N.FL-R-SMT-1(01)
N.FL-R-SMT-1(01)
    HRS(广濑)
    SMD
    Ultra Miniature Coaxial Connector Receptacle, Male Pin 50 Ohm Surface Mount Solder
N.FL-R-SMT-1(01) 数据手册
Lightweight SMT Miniature Coaxial Connectors – 1.4 mm Mated Height N.FL Series N.FL U.FL-LP(V) Fig.1 ■Features ●N.FL Plug and Receptacle 1. Low profile Nominal mated height is 1.4 mm (Max. 1.5 mm) 2. Small size: 7.7 mm2 N.FL-LP-040* Plug 3. Light weight 4. Accepts high frequency transmission of DC to 6 GHz. 3.4 Cable Dia.0.81 Receptacle : 14 mg Plug : 28 mg 1.4(1.5MAX) Sep.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.4(1.5MAX) 1.9(2.0MAX) ●Mated height comparison (With U.FL-LP(V) ) V.S.W.R. = 1.3 max. (DC to 6 GHz) 5. Board placement with automatic equipment Receptacles are packaged in embossed carrier tape and reel for automatic mounting. N.FL-R-SMT-1 Receptacle Fig.2 6. Plugs are terminated with ultra-fine coaxial (fluorinated resin insulated) cable. 7. Special tool for an extraction 8. Verification of the fully mated condition Tactile click sensation confirms fully mated condition, assuring complete electrical and mechanical connection. 9. Halogen-free*(Receptacle, plug(HF type)) *As defined by IEC61249-2-21 Br-900 ppm maximum, Cl-900 ppm maximum, Cl+Br combined - 1,500 ppm maximum ■Applications Mobile phones, wireless communication devices, electronic measuring instruments, GPS, wireless LAN, Bluetooth and any application requiring high frequency transmission using small coaxial connectors. In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2014.10w 1 N.FL Series●Lightweight SMT Miniature Coaxial Connectors – 1.4 mm Mated Height ■Specifications Nominal characteristic impedance 50 ohms Operating temperature range DC to 6 GHz Storage temperature range -40°C to +90°C (90% RH max.) -30°C to +70°C (90% RH max.) Ratings Frequency range Item 1. Contact resistance Specification Center contact: 25 m ohms max. Outer contact: 25 m ohms max. Conditions 10 mA max. 2. Insulation resistance 500 M ohms min. 100V DC 3. Withstanding voltage No flashover or insulation breakdown 200V AC / 1 minute 4. V.S.W.R.(Note) 1.3max. DC to 6GHz Contact resistance 5. Durability Center contact: 30 m ohms max. Outer contact: 30 m ohms max. 20 cycles Sep.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. No damage, cracks, or parts dislocation Frequency: 10 to 100 Hz, single amplitude of 1.5 mm No electrical discontinuity of 1 µs or longer 6. Vibration Acceleration: 59 m/s2, in each of 3 axis No damage, cracks, or parts dislocation 7. Shock 5 cycles No electrical discontinuity of 1 µs or longer Acceleration of 735 m/s2, 11 ms continuous time No damage, cracks, or parts dislocation Waveform: sine half-wave, 3 cycles in each of the 3 axis Insulation resistance: 100 M ohms min. (high humidity) 8. Humidity Insulation resistance: 500 M ohms min. (dry) 96 hours at +40°C, and humidity of 95% No damage, cracks, or parts dislocation Temperature:-40°C/+5°C to +35°C/+90°C/+5°C to +35°C 9. Temperature cycle No damage, cracks, or parts dislocation Time: 30 min./ 5 min. max. / 30 min. / 5 min. max. 5 cycles 10. Salt spray test No excessive corrosion 5% salt water solution, 48 hours Note: Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. * V.S.W.R. Measurement System Measured as shown on the block diagram below. Network Analyzer Test Set Test Port D.U.T Termination Note1: N.FL Cable assembly (plug) is measured with SMA conversion adapters mated with N.FL plugs at both ends of a 100cm coaxial cable harness Note2: N.FL receptacle, which is mounted on a 50 ohms glass epoxy board, is measured with a SMA conversion adapter. Test Port Cable ■Materials / Finishes ●Plugs-Right Angle Shell Part Material Phosphor bronze Finish Silver plated Female center contact Phosphor bronze Gold plated Insulator PBT Color: Black, UL94V-0 Color: Gray, UL94HB(HF type) ●Receptacle Part Shell Male center contact Insulator 2 Material Phosphor bronze Finish Silver plated Brass Gold plated LCP Color: Black, UL94V-0 N.FL Series●Lightweight SMT Miniature Coaxial Connectors – 1.4 mm Mated Height ■Cable Assembly(Plug) 2.8 N.FL-LP-040(06), N.FL-LP-040HF(06)(Applicable cable: outer diameter 0.81) Sep.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.12 3.4 Ordering Information [Plugs can be ordered only as terminated cable assemblies] How To Specify Cable Assembly [Double-ended cable assembly] [Single-ended cable assembly] L(mm) L L(mm) L Ordering Information Ordering Information Used Plug: N.FL-LP-040(06), N.FL-LP-040HF(06) DoubleEnded N.FL - 2LP HF6 - 04N 「」 TV - A - L ❶ SingleEnded ❷ N.FL - LP ❶ ❷ ❸ ❹ ❺ ❻ ❼ HF6 - 04N 「」 TV - A - L ❸ ❶ Series name N.FL ❷ Assembly type LP : Single ended ❸ Environmental compliant ❹ ❺ ❻ ❼ Standard tolerances for (L) (L)mm Standard Tolerance(mm) 2LP : Double ended *L=35 to 200 ±4 HF6 : Halogen-free plug *L=200 to 500 ±8 6 : Standard Plug ❹ Cable type 04N : 0.81mm dia. ultra-time coaxial cable ❺ Cable color 1:White 2:Black *L=500 to 1000 ±12 L=Longer than 1000 ±1.5% of (L) Note: Minimum available length(L) is 35mm. ❻ Cable outer conductor TV: Tin plated braided wire Length(L) ❼ Total length (mm) 3 N.FL Series●Lightweight SMT Miniature Coaxial Connectors – 1.4 mm Mated Height ■Receptacle BRecommended PCB mounting pattern GND GND GND No conductive traces in this area 1.85 2 Ø2 2.05 0.8 0.25 SIG GND SIG 0.6 0.8 3.8 0.6 2.6 3 All dimensions: mm Part No. HRS No. Packaging N.FL-R-SMT-1(60) 331-0332-3 60 Reel (5,000 pcs/reel) N.FL-R-SMT-1(80) 331-0332-3 80 Reel (10,000 pcs/reel) RoHS ●Embossed Carrier Tape Dimensions (IEC 60286-3 compliant) Embossed Carrier tape Dimensions Ø330 4 .5 Unreeling direction 13.5 Material:PS(Black) Ø1 2 Reel Dimensions 12 5.5 1.75 (N.FL-R-SMT-1(60) 8mm pitch) A 8 A(SCALE FREE) (N.FL-R-SMT-1(80) 4mm pitch) 2 4 .5 2 Ø13 Ø1 1.75 Unreeling direction Ø2 1 12 5.5 Sep.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1.8 2.6 3.1 1.9 4 All dimensions: mm 4 N.FL Series●Lightweight SMT Miniature Coaxial Connectors – 1.4 mm Mated Height ■Conversion Adapters ●SMA Conversion Adapter (N.FL / U.FL side jack - SMA side plug) (10.7) Note: The FL side mating portions has a lower lock retention force than the regular product, therefore, cannot be used for purposes other than performance measurements. 8HEX All dimensions: mm HRS No. 311-0300-2 40 Part No. HRMP-U.FLJ(40) RoHS Note: Applicable to both N.FL and U.FL. ●SMA Conversion Adapter (N.FL / U.FL side plug - SMA side jack) 14.05 (4.05) Ø6.35 5.6 1/4-36UNS-2A Note: The FL side mating portions has a lower lock retention force than the regular product, therefore, cannot be used for purposes other than performance measurements. All dimensions: mm Part No. HRS No. HRMJ-U.FLP(40) 311-0301-5 40 RoHS Note: Applicable to both N.FL and U.FL. ●SMA Conversion Adapter (18.3) (4) 5.5 Ø6.35 6 1/4-36UNS-2A Note: When mating with corresponding part (N.FL-RSMT-1) must be pressed down and held to make complete connection. All dimensions: mm HRS No. 311-0423-2 Part No. HRMJ-N.FLP-ST5 ■Receptacle Inspection Adapter Used for inspecting the performance parameters of the cable assembly. RoHS 12.9 (7.9) (4.4) 7HEX 5 1 M5∞0.5 All dimensions: mm HRS No. 331-0466-0 Part No. U.FL-R-1 RoHS Note: Applicable to both N.FL and U.FL. Plug mating tool Ø10 (12.9) This tool is used for mating a plug. JAPAN 8 For distinction with W.FL-LP-IN. All dimensions: mm HRS No. 331-0334-9 Part No. U.FL-LP-IN RoHS 3 50 This jig is used for extraction from a mating condition. Ø15 90 Plug extraction tool U. FL/ 2.1 Sep.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 6 All dimensions: mm Part No. U.FL-LP(V)-N-2 HRS No. 331-0493-2 RoHS Note: Applicable to all the U.FL-LP(V)-040, U.FL-LP-062 and N.FL. 5 N.FL Series●Lightweight SMT Miniature Coaxial Connectors – 1.4 mm Mated Height ■Usage Precautions 1. Plug • Unmating Insert the end of an extraction tool into a space between a plug and receptacle, and pull up the tool in the perpendicular to a mounting surface of a receptacle, as shown in the figure. ●Recomended the use of the extraction tool for unmating. U.FL-LP(V)-N-2 Extraction tool Any attempt of unmating by pulling on the cable may N.FL-LP-040 Plug result in damage to the mechanical / electrical performance. • Mating Do not attempt to insert on an extreme angle. (1) Mating / unmating N.FL-LP-040 Plug (2) Pull forces on the cable after connectors are mated Sep.1.2019 Copyright 2019 HIROSE ELECTRIC CO., LTD. All Rights Reserved. N.FL-R-SMT-1 Receptacle 2.9N max. Do not apply any pull forces after the bending of the cable. N.FL-R-SMT-1 Receptacle (3) Precautions Do not twist connectors excessively during mating / unmating. 2. Receptacle 250 ç max. for 10 seconds [ç] 260 240 220 200 180 160 140 120 100 80 (1) Recommended reflow temperature profile Preheat (130 to 180ç) 120 seconds max. 230ç 220ç 50 seconds max. 60 seconds max. Time q The temperature profile indicates the board surface temperature at the point of contacts with the connector leads. w In individual applications the actual temperature may vary, depending on the solder paste type, volume / thickness and board size / thickness. Consult your solder paste and equipment manufacturer for the detailed recommendations. (2) Manual soldering Soldering iron temperature: 350°C, Soldering time: for 5 seconds max. (3) Recommended metal mask thickness 0.1 mm to 0.12 mm (4) Reflow cycles 2 times 3. Operating environment and storage conditions (1) Operating environment (2) Storage conditions Receptacle The connectors are not designed to operate in the following environments: • Exposed to a excessive amounts of fine particles and dust • Regions and places having a high density of sulfur dioxide, hydrogen sulfide, nitrogen dioxide or other corrosive gasses. • Environments having large rapid variations in temperature. Store in the Hirose Electric packaging. Temperature: -10 to +40ç, Humidity: 85% max. Use within 6 months of delivery. Receptacles for which the storage period has elapsed must be tested for solderability to the PC board mounting surface. ® 6 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 10/2014. Contents are subject to change without notice for the purpose of improvements.
N.FL-R-SMT-1(01) 价格&库存
很抱歉,暂时无法提供与“N.FL-R-SMT-1(01)”相匹配的价格&库存,您可以联系我们找货
