DF65-5S-1.7C
DF65-5S-1.7C
    HRS(广濑)
    P=1.7mm
    CONN RCPT 1.7MM 5POS
DF65-5S-1.7C 数据手册
NEW 1.7 mm pitch, Low Profile Board to Wire Connectors for Power Supplies DF65 Series (UL Pending) Lock structure and operation Socket Latch Header Latches are deflected slightly during mating. ■Features 1. Enhanced contact reliability and lock structure The unique locking structure reinforces the engagement between the wire side portion and the header. This prevents the wire side from becoming misaligned due to stress from poorly routed wiring. (Figure 1) (Patent pending) 2. Vertical mating provides superior handling The use of ver tical mating style reduces assembly time and maximizes precious board space which gives designers more freedom when designing other components on the PCB. (Figure 2) 3. Highly reliable contact structure The two point contact structure provides optimum reliability, a low mated height of 1.8 mm and an effective mating length of 0.35 mm. 4. Increased cable retention The header is designed to press the terminal lance down during the mating operation; this prevents the lance from moving and enhances its strength. And snap back in when mating is complete. A click feeling will be felt! Figure 1 Vertical mating provides superior operability and maximizes board space. Vertical mating type Side view of the PCB Vertical mating style allows other parts to be mounted. (Enhances freedom in designing PCB) 5. High current of MAX 4A(AWG24) By utilizing highly conductive material for the female terminals and suppressing the contact resistance, the DF65 series can handle a maximum of 4 A with AWG #24 wire. The mating face is easy to see, resulting in proper insertion. 6. Solder wicking prevention Molding is done in a way that removes the gap between the contacts and the housing to prevent wicking. Horizontal mating type Unused, open area 7. Prevents Accidental unmating The molded structure is designed to prevent accidental unmating due to poorly routed wiring and harsh loads. The mating face can be hard to see, which can lead to awkward insertion. Figure 2 2013.11 1 DF65 Series●1.7 mm pitch, Low Profile Board to Wire Connectors for Power Supplies ■Product Specifications 4 A/pin (when 24 AWG is used) Operating Temperature Range (Note 1) Operating Humidity Range Current Rating Ratings AC / DC 50V Voltage Rating Item 1. Insulation resistance 2. Withstand voltage 3.Contact resistance 4. Vibration Resistance Storage Temperature Range Storage Humidity Range Specifications − 35 ∼+ 105℃ (Note 2) 20 ∼ 80% (Note 3) − 10 ∼+ 60℃ (Note 4) 40 ∼ 70% (Note 4) Conditions No less than 100 Mø Measured at DC 100 V No flashover or breakdown No more than 10 Mø AC 500 V is applied for one minute. Measured at 1 mA and no higher than 20 mV 10 cycles in each of three directions at frequency 10-55 Hz, half amplitude 0.75 mm Accelerated velocity: 490 m/s2, for 11 ms, half-sine in 3 directions, 3 times for each of the three directions Temperature: 40 ±2ç; humidity: 90 to 95%, left as it is for 96 hours -55ç:30 minutes → 5 - 35ç: 2 - 3 minutes → 85℃ : 30 minutes → 5 - 35ç: 2 - 3 minutes) 5 cycles 30 mating cycles Reflow: according to the Recommended Temperature Profile Hand soldering: temperature of soldering iron at 350ç±10ç for 3 seconds No electrical discontinuity of 1 µs or greater 5. Shock Resistance No electrical discontinuity of 1µs or greater 6. Moistureresistance Contact resistance: no more than 20 mø; insulation resistance: no less than 500 Mø 7. Temperature cycles Contact resistance: no more than 20 mø; insulation resistance: no less than 500 Mø 8. Durability Contact resistance: no more than 20 mø 9. Resistance to solder heat The resin components will not become deformed or lose performance due to deformities (Note 1) This is the maximum current rating while all pins are powered or used as all power lines. If you split the current over multiple lines, please factor in your own safety margin. Please contact Hirose Electric, for inquiries on the assignment of pins and on the currents that can be delivered. (Note 2) Includes the temperature rise of power lines. (Note 3) Use without condensation on parts. (Note 4) The storage condition refers to long-term storage of the product on the shelf before assembly. Please use the operating temperature for temporary storage such as pre-assembly and during shipping. ■Materials Product Part Insulator Contact Insulator Contact Header Crimp socket Crimp contact Materials LCP Brass LCP Phosphorous Bronze Finish Black Tin Plating Beige Tin Plating UL specification UL94V-0 − UL94V-0 − ■Product Number Structure Refer to the charts below for determining specific part number characteristics. Please select connectors listed in this catalog when placing orders and be sure to check the latest delivery specifications at the time of ordering the product. ●Header connector DF 65 - * P - 1.2 V ❶ ❷ ❸ ❹ ❺ ❻ ❻Mounting style  V : SMT Straight Type ❶Series Name:DF ❷Series No. : 65 ❸Number of contacts : 3, 4, 5, 6, 8, 10 ❹Connector type P:Header ❺Pitch : 1.7mm ●Socket connector DF 65 - * S - 1.2 C ❶ ❷ ❸ ❹ ❺ ❻ ❶Series Name : DF ❷Series No. : 65 ❸Number of contacts: 3, 4, 5, 6, 8, 10 ❹Connector type  S:socket ❺Pitch : 1.7mm ❻Termination form  C : crimp case ●Crimp contact DF 65 - 2428 SCF ❶ 2 ❷ ❶Applicable wire size  2428:AWG24∼AWG28 ❷Packaging style  SCF: Socket contact on reel DF65 Series●1.7 mm pitch, Low Profile Board to Wire Connectors for Power Supplies ■Straight pin header A B P= 1.7 t= 0.2 1.65 6.05 5.55 1.605 1.62 Contact No.1 Vacuum nozzle area 0.25 C Recommended PCB layout (t=1 mm) B±0.05 +0.05 0.6 0 1±0.05 1.7 ±0.05 [Specification Number] (21): Tin plating, embossed packaging 1.8 ±0.05 5.45 ±0.05 Contact No.1 1.025 ±0.05 Part Number DF65-3P-1.7V(21) DF65-4P-1.7V(21) DF65-5P-1.7V(21) DF65-6P-1.7V(21) DF65-8P-1.7V(21) DF65-10P-1.7V(21) +0.05 0.7 0 HRS No. 666-6004-5-21 Under development 666-6001-7-21 666-6008-6-21 Under development Under development No. of Contacts 3 4 5 6 8 10 A B C 7.5 9.2 10.9 12.6 16 19.4 3.4 5.1 6.8 8.5 11.9 15.3 6 7.7 9.4 11.1 14.5 17.9 (Note) This product is sold per reel with 4,000 connectors per reel. Please order by reel quantities. 1.75 ±0.1 Tape and Reel Dimensions 12±0.1 4±0.1 2±0.1 .1 +0 0 .5 φ1 Reel dimensions (FREE) 11.5 ±0.1 30.4 MAX n1. 5 To the depth of the perforation 24.4+2 0 3± 0.2 Unreeling direction 0.8 1± n2 R1 0 .5 2± φ80±1 φ380 ±2 +0.2 0 n1 22.25 (24) Product Label Unreeling direction 3 DF65 Series●1.7 mm pitch, Low Profile Board to Wire Connectors for Power Supplies ■Crimp socket A B 1.75 6.1 Contact No.1 mark C D P= 1.7 Part Number DF65-3S-1.7C DF65-4S-1.7C DF65-5S-1.7C DF65-6S-1.7C DF65-8S-1.7C DF65-10S-1.7C No. of Contacts 666-6005-8-00 3 Under development 4 666-6002-0-00 5 666-6009-9-00 6 Under development 8 Under development 10 HRS No. A B C D 6.13 7.83 9.53 11.23 14.63 18.03 5.2 6.9 8.6 10.3 13.7 17.1 7.8 9.5 11.2 12.9 16.3 19.7 3.4 5.1 6.8 8.5 11.9 15.3 [Specification Number] None: 1 package contains 100 pieces (Note) Each package contains 100 pieces. Please order in full package quantities. ■Crimp contact 1.15 0.92 3 4.15 0.65 2.3 0.9 4.3 1.07 φ1 .2 1.45 2.95 4.5 t= 0.15 Part Number HRS No. Description DF65-2428SCF 666-0003-2-00 Reel contact [Specification Number] None: 18,000 pieces per reel Quantity 18,000 pieces per reel Finish RoHS Tin Plating ○ (Note) This product is sold per reel (40,000 connectors per reel), please order by reel quantities. ● Applicable wire (Tinned, annealed copper wire) Conductor size (Core structure) Jacket Diameter 24 AWG (11 pieces/Ø 0.16 mm) Ø1.11mm Ø0.98mm Ø0.88mm 26 AWG (7 pieces/Ø 0.16 mm) 28 AWG (7pieces/Ø 0.127 mm) ●Recommended wire UL10368 ●Strip length 1.4∼1.8mm (Note) Please contact your local Hirose sales rep if you plan on using wires other than those listed above. 4 DF65 Series●1.7 mm pitch, Low Profile Board to Wire Connectors for Power Supplies Tooling Information Item Part Number HRS No. Applicable contact Applicator Press body AP105-DF65-2428S CM-105 CL901-4630-0-00 CL901-0005-4-00 DF65-2428SCF − Hand tool HT305/DF65-2428S DF-C-PO(B) CL550-0306-8-00 DF65-2428SCF CL550-0179-2-00 DF65-2428SCF Extraction tool (Note) Hirose does not cover damage created by the use of unapproved Hirose Tools. Please contact your local Hirose Sales for clarification. Precautionary notes 1. Recommended Soldering Profile (Compatible with lead-free soldering) [Applicable Conditions] 1. Peak temperature : MAX 250ç 2. Heating Area: 220ç or above, within 60sec . 3. Preheating Area: 150~180ç , 90~120 sec. * Measurement is conducted at the contact lead part Please check the mounting conditions before use, conditions such as solder paste types, manufacturer, PCB size and any other soldering materials may alter the performance of such materials. (Note 1) This temperature profile is a recommended value only; please contact your Hirose Sales Rep for more information 2. R e c o m m e n d e d h a n d soldering conditions Temperature of soldering iron: 350±10ç, soldering time: no more than 3 seconds 3. R e c o m m e n d e d s c r e e n thickness, aperture ratio (pattern surface ratio) Thickness: 0.1 mm, aperture opening ratio: 100% 4. Warping of PC Board A maximum of 0.02 mm at the center of connector, as measured from either end of the connector 5. Cleaning Conditions IPA cleaning is allowed. (Cleaning is not recommended because cleaning may change the push/pull feeling etc. Please contact your local Hirose representative prior to the use of any cleaning agents.) 6. Precautions ■ When inserting the crimp contact into the crimp socket, do not insert it at a slanted angle to maintain the reliability of its performance. ■ Please use caution when mating/unmating this connector if it has not been mounted onto the PCB, doing so could deform or damage the contacts. ■ Do not pull on the wires of this connector as this may cause damage to the connector. ■ During the hand soldering process, make sure to not apply too much flux. Doing so may cause a solder wicking problem. ■ This product may experience some differences in color from one production lot to another. This color difference does not influence the performance of the connector. ■ For handling precautions to be used during the insertion/removal process, please refer to the “DF65 Push-pull procedure”. 5 DF65 Series●1.7 mm pitch, Low Profile Board to Wire Connectors for Power Supplies 7. Mating and Unmating Operation Mating operation ① Align the receptacle over the header ② Insert and press down on the receptacle in the direction of the arrow. Reinforced locking portion Friction fit locking portion ③ Completed mating operation Click feeling Unmating operation ① Start by lifting up on the front edge of the receptacle. ② Pull it upward to release the friction fit lock portion. Lever ③ Reinforced lock portion will then be released. Continue lifting the receptacle in an upward direction. ® 6 6-3,Nakagawa Chuoh-2-Chome,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 11/2013. Contents are subject to change without notice for the purpose of improvements.
DF65-5S-1.7C
物料型号:DF65系列,1.7毫米间距,低轮廓板对线连接器,适用于电源。
器件简介:DF65系列连接器具有以下特点: - 独特的锁定结构,增强了线侧部分和插座之间的啮合,防止因布线不当导致的线侧错位。 - 垂直接合方式,减少组装时间,最大化宝贵的板空间,为PCB上其他组件的设计提供更多自由度。 - 高可靠性的接触结构,两点接触结构提供最佳可靠性,低接合高度1.8毫米,有效接合长度0.35毫米。 - 增加电缆保持力,插座设计在接合操作中按下端子凸缘,防止凸缘移动并增强其强度。 - 最大电流4A(AWG24),使用高导电材料的女性端子,降低接触电阻。 - 防止意外脱开,模制结构设计防止因布线不当和恶劣负载导致的意外脱开。
引脚分配:文档中未明确列出具体的引脚分配图,但提供了不同型号的DF65系列连接器的接触数量,包括3、4、5、6、8、10个接触点。
参数特性: - 额定电流:每针4A(使用24 AWG线时)。 - 工作温度范围:-35℃至+105℃。 - 工作湿度范围:20%至80%。 - 电压等级:AC/DC 50V。 - 绝缘电阻:不低于100 MΩ。 - 耐电压:AC 500V,1分钟无闪络或击穿。 - 接触电阻:不超过10 MΩ,测量时电流为1mA,不超过20 mV。
功能详解:DF65系列连接器具有增强的接触可靠性、垂直接合提供优越的操作性、高可靠性的接触结构、增加的电缆保持力、高电流承载能力、防止焊锡吸湿和防止意外脱开的功能。
应用信息:适用于电源的板对线连接器。
封装信息:提供了不同型号的DF65系列连接器的封装尺寸和卷带尺寸,以及卷带包装数量。
DF65-5S-1.7C 价格&库存
很抱歉,暂时无法提供与“DF65-5S-1.7C”相匹配的价格&库存,您可以联系我们找货
DF65-5S-1.7C
