YC124-JR-078K2L
YC124-JR-078K2L
    YAGEO(国巨)
    RA_0402X4
    排阻/电阻网络 RA_0402X4 8.2KΩ ±5% ±200ppm/℃
YC124-JR-078K2L 数据手册
120 DATA SHEET ARRAY CHIP RESISTORS YC/TC 5%, 1% sizes YC:102/104/122/124/162/164/248/324/158/358 TC: 122/124/164 Product specification – November 14, 2014 V.0 RoHS compliant 2 Product specification Chip Resistor Surface Mount YC/TC SERIES 12 102 to 358 SCOPE ORDERING INFORMATION - GLOBAL PART NUMBER & 12NC This specification describes YC (convex) and TC (concave) series chip resistor arrays with lead-free terminations made by thick film process. Both part numbers are identified by the series, size, tolerance, packing type, temperature coefficient, taping reel and resistance value. YAGEO BRAND ordering code GLOBAL PART NUMBER (PREFERRED ) APPLICATIONS  Terminal for SDRAM and DDRAM  Computer applications: laptop computer, desktop computer  Consume electronic equipments: PDAs, PNDs  Mobile phone, telecom… YC XXX – X X X XX XXXX L TC (1) (2) (3) (4) (5) (6) (7) (1) SIZE YC:102/104/122/124/162/164/248/324/158/358 TC: 122/124/164 (2) TOLERANCE F = ± 1% J = ± 5% (for Jumper ordering, use code of J) (3) PACKAGING TYPE R = Paper taping reel FEATURES  More efficient in pick & place application  Low assembly costs (4) TEMPERATURE COEFFICIENT OF RESISTANCE – = Base on spec (5) TAPING REEL 07 = 7 inch dia. Reel 13 = 13 inch dia. Reel  RoHS compliant  Products with lead free terminations meet RoHS requirements (6) RESISTANCE VALUE There are 2~4 digits indicated the resistor value. Letter R/K/M is decimal point.  Pb-glass contained in electrodes  Resistor element and glass are exempted by RoHS K = Embossed plastic tape reel Detailed resistance rules show in table of “Resistance rule of global part number”. (7) DEFAULT CODE Letter L is the system default code for ordering only. (Note)  Reducing environmentally hazardous wastes  High component and equipment reliability  Saving of PCB space  None forbidden-materials used in products/production Resistance rule of global part number Resistance code rule Example  Halogen Free Epoxy 0R 0R = Jumper XRXX (1 to 9.76 Ω) 1R = 1 Ω 1R5 = 1.5 Ω 9R76 = 9.76 Ω XXRX (10 to 97.6 Ω) 10R = 10 Ω 97R6 = 97.6 Ω XXXR (100 to 976 Ω) 100R = 100 Ω XKXX (1 to 9.76 KΩ) 1K = 1,000 Ω 9K76 = 9760 Ω XM (1 MΩ) 1M = 1,000,000 Ω ORDERING EXAMPLE The ordering code of a YC122 convex chip resistor array, value 1,000 Ω with ± 5% tolerance, supplied in 7-inch tape reel is: YC122-JR-071KL. NOTE 1. All our RSMD products meet RoHS compliant. "LFP" of the internal 2D reel label mentions "Lead Free Process" 2. On customized label, "LFP" or specific symbol printed and the optional "L" at the end of GLOBAL PART NUMBER / 12NC can be added (both are on customer request) www.yageo.com Nov. 14, 2014 V.0 Product specification Chip Resistor Surface Mount YC/TC SERIES 3 12 102 to 358 PHYCOMP BRAND ordering codes Both GLOBAL PART NUMBER (preferred) and 12NC (traditional) codes are acceptable to order Phycomp brand products. GLOBAL PART NUMBER (PREFERRED ) For detailed information of GLOBAL PART NUMBER and ordering example, please refer to page 2. TC122 series is supplied and ordered by global part number only. 12NC CODE 2350 XXX XXXXX L (1) (2) (3) Last digit of 12NC Resistance decade (3) (4) PAPER / PE TAPE ON REEL (units) (2) TYPE/ START TOL. RESISTANCE 2×0402 IN (1) (%) RANGE 10,000 ARV321 2350 ± 5% 1 to 1 MΩ 013 11xxx 013 12xxx ARV322 2350 ± 1% 10 to 1 MΩ 013 2xxxx 013 3xxxx Jumper 2350 - 0Ω 013 91001 - 50,000 (1) The resistors have a 12-digit ordering code starting with 2350. (2) The subsequent 4 or 5 digits indicate the resistor tolerance and packaging. (3) The remaining 4 or 3 digits represent the resistance value with the last digit indicating the multiplier as shown in the table of “Last digit of 12NC”. (4) "L" is optional symbol (Note) . Last digit 0.01 to 0.0976 Ω 0.1 to 0.976 Ω 0 1 to 9.76 Ω 8 10 to 97.6 Ω 9 100 to 976 Ω 1 1 to 9.76 KΩ 2 10 to 97.6 KΩ 3 100 to 976 KΩ 4 1 to 9.76 MΩ 5 10 to 97.6 MΩ 6 Example: 7 0.02 Ω = 0200 or 200 0.3 Ω = 3007 or 307 ORDERING EXAMPLE 1Ω = 1008 or 108 The ordering code of a ARV321 resistor, value 1,000Ω with ± 5% tolerance, supplied in tape of 10,000 units per reel is: 235001311102(L) or YC122-JR-071KL. 33 KΩ = 3303 or 333 10 MΩ = 1006 or 106 NOTE 1. All our RSMD products are RoHS compliant. "LFP" of the internal 2D reel label mentions "Lead Free Process" 2. On customized label, "LFP" or specific symbol printed and the optional "L" at the end of GLOBAL PART NUMBER / 12NC can be added (both are on customer request) www.yageo.com Nov. 14, 2014 V.0 Product specification Chip Resistor Surface Mount YC/TC SERIES 4 12 102 to 358 MARKING YC102/122 No marking Fig. 1 YC104 No marking Fig. 2 YC124/164/324 1-Digit marking Fig. 3 Jumper=0Ω E-24 series: 3 digits First two digits for significant figure and 3rd digit for number of zeros Fig. 3-1 Value=240KΩ YC248 1-Digit marking Fig. 4 Jumper=0Ω E-24 series: 3 digits First two digits for significant figure and 3rd digit for number of zeros Fig. 4-1 Value=240KΩ YC158/358 E-24 series: 3 digits Fig. 5 Value=24KΩ Fig. 5-1 Value=240KΩ First two digits for significant figure and 3rd digit for number of zeros TC122 No marking Fig. 6 TC124 No marking Fig. 7 www.yageo.com Nov. 14, 2014 V.0 Product specification Chip Resistor Surface Mount YC/TC SERIES 5 12 102 to 358 TC164 1-Digit marking Fig. 8 Jumper=0Ω E-24 series: 3 digits First two digits for significant figure and 3rd digit for number of zeros Fig. 8-1 Value=240KΩ For further marking information, please refer to data sheet “Chip resistors marking”. CONSTRUCTION The resistor is constructed on top of a high-grade ceramic body. Internal metal electrodes are added on each end to make the contacts to the thick film resistive element. The composition of the resistive element is a noble metal imbedded into a glass and covered by a second glass to prevent environment influences. The resistor is laser trimmed to the rated resistance value. The resistor is covered with a protective epoxy coat, finally the two external terminations (matte tin on Nibarrier) are added as shown in Fig.9. OUTLINES Fig. 9 Chip resistor outlines www.yageo.com Nov. 14, 2014 V.0 Product specification Chip Resistor Surface Mount YC/TC SERIES 102 to 358 6 12 SCHEMATIC Fig. 11 Equivalent circuit diagram Note: 1. YC104 is flat type For dimension, please refer to Table 1 Table 1 Fig. 4 and Fig. 10 YC/TC122 series chip resistors dimension Note: 1. YC104 is flat type www.yageo.com Nov. 14, 2014 V.0 Product specification Chip Resistor Surface Mount YC/TC SERIES 7 12 102 to 358 DIMENSIONS Table 1 TYPE YC102 YC104 H / H1 YC122 YC124 YC162 YC164 YC248 YC324 B P L T W1 W2 H: 0.35 ±0.10 0.20 ±0.10 0.50 ±0.05 0.80 ±0.10 0.35 ±0.10 0.15 ±0.10 0.60 ±0.10 H: 0.20 ±0.10 0.15 ±0.05 0.40 ±0.10 1.40 ±0.10 0.35 ±0.10 0.15 ±0.10 0.60 ±0.10 H: 0.21 +0.10/-0.05 0.20 ±0.10 0.67 ±0.05 1.00 ±0.10 0.30 ±0.10 0.25 ±0.10 1.00 ±0.10 0.20 ±0.15 0.50 ±0.05 2.00 ±0.10 0.45 ±0.10 0.30 ±0.15 1.00 ±0.10 0.30 ±0.10 0.80 ±0.05 1.60 ±0.10 0.40 ±0.10 0.30 ±0.10 1.60 ±0.10 0.30 ±0.15 0.80 ±0.05 3.20 ±0.15 0.60 ±0.10 0.30 ±0.15 1.60 ±0.15 0.30 ±0.15 0.50 ±0.05 4.00 ±0.20 0.45 ±0.10 0.40 ±0.15 1.60 ±0.15 0.50 ±0.20 1.27 ±0.05 5.08 ±0.20 0.60 ±0.10 0.50 ±0.15 3.20 ±0.20 H: 0.45 ±0.05 H1: 0.30 ±0.05 H: 0.30 ±0.10 H: 0.65 ±0.05 H1: 0.50 ±0.15 H: 0.45 ±0.05 H1: 0.30 ±0.05 H: 1.10 ±0.15 H1: 0.90 ±0.15 TC122 TC124 H : 0.30 ±0.05 0.25 ±0.15 0.50 ±0.05 1.00 ±0.10 0.30 ±0.10 0.25 ±0.15 1.00 ±0.10 H : 0.30 ±0.10 0.20 ±0.10 0.50 ±0.05 2.00 ±0.10 0.40 ±0.10 0.25 ±0.10 1.00 ±0.10 TC164 H: 0.60 ±0.15 0.30 ±0.15 0.80 ±0.05 3.20 ±0.15 0.60 ±0.10 0.30 ±0.15 1.60 ±0.15 YC158 H: 0.45±0.05 0.30 ±0.15 0.64 ±0.05 3.20 ±0.20 0.60 ±0.10 0.35 ±0.15 1.60 ±0.15 0.50 ±0.15 1.27 ±0.05 6.40 ±0.20 0.60 ±0.10 0.50 ±0.15 3.20 ±0.20 YC358 H: 1.10±0.15 H1: 0.90±0.15 www.yageo.com Nov. 14, 2014 V.0 Product specification Chip Resistor Surface Mount YC/TC 8 12 102 to 358 SERIES ELECTRICAL CHARACTERISTICS Table 2 TYPE POWER OPERATING P70 TEMP. RANGE YC102 1/32W -55°C to +125°C MWV RCOV DWV RESISTANCE RANGE & TOLERANCE 15V 30V 30V E24 ± 5% 10Ω ≤ R ≤ 1MΩ E24/E96 ± 1% 10Ω ≤ R ≤ 1MΩ Jumper < 0.05Ω T. C. R. Jumper criteria (unit: A) Rated current Max. current 0.5 1.0 Rated current Max. current 0.5 1.0 Rated current Max. current 0.5 1.0 1Ω ≤ R ≤ 10Ω ± 250 ppm/°C Rated current 10Ω ≤ R ≤ 1MΩ Max. current ± 200 ppm/°C 1.0 2.0 Rated current Max. current 1.0 2.0 1.0 2.0 ± 200 ppm/°C YC104 1/32W -55°C to +125°C 12.5V 25V 25V E24 ± 5% 10Ω ≤ R ≤ 1MΩ E24/E96 ± 1% 10Ω ≤ R ≤ 1MΩ Jumper < 0.05Ω YC122 1/16W -55°C to +125°C 50V 100V 100V E24 ± 5% 1Ω ≤ R ≤ 1MΩ E24/E96 ± 1% 1Ω ≤ R ≤ 1MΩ Jumper < 0.05Ω YC124 1/16W -55°C to +155°C 25V 50V 100V E24 ± 5% 1Ω ≤ R ≤ 1MΩ E24/E96 ± 1% 1Ω ≤ R ≤ 1MΩ Jumper < 0.05Ω YC162 1/16W -55°C to +125°C 50V 100V 100V E24 ± 5% 1Ω ≤ R ≤ 1MΩ E/24/E96 ± 1% 1Ω ≤ R ≤ 1MΩ Jumper < 0.05Ω YC164 1/16W -55°C to +155°C 50V 100V 100V E24 ± 5% 1Ω ≤ R ≤ 1MΩ E24/E96 ± 1% 1Ω ≤ R ≤ 1MΩ Jumper < 0.05Ω Rated current Max. current YC248 1/16W -55°C to +155°C 50V 100V 100V E24 ± 5% 10Ω ≤ R ≤ 1MΩ E24/E96 ± 1% 10Ω ≤ R ≤ 1MΩ Jumper < 0.05Ω Rated current 2.0 Max. current 10.0 YC324 1/8W -55°C to +155°C 200V 500V 500V E24 ± 5% 10Ω ≤ R ≤ 1MΩ E24/E96 ± 1% 10Ω ≤ R ≤ 1MΩ --- --- TC122 1/16W -55°C to +125°C 50V 100V 100V E24 ± 5% 10Ω ≤ R ≤ 1MΩ E24/E96 ± 1% 10Ω ≤ R ≤ 1MΩ Jumper < 0.05Ω Rated current Max. current 1.0 1.5 Rated current Max. current 1.0 1.5 Rated current Max. current 1.0 2.0 ± 200 ppm/°C TC124 1/16W -55°C to +125°C 50V 100V 100V E24 ± 5% 10Ω ≤ R ≤ 1MΩ E24/E96 ± 1% 10Ω ≤ R ≤ 1MΩ Jumper < 0.05Ω TC164 1/16W -55°C to +155°C 50V 100V 100V E24 ± 5% 10Ω ≤ R ≤ 1MΩ E24/E96 ± 1% 10Ω ≤ R ≤ 1MΩ Jumper < 0.05Ω YC158 1/16W -55°C to +155°C 25V 50V 50V E24 ± 5% 10Ω ≤ R ≤ 100KΩ --- --- YC358 1/16W -55°C to +155°C 50V 100V 100V E24 ± 5% 10Ω ≤ R ≤ 330KΩ --- --- FOOTPRINT AND SOLDERING PROFILES For recommended footprint and soldering profiles, please refer to data sheet “Chip resistors mounting”. PACKING STYLE AND PACKAGING QUANTITY Table 3 Packing style and packaging quantity PACKING STYLE PACKING STYLE YC102 YC/TC YC/TC YC162 YC/TC YC248 YC324 YC158 YC358 Paper taping reel ( R ) 7" (178mm) Embossed taping reel ( K) /104 122 124 10,000 10,000 10,000 5,000 5,000 164 5,000 --- 5,000 --- 13" (254mm) --- 50,000 40,000 --- 20,000 --- --- 20,000 --- 7" (178mm) --- --- --- --- --- 4,000 4,000 --- 4,000 NOTE 1. For tape and reel specification/dimensions, please refer to data sheet “Chip resistors packing”. www.yageo.com Nov. 14, 2014 V.0 Product specification Chip Resistor Surface Mount YC/TC SERIES 102 to 358 9 12 FUNCTIONAL DESCRIPTION OPERATING TEMPERATURE RANGE YC102/104/122/162, TC122/124 Range: -55℃ to +125℃ (Fig.12) YC124/164/248/324/158/358, TC164 Range: -55℃ to +155℃(Fig.13) POWER RATING Each type rated power at 70℃ YC102/104 = 1/32 W YC122/124/162/164/248/158/358 = 1/16 W YC324 = 1/8 W TC122/124/164 = 1/16 W Fig. 12 Maximum dissipation (P) in percentage of rated power as a function of the operating ambient temperature (T amb ) RATED VOLTAGE The DC or AC (rms) continuous working voltage corresponding to the rated power is determined by the following formula: V= (PxR) or max. working voltage whichever is less Where V=Continuous rated DC or AC (rms) working voltage (V) P=Rated power (W) R=Resistance value (Ω ) Fig. 13 Maximum dissipation (P) in percentage of rated power as a function of the operating ambient temperature (Tamb ) www.yageo.com Nov. 14, 2014 V.0 Product specification Chip Resistor Surface Mount YC/TC SERIES 10 12 102 to 358 TESTS AND REQUIREMENTS Table 4 Test condition, procedure and requirements TEST TEST METHOD PROCEDURE Life/ Operational Life/ Endurance MIL-STD-202G-method 108A 1,000 hours at 70± 5 °C applied RCWV 1.5 hours on, 0.5 hour off, still air required High Temperature Exposure/ Endurance at Upper Category Temperature MIL-STD-202G-method 108A IEC 60115-1 4.25.1 REQUIREMENTS ± (2%+0.05 Ω)
YC124-JR-078K2L 价格&库存
很抱歉,暂时无法提供与“YC124-JR-078K2L”相匹配的价格&库存,您可以联系我们找货
YC124-JR-078K2L
  • 50+0.02142
  • 500+0.01932
  • 5000+0.01792
  • 10000+0.01722
  • 30000+0.01652
  • 50000+0.01610
库存:18080
YC124-JR-078K2L
  • 10000+0.0676510000+0.00840
  • 30000+0.0594530000+0.00738
  • 50000+0.0545250000+0.00677
  • 100000+0.05342100000+0.00663
库存:37370
