USF370-2.00M-0.01%-5PPM 数据手册
Type USF Ultra-Stable Low TC Film Resistors
200 Series and 300 Series
Page 1 of 2
Zero Nominal TC — Maximum Absolute TC to 2 ppm/°C, -40°C to +85°C, ref. to +25°C
Absolute Tol. to ±0.01%, Resistance Range 50 Ohm to 25 Megohm, Voltage Ratings up to 2500 Volts
The USF Ultra-Stable Low TC Ultra-Precision Film Resistors were
developed to meet the requirements for increasing performance for
resistors in high performance analog electronics. Utilizing Caddock
proprietary resistance film systems, the Type USF resistors provide
the Lowest TC with the Widest Resistance Range and the Highest
Voltage Ratings available in the industry.
• Resistance Range 50 ohm to 25 Megohm.
• Temperature Coefficient -40°C to +85°C, referenced to +25°C
200 Series — ZERO Nominal TC — Maximum Absolute TC 2 ppm/°C
300 Series — ZERO Nominal TC — Max. Abs. TC 5 ppm/°C or 10 ppm/°C
• Tolerance: ±0.01% or ±0.1%.
• Specific standard resistance values are available that are most
commonly required in high accuracy analog design. These values
were selected and optimized for produceability and performance.
• “Matched Pairs” of USF 300 Series are available with ratio TC as tight as
0.5 ppm/°C. Contact Applications Engineering.
Type USF 200 Series Ultra-Stable Resistors
• Ceramic package provides cool operation.
Type USF Ultra-Stable Resistors are offered in standard resistance values
that are most commonly used in precision analog design. These standard
resistance values can be used in precise amplifier gain setting, precise
resistor bridge circuits, precise transducer sense circuits, and precise
voltage dividers with up to 2500 volt input voltage.
Extremely Low Power Coefficient (Wattage Coefficient): Type USF
resistors are constructed with an aluminum oxide ceramic sandwich
that provides great thermal conductivity. The ceramic sandwich
package very effectively minimizes the power coefficient drift. Power
coefficient is the resistance drift due to temperature rise in the element
caused by the power (wattage) dissipation in the resistor where the selfheating temperature rise of the resistor element results in TC drift (temp.
rise in °C, times the temperature coefficient of the resistor). In the USF
package, heat is pulled away from the resistance material efficiently by
this ceramic sandwich package construction. Plastic molded Low TC foil
resistors cannot provide this outstanding benefit since the plastic impedes
the flow of heat, causing greater temperature rise at the resistor element
and greater self-heating related resistance drift due to power dissipation.
The USF 200 Series resistors provide a new level of performance with near
ZERO TC, very low power coefficient, wide resistance range, and higher
voltage ratings than is offered by other resistor technologies.
Wattage
Maximum
Continuous
Oper. Voltage
Resistance
Model Number
@ +85°C
USF240
0.33
300
50 Ω
USF270
0.75
1,400
990 K
Min.
Constructed with two selected USF 300 Series
Resistors bonded back to back to achieve
outstanding low Absolute Temperature Coefficient
performance. The resistors are to be connected in
parallel on the circuit board.
ZERO Nominal TC — Max. Absolute TC: 2 ppm/°C,
Type USF 300 Series Ultra-Stable Resistors
• ZERO Nominal TC — Max. Absolute TC: 5 ppm/°C
or 10 ppm/°C, -40°C to +85°C, referenced to +25°C
Tolerance
Temperature
Coefficient
Fig.
10 Meg
0.01% or 0.1%
2 ppm/°C
1
5 Meg
0.01% or 0.1%
2 ppm/°C
1
Max.
Dimensions inches (mm)
A
B
.750 ±.020
(19.05 ±.51)
1.500 ±.020
(38.10 ±.51)
.375 ±.020
(9.53 ±.51)
.500 ±.020
(12.70 ±.51)
USF271
0.75
2,500
9.9 Meg
10 Meg
0.01% or 0.1%
2 ppm/°C
1
1.500 ±.020
(38.10 ±.51)
USF340
0.33
300
50 Ω
20 Meg
0.01% or 0.1%
5 ppm/°C or
10 ppm°C
2
.750 ±.020
(19.05 ±.51)
USF370
0.75
1,400
990 K
10 Meg
0.01% or 0.1%
USF371
0.75
2,500
19.8 Meg
25 Meg
0.01% or 0.1%
5 ppm/°C or
10 ppm°C
5 ppm/°C or
10 ppm°C
2
2
ELECTRONICS, INC.
e-mail: caddock@caddock.com • web: www.caddock.com
For Caddock Distributors listed by country see caddock.com/contact/dist.html
© 2019 Caddock Electronics, Inc.
1.500 ±.020
(38.10 ±.51)
1.500 ±.020
(38.10 ±.51)
.500 ±.020
(12.70 ±.51)
.375 ±.020
(9.53 ±.51)
.500 ±.020
(12.70 ±.51)
.500 ±.020
(12.70 ±.51)
C
.425 Max.
(10.8 Max.)
.550 Max.
(13.97 Max.)
.550 Max.
(13.97 Max.)
D
.600 ±.020
(15.24 ±.51)
1.350 ±.020
(34.29 ±.51)
.395 Max.
(10.03 Max.)
1.350 ±.020
(34.29 ±.51)
.600 ±.020
(15.24 ±.51)
.520 Max.
(13.21 Max.)
.520 Max.
(13.21 Max.)
1.350 ±.020
(34.29 ±.51)
1.350 ±.020
(34.29 ±.51)
Sales and Applications Engineering
17271 North Umpqua Hwy.
Roseburg, Oregon 97470-9422
Phone: (541) 496-0700
Fax: (541) 496-0408
28_IL134.0819
Page 2 of 2
Standard Resistance Values:
Fig. 1
USF 200 Series
USF240 Standard Resistance Values:
Absolute Tolerance: ±0.01% or ±0.1%, Absolute TC: 2 ppm/°C
50.0 Ω
100 Ω
200 Ω
250 Ω
350 Ω
500 Ω
900 Ω
1.00 K
2.00 K
2.50 K
5.00 K
9.00 K
90.0 K
99.0 K
100 K
200 K
10.0 K
20.0 K
25.0 K
50.0 K
250 K
500 K
1.00 Meg
2.00 Meg
USF270 Standard Resistance Values:
2.50 Meg 10.0 Meg
5.00 Meg
9.90 Meg
9.99 Meg
Top View
990 K
.155 ±.025
(3.94 ±.64)
A
Front View
1.00 Meg 2.00 Meg 5.00 Meg
USF271 Standard Resistance Values:
9.90 Meg 9.99 Meg 10.0 Meg
B
CADDOCK
USF240
1921
.032 DIA.
(.81 DIA.)
.50 ±.125
(12.70 ±3.18)
USF340 Standard Resistance Values:
Absolute Tolerance: ±0.01% or ±0.1%, Absolute TC: 5 ppm/°C or 10 ppm/°C
50.0 Ω
100 Ω
200 Ω
350 Ω
400 Ω
500 Ω
700 Ω
1.00 K
1.80 K
2.00 K
4.00 K
5.00 K
10.0 K
18.0 K
20.0 K
40.0 K
50.0 K
90.0 K
99.0 K
100 K
180 K
198 K
200 K
400 K
500 K
990 K
999 K
1.00 Meg
USF370 Standard Resistance Values:
2.00 Meg
4.00 Meg
5.00 Meg
9.90 Meg
9.99 Meg
10.0 Meg
19.8 Meg
19.98 Meg
20.0 Meg
990 K
1.98 Meg 4.00 Meg 9.90 Meg 10.0 Meg
1.00 Meg 2.00 Meg 5.00 Meg 9.99 Meg
Dimensions in inches
and (millimeters)
D
C
(seated height)
Side View
.200 ±.020
(5.08 ±.51)
USF 200 Series Circuit Board Connection Note: The Type USF 200
Series Resistor must have the two “bonded” resistors in the package connected
in parallel on the circuit board as shown. This parallel connection of the two
resistors achieves the specified resistance with the specified performance.
USF371 Standard Resistance Values:
Circuit Board Trace
Circuit Board Trace
19.8 Meg 19.98 Meg 20.0 Meg 25.0 Meg
Specifications:
Resistance Tolerance: ±0.01% or ±0.1% measured at +23°C ±2°C.
Absolute Temperature Coefficient: TC referenced to +25°C,
∆R taken at -40°C and +85°C.
Load Life Stability: 2,000 hours at +85°C at rated voltage, not to
exceed rated power, ∆R (+0.015 ±0.015)% max.
10,000 hours at +85°C at rated voltage, not to exceed rated
power, ∆R (+0.030 ±0.030)% max.
Thermal Shock: Mil-Std-202 Method 107 condition A, except min.
temp. is -40°C, ∆R ±0.01% maximum.
Voltage Coefficient: USF270 at 5 Meg, and USF271, USF370,
USF371 at resistances of 9 Meg or greater, 0.02 ppm/volt
maximum.
Shelf Life Stability: Typical +(20 ppm ± 20 ppm)/yr. after 1 year.
Extended shelf life (ten years) 10 ppm/year maximum.
Operating Temperature: -40°C to +85°C.
Lead Finish: Matte Tin (Sn)
USF200 Series Part Numbers:
USF240 - 10.0M - 0.01% - 2ppm
Resistor Value
USF300 Series Part Numbers:
TC (5ppm or 10ppm)
Tolerance
Resistor Value (0.01% or 0.1%)
Model Number
Front View
.032 DIA.
(.81 DIA.)
.50 ±.125
(12.70 ±3.18)
D
C
(seated height)
Side View
and (millimeters)
Custom USF 200 Series and 300 Series Resistors:
USF 200 Series and 300 Series Resistors are available, for high
quantity applications, with custom performance:
Type TF Low TC Ultra-Precision Film Resistors (1K to 125Meg)
Type TK Low TC Precision Radial-Lead Film Resistors
Type TG Low TC Precision High Voltage Resistors (up to 30KV)
Type USG Low TC Ultra-Precision High Voltage Resistors
T912 and T914 Low TC Ultra-Precision Resistor Networks
Type USVD Ultra-Precision Voltage Dividers (up to 2000 Volts)
Type THV Precision High Voltage Dividers (up to 15KV)
ELECTRONICS, INC.
B
CADDOCK
USF340
1920
.075 ±.020
(1.91 ±.51)
Other Low TC Resistor Products from Caddock:
Tolerance
(0.01% or 0.1%)
USF370 - 990K - 0.1% - 5ppm
A
• In the 200 Series, Absolute TC to as tight as 1 ppm/°C is available
for certain resistances.
• Matched Ratio TC to as tight as 0.5 ppm/°C for equal resistances.
• Matched Ratio TC can be provided in the 200 Series style “bonded”
Resistor pairs.
Ordering Information:
Model Number
Fig. 2
USF 300 Series
Fax: (541) 496-0408
28_IL134.0819
