FH52-15S-0.5SH
FH52-15S-0.5SH
    HRS(广濑)
    SMD,P=0.5mm
    CONN FFC BOTTOM 15POS 0.50MM R/A
FH52-15S-0.5SH 数据手册
0.5mm and 1mm Pitch, 2mm Height, FPC/FFC ZIF Connectors FH52 Series Secure actuator retention May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Metal fittings are designed to hold and stabilize the actuator Contacts are designed to hold and stabilize the actuator ■Features Extended metal fitting option (FH52E/FH52K/FH52T) 1. Highly reliable connection and robust structure With the need for higher contact counts and the need for a connector body that delivers unquestionable strength and a reliable connection in a FPC/FFC connector, the FH52 series has made great strides to meet this need. It meets this need with the following: -An FPC positioning mechanism that delivers the high reliability requested -A reliable and secure connection that is packed into a well-designed, durable structure. 2. Product variations capable of meeting a range of needs ・FH52E : Long metal fittings type Easy visual inspection of solder posts after processing. ・FH52K : Long metal fittings type, 125℃ Heat Resistant Type 125℃ heat resistant connector meets severe automotive requirements ・FH52T : Long metal fittings type, 2-Point Contact Type Contact structure with independent springs connects with FPC/FCC at 2 points reducing failure from dust intrusion. The metal fittings extend out from the connector body to enable a visual inspection of its soldering conditions. 2-Points of Contact (FH52T) 3. Simplified operations The flip lock structure makes it easier to engage/ disengage the actuator and reduces the required force needed to operate. A clear tactile click is delivered upon the successful completion of the mating process. 4. Increased retention force The side catch technology combined with tabbed FPC/FFC increase the horizontal retention force of the FPC/FFC. 5. Accepts standard 0.3mm thick FPC/FFC It accepts 0.3mm thick products that are easy to manufacture and have superb insertion performance. 6. Fully molded structure aids PCB layout The bottom of this connector is enclosed by a fully molded structure that protects the contacts and removes any restrictions from PCB patterning and design. 2-point contact structure with independent springs to improve reliability. Side catch technology designed to place a temporary hold on the FPC/FFC before the lock is engaged. 7. Halogen-free All materials and substances used to produce this product comply with Halogen-free standards.* As defined in IEC 61249-2-21. Br : 900 ppm or less, Cl : 900 ppm or less, Br+Cl : 1,500 ppm or less 8. Supports automatic pick-n-place mounting Offered in tape and reel packaging that is compatible with automatic machine mounting. (3,000pcs/reel) 9. Multiple packing options The standard packaging is 3,000pcs/reel, but it is also offered in a 500pcs/reel. (The outer diameter of the reel will be Ø180mm in this case.) FPC/FFC with tab increase the retention force in horizontal direction. In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2017.8r 1 FH52 Series●0.5mm and 1mm Pitch, 2mm Height, FPC/FFC ZIF Connectors ■Product Specifications Adaptive FPC/FFC contact specifications Thickness: = 0.3 ± 0.05mm Gold plated contact traces Item May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Operating temperature range : -40ç to +105°C (Note 2)(Note 4) Storage temperature range : -10ç to +50°C (Note 3) Operating humidity range : Relative humidity 90% max. Storage humidity range : Relative humidity 90% max. (No condensation) (No condensation) Rated current 0.5A (Note 1) Rated voltage 50V AC rms Rating Specification Conditions 1. Insulation resistance 500Mø min. 100V DC 2. Withstanding voltage No flashover or insulation breakdown 150V AC rms / 1 minute 3. Contact resistance 50mø max. * Including FPC/FFC conductor resistance 1mA (DC or 1000Hz) 4. Durability (insertion / withdrawal) Contact resistance : 50mø max. No damage, cracks, or parts dislocation 20 cycles 5. Vibration No electrical discontinuity of 1µs or more Contact resistance : 50mø max. No damage, cracks, or parts dislocation Frequency : 10 to 55Hz, single amplitude of 0.75mm, 10 cycles in each of the 3 directions 6. Shock No electrical discontinuity of 1µs or more Contact resistance : 50mø max. No damage, cracks, or parts dislocation Acceleration of 981m/s2, duration of 6 ms, sine half-wave waveform, 3 cycles in each of the 3 axes 7. Humidity (Steady state) Contact resistance : 50mø max. Insulation resistance : 50Mø min. No damage, cracks, or parts dislocation 96 hours at temperature of 40ç and humidity of 90% to 95% 8. Temperature cycle Contact resistance : 50mø max. Insulation resistance : 50Mø min. No damage, cracks, or parts dislocation Temperature : -40°C / +15ç to +35ç / +105ç(Note 4) / +15ç to +35ç Time : 30 / 2 to 3 / 30 / 2 to 3 (Minutes) 5 cycles 9. Resistance to soldering heat No deformation of components affecting performance Reflow : Peak temperature 250°C max., 230°C or more, 30 seconds or less Manual soldering: 350 ± 10°C for 5 seconds Note 1 : When passing the current through all of the contacts, use 70% of the current rating. Note 2 : Includes temperature rise caused by current flow. Note 3 : The term “storage” refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity Range covers non-conducting condition of installed connectors in storage, shipment or during transportation. Note 4 : FH52K withstands up to +125°C. ■Materials / Finish Part Material Insulator LCP Contacts Metal fittings Copper alloy Brass Finish Remarks Color : Grey Color : Black Partially gold plated Tine plated UL94V-0 –––––– ■Product Number Structure Refer to the chart below when datermining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. FH 52 E − 50 (25) S B − 0.5 SH (99) ❶ w e r t y u q Series name : FH w Series No. : 52 e Blank : Standard type E : Long metal fittings type K : Long metal fittings type, +125°C Heat Resistant type T : Long metal fittings type, 2-Point Contact type r Standard type : Number of contacts Alternating contact type : Mold size t Standard type : No symbol Alternating contact type : Number of contacts 2 i o !0 y Contact arrangement : Single (pole piece array) u Alternating direction : No symbol : Standard type (all contacts loaded) A : Alternating contact type (Alternating on the polarity side) B : Alternating contact type (Alternating on the opposite polarity side) i Contact pitch : 0.5mm, 1mm o Termination type SH : SMT horizontal mounting type !00 SpecificationBlank : Partially gold plated, 3,000pcs/reel (99) : Partially gold plated, 500pcs/reel FH52 Series●0.5mm and 1mm Pitch, 2mm Height, FPC/FFC ZIF Connectors ■Connector Dimensions [FH52 (Standard Type) 0.5mm Pitch product] A±0.15 B±0.08 (0.12) (5) 0.5±0.08 A ** a (0.15) (C) D±0.1 c b 6 c 1.75±0.2 a detail drawing ˚) (3.9) 10 1 2 (1 2±0.2 May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Cav No. Number of contacts indicator 0 0 (1.3) 0.15MAX Notes 1 The coplanarity of each terminal lead is within 0.1. 2 The contact terminal lead position indicates the dimension from the b surface, the bottom surface of the insulator body. 3 Packaged on tape and reel only. Check the packaging specification on Page 16 for details. 4 Sink mark reliefs may be added due to improvements 5 Sight variations in color of the plastic compounds do not affect form, fit or function. After reflow, the terminal plating may change color; however this does not represent a quality issue. 6 The dimensions of 60-contact actuators are shown in the figures. 0.15MAX 1 1.4±0.1 3±0.1 2 0.45±0.1 0.7±0.2 (4.3) 5.7±0.2 Unit : mm Part No. FH52-4S-0.5SH(**) FH52-5S-0.5SH(**) FH52-6S-0.5SH(**) FH52-8S-0.5SH(**) FH52-10S-0.5SH(**) FH52-11S-0.5SH(**) FH52-12S-0.5SH(**) FH52-15S-0.5SH(**) FH52-16S-0.5SH(**) FH52-18S-0.5SH(**) FH52-20S-0.5SH(**) FH52-22S-0.5SH(**) FH52-24S-0.5SH(**) FH52-25S-0.5SH(**) FH52-26S-0.5SH(**) FH52-28S-0.5SH(**) FH52-30S-0.5SH(**) FH52-32S-0.5SH(**) FH52-40S-0.5SH(**) FH52-42S-0.5SH(**) FH52-45S-0.5SH(**) FH52-50S-0.5SH(**) FH52-60S-0.5SH(**) HRS No. Under planning (Note 2) 580-3304-0 ** 580-3305-3 ** 580-3306-6 ** 580-3320-7 ** 580-3307-9 ** 580-3302-5 ** Under planning (Note 2) 580-3321-0 ** 580-3309-4 ** 580-3317-2 ** 580-3318-5 ** 580-3316-0 ** 580-3319-8 ** 580-3324-8 ** 580-3310-3 ** 580-3325-0 ** 580-3300-0 ** 580-3329-1 ** 580-3311-6 ** 580-3303-8 ** 580-3301-2 ** No. of contacts A B C D 4 5 6 8 10 11 12 15 16 18 20 22 24 25 26 28 30 32 40 42 45 50 60 6.3 6.8 7.3 8.3 9.3 9.8 10.3 11.8 12.3 13.3 14.3 15.3 16.3 16.8 17.3 18.3 19.3 20.3 24.3 25.3 26.8 29.3 34.3 1.5 2.0 2.5 3.5 4.5 5.0 5.5 7.0 7.5 8.5 9.5 10.5 11.5 12.0 12.5 13.5 14.5 15.5 19.5 20.5 22.0 24.5 29.5 2.57 3.07 3.57 4.57 5.57 6.07 6.57 8.07 8.57 9.57 10.57 11.57 12.57 13.07 13.57 14.57 15.57 16.57 20.57 21.57 23.07 25.57 30.57 4.7 5.2 5.7 6.7 7.7 8.2 8.7 10.2 10.7 11.7 12.7 13.7 14.7 15.2 15.7 16.7 17.7 18.7 22.7 23.7 25.2 27.7 32.7 Note 1 : Tape and reel packaging. (3,000pcs/reel, 500pcs/reel) Order by number of reels. Note 2 : Contact positions without HRS No. are currently under planning. Please contact hirose for detailed information about product variation. 3 FH52 Series●0.5mm and 1mm Pitch, 2mm Height, FPC/FFC ZIF Connectors ■Connector Dimensions [FH52 (Standard Type) 1mm Pitch product] A±0.15 (Q) (R) B±0.08 1±0.08 (5) (0.12) A ** a Cav No. May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. c (0.15) b (C) D±0.1 a detail drawing ˚) 1.75±0.2 10 (1 (3.9) 2±0.2 6 c 0 1 2 0 (1.3) 0.15MAX 0.15MAX 1 2 0.45±0.1 1.4±0.1 0.7±0.2 3±0.1 (4.3) 5.7±0.2 Notes 1 The coplanarity of each terminal lead is within 0.1. 2 The contact terminal lead position indicates the dimension from the b surface, the bottom surface of the insulator body. 3 Packaged on tape and reel only. Check the packaging specification on Page 16 for details. 4 Sink mark reliefs may be added due to improvements 5 Sight variations in color of the plastic compounds do not affect form, fit or function. After reflow, the terminal plating may change color; however this does not represent a quality issue. 6 The dimensions of 30-contact actuators are shown in the figures. Unit : mm Part No. FH52-10(4)SA-1SH(**) FH52-12S-1SH(**) FH52-32(16)SB-1SH(**) FH52-60(30)SB-1SH(**) HRS No. 580-3330-0 ** 580-3323-5 ** 580-3338-2 ** 580-3315-7 ** No. of contacts 4 12 16 30 Note 1 : Tape and reel packaging. (3,000pcs/reel, 500pcs/reel) Order by number of reels. 4 A 9.3 16.8 20.3 34.3 B 3 11 15 29 C 5.57 13.07 16.57 30.57 D 7.7 15.2 18.7 32.7 Q 2.9 2.9 2.4 2.4 R 3.4 2.9 2.9 2.9 FH52 Series●0.5mm and 1mm Pitch, 2mm Height, FPC/FFC ZIF Connectors ■Connector Dimensions [FH52E (Long Metal Fittings Type) 0.5mm Pitch product] A±0.15 B±0.08 (0.12) (5) 0.5±0.08 A ** a Number of contacts indicator c (C) b D±0.1 E±0.2 0˚ c 1 2 1.75±0.2 6 a detail drawing (3.9) 2±0.2 May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Cav No. ) 11 ( 0 0 0.15MAX Notes 1 The coplanarity of each terminal lead is within 0.1. 1.55±0.2 2 The contact terminal lead position indicates the dimension from the b surface, the bottom surface of the insulator body. 3 Packaged on tape and reel only. Check the packaging specification on Page 16 for details. 4 Sink mark reliefs may be added due to improvements 5 Sight variations in color of the plastic compounds do not affect form, fit or function. After reflow, the terminal plating may change color ; however this does not represent a quality issue. 6 The dimensions of 60-contact actuators are shown in the figures. 1.2±0.2(1.3) 0.15MAX 1 2 0.45±0.1 0.7±0.2 (4.3) 5.7±0.2 Unit : mm Part No. FH52E-4S-0.5SH(**) FH52E-5S-0.5SH(**) FH52E-6S-0.5SH(**) FH52E-8S-0.5SH(**) FH52E-10S-0.5SH(**) FH52E-11S-0.5SH(**) FH52E-12S-0.5SH(**) FH52E-15S-0.5SH(**) FH52E-16S-0.5SH(**) FH52E-18S-0.5SH(**) FH52E-20S-0.5SH(**) FH52E-22S-0.5SH(**) FH52E-24S-0.5SH(**) FH52E-25S-0.5SH(**) FH52E-26S-0.5SH(**) FH52E-28S-0.5SH(**) FH52E-30S-0.5SH(**) FH52E-32S-0.5SH(**) FH52E-40S-0.5SH(**) FH52E-42S-0.5SH(**) FH52E-45S-0.5SH(**) FH52E-50S-0.5SH(**) FH52E-60S-0.5SH(**) FH52E-64S-0.5SH(**) FH52E-68S-0.5SH(**) HRS No. Under planning (Note 2) 580-3349-0 ** 580-3346-0 ** Under planning (Note 2) 580-3337-0 ** Under planning (Note 2) 580-3331-3 ** 580-3357-0 ** 580-3343-2 ** 580-3340-4 ** Under planning (Note 2) 580-3347-3 ** Under planning (Note 2) 580-3334-1 ** Under planning (Note 2) 580-3335-4 ** 580-3339-5 ** 580-3333-9 ** 580-3332-6 ** No. of contacts A B C D E 4 5 6 8 10 11 12 15 16 18 20 22 24 25 26 28 30 32 40 42 45 50 60 64 68 6.3 6.8 7.3 8.3 9.3 9.8 10.3 11.8 12.3 13.3 14.3 15.3 16.3 16.8 17.3 18.3 19.3 20.3 24.3 25.3 26.8 29.3 34.3 36.3 38.3 1.5 2.0 2.5 3.5 4.5 5.0 5.5 7.0 7.5 8.5 9.5 10.5 11.5 12.0 12.5 13.5 14.5 15.5 19.5 20.5 22.0 24.5 29.5 31.5 33.5 2.57 3.07 3.57 4.57 5.57 6.07 6.57 8.07 8.57 9.57 10.57 11.57 12.57 13.07 13.57 14.57 15.57 16.57 20.57 21.57 23.07 25.57 30.57 32.57 34.57 4.55 5.05 5.55 6.55 7.55 8.05 8.55 10.05 10.55 11.55 12.55 13.55 14.55 15.05 15.55 16.55 17.55 18.55 22.55 23.55 25.05 27.55 32.55 34.55 36.55 7.1 7.6 8.1 9.1 10.1 10.6 11.1 12.6 13.1 14.1 15.1 16.1 17.1 17.6 18.1 19.1 20.1 21.1 25.1 26.1 27.6 30.1 35.1 37.1 39.1 Note 1 : Tape and reel packaging. (3,000pcs/reel, 500pcs/reel) Order by number of reels. Note 2 : Contact positions without HRS No. are currently under planning.Please contact hirose for detailed information about product variation. 5 FH52 Series●0.5mm and 1mm Pitch, 2mm Height, FPC/FFC ZIF Connectors ■Connector Dimensions [FH52E (Long Metal Fittings Type) 1mm Pitch product] A±0.15 (Q) (R) B±0.08 (0.12) (5) 1±0.08 A ** a Cav No. May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. c (C) b D±0.1 a detail drawing 2±0.2 E±0.2 ˚) 1.75±0.2 10 (1 (3.9) 6 c 0 1 2 0 0.15MAX 1.2±0.2 (1.3) 0.15MAX 0.45±0.1 1.55±0.2 0.7±0.2 1 2 (4.3) Notes 1 The coplanarity of each terminal lead is within 0.1. 5.7±0.2 2 The contact terminal lead position indicates the dimension from the b surface, the bottom surface of the insulator body. 3 Packaged on tape and reel only. Check the packaging specification on Page 16 for details. 4 Sink mark reliefs may be added due to improvements 5 Sight variations in color of the plastic compounds do not affect form, fit or function. After reflow, the terminal plating may change color; however this does not represent a quality issue. 6 The dimensions of 30-contact actuators are shown in the figures. Unit : mm Part No. FH52E-8(4)SB-1SH(**) FH52E-20(10)SA-1SH(**) FH52E-20(10)SB-1SH(**) FH52E-50(25)SA-1SH(**) FH52E-50(25)SB-1SH(**) FH52E-60(30)SB-1SH(**) HRS No. 580-3351-0 ** 580-3352-0 ** 580-3353-0 ** 580-3354-0 ** 580-3355-0 ** 580-3358-0 ** No. of contacts 4 10 10 25 25 30 Note 1 : Tape and reel packaging. (3,000pcs/reel, 500pcs/reel) Order by number of reels. 6 A 8.3 14.3 14.3 29.3 29.3 34.3 B 3 9 9 24 24 29 C 4.57 10.57 10.57 25.57 25.57 30.57 D 6.55 12.55 12.55 27.55 27.55 32.55 E 9.1 15.1 15.1 30.1 30.1 35.1 Q 2.4 2.9 2.4 2.9 2.4 2.4 R 2.9 2.4 2.9 2.4 2.9 2.9 FH52 Series●0.5mm and 1mm Pitch, 2mm Height, FPC/FFC ZIF Connectors ■Connector Dimensions [FH52K (Long Metal Fittings Type, 125°C Heat Resistant Type) 0.5mm Pitch product] A±0.15 B±0.08 (0.12) (5) 0.5±0.08 A ** Cav No. a c (C) b D±0.1 a detail drawing E±0.2 ˚) 10 2±0.2 (1 1.75±0.2 6 c (3.9) May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Number of contacts indicator 0 1 2 0 (1.3) 0.15MAX 1.2±0.2 0.15MAX 1.55±0.2 Unit : mm HRS No. No. of contacts A B C D E 580-4613-0 ** 580-4611-0 ** 580-4606-0 ** 6 8 10 12 15 18 20 22 24 25 26 30 32 34 40 50 60 64 68 7.3 8.3 9.3 10.3 11.8 13.3 14.3 15.3 16.3 16.8 17.3 19.3 20.3 21.3 24.3 29.3 34.3 36.3 38.3 2.5 3.5 4.5 5.5 7.0 8.5 9.5 10.5 11.5 12.0 12.5 14.5 15.5 16.5 19.5 24.5 29.5 31.5 33.5 3.57 4.57 5.57 6.57 8.07 9.57 10.57 11.57 12.57 13.07 13.57 15.57 16.57 17.57 20.57 25.57 30.57 32.57 34.57 5.55 6.55 7.55 8.55 10.05 11.55 12.55 13.55 14.55 15.05 15.55 17.55 18.55 19.55 22.55 27.55 32.55 34.55 36.55 8.1 9.1 10.1 11.1 12.6 14.1 15.1 16.1 17.1 17.6 18.1 20.1 21.1 22.1 25.1 30.1 35.1 37.1 39.1 Under planning (Note 2) 580-4604-0 ** Under planning (Note 2) 580-4600-9 ** 580-4601-0 ** Under planning (Note 2) 580-4614-0 ** 2 0.7±0.2 (4.3) Notes 1 The coplanarity of each terminal lead is within 0.1. 2 The contact terminal lead position indicates the dimension from the b surface, 5.7±0.2 the bottom surface of the insulator body. 3 Packaged on tape and reel only. Check the packaging specification on Page 16 for details. 4 Sink mark reliefs may be added due to improvements 5 Sight variations in color of the plastic compounds do not affect form, fit or function. After reflow, the terminal plating may change color; however this does not represent a quality issue. 6 The dimensions of 60-contact actuators are shown in the figures. Part No. FH52K-6S-0.5SH(**) FH52K-8S-0.5SH(**) FH52K-10S-0.5SH(**) FH52K-12S-0.5SH(**) FH52K-15S-0.5SH(**) FH52K-18S-0.5SH(**) FH52K-20S-0.5SH(**) FH52K-22S-0.5SH(**) FH52K-24S-0.5SH(**) FH52K-25S-0.5SH(**) FH52K-26S-0.5SH(**) FH52K-30S-0.5SH(**) FH52K-32S-0.5SH(**) FH52K-34S-0.5SH(**) FH52K-40S-0.5SH(**) FH52K-50S-0.5SH(**) FH52K-60S-0.5SH(**) FH52K-64S-0.5SH(**) FH52K-68S-0.5SH(**) 1 0.45±0.1 Note 1 : Tape and reel packaging. (3,000pcs/reel, 500pcs/reel) Order by number of reels. Note 2 : Contact positions without HRS No. are currently under planning. Please contact hirose for detailed information about product variation. 7 FH52 Series●0.5mm and 1mm Pitch, 2mm Height, FPC/FFC ZIF Connectors ■Connector Dimensions [FH52T (Long Metal Fittings Type, 2-Point Contact Type) 0.5mm Pitch product] A±0.15 (2.35) B±0.08 0.5±0.08 (2.45) (5) (0.08) A ** Cav No. a Number of contacts indicator (C) b D±0.1 a detail drawing E±0.2 ˚) 2±0.2 10 (1 (3.9) 6 c 1.75±0.2 May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. c 0 0 (1.2) 1 2 0.15MAX (1.6) 0.45±0.1 0.15MAX 1.2±0.2 1.55±0.2 Notes 1 The coplanarity of each terminal lead is within 0.1. 2 The contact terminal lead position indicates the dimension from the b surface, (4.2) 5.7±0.2 the bottom surface of the insulator body. 3 Packaged on tape and reel only. Check the packaging specification on Page 16 for details. 4 Sink mark reliefs may be added due to improvements 5 Sight variations in color of the plastic compounds do not affect form, fit or function. After reflow, the terminal plating may change color; however this does not represent a quality issue. 6 The dimensions of 60-contact actuators are shown in the figures. 1 2 0.7±0.2 Unit : mm Part No. FH52T-4S-0.5SH(**) FH52T-5S-0.5SH(**) FH52T-6S-0.5SH(**) FH52T-8S-0.5SH(**) FH52T-10S-0.5SH(**) FH52T-11S-0.5SH(**) FH52T-12S-0.5SH(**) FH52T-15S-0.5SH(**) FH52T-16S-0.5SH(**) FH52T-18S-0.5SH(**) FH52T-20S-0.5SH(**) FH52T-22S-0.5SH(**) FH52T-24S-0.5SH(**) FH52T-25S-0.5SH(**) FH52T-26S-0.5SH(**) FH52T-28S-0.5SH(**) FH52T-30S-0.5SH(**) FH52T-32S-0.5SH(**) FH52T-40S-0.5SH(**) FH52T-42S-0.5SH(**) FH52T-45S-0.5SH(**) FH52T-50S-0.5SH(**) FH52T-60S-0.5SH(**) FH52T-64S-0.5SH(**) FH52T-68S-0.5SH(**) HRS No. Under planning (Note 2) 580-4503-0 ** Under planning (Note 2) 580-4500-0 ** Under planning (Note 2) 580-4502-0 ** Under planning (Note 2) 580-4501-7 ** Under planning (Note 2) No. of contacts 4 5 6 8 10 11 12 15 16 18 20 22 24 25 26 28 30 32 40 42 45 50 60 64 68 A 6.3 6.8 7.3 8.3 9.3 9.8 10.3 11.8 12.3 13.3 14.3 15.3 16.3 16.8 17.3 18.3 19.3 20.3 24.3 25.3 26.8 29.3 34.3 36.3 38.3 B 1.5 2.0 2.5 3.5 4.5 5.0 5.5 7.0 7.5 8.5 9.5 10.5 11.5 12.0 12.5 13.5 14.5 15.5 19.5 20.5 22.0 24.5 29.5 31.5 33.5 C 2.57 3.07 3.57 4.57 5.57 6.07 6.57 8.07 8.57 9.57 10.57 11.57 12.57 13.07 13.57 14.57 15.57 16.57 20.57 21.57 23.07 25.57 30.57 32.57 34.57 D 4.55 5.05 5.55 6.55 7.55 8.05 8.55 10.05 10.55 11.55 12.55 13.55 14.55 15.05 15.55 16.55 17.55 18.55 22.55 23.55 25.05 27.55 32.55 34.55 36.55 E 7.1 7.6 8.1 9.1 10.1 10.6 11.1 12.6 13.1 14.1 15.1 16.1 17.1 17.6 18.1 19.1 20.1 21.1 25.1 26.1 27.6 30.1 35.1 37.1 39.1 Note 1 : Tape and reel packaging. (3,000pcs/reel, 500pcs/reel) Order by number of reels. Note 2 : Contact positions without HRS No. are currently under planning. Please contact hirose for detailed information about product variation. 8 FH52 Series●0.5mm and 1mm Pitch, 2mm Height, FPC/FFC ZIF Connectors BRecommended PCB Mounting Pattern and Metal Mask Dimensions Recommended metal mask thickness : 0.12mm B±0.05 Connector image 0.3±0.03(Land pattern) 0.25±0.03(Metal mask) 2±0.05 0.5±0.05 E±0.05 0.8±0.03 * The recommended PCB mounting pattern for the FH12 Series (horizontal mounting type) can be used as well. BRecommended FPC/FFC Dimensions [FH52 (Standard Type) 0.5mm Pitch product] G±0.05 B±0.03 0.5±0.07 0.5±0.03 0.5±0.07 0.35±0.03(FPC) 0.3±0.03(FFC) 0.3±0.05 2-R0.2±0.1 1 2-R0.2±0.1 1 2-R0.2±0.1 1 2-R0.2±0.05 1 (1MIN) 1.35±0.1 1 3.5MIN 2-R0.2±0.05 F±0.1 4.5MIN 1 1 3.1±0.1 May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4.6±0.05 0.85±0.05 [FH52 (Standard Type) 0.5mm Pitch product] Notes 1 FFC/FPC without tabs can also be used. In that case, the specified portions are not necessary. Part No. FH52-4S-0.5SH(**) FH52-5S-0.5SH(**) FH52-6S-0.5SH(**) FH52-8S-0.5SH(**) FH52-10S-0.5SH(**) FH52-11S-0.5SH(**) FH52-12S-0.5SH(**) FH52-15S-0.5SH(**) FH52-16S-0.5SH(**) FH52-18S-0.5SH(**) FH52-20S-0.5SH(**) FH52-22S-0.5SH(**) FH52-24S-0.5SH(**) FH52-25S-0.5SH(**) FH52-26S-0.5SH(**) FH52-28S-0.5SH(**) FH52-30S-0.5SH(**) FH52-32S-0.5SH(**) FH52-40S-0.5SH(**) FH52-42S-0.5SH(**) FH52-45S-0.5SH(**) FH52-50S-0.5SH(**) FH52-60S-0.5SH(**) HRS No. Under planning (Note 1) 580-3304-0 ** 580-3305-3 ** 580-3306-6 ** 580-3320-7 ** 580-3307-9 ** 580-3302-5 ** Under planning (Note 1) 580-3321-0 ** 580-3309-4 ** 580-3317-2 ** 580-3318-5 ** 580-3316-0 ** 580-3319-8 ** 580-3324-8 ** 580-3310-3 ** 580-3325-0 ** 580-3300-0 ** 580-3329-1 ** 580-3311-6 ** 580-3303-8 ** 580-3301-2 ** Unit : mm No. of contacts B E F G 4 5 6 8 10 11 12 15 16 18 20 22 24 25 26 28 30 32 40 42 45 50 60 1.5 2.0 2.5 3.5 4.5 5.0 5.5 7.0 7.5 8.5 9.5 10.5 11.5 12.0 12.5 13.5 14.5 15.5 19.5 20.5 22.0 24.5 29.5 4.1 4.6 5.1 6.1 7.1 7.6 8.1 9.6 10.1 11.1 12.1 13.1 14.1 14.6 15.1 16.1 17.1 18.1 22.1 23.1 24.6 27.1 32.1 4.1 4.6 5.1 6.1 7.1 7.6 8.1 9.6 10.1 11.1 12.1 13.1 14.1 14.6 15.1 16.1 17.1 18.1 22.1 23.1 24.6 27.1 32.1 2.5 3.0 3.5 4.5 5.5 6.0 6.5 8.0 8.5 9.5 10.5 11.5 12.5 13.0 13.5 14.5 15.5 16.5 20.5 21.5 23.0 25.5 30.5 Note 1 : Contact positions without HRS No. are currently under planning. Please contact hirose for detailed information about product variation. 9 FH52 Series●0.5mm and 1mm Pitch, 2mm Height, FPC/FFC ZIF Connectors BRecommended PCB Mounting Pattern and Metal Mask Dimensions 0.85±0.05 [FH52 (Standard Type) 1mm Pitch product] Recommended metal mask thickness : 0.12mm B±0.05 1±0.05 0.3±0.03 (Land pattern) 4.6±0.05 0.25±0.03 (Metal mask) May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2±0.05 (Connector image) S±0.05 T±0.05 E±0.05 0.8±0.03 BRecommended FPC/FFC Dimensions [FH52 (Standard Type) 1mm Pitch product] 1 F±0.1 G±0.07 0.3±0.05 0.6±0.03 1±0.05 2-R0.2±0.1 1 2-R0.2±0.1 1 2-R0.2±0.1 1 1.35±0.1 2-R0.2±0.05 4.5MIN 1 1 1 3.1±0.1 (1MIN) 3.5MIN 2-R0.2±0.05 V±0.1 B±0.05 U±0.1 Notes 1 FFC/FPC without tabs can also be used. In that case, the specified portions are not necessary. Unit : mm Part No. FH52-10(4)SA-1SH(**) FH52-12S-1SH(**) FH52-32(16)SB-1SH(**) FH52-60(30)SB-1SH(**) 10 HRS No. 580-3330-0 ** 580-3323-5 ** 580-3338-2 ** 580-3315-7 ** No. of contacts 4 12 16 30 B 3 11 15 29 E 7.1 14.6 18.1 32.1 F 7.1 14.6 18.1 32.1 G 5.5 13.0 16.5 30.5 S 1.8 1.8 1.3 1.3 T 2.3 1.8 1.8 1.8 U 1.5 1 1 1 V 1 1 0.5 0.5 FH52 Series●0.5mm and 1mm Pitch, 2mm Height, FPC/FFC ZIF Connectors BRecommended PCB Mounting Pattern and Metal Mask Dimensions Recommended metal mask thickness : 0.12mm Connector image (0.2) B±0.05 (0.2) 0.85±0.05 [FH52E (Long Metal Fittings Type) 0.5mm Pitch product] 0.3±0.03(Land pattern) 0.25±0.03(Metal mask) (0.3) F±0.05 (0.225) (0.5) 2±0.03 BRecommended FPC/FFC Dimensions [FH52E (Long Metal Fittings Type) 0.5mm Pitch product] 1 G±0.1 H±0.05 B±0.03 0.5±0.07 2-R0.2±0.05 0.5±0.03 0.5±0.07 0.3±0.05 0.35±0.03(FPC) 0.3±0.03(FFC) 2-R0.2±0.1 1 2-R0.2±0.1 1 2-R0.2±0.1 1 2-R0.2±0.05 1 3.1±0.1 1.35±0.1 1 1 4.5MIN (1MIN) 3.5MIN May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (0.3) 1.8±0.05 5.85±0.05 0.5±0.05 Notes 1 FFC/FPC without tabs can also be used. In that case, the specified portions are not necessary. Part No. FH52E-4S-0.5SH(**) FH52E-5S-0.5SH(**) FH52E-6S-0.5SH(**) FH52E-8S-0.5SH(**) FH52E-10S-0.5SH(**) FH52E-11S-0.5SH(**) FH52E-12S-0.5SH(**) FH52E-15S-0.5SH(**) FH52E-16S-0.5SH(**) FH52E-18S-0.5SH(**) FH52E-20S-0.5SH(**) FH52E-22S-0.5SH(**) FH52E-24S-0.5SH(**) FH52E-25S-0.5SH(**) FH52E-26S-0.5SH(**) FH52E-28S-0.5SH(**) FH52E-30S-0.5SH(**) FH52E-32S-0.5SH(**) FH52E-40S-0.5SH(**) FH52E-42S-0.5SH(**) FH52E-45S-0.5SH(**) FH52E-50S-0.5SH(**) FH52E-60S-0.5SH(**) FH52E-64S-0.5SH(**) FH52E-68S-0.5SH(**) HRS No. Under planning (Note 1) 580-3349-0 ** 580-3346-0 ** Under planning (Note 1) 580-3337-0 ** Under planning (Note 1) 580-3331-3 ** 580-3357-0 ** 580-3343-2 ** 580-3340-4 ** Under planning (Note 1) 580-3347-3 ** Under planning (Note 1) 580-3334-1 ** Under planning (Note 1) 580-3335-4 ** 580-3339-5 ** 580-3333-9 ** 580-3332-6 ** No. of contacts 4 5 6 8 10 11 12 15 16 18 20 22 24 25 26 28 30 32 40 42 45 50 60 64 68 Unit : mm B 1.5 2.0 2.5 3.5 4.5 5.0 5.5 7.0 7.5 8.5 9.5 10.5 11.5 12.0 12.5 13.5 14.5 15.5 19.5 20.5 22.0 24.5 29.5 31.5 33.5 F 4.1 4.6 5.1 6.1 7.1 7.6 8.1 9.6 10.1 11.1 12.1 13.1 14.1 14.6 15.1 16.1 17.1 18.1 22.1 23.1 24.6 27.1 32.1 34.1 36.1 G 4.1 4.6 5.1 6.1 7.1 7.6 8.1 9.6 10.1 11.1 12.1 13.1 14.1 14.6 15.1 16.1 17.1 18.1 22.1 23.1 24.6 27.1 32.1 34.1 36.1 H 2.5 3.0 3.5 4.5 5.5 6.0 6.5 8.0 8.5 9.5 10.5 11.5 12.5 13.0 13.5 14.5 15.5 16.5 20.5 21.5 23.0 25.5 30.5 32.5 34.5 Note 1 : Contact positions without HRS No. are currently under planning. Please contact hirose for detailed information about product variation. 11 FH52 Series●0.5mm and 1mm Pitch, 2mm Height, FPC/FFC ZIF Connectors BRecommended PCB Mounting Pattern and Metal Mask Dimensions 0.85±0.05 [FH52E (Long Metal Fittings Type) 1mm Pitch product] Recommended metal mask thickness : 0.12mm B±0.05 1±0.05 0.3±0.03 (Land pattern) (Connector image) T±0.05 S±0.05 1.8±0.05 May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5.85±0.05 0.25±0.03 (Metal mask) F±0.05 2±0.03 BRecommended FPC/FFC Dimensions [FH52E (Long Metal Fittings Type) 1mm Pitch product] 1 G±0.1 H±0.07 B±0.05 0.6±0.03 1±0.05 0.3±0.05 2-R0.2±0.1 1 1.35±0.1 2-R0.2±0.1 2-R0.2±0.05 1 1 1 1 1 3.1±0.1 3.5MIN 2-R0.2±0.1 4.5MIN 2-R0.2±0.05 V±0.1 (1MIN) U±0.1 Notes 1 FFC/FPC without tabs can also be used. In that case, the specified portions are not necessary. Unit : mm Part No. FH52E-8(4)SB-1SH(**) FH52E-20(10)SA-1SH(**) FH52E-20(10)SB-1SH(**) FH52E-50(25)SA-1SH(**) FH52E-50(25)SB-1SH(**) FH52E-60(30)SB-1SH(**) 12 HRS No. 580-3351-0 ** 580-3352-0 ** 580-3353-0 ** 580-3354-0 ** 580-3355-0 ** 580-3358-0 ** No. of contacts 4 10 10 25 25 30 B 3 9 9 24 24 34.3 F 6.1 12.1 12.1 27.1 27.1 32.1 G 6.1 12.1 12.1 27.1 27.1 32.1 H 4.5 10.5 10.5 25.5 25.5 30.5 S 1.3 1.8 1.3 1.8 1.3 1.3 T 1.8 1.3 1.8 1.3 1.8 1.8 U 1 0.5 1 0.5 1 1 V 0.5 1 0.5 1 0.5 0.5 FH52 Series●0.5mm and 1mm Pitch, 2mm Height, FPC/FFC ZIF Connectors BRecommended PCB Mounting Pattern and Metal Mask Dimensions [FH52K (Long Metal Fittings Type, 125°C Heat Resistant Type) 0.5mm Pitch product] (0.2) (0.2) 0.85±0.05 Recommended metal mask thickness : 0.12mm Connector image B±0.05 0.3±0.03(Land pattern) 0.25±0.03(Metal mask) (0.3) (0.3) F±0.05 (0.225) (0.5) 2±0.03 BRecommended FPC/FFC Dimensions [FH52K (Long Metal Fittings Type, 125°C Heat Resistant Type) 0.5mm Pitch product] 1 0.5±0.07 2-R0.2±0.05 0.5±0.03 G±0.1 H±0.05 B±0.03 0.35±0.03(FPC) 0.3±0.03(FFC) 0.3±0.05 0.5±0.07 2-R0.2±0.1 1 2-R0.2±0.1 1 2-R0.2±0.1 1 2-R0.2±0.05 1 3.1±0.1 1.35±0.1 1 1 4.5MIN (1MIN) 3.5MIN May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.8±0.05 5.85±0.05 0.5±0.05 Notes 1 FFC/FPC without tabs can also be used. In that case, the specified portions are not necessary. Unit : mm Part No. FH52K-6S-0.5SH(**) FH52K-8S-0.5SH(**) FH52K-10S-0.5SH(**) FH52K-12S-0.5SH(**) FH52K-15S-0.5SH(**) FH52K-18S-0.5SH(**) FH52K-20S-0.5SH(**) FH52K-22S-0.5SH(**) FH52K-24S-0.5SH(**) FH52K-25S-0.5SH(**) FH52K-26S-0.5SH(**) FH52K-30S-0.5SH(**) FH52K-32S-0.5SH(**) FH52K-34S-0.5SH(**) FH52K-40S-0.5SH(**) FH52K-50S-0.5SH(**) FH52K-60S-0.5SH(**) FH52K-64S-0.5SH(**) FH52K-68S-0.5SH(**) HRS No. 580-4613-0 ** 580-4611-0 ** 580-4606-0 ** Under planning (Note 1) 580-4604-0 ** Under planning (Note 1) 580-4600-9 ** 580-4601-0 ** Under planning (Note 1) 580-4614-0 ** No. of contacts 6 8 10 12 15 18 20 22 24 25 26 30 32 34 40 50 60 64 68 B 2.5 3.5 4.5 5.5 7.0 8.5 9.5 10.5 11.5 12.0 12.5 14.5 15.5 16.5 19.5 24.5 29.5 31.5 33.5 F 5.1 6.1 7.1 8.1 9.6 11.1 12.1 13.1 14.1 14.6 15.1 17.1 18.1 19.1 22.1 27.1 32.1 34.1 36.1 G 5.1 6.1 7.1 8.1 9.6 11.1 12.1 13.1 14.1 14.6 15.1 17.1 18.1 19.1 22.1 27.1 32.1 34.1 36.1 H 3.5 4.5 5.5 6.5 8.0 9.5 10.5 11.5 12.5 13.0 13.5 15.5 16.5 17.5 20.5 25.5 30.5 32.5 34.5 Note 1 : Contact positions without HRS No. are currently under planning. Please contact hirose for detailed information about product variation. 13 FH52 Series●0.5mm and 1mm Pitch, 2mm Height, FPC/FFC ZIF Connectors BRecommended PCB Mounting Pattern and Metal Mask Dimensions [FH52T (Long Metal Fittings Type, 2-Point Contact Type) 0.5mm Pitch product] 0.85±0.05 Recommended metal mask thickness : 0.12mm B±0.05 0.3±0.03 (Land pattern) 0.5±0.05 (Connector image) 1.8±0.05 May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5.85±0.05 0.25±0.03 (Metal mask) F±0.05 2±0.03 BRecommended FPC/FFC Dimensions [FH52T (Long Metal Fittings Type, 2-Point Contact Type) 0.5mm Pitch product] 1 0.5±0.07 0.5±0.03 0.3±0.05 0.5±0.07 2-R0.2±0.1 1 2-R0.2±0.1 1 2-R0.2±0.1 1 2-R0.2±0.05 1 3.1±0.1 1.35±0.1 1 1 4.5MIN (1MIN) 3.5MIN 2-R0.2±0.05 G±0.1 H±0.05 B±0.03 0.35±0.03(FPC) 0.3±0.03(FFC) Notes 1 FFC/FPC without tabs can also be used. In that case, the specified portions are not necessary. Part No. FH52T-4S-0.5SH(**) FH52T-5S-0.5SH(**) FH52T-6S-0.5SH(**) FH52T-8S-0.5SH(**) FH52T-10S-0.5SH(**) FH52T-11S-0.5SH(**) FH52T-12S-0.5SH(**) FH52T-15S-0.5SH(**) FH52T-16S-0.5SH(**) FH52T-18S-0.5SH(**) FH52T-20S-0.5SH(**) FH52T-22S-0.5SH(**) FH52T-24S-0.5SH(**) FH52T-25S-0.5SH(**) FH52T-26S-0.5SH(**) FH52T-28S-0.5SH(**) FH52T-30S-0.5SH(**) FH52T-32S-0.5SH(**) FH52T-40S-0.5SH(**) FH52T-42S-0.5SH(**) FH52T-45S-0.5SH(**) FH52T-50S-0.5SH(**) FH52T-60S-0.5SH(**) FH52T-64S-0.5SH(**) FH52T-68S-0.5SH(**) HRS No. Under planning (Note 1) 580-4503-0 ** Under planning (Note 1) 580-4500-0 ** Under planning (Note 1) 580-4502-0 ** Under planning (Note 1) 580-4501-7 ** Under planning (Note 1) Unit : mm No. of contacts 4 5 6 8 10 11 12 15 16 18 20 22 24 25 26 28 30 32 40 42 45 50 60 64 68 B 1.5 2.0 2.5 3.5 4.5 5.0 5.5 7.0 7.5 8.5 9.5 10.5 11.5 12.0 12.5 13.5 14.5 15.5 19.5 20.5 22.0 24.5 29.5 31.5 33.5 F 4.1 4.6 5.1 6.1 7.1 7.6 8.1 9.6 10.1 11.1 12.1 13.1 14.1 14.6 15.1 16.1 17.1 18.1 22.1 23.1 24.6 27.1 32.1 34.1 36.1 G 4.1 4.6 5.1 6.1 7.1 7.6 8.1 9.6 10.1 11.1 12.1 13.1 14.1 14.6 15.1 16.1 17.1 18.1 22.1 23.1 24.6 27.1 32.1 34.1 36.1 H 2.5 3.0 3.5 4.5 5.5 6.0 6.5 8.0 8.5 9.5 10.5 11.5 12.5 13.0 13.5 14.5 15.5 16.5 20.5 21.5 23.0 25.5 30.5 32.5 34.5 Note 1 : Contact positions without HRS No. are currently under planning. Please contact hirose for detailed information about product variation. 14 FH52 Series●0.5mm and 1mm Pitch, 2mm Height, FPC/FFC ZIF Connectors BFH52 Series FPC/FFC Construction (Recommended Specifications) 1. Using Single-Sided FPC FPC : Flexible Printed Circuit Material name Covering film layer Material Polyimide 1mil May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Cover adhesive 3 Surface treatment 0.2 µm thick gold plated over 1 to 5 µm thick nickel underplating Copper foil Cu Base adhesive Thermosetting adhesive 25 Base film Polyimide 1mil thick 25 Reinforcement material adhesive Thermosetting adhesive 30 Stiffener Polyimide 1oz 7mil thick 35 175 293 FPC : Flexible Printed Circuit Material name Covering film layer Material Polyimide 1mil Thickness (µm) (25) (25) Cover adhesive 3 Surface treatment 0.2 µm thick gold plated over 1 to 5 µm thick nickel underplating Through-hole copper Cu Copper foil Cu Base adhesive Thermosetting adhesive 18 Base film Polyimide 25 Base adhesive Thermosetting adhesive Copper foil Cu Cover adhesive Thermosetting adhesive 25 Covering layer film Polyimide 25 Reinforcement material adhesive Thermosetting adhesive Stiffener Polyimide * To prevent release of the FPC due to its bending, use of the double sided FPC with copper foil on the back side is not recommended. 3. Using FFC (25) (25) Total 2. Using Double-Sided FPC Thickness (µm) 15 1/2oz 1mil thick 1/2oz 1mil thick 4mil thick 18 18 (18) 50 100 297 Total FFC : Flexible Flat Cable Material name Material Polyester film Adhesive (12) Thermoplastic polyester (30) 35 Gold plated annealed copper foil Adhesive Thickness (µm) Polyester 30 12 Polyester Adhesive Polyester 30 Stiffener Polyester 188 Total 295 * Typical thickness tolerance is about ±20µm 1. This specification is a recommendation for the construction of the FH52 Series FPC and FFC (t = 0.3 ± 0.05mm). 2. For details about the construction, please contact the FPC/FFC manufacturers. 15 FH52 Series●0.5mm and 1mm Pitch, 2mm Height, FPC/FFC ZIF Connectors BPackaging Specification ●Embossed carrier tape dimensions ●Embossed carrier tape dimensions 1.7 +0.15 0 1.5+0.1 0 Unreeling direction ●Reel Dimensions May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (2.4) (0.3) (J) K±0.1 M±0.1 L±0.3 (4.65) (6.4) Unreeling direction 1.75±0.1 2±0.1 12±0.1 Ø1 .5 + 0 0 .1 4±0.1 0 0 .1 (tape width 32mm or more) (2.4) (0.3) (J) K±0.1 L±0.3 Ø1 .5 + 2±0.1 12±0.1 4±0.1 1.75±0.1 (tape width 24mm or less) (4.65) (6.4) 1± Ø80±1 Ø2 N±1: Reel outside width Ø380±2 0.8 a detail drawing 2±0.5 Ø13±0.2 P±1: Reel inside width R1 a End section Mounting section Blank section Lead section (400mm min.) Embossed carrier tape Blank section (15 pockets min.) Top cover tape (10 pockets min.) [FH52 (Standard Type) 0.5mm Pitch product] Part No. FH52-4S-0.5SH(**) FH52-5S-0.5SH(**) FH52-6S-0.5SH(**) FH52-8S-0.5SH(**) FH52-10S-0.5SH(**) FH52-11S-0.5SH(**) FH52-12S-0.5SH(**) FH52-15S-0.5SH(**) FH52-16S-0.5SH(**) FH52-18S-0.5SH(**) FH52-20S-0.5SH(**) FH52-22S-0.5SH(**) FH52-24S-0.5SH(**) FH52-25S-0.5SH(**) FH52-26S-0.5SH(**) FH52-28S-0.5SH(**) FH52-30S-0.5SH(**) FH52-32S-0.5SH(**) FH52-40S-0.5SH(**) FH52-42S-0.5SH(**) FH52-45S-0.5SH(**) FH52-50S-0.5SH(**) FH52-60S-0.5SH(**) HRS No. Under planning (Note 1) 580-3304-0 ** 580-3305-3 ** 580-3306-6 ** 580-3320-7 ** 580-3307-9 ** 580-3302-5 ** Under planning (Note 1) 580-3321-0 ** 580-3309-4 ** 580-3317-2 ** 580-3318-5 ** 580-3316-0 ** 580-3319-8 ** 580-3324-8 ** 580-3310-3 ** 580-3325-0 ** 580-3300-0 ** 580-3329-1 ** 580-3311-6 ** 580-3303-8 ** 580-3301-2 ** No. of contacts 4 5 6 8 10 11 12 15 16 18 20 22 24 25 26 28 30 32 40 42 45 50 60 Unit : mm J 6.6 7.1 7.6 8.6 9.6 10.1 10.6 12.1 12.6 13.6 14.6 15.6 16.6 17.1 17.6 18.6 19.6 20.6 24.6 25.6 27.1 29.6 34.6 K 7.5 L 16.0 M ––––––– ––––––– ––––––– ––––––– ––––––– ––––––– ––––––– ––––––– ––––––– ––––––– ––––––– N 21.4 P 17.4 11.5 24.0 29.4 25.4 14.2 32.0 28.4 37.4 33.4 20.2 44.0 40.4 49.4 45.4 26.2 56.0 52.4 61.4 57.4 [FH52 (Standard Type) 1mm Pitch product] Part No. FH52-10(4)SA-1SH(**) FH52-12S-1SH(**) FH52-32(16)SB-1SH(**) FH52-60(30)SB-1SH(**) HRS No. 580-3330-0 ** 580-3323-5 ** 580-3338-2 ** 580-3315-7 ** Unit : mm No. of contacts 4 12 16 30 J 9.6 17.1 20.6 34.6 K 11.5 14.2 20.2 26.2 L 24.0 32.0 44.0 56.0 M ––––––– 28.4 40.4 52.4 N 29.4 37.4 49.4 61.4 P 25.4 33.4 45.4 57.4 Note 1 : Contact positions without HRS No. are currently under planning. Please contact hirose for detailed information about product variation. 16 FH52 Series●0.5mm and 1mm Pitch, 2mm Height, FPC/FFC ZIF Connectors May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. [FH52E (Long Metal Fittings Type) 0.5mm Pitch product] Part No. FH52E-4S-0.5SH(**) FH52E-5S-0.5SH(**) FH52E-6S-0.5SH(**) FH52E-8S-0.5SH(**) FH52E-10S-0.5SH(**) FH52E-11S-0.5SH(**) FH52E-12S-0.5SH(**) FH52E-15S-0.5SH(**) FH52E-16S-0.5SH(**) FH52E-18S-0.5SH(**) FH52E-20S-0.5SH(**) FH52E-22S-0.5SH(**) FH52E-24S-0.5SH(**) FH52E-25S-0.5SH(**) FH52E-26S-0.5SH(**) FH52E-28S-0.5SH(**) FH52E-30S-0.5SH(**) FH52E-32S-0.5SH(**) FH52E-40S-0.5SH(**) FH52E-42S-0.5SH(**) FH52E-45S-0.5SH(**) FH52E-50S-0.5SH(**) FH52E-60S-0.5SH(**) FH52E-64S-0.5SH(**) FH52E-68S-0.5SH(**) HRS No. Under planning (Note 1) 580-3349-0 ** 580-3346-0 ** Under planning (Note 1) 580-3337-0 ** Under planning (Note 1) 580-3331-3 ** 580-3357-0 ** 580-3343-2 ** 580-3340-4 ** Under planning (Note 1) 580-3347-3 ** Under planning (Note 1) 580-3334-1 ** Under planning (Note 1) 580-3335-4 ** 580-3339-5 ** 580-3333-9 ** 580-3332-6 ** No. of contacts 4 5 6 8 10 11 12 15 16 18 20 22 24 25 26 28 30 32 40 42 45 50 60 64 68 J 6.6 7.1 7.6 8.6 9.6 10.1 10.6 12.1 12.6 13.6 14.6 15.6 16.6 17.1 17.6 18.6 19.6 20.6 24.6 25.6 27.1 29.6 34.6 36.6 38.6 Unit : mm K 7.5 L 16.0 M ––––––– ––––––– ––––––– ––––––– ––––––– ––––––– ––––––– ––––––– ––––––– ––––––– ––––––– N 21.4 P 17.4 11.5 24.0 29.4 25.4 14.2 32.0 28.4 37.4 33.4 20.2 44.0 40.4 49.4 45.4 26.2 56.0 52.4 61.4 57.4 K L N P 11.5 24.0 M ––––––– ––––––– ––––––– 29.4 25.4 20.2 44.0 40.4 49.4 45.4 26.2 56.0 52.4 61.4 57.4 [FH52E (Long Metal Fittings Type) 1mm Pitch product] Part No. FH52E-8(4)SB-1SH(**) FH52E-20(10)SA-1SH(**) FH52E-20(10)SB-1SH(**) FH52E-50(25)SA-1SH(**) FH52E-50(25)SB-1SH(**) FH52E-60(30)SB-1SH(**) HRS No. 580-3351-0 ** 580-3352-0 ** 580-3353-0 ** 580-3354-0 ** 580-3355-0 ** 580-3358-0 ** No. of contacts 4 10 10 25 25 30 Unit : mm J 8.6 14.6 14.6 29.6 29.6 34.6 [FH52K (Long Metal Fittings Type, 125°C Heat Resistant Type) 0.5mm Pitch product] Part No. FH52K-6S-0.5SH(**) FH52K-8S-0.5SH(**) FH52K-10S-0.5SH(**) FH52K-12S-0.5SH(**) FH52K-15S-0.5SH(**) FH52K-18S-0.5SH(**) FH52K-20S-0.5SH(**) FH52K-22S-0.5SH(**) FH52K-24S-0.5SH(**) FH52K-25S-0.5SH(**) FH52K-26S-0.5SH(**) FH52K-30S-0.5SH(**) FH52K-32S-0.5SH(**) FH52K-34S-0.5SH(**) FH52K-40S-0.5SH(**) FH52K-50S-0.5SH(**) FH52K-60S-0.5SH(**) FH52K-64S-0.5SH(**) FH52K-68S-0.5SH(**) HRS No. 580-4613-0 ** 580-4611-0 ** 580-4606-0 ** Under planning (Note 1) 580-4604-0 ** Under planning (Note 1) 580-4600-9 ** 580-4601-0 ** Under planning (Note 1) 580-4614-0 ** No. of contacts 6 8 10 12 15 18 20 22 24 25 26 30 32 34 40 50 60 64 68 J 7.6 8.6 9.6 10.6 12.1 13.6 14.6 15.6 16.6 17.1 17.6 19.6 20.6 21.6 24.6 29.6 34.6 36.6 38.6 K L 11.5 24.0 14.2 32.0 20.2 26.2 M ––––––– ––––––– ––––––– ––––––– ––––––– ––––––– ––––––– Unit : mm N P 29.4 25.4 28.4 37.4 33.4 44.0 40.4 49.4 45.4 56.0 52.4 61.4 57.4 Note 1 : Contact positions without HRS No. are currently under planning. Please contact hirose for detailed information about product variation. 17 FH52 Series●0.5mm and 1mm Pitch, 2mm Height, FPC/FFC ZIF Connectors [FH52T (Long Metal Fittings Type, 2-Point Contact Type) 0.5mm Pitch product] May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. FH52T-4S-0.5SH(**) FH52T-5S-0.5SH(**) FH52T-6S-0.5SH(**) FH52T-8S-0.5SH(**) FH52T-10S-0.5SH(**) FH52T-11S-0.5SH(**) FH52T-12S-0.5SH(**) FH52T-15S-0.5SH(**) FH52T-16S-0.5SH(**) FH52T-18S-0.5SH(**) FH52T-20S-0.5SH(**) FH52T-22S-0.5SH(**) FH52T-24S-0.5SH(**) FH52T-25S-0.5SH(**) FH52T-26S-0.5SH(**) FH52T-28S-0.5SH(**) FH52T-30S-0.5SH(**) FH52T-32S-0.5SH(**) FH52T-40S-0.5SH(**) FH52T-42S-0.5SH(**) FH52T-45S-0.5SH(**) FH52T-50S-0.5SH(**) FH52T-60S-0.5SH(**) FH52T-64S-0.5SH(**) FH52T-68S-0.5SH(**) HRS No. Under planning (Note 1) 580-4503-0 ** Under planning (Note 1) 580-4500-0 ** Under planning (Note 1) 580-4502-0 ** Under planning (Note 1) 580-4501-7 ** Under planning (Note 1) No. of contacts 4 5 6 8 10 11 12 15 16 18 20 22 24 25 26 28 30 32 40 42 45 50 60 64 68 J 6.6 7.1 7.6 8.6 9.6 10.1 10.6 12.1 12.6 13.6 14.6 15.6 16.6 17.1 17.6 18.6 19.6 20.6 24.6 25.6 27.1 29.6 34.6 36.6 38.6 K 7.5 L 16.0 11.5 24.0 14.2 Unit : mm M ––––––– ––––––– ––––––– ––––––– ––––––– ––––––– ––––––– ––––––– ––––––– ––––––– ––––––– N 21.4 P 17.4 29.4 25.4 32.0 28.4 37.4 33.4 20.2 44.0 40.4 49.4 45.4 26.2 56.0 52.4 61.4 57.4 Note 1 : Contact positions without HRS No. are currently under planning. Please contact hirose for detailed information about product variation. BRecommended Temperature Profile MAX 250ç Temperature 250 230ç 200 200ç 150 150ç (ç) 100 50 0 25℃ (60sec.) 90sec. to 120sec. Preheating time (30sec.) Soldering time Start 180 Time (seconds) 18 HRS test condition Solder method Reflow furnace atmosphere Solder composition : Reflow, IR : Atmosphere : Paste, 96.5%Sn/3.0%Ag/0.5%Cu (Senju Metal Industry's Part Number : M705221CM5-32-10.5) Test board : Material and size Glass epoxy : 80mm × 100mm × 1.6mm thick Land dimensions : 0.3 × 0.85mm Metal mask dimensions : 0.12mm thick Opening dimensions : 0.25 × 0.85mm The temperature profiles are based on the above conditions. In individual applications the actual temperature may vary, depending on solder paste type, volume/thickness and board size/thickness. Consult your solder paste and equipment manufacturer for specific recommendations. FH52 Series●0.5mm and 1mm Pitch, 2mm Height, FPC/FFC ZIF Connectors BOperation and Precautions Operation 1. FPC/FFC insertion procedure qLift up the actuator to release the lock. May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. You can easily pop it up with the thumbnail or index-finger nail. Precautions qThe FH52 Series is equipped with an actuator that rotates approximately 110°. Do not apply a force to open it beyond its fully open position. The actuator may come off or be permanently damaged. wInsert the FPC or FFC with the exposed conductive traces facing down. When connecting a tabbed FPC or FFC, securely insert it to the bottom, perpendicular to the connector with an angle of 10° with respect to the PCB surface, using the FFC/FPC positioning guide. wInsert the FPC or FFC properly to the opening of the connector. Improper insertion may lead to a break or poor continuity of the FPC or FFC. FFC/FPC positioning guide eRotate down the actuator until firmly closed. eThe connector does not have a strong upward tensile strength owing to its structure. Secure the FPC or FFC when it is subjected to a tensile force. 2. FPC/FFC removal qLift up the actuator to release the lock. Pull up the FPC or FFC a little and then withdraw it from the connector. rWhen inserting an FPC or FFC, do not rub it vigorously against the bottom side of the connector opening. Excessive contact between the contacts and the FPC or FFC may result in the deformation of contacts, peeling of conductive traces, or other faults. FFC positioning guide 19 FH52 Series●0.5mm and 1mm Pitch, 2mm Height, FPC/FFC ZIF Connectors BPrecautions (Mating/Un-Mating FPC/FFC with the Retention Tabs) Operation Precautions 1. How to insert wAvoid “ride on” May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Insert the cable into the ) between interspace ( at the mold walls ( both ends of entrance where the connector is inserted and the guide walls ) at both ends of ( interior connector so the cable tabs are properly located. Avoid insertion so the cables ride on any guide. Be sure NOT to close the actuator as the cables ride on any guide. It may cause conduction failure. Ride on the both guides 2. Precautions when mating/un-mating qAvoid insertion in Diagonal insertion diagonal direction. Ride on the right guide Do not insert the cable in diagonal direction. A part of the connector may touches the contacts resulting in deformation of the contacts. Correct insertion Be sure to insert the FPC or FFC straight into the connector opening until the bottom of the connector. Perpendicular to the connector ® 20 FFC/FPC retention tab FFC/FPC positioning guide 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 08/2017. Contents are subject to change without notice for the purpose of improvements.
FH52-15S-0.5SH 价格&库存
很抱歉,暂时无法提供与“FH52-15S-0.5SH”相匹配的价格&库存,您可以联系我们找货
FH52-15S-0.5SH
  • 1+1.39350
库存:1608
FH52-15S-0.5SH
    • 1+16.923691+2.04174
    • 15+15.3851815+1.85613
    • 75+14.5706775+1.75786
    • 300+13.84666300+1.67051
    • 1500+12.941651500+1.56133
    库存:10
