DF23C-60DP-0.5V(92)
DF23C-60DP-0.5V(92)
    HRS(广濑)
    SMD,P=0.5mm
    CONN PLUG 60POS DUAL 0.5MM SMD
DF23C-60DP-0.5V(92) 数据手册
0.5mm Pitch Low-Profile Board-to-Board/Board-to-FPC Connectors DF23 Series Low profile - 1.5 mm board-to-board distance ●Board-to-Board Application Board 1.5 +0.2 - 0.1 Plug Board ●Board-to-FPC Application Plug FPC 1.5 +0.2 - 0.1 May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Receptacle Board Receptacle ■Features High Contact Reliability 1. Low profile The 1.5 mm board-to-board distance makes these connectors ideal for limited space applications. 2. Large variety of number of contacts Available with 10, 12, 14, 16, 18, 20, 30, 40, 50, and 60 contacts. Connectors with 10 to 20 contacts are ideal for use in small LCD connections in cellular phones, PDA’s, video equipment, photo cameras and miniature of other devices requiring reliable connections in a small spaces. Male contact Female contact 3. Click sensation Positive click sensation when completely mated confirms correct insertion and connection of all contacts. 4. High contact reliability Although connectors are low profile, the female contacts maintain reliable spring force assuring secure electrical contact. Large Self-alignment 0.3 5. Large self-alignment The large range of alignment of 0.3 mm allows for smooth insertion. 6. Board placement with automatic equipment Flat surfaces allows placement of embossed tape packaged connectors with vacuum nozzles. ■Applications Mobile phones, PDA’s, notebook PC’s, digital cameras and other miniature devices. A238 0.3 DF23 Series●0.5mm Pitch Low-Profile Board-to-Board/Board-to-FPC Connectors ■Product Specifications Current rating 0.3A Storage Operating temperature range -35ç to 85ç (Note 1) temperature range -10ç to 60ç (Note 2) Voltage rating 50V AC Operating humidity -20% to 80% range Ratings May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Item Storage humidity range Specification -40% to 70% (Note 2) Condition 1. Insulation resistance 2. Withstanding voltage 3. Contact resistance 500M ohms min. No flashover or insulation breakdown 60m ohms max. 100V DC 150V AC/1 minute 100mA 4. Vibration No momentary disconnections of 1 μs min Frequency of 10 to 55 Hz, single amplitude of 0.75 mm, in 3 directions for 2 hours 5. Humidity Contact resistance : 60 m ohms max. Insulation resistance : 250 M ohms min. Temperature of 40ç±2ç, humidity of 90% to 95%, 96 hours 6. Temperature cycle Contact resistance : 60 m ohms max. Insulation resistance : 500 M ohms min. (-55ç : 30minutes /5 to 35ç : 10minutes /85ç : 30minutes /5 to 35ç: 10minutes ) for 5 cycles 7. Durability Contact resistance 8. Resistance to soldering heat No deformation of the insulator parts affecting performance 50 cycles (mating/unmating) : 60m ohms max. Reflow: At recommended temperature profile Manual soldering: Soldering iron temperature 300°C, for 3 seconds Note 1: Includes temperature rise caused by the current flow. Note 2: The term “storage” refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non- conducting condition of installed connectors in storage, shipment or during transportation. Note 3: Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. ■Materials Item Part Material Finish Remarks Receptacles Insulator LCP Color : Black UL94V-0 Plugs Contacts Phosphor bronze Gold plated ---------- ■Ordering information ●Receptacles/Plugs DF23 C - * DS - 0.5 V ( * * ) 1 2 3 4 5 6 7 1 Series name: DF23 5 Contact pitch: 0.5mm 2 Metal fitting & Locating boss type C: Without metal fittings, without Locating boss 6 Terminal type V: Straight SMT 3 Number of contacts: 10, 12, 14, 16, 18, 20, 22, 30, 40, 50, 60 7 4 Connector type DS: Double-row receptacle DP: Double-row plug Packaging type Receptacle(51): Embossed tape packaging (2,000 pieces per reel) Receptacle(53): Embossed tape packaging (3,000 pieces per reel) Plug(92): Embossed tape packaging (2,000 pieces per reel) Plug(91): Embossed tape packaging (3,000 pieces per reel) A239 DF23 Series●0.5mm Pitch Low-Profile Board-to-Board/Board-to-FPC Connectors ■Receptacles A±0.3 B±0.15 P=0.5±0.1 0.25±0.05 5±0.2 1.45±0.1 1.1±0.05 0.9±0.05 B±0.03 P=0.5±0.02 0.25±0.02 Note: Shaded area should be free of any conductive traces. [Packaging/ quantity per reel code] - * *, (* *) (51): Embossed tape packaging (2,000 pieces per reel) (53): Embossed tape packaging (3,000 pieces per reel) Unit: mm Product No. CL No. Number of Contacts A B DF23C-10DS-0.5V(**) CL688-0306-9-** 10 05.1 02.0 DF23C-12DS-0.5V(**) CL688-0309-7-** 12 05.6 02.5 DF23C-14DS-0.5V(**) CL688-0300-2-** 14 06.1 03.0 DF23C-16DS-0.5V(**) CL688-0307-1-** 16 06.6 03.5 (Note 1) DF23C-18DS-0.5V(**) CL688-0308-4-** 18 07.1 04.0 (Note 2) DF23C-20DS-0.5V(**) CL688-0301-5-** 20 07.6 04.5 (Note 1) DF23C-22DS-0.5V(**) CL688-0310-6-** 22 08.1 05.0 (Note 2) DF23C-30DS-0.5V(**) CL688-0302-8-** 30 10.1 07.0 (Note 1) DF23C-40DS-0.5V(**) CL688-0303-0-** 40 12.6 09.5 (Note 1) DF23C-50DS-0.5V(**) CL688-0304-3-** 50 15.1 12.0 (Note 1) CL688-0305-6-** 60 17.6 14.5 (Note 1) DF23C-60DS-0.5V(**) Note Note Note Note A240 0.5±0.1 BRecommended PCB Footprints 4.4±0.05 May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 6±0.2 0.15±0.05 1: 2: 3: 4: Available in code (51) only. Available in code (53) only. Contact Hirose for availability. Please order embossed tape packaging items by the reel. Remarks RoHS (Note 2) YES DF23 Series●0.5mm Pitch Low-Profile Board-to-Board/Board-to-FPC Connectors ■Plugs A±0.15 B±0.15 P=0.5±0.1 0.15±0.05 4.3±0.2 1.2±0.1 0.45±0.1 BRecommended PCB Footprints C B±0.03 1±0.05 P=0.5±0.02 0.25±0.02 Note 1: Shaded area should be free of any conductive traces. Note 2: Do not leave any conductive traces or install components in this area. 0 1.7 -0.1 2.9±0.05 6 May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3.1±0.15 0.19±0.05 [Packaging/ quantity per reel code] - * *, (* *) (92): Embossed tape packaging (2,000 pieces per reel) (91): Embossed tape packaging (3,000 pieces per reel) Unit: mm Product No. CL No. Number of Contacts A B C DF23C-10DP-0.5V(**) CL688-0806-1-** 10 04.0 02.0 05.1 DF23C-12DP-0.5V(**) CL688-0809-0-** 12 04.5 02.5 05.6 DF23C-14DP-0.5V(**) CL688-0800-5-** 14 05.0 03.0 06.1 DF23C-16DP-0.5V(**) CL688-0807-4-** 16 05.5 03.5 06.6 DF23C-18DP-0.5V(**) CL688-0808-7-** 18 06.0 04.0 07.1 DF23C-20DP-0.5V(**) CL688-0801-8-** 20 06.5 04.5 07.6 (Note 2) DF23C-22DP-0.5V(**) CL688-0810-9-** 22 07.0 05.0 08.1 (Note 1) DF23C-30DP-0.5V(**) CL688-0802-0-** 30 09.0 07.0 10.1 DF23C-40DP-0.5V(**) CL688-0803-3-** 40 11.5 09.5 12.6 (Note 2) DF23C-50DP-0.5V(**) CL688-0804-6-** 50 14.0 12.0 15.1 (Note 2) DF23C-60DP-0.5V(**) CL688-0805-9-** 60 16.5 14.5 17.6 (Note 2) Note Note Note Note 1: 2: 3: 4: Remarks RoHS (Note 1) (Note 2) YES Available in code (91) only. Available in code (92) only. Contact Hirose for availability. Please order embossed tape packaged items by the reel. A241 DF23 Series●0.5mm Pitch Low-Profile Board-to-Board/Board-to-FPC Connectors BEmbossed Career Tape Dimensions 2±0.1 1.6±0.15 1.75±0.1 ■Receptacles Y-Y 12±0.1 0.3±0.1 E±0.1 .7 5 + 0 0 .1 X 1 0. + 0 5 .7 R0 0.2±0.05 X Y (Note.1) Unreeling direction X-X Product name label 3± ■Reel Dimensions 0.2 (Note.2) Ø1 Ø330±2 Ø80±1 Depth of 1.5 diameter PS May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. R0 D±0.3 F±0.1 .1 +0 0 .5 Ø1 4±0.1 Y G±0.5 H±1 Unit: mm Product No. D E F G H DF23C-10DS-0.5V(**) 16.0 ---- 07.5 17.5 21.5 DF23C-12DS-0.5V(**) 16.0 ---- 07.5 17.5 21.5 DF23C-14DS-0.5V(**) 16.0 ---- 07.5 17.5 21.5 DF23C-16DS-0.5V(**) 16.0 ---- 07.5 17.5 21.5 DF23C-18DS-0.5V(**) 16.0 ---- 07.5 17.5 21.5 DF23C-20DS-0.5V(**) 16.0 ---- 07.5 17.5 21.5 DF23C-22DS-0.5V(**) 24.0 ---- 11.5 25.5 29.5 DF23C-30DS-0.5V(**) 24.0 ---- 11.5 25.5 29.5 DF23C-40DS-0.5V(**) 24.0 ---- 11.5 25.5 29.5 DF23C-50DS-0.5V(**) 24.0 ---- 11.5 25.5 29.5 DF23C-60DS-0.5V(**) 32.0 28.4 14.2 33.5 37.5 Note 1: This side feed hole is added to embossed tape where the D dimension is 32.0 min. wide. Note 2: (53) packaging code embossed tape is without the bottom surface protrusion. A242 DF23 Series●0.5mm Pitch Low-Profile Board-to-Board/Board-to-FPC Connectors ■Plugs Y-Y 2±0.1 1.5±0.15 1.75±0.1 12±0.1 Ø1 4±0.1 .1 +00 .5 X X Y Unreeling direction X-X (Note.1) 0.2 ■Reel Dimensions 3± Product name label Ø1 Ø80±1 Ø330±2 Depth of 1.5 diameter PS May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. D±0.3 F±0.1 Y 0.3±0.1 G±0.5 H±1 Unit: mm Product No. D F G H DF23C-10DP-0.5V(**) 16.0 07.5 17.5 21.5 DF23C-12DP-0.5V(**) 16.0 07.5 17.5 21.5 DF23C-14DP-0.5V(**) 16.0 07.5 17.5 21.5 DF23C-16DP-0.5V(**) 16.0 07.5 17.5 21.5 DF23C-18DP-0.5V(**) 16.0 07.5 17.5 21.5 DF23C-20DP-0.5V(**) 16.0 07.5 17.5 21.5 DF23C-22DP-0.5V(**) 24.0 11.5 25.5 29.5 DF23C-30DP-0.5V(**) 16.0 07.5 17.5 21.5 DF23C-40DP-0.5V(**) 24.0 11.5 25.5 29.5 DF23C-50DP-0.5V(**) 24.0 11.5 25.5 29.5 DF23C-60DP-0.5V(**) 24.0 11.5 25.5 29.5 Note : Code number (91) embossed tape is without the bottom surface protrusion. A243 DF23 Series●0.5mm Pitch Low-Profile Board-to-Board/Board-to-FPC Connectors BUsage Precautions 1.Recommended Temperature (ç) Temperature Profile 250ç 250 Temperature 220ç 200 180ç 150 150ç 90~120sec Preheating May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 100 A244 60sec max Soldering 50 Room temperature 0 50 100 150 200 250 300 Time (sec.) Note 1: Up to 2 cycles of Reflow soldering are possible under the same conditions, provided that there is a return to normal temperature between the first and second cycle. Note 2: The temperature profile indicates the board surface temperature at the point of contacts with the connector terminals. 2.Recommended Manual Soldering Conditions 3.Recommended Screen Thickness and Open Area Ratio (Pattern Area Ratio) Temperature: 290ç±10ç, Soldering time: within 2 sec. ■Thickness : 0.12 mm ■Open Area ratio: 80% 4.Board Warping ■Maximum of 0.03 mm at the connector center section, with both ends of the connector as reference points. 5.Cleaning Conditions ■Refer to the "Nylon Connector Use Handbook." 6.Use and handling precautions. ■When manually handling the connectors avoid touching any portion of exposed terminal leads. ■This may cause deformation and lead to difficulties with placement and soldering on the PCB. ■When mating/un-mating do not use excessive force or lifting of one side only.
DF23C-60DP-0.5V(92) 价格&库存
很抱歉,暂时无法提供与“DF23C-60DP-0.5V(92)”相匹配的价格&库存,您可以联系我们找货
DF23C-60DP-0.5V(92)
  • 1+11.918201+1.43740
  • 10+10.4138010+1.25600
  • 100+9.31760100+1.12380
  • 500+7.72000500+0.93110
  • 1000+6.612101000+0.79750
  • 2000+6.262302000+0.75530
  • 4000+6.099004000+0.73560
  • 10000+6.0174010000+0.72570
库存:1224
