DF57-3234SCF
DF57-3234SCF
    HRS(广濑)
    CONN SOCKET CRIMP 32-34AWG TIN
DF57-3234SCF 数据手册
APPLICABLE STANDARD OPERATING TEMPERATURE RANGE OPERATING HUMIDITY RANGE May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents. RATING STORAGE TEMPERATURE RANGE STORAGE HUMIDITY RANGE APPLICABLE 2 CONTACT -35 C TO +85C (NOTE1) 20% TO 80% (NOTE2) 50 VOLTAGE V -10 C TO +60C (NOTE3) 40% 70% (NOTE3) DF57-*S-1.2C DF57H-*S-1.2C △ AC/DC TO APPLICABLE CABLE INSULATION DIAMETER AWG32 TO AWG 34 φ0.32~0.63 mm SPECIFICATIONS ITEM TEST METHOD REQUIREMENTS QT AT X X X X X - X - X - X - X - X - X - X - CONSTRUCTION GENERAL EXAMINATION VISUALLY AND BY MEASURING INSTRUMENT. MARKING ACCORDING TO DRAWING. CONFIRMED VISUALLY. ELECTRIC CHARACTERISTICS CONTACT RESISTANCE 20 mV MAX, 1 mA(DC OR 1000 Hz). 10 mMAX. MECHANICAL CHARACTERISTICS CONTACT INSERTION AND EXTRACTION FORCES MECHANICAL OPERATION VIBRATION SHOCK INSERTION FORCE EXTRACTION FORCE T=0.2±0.002 mm BY STEEL GAUGE. 5 N MAX. 0.1 N MIN. ① CONTACT RESISTANCE: 20 mΩ MAX. ② NO DAMAGE, CRACK OR LOOSENESS OF PARTS. FREQUENCY 10 TO 55 Hz, SINGLE AMPLITUDE ① NO ELECTRICAL DISCONTINUITY OF 0.75 mm, AT 10 CYCLES FOR 3 DIRECTION. 1μs. 2 490 m/s DURATION OF PULSE 11 ms AT 3 TIMES ② NO DAMAGE, CRACK OR LOOSENESS OF PARTS. FOR 3 DIRECTIONS. 30 TIMES INSERTION AND EXTRACTION. ① #AWG32 ② #AWG34 CRIMP TENSILE STRENGTH : : 5 N MIN. 3 N MIN. ENVIRONMENTAL CHARACTERISTICS DAMP HEAT(STEADY STATE) RAPID CHANGE OF TEMPERATURE EXPOSED AT 40 ± 2℃ , 90 TO 95 %, 96 h. (AFTER LEAVING THE ROOM TEMPERATURE FOR 1~2h.) TEMPERATURE -55℃→ +85℃ TIME 30min→ 30min UNDER 5 CYCLES. (AFTER LEAVING THE ROOM TEMPERATURE FOR 1~2h.) ① CONTACT RESISTANCE: 20 mΩ MAX. ② NO DAMAGE, CRACK OR LOOSENESS OF PARTS. REMARKS NOTE 1:INCLUDING THE TEMPERATURE RISE BY CURRENT NOTE 3:NON-CONDENSING. NOTE 2:APPLY TO THE CONDITION OF LONG TERM STORAGE FOR UNUSED PRODUCTS BEFORE PCB ON BOARD, AFTER PCB BOARD, OPERATING TEMPERATURE AND HUMIDITY RANGE IS APPLIED FOR INTERIM STORAGE DURING TRANSPORTATION. △ 2 COUNT DESCRIPTION OF REVISIONS DESIGNED CHECKED DATE 1 DIS-H-00000127 MI.SAKIMURA KI.AKIYAMA 15.02.16 APPROVED Unless otherwise specified, refer to IEC 60512 Note QT:Qualification Test FORM HD0011-2-1 AT:Assurance Test X:Applicable Test PART NO. HIROSE ELECTRIC CO., LTD. CODE NO. 10.12.02 CHECKED HK.UMEHARA 10.12.02 DESIGNED TS.KUMAZAWA 10.12.02 DRAWN TS.KUMAZAWA 10.12.02 DRAWING NO. SPECIFICATION SHEET KI.AKIYAMA ELC4-335549-00 DF57-3234SCF CL666-0016-1-00 2 △ 1/1
DF57-3234SCF 价格&库存
很抱歉,暂时无法提供与“DF57-3234SCF”相匹配的价格&库存,您可以联系我们找货
