0.3mm Pitch, 1.0mm Height FPC Connector
FH26 Series
1.0mm
●Space saving(51 pos. shown)
3.2mm
Jul.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
16.8mm
Metal fittings do no protrude
outside of the connector body
■Features
●Can be mounted over conductive traces.
1. Low-profile 0.3mm pitch FPC connector
Ultra-thin design, 1.0mm height, 3.2mm width all add up
to a compact, space saving form factor.
*30% reduction in PCB footprint
*40% reduction in weight
(Compared to our 0.3mm pitch FH23 Series 51 position connector.)
2. Easy PCB Mounting
The leads are double sided and have a 0.6mm mounting
lead pitch to simplify mounting.
No exposed contacts on the bottom
of the connector
3. Fully molded structure aids PCB layout
The bottom of this connector is enclosed by a fully molded
structure that protects the contacts and removes any
restrictions from PCB patterning and design.
4. Rotating one-touch ZIF mechanism
●Operation
(1)
(1) Actuator
Actuator open
open
(2)
(2) Insert
Insert FPC
FPC
The one-touch rotating ZIF mechanism is easier to operate and
works with a light force, and a clear tactile click is delivered upon
the successful completion of the mating process.
Actuator
q
5. Easy FPC insertion
The metal FPC insertion guides helps to make this the
FPC insertion process easier.
w
6. FPC. Accepts standard 0.2mm thick FPC
This connector accepts standard 0.2mm thick FPC. (The
proper FPC stiffener thickness will prevent FPC
deformation and ease insertion and mating.)
FPC
7. Supports automatic pick-n-place mounting
Offered in tape and reel packaging that is compatible with
automatic machine mounting. (5,000 pieces per reel)
(3)
(3) Close
Close the
the actuator
actuator
(4)
(4) FPC
FPC connected
connected
8. Halogen-free
All materials and substances used to produce this product
comply with Halogen-free standards.
* Defined according to IEC61249-2-21
Br : 900ppm max, Cl : 900ppm max, Br+Cl : 1,500ppm max.
e
9. Multiple packing options
The standard packaging is 5,000 pieces per reel, but it is
also offered in a 500 piece reel. (The outer diameter of the
reel will be Ø180mm in this case.)
r
2017.5③
1
FH26 Series●0.3mm Contact Pitch, 1mm above the board, Flexible Printed Circuit ZIF Connectors
■Product Specifications
Rating
Storage temperature range -10ç to +50ç (Note 3)
Storage humidity range
Relative humidity 90%
max.
Thickness : = 0.2±0.03mm gold plated
Recommended FPC :
Item
Operating temperature range -55 ç to +85ç (Note 2)
Operating humidity range
Relative humidity 90% max.
(No condensation)
Current rating 0.2A DC (Note 1)
Voltage rating 30V AC
Specification
Conditions
1. Insulation resistance
50Mø min.
100V DC
2. Withstanding voltage
No flashover or insulation breakdown.
90V AC /1 minute
3. Contact resistance
100mø max.
* Including FPC conductor resistance
1mA
4. Durability
(Insertion/ withdrawal)
Contact resistance : 100mø max.
No damage, cracks, or parts dislocation.
10 cycles
5. Vibration
No electrical discontinuity of 1μs or more.
Frequency : 10 to 55 Hz, single amplitude of 0.75mm, 10 cycles,
3 directions.
6. Shock
No electrical discontinuity of 1μs. min.
Acceleration of 981 m/s2, 6 ms duration, sine half-wave waveform,
3 cycles in each of the 3 axis
7. Humidity
(Steady state)
Insulation resistance : 50Mø min.
No affect on appearance or performance.
96 hours at temperature of 40±2ç and humidity of 90% to 95%.
8. Temperature cycle
No damage, cracks, or parts looseness.
Temperature : -55 ç/+15ç to +35ç/+85ç/+15ç to +35ç
Time : 30 / 2 to 3 / 30 / 2 to 3 (Minutes)
5 cycles
9. Resistance to soldering heat
No deformation of components affecting
performance.
Reflow : At the recommended temperature profile
Manual soldering: 350ç +/-10ç for 5±1 seconds
Note 1 : When passing the current through all of the contacts, use 70% of the rated current.
Note 2 : Includes temperature rise caused by current flow.
Note 3 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating
Temperature Range and Humidity range covers non- conducting condition of installed connectors in storage,
shipment or during transportation.
■Materials / Finish
Part
Material
Insulator
Contacts
Metalfittings
Finish
Remarks
LCP
Color : Black
UL94V-0
PA
FH26W series : Light brown
UL94HB
Gold plating
Pure tin reflow plating
Phosphor bronze
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
FH 26W - 51S - 0.3 SHW (05)
1
2
2
3
4
5
6
1 Series name : FH
5 Termination type SHW : SMT horizontal staggered mounting type
2 Series No. : 26W
6 Specifications
3 Number of Contacts : 13 to 71
(60)…Gold plating with nickel barrier, 5,000pcs/reel
4 Contact pitch : 0.3mm
(97)…Gold plating with nickel barrier, 500pcs/reel
■Connector Dimensions
0.3
A
B
0.6
(0.3)
3.2
(1.25)
(0.12)
0.6
Number of contacts indicator
(0.12)
1
C
0.5
0.3
3.2
(D : FPC insertion slot dimension)
0.1
1
0.1
1
E
Notes 1 The coplanarity of each terminal lead within specified dimension is 0.1mm Max.
2 Packaged on tape and reel only. Check packaging specification.
3 Slight variations in color of the plastic compounds do not affect form, fit or function of the connector.
4 After reflow, the terminal plating may change color, however this does not represent a quality issue.
All dimensions : mm
Part No.
HRS No.
No. of Contacts
A
FH26W-13S-0.3SHW(**)
580-2401-1 **
13
FH26W-15S-0.3SHW(**)
580-2402-4 **
15
FH26W-17S-0.3SHW(**)
580-2403-7 **
FH26W-19S-0.3SHW(**)
580-2437-9 **
FH26W-21S-0.3SHW(**)
FH26W-23S-0.3SHW(**)
B
C
D
E
5.4
3
3.6
4.23
4.9
6.0
3.6
4.2
4.83
5.5
17
6.6
4.2
4.8
5.43
6.1
19
7.2
4.8
5.4
6.03
6.7
580-2404-0 **
21
7.8
5.4
6.0
6.63
7.3
580-2405-2 **
23
8.4
6.0
6.6
7.23
7.9
FH26W-25S-0.3SHW(**)
580-2406-5 **
25
9.0
6.6
7.2
7.83
8.5
FH26W-27S-0.3SHW(**)
580-2400-9 **
27
9.6
7.2
7.8
8.43
9.1
FH26W-29S-0.3SHW(**)
580-2407-8 **
29
10.2
7.8
8.4
9.03
9.7
FH26W-31S-0.3SHW(**)
580-2408-0 **
31
10.8
8.4
9.0
9.63
10.3
FH26W-33S-0.3SHW(**)
580-2409-3 **
33
11.4
9.0
9.6
10.23
10.9
FH26W-35S-0.3SHW(**)
580-2410-2 **
35
12.0
9.6
10.2
10.83
11.5
FH26W-37S-0.3SHW(**)
580-2411-5 **
37
12.6
10.2
10.8
11.43
12.1
FH26W-39S-0.3SHW(**)
580-2412-8 **
39
13.2
10.8
11.4
12.03
12.7
FH26W-41S-0.3SHW(**)
580-2413-0 **
41
13.8
11.4
12.0
12.63
13.3
FH26W-45S-0.3SHW(**)
580-2414-3 **
45
15.0
12.6
13.2
13.83
14.5
FH26W-51S-0.3SHW(**)
580-2415-6 **
51
16.8
14.4
15.0
15.63
16.3
FH26W-57S-0.3SHW(**)
580-2417-1 **
57
18.6
16.2
16.8
17.43
18.1
FH26W-61S-0.3SHW(**)
580-2418-4 **
61
19.8
17.4
18.0
18.63
19.3
FH26W-71S-0.3SHW(**)
580-2419-7 **
71
22.8
20.4
21.0
21.63
22.3
Note 1 : Embossed tape reel packaging (5,000pcs/reel, 500pcs/reel). Order by number of reels.
3
(0.55 : Metal mask)
Recommended metal mask thickness : t=0.1
0.95±0.05
2.15±0.05
(0.7 : Metal mask)
(0.2)
0.6±0.05
(0.3 : Metal mask)
0.4±0.05
0.2±0.05
Outline of
the connector
0.6±0.05
0.3±0.03
(0.23 : Metal mask)
C±0.05
0.5±0.05
BRecommended FPC Dimensions
Detail H
(Lead plated 0.1 MAX)
F±0.05
0.3±0.07
(0.15)
0.2±0.03
1
M
2.25±0.1
(2.5)
(0.5)
2.5±0.3
B
A
2.1±0.1
AX
1.1±0.1
0.3+0.04
-0.03
0.3±0.02
H
M
0.3±0.1
.2
1±0.1
0.6±0.02
R0
0.3+0.04
-0.03
0.1±0.02
(0.2)
(0.2)
(0.07)
0.6±0.07
(0.05)
B±0.03
1
(0.15)
0.6±0.07
Dimention M must be 0.5mm minimum when the stiffener is shorter than 3.5 min.
All dimensions : mm
Part No.
4
HRS No.
580-2401-1 **
580-2402-4 **
580-2403-7 **
580-2437-9 **
580-2404-0 **
580-2405-2 **
580-2406-5 **
580-2400-9 **
580-2407-8 **
580-2408-0 **
580-2409-3 **
580-2410-2 **
580-2411-5 **
580-2412-8 **
580-2413-0 **
580-2414-3 **
580-2415-6 **
580-2417-1 **
580-2418-4 **
580-2419-7 **
No. of Contacts
13
15
17
19
21
23
25
27
29
31
33
35
37
39
41
45
51
57
61
71
B
3.0
3.6
4.2
4.8
5.4
6.0
6.6
7.2
7.8
8.4
9.0
9.6
10.2
10.8
11.4
12.6
14.4
16.2
17.4
20.4
0±0.03
1.1±0.1
1±0.1
C±0.03
3.5 MIN.(Stiffener)
0.3±0.07
C
3.6
4.2
4.8
5.4
6.0
6.6
7.2
7.8
8.4
9.0
9.6
10.2
10.8
11.4
12.0
13.2
15.0
16.8
18.0
21.0
F
4.2
4.8
5.4
6.0
6.6
7.2
7.8
8.4
9.0
9.6
10.2
10.8
11.4
12.0
12.6
13.8
15.6
17.4
18.6
21.6
πRELATIVE
POSITIONS
OF POINT-A dnd B
0.3±0.03
(0.23 : Metal mask)
(0.45)
B±0.05
0.3±0.05
(0.65 : Metal mask)
0.8±0.05
(3.6)
0.65±0.05
BRecommended PCB mounting pattern and metal mask dimensions
BRecommended FPC Construction
●Contact FPC manufacturer for specific details.
1. Using Single-sided FPC
Connecting side
Material Name
Covering film layer.
Material
Polyimide
1 mil thick.
Cover adhesive
Thickness (μm)
25
25
Surface treatment
1μm to 5μm Nickel underplated
0.2μm Gold plated
Copper foil
Cu
Base adhesive
Thermosetting adhesive
25
Base film
Polyimide
1 mil thick
25
Reinforcement material adhesive
40
Stiffener
Polyimide
75
1oz
3 mil thick
Total
3
35
203
Back side
2. Using Double-sided FPC
Connecting side
Material
Material Name
Covering layer film
Polyimide
1 mil thick
25
25
Cover adhesive
Surface treatment
0.2μm Gold plated
Through-hole copper
Cu
Copper foil
Cu
Base adhesive
18
Base film
Polyimide
1 mil thick
25
Base adhesive
18
Copper foil
Cu
18
Cover adhesive
25
Covering layer film
Polyimide
1 mil thick
25
Reinforcement material adhesive Thermosetting adhesive
25
Stiffener
Back side
Thickness (μm)
Polyimide
3
15
1/2oz
1/2oz
1 mil thick
Total
18
25
197
●To prevent release of the FPC due to it's bending, use of double sided FPC with copper foil on the back side is NOT RECOMMENDED.
3. Precautions
1. This specification is a recommendation for the construction of the FH26 Series FPC (t=0.2 ± 0.03).
2. For details about the construction, please contact the FPC manufacturers.
5
BPackaging Specification
●Embossed Carrier Tape Dimensions
(3.05)
(4.55)
(K)
J±0.1
H±0.1
G±0.3
Flat surface,
for placement with
automatic equipment
(1.25)
(0.3)
Unreeling direction
(3.05)
(4.55)
1.5+0.1
Unreeling direction
Ø1
.5
(1.6)
(K)
J±0.1
(0.3)
1.75±0.1
8±0.1
Ø1
.5
4±0.1 2±0.15
(1.6)
(1.25)
(Ø1
3)
●Reel Dimensions
Unreeling direction
(Ø80)
(Ø380)
(L : INSIDE)
(M : OUTSIDE)
End section
Mounting section
Lead section (400mm min.)
Connectors
Blank section
(10 pockets min.)
6
Embossed carrier tape
Blank section
(10 pockets min.)
Top cover tape
G±0.3
1.75±0.1
(Tape width of 32mm min.)
1
(Tape width of 24mm max.)
Flat surface,
for placement with
automatic equipment
HRS No.
No. of Contacts
G
H
J
K
L
M
580-2401-1 **
13
16
7.5
5.6
17.4
21.4
580-2402-4 **
15
16
7.5
6.2
17.4
21.4
580-2403-7 **
17
16
7.5
6.8
17.4
21.4
580-2437-9 **
19
16
7.5
7.4
17.4
21.4
580-2404-0 **
21
16
7.5
8.0
17.4
21.4
580-2405-2 **
23
16
7.5
8.6
17.4
21.4
580-2406-5 **
25
16
7.5
9.2
17.4
21.4
580-2400-9 **
27
16
7.5
9.8
17.4
21.4
580-2407-8 **
29
24
11.5
10.4
25.4
29.4
580-2408-0 **
31
24
11.5
11.0
25.4
29.4
580-2409-3 **
33
24
11.5
11.6
25.4
29.4
580-2410-2 **
35
24
11.5
12.2
25.4
29.4
11.5
12.8
25.4
29.4
580-2411-5 **
37
24
580-2412-8 **
39
24
11.5
13.4
25.4
29.4
580-2413-0 **
41
24
11.5
14.0
25.4
29.4
580-2414-3 **
45
24
11.5
15.2
25.4
29.4
580-2415-6 **
51
24
11.5
17.0
25.4
29.4
580-2417-1 **
57
32
28.4
14.2
18.8
33.4
37.4
580-2418-4 **
61
32
28.4
14.2
20.0
33.4
37.4
580-2419-7 **
71
44
40.4
20.2
23.0
45.4
49.4
BRecommended Temperature Profile
MAX 250ç
250
230ç
Temperature
All dimensions : mm
Part No.
200
200ç
150
150ç
(ç)
100
50
25ç
(60sec.)
90 sec. to 120 sec.
Start
60
Preheating
120
Time (Seconds)
(60sec.)
Soldering
HRS test conditions
Solder method
: Reflow, IR/hot air
Environment
: Room air
Solder composition : Paste,
96.5%Sn/3.0%Ag/0.5%Cu
(Senju Metal Industry,
Co., Ltd.'s
Part Number: M705221CM5-32-10.5)
Test board
: Glass epoxy
25mm∞50mm∞0.8mm thick
Land dimensions
: 0.3mm∞0.65mm,
0.3mm∞0.8mm
Metal mask
: 0.23∞0.55∞0.1mm thick,
0.23∞0.65∞0.1mm thick
The temperature profiles are based on the above
conditions.
In individual applications the actual temperature
may vary, depending on solder paste type,
volume/thickness and board size/thickness.
Consult your solder paste and equipment
manufacturer for specific recommendations.
7
BOperation and Precautions
Operation
1.FPC insertion procedure. Connector installed on the board.
1 Lift up the actuator. Use thumb or index finger.
2 Fully insert the FPC in the connector par-
allel to mounting surface, with the
exposed conductive traces facing down.
FPC conductor
surface (Bottom side)
3 Rotate down the actuator until firmly closed. It is
critical that the inserted FPC is not moved and
remains fully inserted.
2.FPC removal
1 Lift up the actuator. Carefully withdraw the
FPC.
8
Precautions
This connector needs to be handled with care due to its thin design and miniature
stature.
[ Precautions when mounting to PCB ]
The PCB distortion should be kept to a minimum. The maximum coplanarity of this connector is 0.1
mm, but excessive distortion can create solder failure.
SFPC specifications
Stiffeners can be used to improve the rigidity of the FPC. We recommend using a glass epoxy with
the thickness of 0.3mm or more.
SLoad to the connector
Do not apply any excessive force or mate/unmate these connectors until they are mounted, failure to
follow this precaution can lead to deformation or damage to these connectors. Inserting the FPC
prior to mounting is not recommended either.
[ Precautions in handling PCB after mounting ]
SApplied force to the PCB
Do not place any excessive force on the PCB after the connector has been mounted, this type of
action may damage the connectors. (e.g., When separating the PCB into multiple boards or
installing fastening screws onto the PCB)
SPCB bending
For PCB with a width of 100mm, it should not be bent more than a maximum of 0.5 mm. (Please
refer to the diagrams below.) PCB bending places an extra load onto the connector and will lead to
damage or malfunction.
Connector
PCB
100
0.5MAX
Connector
0.5MAX
SAcceptable amount of PCB distortion
100
PCB
Precautions When Inserting or Coupling FPC
Pay attention to the following points when inserting FPC.
SActuator operation
1 Do not apply excessive force when opening the actuator prior to FPC insertion. When opening
make sure that the force is applied only to the actuator itself, avoiding touching of the contacts.
Actuator
Damage to the contacts
Damage
Axis of rotation
2 Axis of rotation
Assure free rotation of
the actuator
9
Precautions
3 The actuator will rotate 135 degrees
135˚
maximum. Do not apply force to rotate
further. (1N max.)
4 When operating the actuator, do so at the
center portion.
5 As illustrated, do not attempt removal or re-
positioning of the actuator.
SFPC Insertionq
The FPC should be aligned parallel with the board surface and perpendicular with the connector (as
shown), then completely inserted.
Perpendicular with
the connector
To assure correct electrical and mechanical connection do not insert FPC at angle. It must be fully
inserted.
Make sure that the FPC is NOT MOVED during the closing of the actuator.
10
Precautions
SFPC Insertionw
Do not insert the FPC at any angle from above.
As illustrated, angle insertion may cause electrical discontinuity when the FPC is deflected in use.
*To avert insertion of the FPC on an angle, consideration should be given to securing FPC insertion
space at the time of board layout. Insertion will be difficult when the FPC is too short.
*Contact the FPC manufacturer for information about the bending specifications.
SVerification of the fully closed actuator.
The actuator should be fully closed (as illustrated) and the FPC held firmly in the connector.
Do not press against the actuator when is fully closed. Max force applied to the fully closed actuator
should not exceed 1 N.
Routing the FPC (FPC fully inserted/ actuator closed)
SFPC Load
Do not apply force in excess of 0.05N/pin max. in the upward direction (as illustrated). Do not bend
the FPC too close to the actuator.
Load : 0.05N/pin max.
11
Precautions
Removing the FPC
Rotate the actuator to the open position (maximum open angle of 135). Carefully withdraw the FPC.
135˚
Other Precautions
SHand Soldering Precautions
When hand soldering:
1 Do not perform reflow or hand soldering with the FPC inserted in the connector.
2 Do not apply excessive heat or touch the soldering iron anywhere other than the connector leads.
3 Do not use excessive amount of solder or flux compounds.
Operation of the actuator and contacts may be affected by excessive amounts of solder or flux
compounds.
12
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 05/2017. Contents are subject to change without notice for the purpose of improvements.
