U.T. details D.U.T Termination HV-P-SF085 with double ended harness Test Port Cable In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2019.4③ 1 1.85mm Series●IEC Standard Compliant 1.85mm coaxial connectors Materials / Finish Part Materials Finish Shell Stainless steel Passivated Insulator PPO / PTFE resin --------------- Contact Beryllium copper Gold plated Ring Stainless steel Gold plated Plug HV-P-SF085 Feb.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 8HEX 11.1 [Please place cable assembly orders per the specifications below] Cable assembly specifications Please specify the dimensions of 1.85mm Series cable assembly as follows : Please contact HRS representative for cable length. [Double ended assembly] [Single ended assembly] L(mm) L(mm) ●Cable harness part numbering system Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. HV -「」P - SF085N 1 - A - L RS q w e r ❺ qSeries identifier : HV wHarness type None : On either end 2 : On both ends eCable type SF085N : 0.085-inch, semi-flexible cable rCable color  None : No jacket  1 : Blue ❺Overall length L (mm) : Length L is expressed by the unit of mm. 2 1.85mm Series●IEC Standard Compliant 1.85mm coaxial connectors Nonreflective terminator Product Specifications Nominal characteristic impedance 50ø Rated frequency DC to 67GHz Power 0.5W CW (+65°C) Ratings Materials / Finish -10°C to +65°C Operating relative humidity 95% RH or less Product Number Structure Materials Stainless steel PTFE Brass Stainless steel Metal film HV - TM P (40) Finish Passivate ---Gold plated Passivate ---- ❶ ❷ ❸ ❶Series identifier HV ❷TM Non-reflective terminator ❸Connector type P : Plug type Ø8.5 M7x0.75-6H 8HEX Part No. HRS No. HV-TMP(40) 353-0146-6 40 18.3 Voltage standing wave ratio (V.S.W.R.)(max) DC∼50GHz 50∼67GHz 1.3 1.4 Frequency characteristics (TYPICAL) V.S.W.R. Feb.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part Shell Insulator Male contact Coupling Resistive element Operating Temperature Range 2.0 1.9 1.8 1.7 1.6 1.5 1.4 1.3 1.2 1.1 1.0 0 10 20 30 40 FREQUENCY(GHz) 50 60 67 3 1.85mm Series●IEC Standard Compliant 1.85mm coaxial connectors Attenuator Product Specifications Nominal characteristic impedance 50ø Rated frequency DC to 67GHz Power 1W CW (+65°C) Ratings   -10°C to +65°C 95% RH or less Product Number Structure Materials / Finish Part Materials Shell Stainless steel Insulator PTFE resin Male contact Brass Female contact Beryllium coppoer Coupling Stainless steel Resistive element Metal film HV - AT (ππ) - PJ Finish Passivate ---Gold plated ❶ ❷ ❸ ❶Series identifier ❷AT Gold plated Passivate ---- ❹ HV Attenuator (0) : 0dB (through) (Ex.) (3) : 3dB ❸Attenuation (10) : 10dB ❹Connector type PJ : Plug Jack 24.64 8HEX Ø9 Feb.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Operating Temperature Range Operating relative humidity M7×0.75-6g Part No. Attenuation (dB) HRS No. DC∼18GHz +0.4 0 18∼26.5GHz 26.5∼40GHz 0 +0.5 0 0 40∼67GHz +0.8 0 0 +1.0 0 HV-AT(0)-PJ 354-0244-1 0 HV-AT(1)-PJ 354-0288-0 1 −+0.7 0.3 1 −+0.8 0.3 1 −+1.0 0.3 1 −+1.6 0.3 HV-AT(2)-PJ 354-0289-0 2 −+0.7 0.3 2 −+0.8 0.3 2 −+1.0 0.3 2 −+1.6 0.3 HV-AT(3)-PJ 354-0245-4 3 −+0.6 0.4 3 −+0.7 0.4 3 −+0.9 0.4 3 −+1.5 0.4 HV-AT(4)-PJ 354-0300-0 4 −+0.6 0.4 4 −+0.7 0.4 4 −+0.9 0.4 4 −+1.6 0.4 HV-AT(5)-PJ 354-0301-0 5 −+0.7 0.4 5 −+0.8 0.4 5 −+1.0 0.4 5 −+1.8 0.4 HV-AT(6)-PJ 354-0246-7 6 −+0.7 0.3 6 −+0.8 0.3 6 −+0.9 0.3 6 −+1.7 0.3 HV-AT(7)-PJ 354-0302-0 7 −+0.9 0.4 7 −+1.0 0.4 7 −+1.2 0.4 7 −+2.0 0.4 HV-AT(8)-PJ 354-0303-0 8 −+0.9 0.5 8 −+1.0 0.5 8 −+1.2 0.5 8 −+1.8 0.5 HV-AT(9)-PJ 354-0304-0 9 −+0.9 0.5 9 −+1.0 0.5 9 −+1.2 0.5 9 −+1.8 0.5 HV-AT(10)-PJ 354-0247-0 10±0.7 10 −+0.8 0.7 10 −+1.0 0.7 10 −+2.1 0.7 HV-AT(20)-PJ 354-0248-2 20±1.0 20 −+1.2 1.0 20 −+1.4 1.0 20 −+1.6 1.0 M7×0.75-6H Voltage standing wave ratio (V.S.W.R.)(max) DC∼18GHz 18∼26.5GHz 26.5∼40GHz 40∼67GHz 1.4 1.35 1.4 1.55 1.4 1.6 4 1.85mm Series●IEC Standard Compliant 1.85mm coaxial connectors Frequency characteristics (TYPICAL) 5 10 15 20 25 30 35 40 45 50 55 60 65 FREQUENCY(GHz) 2.0 1.9 1.8 1.7 1.6 1.5 1.4 1.3 1.2 1.1 1.0 0 5 10 15 20 25 30 35 40 45 50 55 60 65 FREQUENCY(GHz) 0 2.0 1.9 1.8 1.7 1.6 1.5 1.4 1.3 1.2 1.1 1.0 0 5 10 15 20 25 30 35 40 45 50 55 60 65 FREQUENCY(GHz) ATTENUATION(dB) -3.0 -3.5 -4.0 -4.5 -5.0 -5.5 -6.0 -6.5 -7.0 -7.5 -8.0 2.0 1.9 1.8 1.7 1.6 1.5 1.4 1.3 1.2 1.1 1.0 5 10 15 20 25 30 35 40 45 50 55 60 65 FREQUENCY(GHz) 5dB V.S.W.R. 4dB 2.0 1.9 1.8 1.7 1.6 1.5 1.4 1.3 1.2 1.1 1.0 V.S.W.R. 0 -2.0 -2.5 -3.0 -3.5 -4.0 -4.5 -5.0 -5.5 -6.0 -6.5 -7.0 V.S.W.R. 2.0 1.9 1.8 1.7 1.6 1.5 1.4 1.3 1.2 1.1 1.0 ATTENUATION(dB) -1.0 -1.5 -2.0 -2.5 -3.0 -3.5 -4.0 -4.5 -5.0 -5.5 -6.0 5 10 15 20 25 30 35 40 45 50 55 60 65 FREQUENCY(GHz) 3dB V.S.W.R. ATTENUATION(dB) 2dB ATTENUATION(dB) Feb.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0 0 -0.5 -1.0 -1.5 -2.0 -2.5 -3.0 -3.5 -4.0 -4.5 -5.0 V.S.W.R. 2.0 1.9 1.8 1.7 1.6 1.5 1.4 1.3 1.2 1.1 1.0 ATTENUATION(dB) 0 -0.5 -1.0 -1.5 -2.0 -2.5 -3.0 -3.5 -4.0 -4.5 -5.0 1dB V.S.W.R. ATTENUATION(dB) 0dB -4.0 -4.5 -5.0 -5.5 -6.0 -6.5 -7.0 -7.5 -8.0 -8.5 -9.0 0 5 10 15 20 25 30 35 40 45 50 55 60 65 FREQUENCY(GHz) 5 1.85mm Series●IEC Standard Compliant 1.85mm coaxial connectors Frequency characteristics (TYPICAL) ATTENUATION(dB) 2.0 1.9 1.8 1.7 1.6 1.5 1.4 1.3 1.2 1.1 1.0 2.0 1.9 1.8 1.7 1.6 1.5 1.4 1.3 1.2 1.1 1.0 5 10 15 20 25 30 35 40 45 50 55 60 65 FREQUENCY(GHz) 0 ATTENUATION(dB) 2.0 1.9 1.8 1.7 1.6 1.5 1.4 1.3 1.2 1.1 1.0 0 -8.0 -8.5 -9.0 -9.5 -10.0 -10.5 -11.0 -11.5 -12.0 -12.5 -13.0 ATTENUATION(dB) -7.0 -7.5 -8.0 -8.5 -9.0 -9.5 -10.0 -10.5 -11.0 -11.5 -12.0 5 10 15 20 25 30 35 40 45 50 55 60 65 FREQUENCY(GHz) 0 ATTENUATION(dB) 2.0 1.9 1.8 1.7 1.6 1.5 1.4 1.3 1.2 1.1 1.0 5 10 15 20 25 30 35 40 45 50 55 60 65 FREQUENCY(GHz) -19.0 -19.5 -20.0 -20.5 -21.0 -21.5 -22.0 -22.5 -23.0 -23.5 -24.0 ATTENUATION(dB) -9.0 -9.5 -10.0 -10.5 -11.0 -11.5 -12.0 -12.5 -13.0 -13.5 -14.0 0 2.0 1.9 1.8 1.7 1.6 1.5 1.4 1.3 1.2 1.1 1.0 5 10 15 20 25 30 35 40 45 50 55 60 65 FREQUENCY(GHz) 20dB V.S.W.R. 10dB 2.0 1.9 1.8 1.7 1.6 1.5 1.4 1.3 1.2 1.1 1.0 V.S.W.R. 9dB V.S.W.R. 8dB 5 10 15 20 25 30 35 40 45 50 55 60 65 FREQUENCY(GHz) V.S.W.R. Feb.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0 -6.0 -6.5 -7.0 -7.5 -8.0 -8.5 -9.0 -9.5 -10.0 -10.5 -11.0 ATTENUATION(dB) -5.0 -5.5 -6.0 -6.5 -7.0 -7.5 -8.0 -8.5 -9.0 -9.5 -10.0 V.S.W.R. 7dB V.S.W.R. 6dB 0 5 10 15 20 25 30 35 40 45 50 55 60 65 FREQUENCY(GHz) Precautions 1. The center pin contact has the diameter of 0.511mm. Exercise caution when handling the attenuator. When mating the attenuator with the corresponding connector rotate the hex part only. 2. When mating the attenuator pay attention to dirt on a shell interface. When becoming dirty, please clean with alcohol wipe. ® 6 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 04/2019. Contents are subject to change without notice for the purpose of improvements.
HV-AT(6)-PJ 价格&库存
很抱歉,暂时无法提供与“HV-AT(6)-PJ”相匹配的价格&库存,您可以联系我们找货
