RFBPF1608070A0T
RFBPF1608070A0T
    WALSIN(华新科)
RFBPF1608070A0T 数据手册
Approval sheet RFBPF Series – 1608(0603)- RoHS Compliance MULTILAYER CERAMIC BAND PASS FILTER Halogens Free Product 2.4 GHz ISM Band Working Frequency P/N: RFBPF1608070A0T *Contents in this sheet are subject to change without prior notice. Page 1 of 7 ASC_RFBPF1608070A0T_V06 Oct. 2011 Approval sheet FEATURES 1. Miniature footprint: 1.6 X 0.8 X 0.7 mm 2. Low Profile Thickness 3. Low Insertion loss 4. High Rejection Rate 5. High attenuation on 2 6. LTCC process nd 3 harmonic suppressed APPLICATIONS 1. 2.4GHz ISM band RF applications 2. Bluetooth, Wireless LAN 802.11b/g, HomeRF CONSTRUCTION PIN Connection 1 Input port 2 GND 3 Output port 4 GND DIMENSIONS Figure Page 2 of 7 Symbol Dimension (mm) L 1.60 ± 0.15 W 0.80 ± 0.15 T 0.70 ± 0.10 A 0.45 ± 0.15 B 0.70 ± 0.15 C 0.20 ± 0.15 D 0.20 ± 0.15 E 0.25 ± 0.15 F 0.30 ± 0.15 ASC_RFBPF1608070A0T_V06 Oct. 2011 Approval sheet ELECTRICAL CHARACTERISTICS RFBPF1608070A0T Specification Frequency range 2450 ± 50 MHz Insertion Loss 2.5 dB max VSWR 2.0 max Impedance 50 Ω 30 dB @ 960MHz 25dB @ 1910 MHz Attenuation (min.) 20 dB @ 1990 MHz 30 dB @ 4800 MHz 25 dB @ 7200 MHz Operation Temperature Range -40°C ~ +85°C Typical Electrical Chart SOLDER LAND PATTERN Figure Symbol Dimension (mm) L1 1.40 ± 0.10 L2 0.80 ± 0.05 L3 0.50 ± 0.05 L4 0.64 ± 0.05 L5 0.37 ± 0.05 W1 0.94 ± 0.10 W2 0.70 ± 0.05 W3 0.43 ± 0.05 D1 0.30 ± 0.05 D2 0.35 ± 0.05 S1 0.35 ± 0.05 Line width to de designed to match 50 Ω characteristic impedance, depending on PCB material and thickness. D1 and D2 are the grounding through holes. Page 3 of 7 ASC_RFBPF1608070A0T_V06 Oct. 2011 Approval sheet RELIABILITY TEST Test item Test condition / Test method Specification Solderability JIS C 0050-4.6 *Solder bath temperature:235 ± 5°C At least 95% of a surface of each terminal JESD22-B102D *Immersion time:2 ± 0.5 sec electrode must be covered by fresh solder. *Solder:Sn3Ag0.5Cu for lead-free Leaching *Solder bath temperature:260 ± 5°C Loss of metallization on the edges of each of metallization) *Leaching immersion time:30 ± 0.5 sec electrode shall not exceed 25%. IEC 60068-2-58 *Solder : SN63A (Resistance to dissolution Resistance to soldering heat *Preheating temperature:120~150℃, JIS C 0050-5.4 1 minute. No mechanical damage. Samples shall satisfy electrical specification *Solder temperature:270±5°C after test. *Immersion time:10±1 sec Loss of metallization on the edges of each electrode shall not exceed 25%. *Solder:Sn3Ag0.5Cu for lead-free Measurement to be made after keeping at room temperature for 24±2 hrs Drop Test JIS C 0044 *Height:75 cm No mechanical damage. *Test Surface:Rigid surface of concrete Samples shall satisfy electrical specification after test. or steel. *Times:6 surfaces for each units;2 times for each side. Adhesive Strength of Termination JIS C 0051- 7.4.3 Bending test JIS C 0051- 7.4.1 *Pressurizing force: 5N(≦0603);10N(>0603) No remarkable damage or removal of the termination. *Test time:10±1 sec The middle part of substrate shall be No mechanical damage. pressurized by means of the pressurizing Samples shall satisfy electrical specification rod at a rate of about 1 mm/s per second after test. until the deflection becomes 1mm/s and then pressure shall be maintained for 5±1 sec. Measurement to be made after keeping at room temperature for 24±2 hours Page 4 of 7 ASC_RFBPF1608070A0T_V06 Oct. 2011 Approval sheet Temperature cycle JIS C 0025 1. 30±3 minutes at -40°C±3°C, No mechanical damage. 2. 10~15 minutes at room temperature, Samples shall satisfy electrical 3. 30±3 minutes at +85°C±3°C, 4. 10~15 minutes at room temperature, specification after test. Total 100 continuous cycles Measurement to be made after keeping at room temperature for 24±2 hrs Vibration JIS C 0040 *Frequency:10Hz~55Hz~10Hz(1min) No mechanical damage. *Total amplitude:1.5mm Samples shall satisfy electrical specification *Test times:6hrs.(Two hrs each in three after test. mutually perpendicular directions) High temperature JIS C 0021 *Temperature:85°C±2°C No mechanical damage. *Test duration:1000+24/-0 hours Samples shall satisfy electrical specification Measurement to be made after keeping at after test. room temperature for 24±2 hrs Humidity (steady conditions) *Humidity:90% to 95% R.H. No mechanical damage. *Temperature:40±2°C Samples shall satisfy electrical specification JIS C 0022 *Time:1000+24/-0 hrs. after test. Measurement to be made after keeping at room temperature for 24±2 hrs ※ 500hrs measuring the first data then 1000hrs data Low temperature JIS C 0020 *Temperature:-40°C±2°C No mechanical damage. *Test duration:1000+24/-0 hours Samples shall satisfy electrical specification Measurement to be made after keeping at after test. room temperature for 24±2 hrs Page 5 of 7 ASC_RFBPF1608070A0T_V06 Oct. 2011 Approval sheet SOLDERING CONDITION Typical examples of soldering processes that provide reliable joints without any damage are given in Fig 2, Fig 2. Infrared soldering profile ORDERING CODE RF BPF 160807 0 Walsin Product Code Dimension code RF Pb free device BPF : Band Pass Filter Per 2 digits of Length, Width, Thickness : A Unit of dimension 0 : 0.1 mm 0 T Application Specification Packing A : 2.4GHZ ISM Band Design Code T : Reeled 1 : 1.0 mm e.g. : 160807 = Length 16, Width 08, Thickness 07 Minimum Ordering Quantity: 4000 pcs per reel. PACKAGING Paper Tape specifications (unit :mm) Index Dimension (mm) Index Dimension (mm) Page 6 of 7 Ao Bo ΦD T W 0.975 ± 0.05 1.76 ± 0.05 1.55 + 0.05 0.75 ± 0.03 8.0 ± 0.10 E F Po P1 P2 1.75 ± 0.10 3.50 ± 0.05 4.00 ± 0.10 4.00 ± 0.10 2.00 ± 0.05 ASC_RFBPF1608070A0T_V06 Oct. 2011 Approval sheet Reel dimensions C Index A Φ178.0 Dimension (mm) B Φ60.0 A B C Φ13.0 Taping Quantity: 4000 pieces per 7” reel CAUTION OF HANDLING Limitation of Applications Please contact us before using our products for the applications listed below which require especially high reliability for the prevention of defects, which might directly cause damage to the third party’s life, body or property. (1) (2) (3) (4) (5) (6) (7) (8) Aircraft equipment Aerospace equipment Undersea equipment Medical equipment Disaster prevention / crime prevention equipment Traffic signal equipment Transportation equipment (vehicles, trains, ships, etc.) Applications of similar complexity and /or reliability requirements to the applications listed in the above. Storage condition (1) Products should be used in 6 months from the day of WALSIN outgoing inspection, which can be confirmed. (2) Storage environment condition.     Products should be storage in the warehouse on the following conditions.    Products should be storage on the palette for the prevention of the influence from humidity, dust and son on. Page 7 of 7 Temperature : -10 to +40℃ Humidity : 30 to 70% relative humidity Don’t keep products in corrosive gases such as sulfur. Chlorine gas or acid or it may cause oxidization of electrode, resulting in poor solderability. Products should be storage in the warehouse without heat shock, vibration, direct sunlight and so on. Products should be storage under the airtight packaged condition. ASC_RFBPF1608070A0T_V06 Oct. 2011
RFBPF1608070A0T 价格&库存
很抱歉,暂时无法提供与“RFBPF1608070A0T”相匹配的价格&库存,您可以联系我们找货
RFBPF1608070A0T
  • 1+1.942621+0.25250
  • 10+1.6064010+0.20880
  • 25+1.4759725+0.19184
  • 50+1.3893050+0.18058
  • 100+1.30551100+0.16969
  • 250+1.20362250+0.15644
  • 500+1.13193500+0.14713
  • 1000+1.064681000+0.13839
库存:2080
