FH43BW-35S-0.2SHW(10)
    HRS(广濑)
    SMD,P=0.2mm
    CONNFPC35POS.2MM
FH43BW-35S-0.2SHW(10) 数据手册
0.2 mm Pitch, 0.9 mm Height FPC Connectors FH43B Series m 7m 2.7 11.8 mm( 0.9mm The staggered lead structure simplifies PCB mounting and provides a low profile height of 0.9 mm and a 2.77 mm mounting width depth. 51 p os.) Aug.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Fig 1. ■Features FH43B differential impedance 1. 0.2 mm pitch low profile bottom contact FPC connector Spec MAX : 115ohm Maximizes space with contact pitch of 0.2 mm, a mated height of 0.9 mm, and mounted depth of 2.77 mm. *45% reduction in occupied PCB area *55% reduction in weight (Compared to our 0.3 mm pitch FH26 Series 51 position connector) 97.2 2. Easy PCB mounting 100.6 Connector The PCB leads use 0.4 mm pitch and are staggered which simplifies the PCB mounting process. FPC Spec MIN : 85ohm 3. Supports high-speed transmissions By utilizing differential pairs of identical contacts (even - even contact or odd - odd contacts) these connectors are able to provide superb transmission characteristics and supports eDP (ver. 1.3), MIPI (D-PHY), HDMI (ver 1.3), and USB (3.0) standards. impedance@200ps rise time(10-90%) FPC insertion Actuator open 4. Molded structure aids PCB layout The bottom of this connector is enclosed by a fully molded structure that protects the contacts and removes any restrictions from PCB patterning and layout design. 5. Rotating one-touch ZIF mechanism The one-touch rotating ZIF mechanism is easier to operate and works with a light force, and a clear tactile click is delivered upon the successful completion of the mating process. FPC 6. Easy FPC insertion The FPC aligning mechanism holds onto the FPC prior to locking the actuator. With actuator locked 7. Insertion check window There is a cutout on the actuator that allows you to visually inspect the FPC to make sure that it is locked into place, preventing incorrect insertion of the FPC. 8. Accepts standard 0.2 mm thick FPC This connector accepts standard 0.2 mm thick FPC. (A stiffener with adequate strength will prevent FPC deformation and ease insertion and mating.) 9. Halogen-free available (FH43BW Series) The connector does not use chlorine and bromine exceeding standard limits. (FH43BW Series) *Defined in accordance with IEC61249-2-21 Br 900ppm or lower, Cl 900ppm or lower, Br + Cl 1,500ppm or lower FPC temporary retention system 10.Available for 500 pieces packaging Although the normal product is 5,000 pieces per reel, 500 winds per reel is also available. (Emboss reel external diameter is Ø180mm.) FPC temporary retention system In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. visual check area to confirm mating 2014.3w 1 FH43B Series●0.2 mm Pitch, 0.9 mm Height FPC Connectors ■Product Specifications Current DC 0.2 A Rating (Note 1) Rating Voltage Operating AC 30 Vrms Rating Humidity Range Recommended FPC spec Items Storage Temperature Range Relative humidity 90% max Storing Humidity (should be no condensation) Range Specifications 100 V DC 2. Withstanding Voltage No flashover or breakdown 100 mø Max. *Excluding FPC conductor resistance 90 V AC for 1 Min 1 mA Contact Resistance: 100 mø Max No damage, cracks and looseness of parts 5. Vibration 6. Shock 7. Humidity (Steady State) 8. Temperature Cycle 9. Resistance to soldering heat Relative humidity 90% max (should be no condensation) Conditions 50 Mø Min 4. Durability -10 to +50℃ (Note 3) t = 0.2 ±0.02 Gold plating 1. Insulation Resistance 3. Contact Resistance Aug.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Operating -55 to +85℃ (Note 2) Temperature Range No electrical discontinuity of 1µ or longer Contact Resistance: 100 mø Max No damage, cracks and looseness of parts No electric discontinuity of 1µ or longer Contact Resistance: 100 mø Max No damage, cracks and looseness of parts Contact Resistance: 100 mø Max Insulation Resistance: 50 Mø Min No damage, cracks and looseness of parts Contact Resistance: 100 mø Max Insulation Resistance: 50 Mø Min No damage, cracks and looseness of parts No deformation of case of excessive looseness of the terminal 10 cycles Frequency 10 to 55Hz, Half amplitude 0.75 mm for 10 cycles in 3 axial directions 2 Acceleration: 981 m/s , Retention time: 6 ms, Semisinusoidal 3 times in 3 both axial directions 96 hours at 40ç and humidity of 90 to 95% Temperature: -55 → +15 to +35 → +85 → +15 to +35ç Time: 30 → 2 to 3 → 30 → 2 to 3 minutes 5 cycles 1) Reflow: Peak TMP 250ç MAX, reflow TMP over 230ç within 60 seconds 2) Manual soldering: 350 ±10ç for 5 seconds (Note 1) When electrifying rated current to all contacts, use 70% of rated current. (Note 2) Includes temperature rise caused by current flow. (Note 3) The term “storage” refers to the long-term storage condition of unused products before PCB mounting. For no-electrification state after PCB mounting, the operating temperature and humidity are applied. ■Materials Product Materials Color/Finish LCP Beige Insulator FH43B Series: Deep brown PA Contacts Phosphor bronze Metal fittings Remarks UL94V-0 FH43BW Series: Black UL94HB Gold plating ― Pure tin reflow plating ― ■Product Number Structure Refer to this page when determining product specifications by model types. Please place orders with part numbers listed in this catalog. The characteristics and specifications of the product described in this catalog are reference values. Please make sure to check the latest delivery specifications at the time of product use. FH 43B W − 51S − 0.2 SHW (10) ❶ ❷ ❸ ❶ Series Name: FH ❷ Series No.: 43B ❸ Blank: Standard W: Halogen-free product ❹ No. of Contacts: 21~71 ❺ Contact Pitch: 0.2 mm 2 ❹ ❺ ❻ ❼ ❻ Terminal Type SHW ... SMT horizontal staggered row mounting type ❼ Specifications (10):Nickel barrier gold plating, 5,000 pieces per reel (99):Nickel barrier gold plating 500 pieces per reel FH43B Series●0.2 mm Pitch, 0.9 mm Height FPC Connectors ■Connector Dimensions (0.08) P Enlarged figure Lot No. HRS mark Polarization mark 0.4±0.1 Cavity No. No. of contacts (0.08) C±0.1 Aug.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. P (D) E±0.1 Contact point (0.31) Contact No.1 FPC:t0.2 (0.95) (2.85) (2.08) 0.9±0.1 (1.75) (2) 0.4±0.1 Contact No.2 A±0.15 B±0.1 (9 (1 0°) 25 °) 0.2±0.1 (0.53) (1.2) (1.6) 2.17±0.15 0.47±0.1 0.4±0.15 (0.12) 0.3±0.1 0.2±0.15 (0.45) (2.5) Note 1: The dimensions in parentheses are for reference. 2: Lead coplanarity including reinforced metal fittings shall be 0.1 mm MAX. 3: To be delivered with tape and reel packages. See attached packaging specifications for details. 4: Note that preventive hole for sink mark or slit could be added for improvement. 5: The quality remains good, even with the dark spots, which could occasionally occur on molded plastic. 6: The color of the plating may change after the reflow process, but it will not negatively affect the performance of these connectors. Unit: mm HRS No. No. of Contacts A B C D E FH43B-21S-0.2SHW(**) Product No. CL580-2810-0-** 21 5.8 3.6 4 4.53 5.29 FH43B-25S-0.2SHW(**) CL580-2804-8-** 25 6.6 4.4 4.8 5.33 6.09 FH43B-29S-0.2SHW(**) CL580-2811-3-** 29 7.4 5.2 5.6 6.13 6.89 FH43B-31S-0.2SHW(**) CL580-2808-9-** 31 7.8 5.6 6 6.53 7.29 FH43B-35S-0.2SHW(**) CL580-2803-5-** 35 8.6 6.4 6.8 7.33 8.09 FH43B-41S-0.2SHW(**) CL580-2809-1-** 41 9.8 7.6 8 8.53 9.29 FH43B-45S-0.2SHW(**) CL580-2812-6-** 45 10.6 8.4 8.8 9.33 10.09 FH43B-51S-0.2SHW(**) CL580-2806-3-** 51 11.8 9.6 10 10.53 11.29 FH43B-61S-0.2SHW(**) CL580-2805-0-** 61 13.8 11.6 12 12.53 13.29 FH43B-71S-0.2SHW(**) CL580-2807-6-** 71 15.8 13.6 14 14.53 15.29 Product No. HRS No. No. of Contacts A B C D E FH43BW-21S-0.2SHW(**) CL580-2822-0-** 21 5.8 3.6 4 4.53 5.29 FH43BW-25S-0.2SHW(**) - 25 6.6 4.4 4.8 5.33 6.09 FH43BW-29S-0.2SHW(**) - 29 7.4 5.2 5.6 6.13 6.89 FH43BW-31S-0.2SHW(**) CL580-2820-4-** 31 7.8 5.6 6 6.53 7.29 FH43BW-35S-0.2SHW(**) CL580-2821-7-** 35 8.6 6.4 6.8 7.33 8.09 FH43BW-41S-0.2SHW(**) CL580-2813-9-** 41 9.8 7.6 8 8.53 9.29 FH43BW-45S-0.2SHW(**) CL580-2815-4-** 45 10.6 8.4 8.8 9.33 10.09 FH43BW-51S-0.2SHW(**) CL580-2814-1-** 51 11.8 9.6 10 10.53 11.29 FH43BW-61S-0.2SHW(**) CL580-2816-7-** 61 13.8 11.6 12 12.53 13.29 FH43BW-71S-0.2SHW(**) CL580-2819-5-** 71 15.8 13.6 14 14.53 15.29 (Note 1)This product is packaged on tape and reel and is only sold in full reel quantities of either 5,000 or 500 piece reels. Please place orders by full reel quantities. 3 FH43B Series●0.2 mm Pitch, 0.9 mm Height FPC Connectors BRecommended PCB Mounting Pattern B 0.4 (0.2) 0.65±0.03 0.2 0.2±0.02 Contact No.2 (n-1)/2× 0.04 Contact No.1 0.4±0.05 0.4 X Aug.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.2±0.02 C±0.04 (n+1)/2× 0.04 0.485±0.05 0.9±0.03 1.6±0.05 1.65±0.05 0.87±0.03 3.17±0.05 Connector Image (Mounting Section) 0.55±0.03 BRecommended Stencil Pattern (Recommended stencil thickness: t= 0.1) 0.2 B 0.4 0.18±0.01 (n-1)/2× 0.04 Y 1.92±0.05 0.3±0.03 0.4 0.18±0.01 C±0.04 Y (n+1)/2× 0.04 Y 0.585±0.05 0.68±0.03 1.94±0.05 0.68±0.03 3.17±0.05 (PCB mounting pattern image) Note 7: 'n' is the number of contacts. Product No. 4 Unit: mm C HRS No. No. of Contacts B FH43B-21S-0.2SHW(**) CL580-2810-0-** 21 3.6 4 FH43B-25S-0.2SHW(**) CL580-2804-8-** 25 4.4 4.8 FH43B-29S-0.2SHW(**) CL580-2811-3-** 29 5.2 5.6 FH43B-31S-0.2SHW(**) CL580-2808-9-** 31 5.6 6 FH43B-35S-0.2SHW(**) CL580-2803-5-** 35 6.4 6.8 FH43B-41S-0.2SHW(**) CL580-2809-1-** 41 7.6 8 FH43B-45S-0.2SHW(**) CL580-2812-6-** 45 8.4 8.8 FH43B-51S-0.2SHW(**) CL580-2806-3-** 51 9.6 10 FH43B-61S-0.2SHW(**) CL580-2805-0-** 61 11.6 12 FH43B-71S-0.2SHW(**) CL580-2807-6-** 71 13.6 14 Product No. HRS No. No. of Contacts B C FH43BW-21S-0.2SHW(**) CL580-2822-0-** 21 3.6 4 FH43BW-25S-0.2SHW(**) - 25 4.4 4.8 FH43BW-29S-0.2SHW(**) - 29 5.2 5.6 FH43BW-31S-0.2SHW(**) CL580-2820-4-** 31 5.6 6 FH43BW-35S-0.2SHW(**) CL580-2821-7-** 35 6.4 6.8 FH43BW-41S-0.2SHW(**) CL580-2813-9-** 41 7.6 8 FH43BW-45S-0.2SHW(**) CL580-2815-4-** 45 8.4 8.8 FH43BW-51S-0.2SHW(**) CL580-2814-1-** 51 9.6 10 FH43BW-61S-0.2SHW(**) CL580-2816-7-** 61 11.6 12 FH43BW-71S-0.2SHW(**) CL580-2819-5-** 71 13.6 14 FH43B Series●0.2 mm Pitch, 0.9 mm Height FPC Connectors BRecommended FPC Pattern 0.25±0.05 0.25±0.05 C±0.02 R 0.4 0.4 (n+1)/2× 0.04 Z R0.2MAX Contact No.1 R0.2MAX R0.2±0.1 R0.2±0.1 3.1±0.3(Stiffener) 2.1±0.3 1.6±0.05 1.1±0.05 Z 0.2+0.03 −0.02 8 0.1±0.03 8 0.1±0.03 8 0.055±0.02 0.2 0.75±0.1(Odd pattern) 0.76±0.1(Even pattern) 1.55±0.15 0.74±0.1(Even pattern) 0.75±0.1(Odd pattern) 1.45±0.1 0.2±0.02 A±0.1 (F) G±0.05 R0.2MAX 9 0.055±0.02 0.2+0.03 −0.02 0.67±0.05 10 Q 0.1±0.15 (n-1)/2× B 9 H±0.05 9 0.04 Z 0.67±0.05 R Enlarged figure U V (0.05) : Shows recommended demension when lead for plating is required. : Indicated tolerance is applicable to the exposed conductor. : Dimension Q must be 0.5 mm minimum. (0.35) Note 8 9 10 (Reference shape) Check mark for press misalignment (0) *Relative positions of point-U and V (0.01) *Relative positions of point-S and T (0.10:Even pattern) (0.13:Odd pattern) (0.5) Aug.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Contact No.2 T S 0.01±0.02 Unit: mm Product No. HRS No. No. of Contacts A B C F G H FH43B-21S-0.2SHW(**) CL580-2810-0-** 21 5.8 3.6 4 5.3 4.5 4.94 FH43B-25S-0.2SHW(**) CL580-2804-8-** 25 6.6 4.4 4.8 6.1 5.3 5.74 FH43B-29S-0.2SHW(**) CL580-2811-3-** 29 7.4 5.2 5.6 6.9 6.1 6.54 FH43B-31S-0.2SHW(**) CL580-2808-9-** 31 7.8 5.6 6 7.3 6.5 6.94 FH43B-35S-0.2SHW(**) CL580-2803-5-** 35 8.6 6.4 6.8 8.1 7.3 7.74 FH43B-41S-0.2SHW(**) CL580-2809-1-** 41 9.8 7.6 8 9.3 8.5 8.94 FH43B-45S-0.2SHW(**) CL580-2812-6-** 45 10.6 8.4 8.8 10.1 9.3 9.74 FH43B-51S-0.2SHW(**) CL580-2806-3-** 51 11.8 9.6 10 11.3 10.5 10.94 FH43B-61S-0.2SHW(**) CL580-2805-0-** 61 13.8 11.6 12 13.3 12.5 12.94 FH43B-71S-0.2SHW(**) CL580-2807-6-** 71 15.8 13.6 14 15.3 14.5 14.94 Product No. HRS No. No. of Contacts A B C F G H FH43BW-21S-0.2SHW(**) CL580-2822-0-** 21 5.8 3.6 4 5.3 4.5 4.94 FH43BW-25S-0.2SHW(**) - 25 6.6 4.4 4.8 6.1 5.3 5.74 FH43BW-29S-0.2SHW(**) - 29 7.4 5.2 5.6 6.9 6.1 6.54 FH43BW-31S-0.2SHW(**) CL580-2820-4-** 31 7.8 5.6 6 7.3 6.5 6.94 FH43BW-35S-0.2SHW(**) CL580-2821-7-** 35 8.6 6.4 6.8 8.1 7.3 7.74 FH43BW-41S-0.2SHW(**) CL580-2813-9-** 41 9.8 7.6 8 9.3 8.5 8.94 FH43BW-45S-0.2SHW(**) CL580-2815-4-** 45 10.6 8.4 8.8 10.1 9.3 9.74 FH43BW-51S-0.2SHW(**) CL580-2814-1-** 51 11.8 9.6 10 11.3 10.5 10.94 FH43BW-61S-0.2SHW(**) CL580-2816-7-** 61 13.8 11.6 12 13.3 12.5 12.94 FH43BW-71S-0.2SHW(**) CL580-2819-5-** 71 15.8 13.6 14 15.3 14.5 14.94 5 FH43B Series●0.2 mm Pitch, 0.9 mm Height FPC Connectors BFPC Material Configuration (Reference Example) Single-Sided FPC Material name Material Covering film layer Polyimide 1 mil Aug.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1 µm to 6 µm Nickel underplated + 0.2 µm Gold plated 4 12 Copper foil Cu  1/3 oz Base adhesive Heat-hardened adhesive No adhesion material Base film Polyimide 1 mil 25 Reinforcement material adhesive Heat-hardened adhesive 30 Stiffener Polyimide 5 mil 125 Total 196 Precautions 1. This specification is a recommendation for the construction of the FH43B Series FPC (t=0.2±0.02). 2. For details about the construction, please contact the FPC manufacturers. 6 (25) (25) Cover adhesive Surface treatment Thickness (µm) FH43B Series●0.2 mm Pitch, 0.9 mm Height FPC Connectors BPackaging Specifications 1.75±0.1 J±0.3 L±0.1 ●Reel Condition Dimensions Ø1.7 0 +0.1 Ø1.5 0 +0.15 K±0.1 J±0.3 Direction of unreeling ●Leader, Trailer Dimensions (M: Inside) (Ø13) 400 mm MIN (Leader) Direction of unreeling (Ø380) (Ø80) Aug.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4±0.1 (2) L±0.1 (2) +0 0 .1 4±0.1 (0.3) 1.75±0.1 +0 0 .1 (0.3) 8±0.1 (1.2) 8±0.1 Ø1 .5 (1.2) ●Embossed Carrier Tape Dimension (Tape width: 32 mm MIN) Ø1 .5 ●Embossed Carrier Tape Dimension (Tape width: 24 mm MAX) 160 mm MIN (Trailer, Empty) Embossed carrier tape 100 mm MIN (Empty) Top cover tape (N: Outside) Unit: mm Product No. HRS No. No. of Contacts J K L M N FH43B-21S-0.2SHW(**) CL580-2810-0-** 21 16 - 7.5 17.4 21.4 FH43B-25S-0.2SHW(**) CL580-2804-8-** 25 16 - 7.5 17.4 21.4 FH43B-29S-0.2SHW(**) CL580-2811-3-** 29 16 - 7.5 17.4 21.4 FH43B-31S-0.2SHW(**) CL580-2808-9-** 31 24 - 11.5 25.4 29.4 FH43B-35S-0.2SHW(**) CL580-2803-5-** 35 24 - 11.5 25.4 29.4 FH43B-41S-0.2SHW(**) CL580-2809-1-** 41 24 - 11.5 25.4 29.4 FH43B-45S-0.2SHW(**) CL580-2812-6-** 45 24 - 11.5 25.4 29.4 FH43B-51S-0.2SHW(**) CL580-2806-3-** 51 24 - 11.5 25.4 29.4 FH43B-61S-0.2SHW(**) CL580-2805-0-** 61 24 - 11.5 25.4 29.4 FH43B-71S-0.2SHW(**) CL580-2807-6-** 71 32 28.4 14.2 33.4 37.4 HRS No. No. of Contacts J K L M N Product No. FH43BW-21S-0.2SHW(**) CL580-2822-0-** 21 16 - 7.5 17.4 21.4 FH43BW-25S-0.2SHW(**) - 25 16 - 7.5 17.4 21.4 FH43BW-29S-0.2SHW(**) - 29 16 - 7.5 17.4 21.4 FH43BW-31S-0.2SHW(**) CL580-2820-4-** 31 24 - 11.5 25.4 29.4 FH43BW-35S-0.2SHW(**) CL580-2821-7-** 35 24 - 11.5 25.4 29.4 FH43BW-41S-0.2SHW(**) CL580-2813-9-** 41 24 - 11.5 25.4 29.4 FH43BW-45S-0.2SHW(**) CL580-2815-4-** 45 24 - 11.5 25.4 29.4 FH43BW-51S-0.2SHW(**) CL580-2814-1-** 51 24 - 11.5 25.4 29.4 FH43BW-61S-0.2SHW(**) CL580-2816-7-** 61 24 - 11.5 25.4 29.4 FH43BW-71S-0.2SHW(**) CL580-2819-5-** 71 32 28.4 14.2 33.4 37.4 7 FH43B Series●0.2 mm Pitch, 0.9 mm Height FPC Connectors BTemperature Profile MAX 250ç 250 Temperature (ç) 230ç 200 200ç 150 150ç Applicable Conditions Reflow method:IR/Hot air Reflow environment :Room air Solder :Paste type Sn/3.0Ag/0.5Cu (M705-GRN360-K2-V made by Senju Metal Industry Co.) Test PCB :PCB material and size Glass epoxy 100×72.5×0.8mm Land pattern 0.2×0.65, 0.2×0.87mm Stencil :Thickness 0.1mm Opening size 0.18×0.55, 0.18×0.68mm 100 Aug.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 50 25ç (60sec) 0 90∼120sec Pre-heating Start Time (sec) 8 (60sec) Soldering The temperature profiles are based on the above conditions. In individual applications the actual temperature may vary, depending on solder paste type, volume/thickness and board size/thickness. Consult your solder paste and equipment manufacturer for specific recommendations. FH43B Series●0.2 mm Pitch, 0.9 mm Height FPC Connectors BOperation and Precautions Operation Methods This connector needs to be handled with care due to its thin design and miniature stature. Please refer to the following descriptions for handling precautions. 1. Initial Delivery Condition Aug.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❶ The connector is delivered with the actuator closed. [Caution] ・Do not insert FPC or operate actuator before mounting. 2. How to unlock ❶ Rotate slowly flip up the actuator to release the lock. [Caution] ・When operating the actuator do not apply any force in the direction of the connector. ・The actuator rotates 125 degrees max. Do not attempt to force the actuator to backside further. PCB PCB Failure from the actuator pushed in - Incorrect Operation - PCB - Incorrect Operation - 3. How to insert FPC ❶ This connector has contacts on the bottom. Insert the FPC with the exposed conductors face down. [Caution] ・Insert the FPC with the actuator opened. ・This connector utilizes metal fittings designed to align the FPC. ・Do not twist the FPC to up and down, right and left or an angle. 12 5° 15° FPC contact side is down Metal fitting for positioning FPC 9 FH43B Series●0.2 mm Pitch, 0.9 mm Height FPC Connectors Operation Methods 4. FPC insertion check ❶ Metal fittings guide the FPC tabs to the correct position. Make sure that the FPC tabs are located in correct position as shown in the figure below after FPC insertion. [Caution] ・Do not insert the FPC at an angle and/or stop it before insertion is completed. Aug.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FPC TAB FPC(Insufficient inserted) Metal fitting - Incorrect Operation - - Correct Operation - Hook of metal fittings fits in FPC TAB. FPC(Inserted with angle) FPC TAB run on the metal fittings. - Incorrect Operation - FPC TAB run on the metal fittings. 5. How to lock ❶ Apply load to rotate the actuator after inserting the FPC. [Caution] ・The actuator rotates on its axis. Make sure to operate the actuator with a rotating motion. ・In order to lock the actuator, apply force to the center of the actuator. ・Do not operate the actuator at one end only. ・Do not apply excessive force during this operation, the lock. Close the actuator at the center. - Correct Operation - 10 Do not operate the actuator at one end only. - Incorrect Operation - FH43B Series●0.2 mm Pitch, 0.9 mm Height FPC Connectors Operation Methods 6. Mating confirmation of the FPC ❶ This connector uses reinforced metal fittings to align the FPC. Visually confirm the FPC positioning after closing the actuator. [Caution] ・Do not insert the FPC at an angle and/or stop it before insertion is completed. - Correct mating process - - Incomplete insertion Window is not fully covered by FPC when FPC is miss-inserted. and FPC tabs extend from the connector. FPC fully fills window when FPC is correctly inserted. Aug.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. - Diagonal insertion Window is not fully covered by FPC when FPC is miss-inserted. and FPC tabs extend from the connector. Check window FPC FPC TAB FPC(Inserted with angle) FPC(Insufficient inserted) 7. FPC Withdrawal (Unlock) ❶ Rotate slowly flipup the actuator to release the lock. ❷ After rotating the actuator to the fully opened position carefully withdraw the FPC pulling out at about 15 degree angle to the PCB mounting surface. [Caution] ・Open the actuator by carefully lifting it at the center. ・Do not operate the actuator at one end only. Actuator (Close) PCB - Correct Operation - PCB - Incorrect Operation - 8. FPC routing after connecting ❶ Depending on a FPC rounding, a load is applied to the connector, and a contact failure may occur. To prevent a failure, take the following notes into a consideration during mechanism design. [Caution] ・Make sure that the FPC and its stiffener do not contact chassis. ・Avoid applying forces to FPC in vertical or horizontal directions. In addition, avoid pulling up and down on the FPC. ・ When fixing FPC after FPC cabling, avoid pulling FPC, and route the wire FPC with slack. In this regard, the stiffener is parallel to the PCB. ・Do not mount other components touching to the FPC underneath the FPC stiffenner. 11 FH43B Series●0.2 mm Pitch, 0.9 mm Height FPC Connectors Cautions when Mounting PCB 使用上の注意点 Stiffener film Stiffener film PCB PCB PCB Aug.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Component part Stiffener film S Warp of PCB Minimize warp of the PCB as much as possible. Lead co-planarity including reinforced metal fittings is 0.1 mm or less. Too much warp of the PCB may result in a soldering failure. S Flexible board design Please make sure to put a stiffener on the backside of the flexible board. We recommend a glass epoxy material with the thickness of 0.3 mm MIN. S Load to Connector Do not add 0.5N or greater external force when unreel or pick and place the connector etc, or it may get broken. In addition, do not insert the FPC or operate the connector before mounting. S Load to PCB ・Splitting a large PCB into several pieces ・Screwing the PCB Avoid the handling described above so that no force is exerted on the PCB during the assembly process. Otherwise, the connector may become defective. Connector FPC(For connector mounting) S Instructions on manual soldering Follow the instructions shown below when soldering the connector manually during repair work, etc. ❶ Do not perform manual soldering with the FPC inserted into the connector. ❷ Do not heat the connector excessively. Be very careful not to let the soldering iron contact any parts other than connector leads. Otherwise, the connector may be deformed or melt. ❸ Do not supply excessive solder (or flux). If excessive solder (or flux) is supplied on the terminals, solder or flux may adhere to the contacts or rotating parts of the actuator, resulting in poor contact or a rotation failure of the actuator. Supplying excessive solder to the metal fittings may hinder actuator rotation, resulting in breakage of the connector. ® 12 6-3,Nakagawa Chuoh-2-Chome,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 3/2014. Contents are subject to change without notice for the purpose of improvements.
物料型号: - 系列名称:FH43B - 产品型号示例:FH43B-21S-0.2SHW、FH43BW-21S-0.2SHW等,其中W表示无卤素产品。
器件简介: - 该系列连接器具有0.2毫米的低轮廓底部接触FPC连接器,最大空间利用率,接触间距为0.2毫米,配合高度为0.9毫米,安装深度为2.77毫米。 - 与0.3毫米间距的FH26系列51位连接器相比,占用的PCB面积减少了45%,重量减轻了55%。
引脚分配: - 引脚间距为0.2毫米,支持高达71个接触点。
参数特性: - 电流额定值:直流0.2A(注1) - 电压额定值:交流30Vrms - 工作温度范围:-55至+85°C(注2) - 存储温度范围:-10至+50°C(注3) - 推荐FPC规格:厚度0.2±0.02毫米,金层厚度4微米。
功能详解: - 易于PCB安装:PCB引脚使用0.4毫米间距并错开排列,简化了PCB安装过程。 - 支持高速传输:通过使用相同接触点的差分对(偶数-偶数接触或奇数-奇数接触),这些连接器能够提供出色的传输特性,并支持eDP(版本1.3)、MIPI(D-PHY)、HDMI(版本1.3)和USB(3.0)标准。 - 旋转一键式ZIF机制:操作简便,轻力即可操作,成功配合后有明显的触觉点击感。 - 易于FPC插入:FPC对准机制在锁定执行器之前会固定FPC。 - 插入检查窗口:执行器上的切口允许视觉检查FPC,确保其正确锁定,防止FPC错误插入。
应用信息: - 适用于需要高可靠性的应用,如汽车领域。
封装信息: - 材料:绝缘体为LCP PA(浅棕色,UL94V-0),接触件为磷青铜(金镀层),金属配件为纯锡回流镀层。 - 产品编号结构:提供了详细的产品编号规则,以确定产品规格。
其他信息: - 包装规格:提供了胶带和卷轴包装的规格。 - 推荐PCB安装图案和推荐模板图案:提供了详细的PCB安装和模板设计建议。 - FPC材料配置(参考示例):提供了单面FPC的材料名称、材料、厚度等信息。 - 操作和注意事项:提供了操作方法和注意事项,以确保正确和安全地使用连接器。
FH43BW-35S-0.2SHW(10) 价格&库存
很抱歉,暂时无法提供与“FH43BW-35S-0.2SHW(10)”相匹配的价格&库存,您可以联系我们找货
