HV-AT(20)-PJ
HV-AT(20)-PJ
    HRS(广濑)
    V连接器直插式模块
    CONN HV ATTENUATOR FIXED 20 DB
HV-AT(20)-PJ 数据手册
APPLICABLE STANDARD FREQUENCY RANGE 1 W CW (AT 65℃) POWER Feb.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved. In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents. RATING STORAGE TEMPERATURE RANGE CHARACTERISTIC IMPEDANCE APPLICABLE CABLE USED CONNECTOR DC ~ 67 GHz 1 OPERATING TEMPERATURE RANGE OPERATING RELATIVE HUMIDITY -10 ℃ TO +65 ℃ ~ 90 % -55℃~+ 125℃(No Load) (※1) 50Ω --HV-P , HV-J SPECIFICATIONS ITEM TEST METHOD REQUIREMENTS QT AT CONSTRUCTION GENERAL EXAMINATION VISUALLY AND BY MEASURING INSTRUMENT. MARKING CONFIRMED VISUALLY. ACCORDING TO DRAWING. X X X X ELECTRIC CHARACTERISTICS V.S.W.R MUST BE UNDER THE STD.VALUE AT FREQENCY DC TO 67 GHz 1 INSERTION LOSS 1 MUST BE UNDER THE STD.VALUE AT FREQENCY DC TO 67 GHz 1 INSULATION RESISTANCE X X - - - - - - NO FLASHOVER OR BREAKDOWN. V AC FOR 1 min.CURRENT LEAKAGE 2mA MAX. MEASURE THE RESISTANCE VALUE AT DC RESISTANCE VALUE X X 19dB ~21.4dB ( 26.5 ~40GHz) 1 19dB ~21.6dB ( 40 ~67GHz) MINIMUM OF MΩ MUST BE OVER STANDARD VALUE AT DC V. VOLTAGE PROOF 1.40 MAX (DC~40GHz) 1.60 MAX (40 ~67GHz) 19dB ~21dB ( DC ~18GHz) 19dB ~21.2dB ( 18 ~26.5GHz) MAX V. MECHANICAL CHARACTERISTICS MECHANICAL OPERATION VIBRATION SHOCK 500 TIMES INSERTIONS AND EXTRACTIONS. ①ELECTRICAL CHARACTERISTIC SHALL BE MET. X - ②NO DAMAGE, CRACK, AND LOOSENESS, OF PARTS. ①ELECTRICAL CHARACTERISTIC SHALL BE MET. X - ②NO DAMAGE, CRACK, AND LOOSENESS, OF PARTS. ①ELECTRICAL CHARACTERISTIC SHALL BE MET. X - ②NO DAMAGE, CRACK, AND LOOSENESS, OF PARTS. FREQUENCY 10 TO 55 Hz, SINGLE AMPLITUDE 0.75 mm OR 1 oct/min AT 10 CYCLES FOR 3 DIRECTIONS. 490 m/s2 AT 18 TIMES FOR 3 DIRECTIONS. ENVIRONMENTAL CHARACTERISTICS DAMP HEAT (STEADY STATE) TEMPERATURE -55 → 15~25 → 125 → 15~25 ℃ TIME 30 → 2~3 → 30 → 2~3 min UNDER 100 CYCLES. EXPOSED AT 40 C, 90% TO 95 TOTAL 96 h. DRY HEAT EXPOSED AT RAPID CHANGE OF TEMPERATURE COLD EXPOSED AT CORROSION SALT MIST △ 1 125 C -55 C TOTAL TOTAL ①ELECTRICAL CHARACTERISTIC SHALL BE MET. ②NO HEAVY CORROSION. ①ELECTRICAL CHARACTERISTIC SHALL BE MET. ②NO HEAVY CORROSION. ①ELECTRICAL CHARACTERISTIC SHALL BE MET. ②NO HEAVY CORROSION. ①ELECTRICAL CHARACTERISTIC SHALL BE MET. ②NO HEAVY CORROSION. NO HEAVY CORROSION. 48 h. 48 h. EXPOSED IN 5±1 % SALT WATER , AT 35±2℃ SPRAY FOR 48 HOURS. X - X - X - X - COUNT DESCRIPTION OF REVISIONS DESIGNED CHECKED DATE 5 DIS-D-00002210 HA.NISHIMURA TS.NOBE 17.06.23 REMARKS RoHS COMPLIANT High frequency performance is only measured and the data is not attached. (※1 ) The storage temperature range means the one of the product itself without packaging. Note X - QT:Qualification Test AT:Assurance Test X:Applicable Test Unless otherwise specified, refer to JIS C 5402. FORM HD0011-2-1 APPROVED KY.SHIMIZU 14.12.18 CHECKED TO.KATAYAMA 14.12.18 DESIGNED YI.FUNADA 14.12.17 DRAWN YI.FUNADA 14.12.17 DRAWING NO. SPECIFICATION SHEET PART NO. HIROSE ELECTRIC CO., LTD. CODE NO. ELC4-180473-00 HV-AT(20)-PJ CL354-0248-2-00 1 △ 1/1
HV-AT(20)-PJ
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入、输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件可以实现信号的多路切换,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗设备等领域。
7. 封装信息:采用QFN封装,尺寸为4x4mm。
HV-AT(20)-PJ 价格&库存
很抱歉,暂时无法提供与“HV-AT(20)-PJ”相匹配的价格&库存,您可以联系我们找货
