Type SR Precision Current Sense Resistors
Non-inductive Design - Compact Footprint Minimizes Circuit Board Space
Kelvin Terminals (Four Wire) - Resistance Values 0.005Ω to 1.00Ω
Type SR Current Sense Resistors utilize Caddock's Micronox® resistance
films to achieve a low cost resistor with Non-inductive Performance. This
compact construction makes this sense resistor ideal for many current
monitoring or control applications.
The special performance features of these Type SR Current Sense
Resistors include:
• Available in Standard Resistances down to 5 milliohm.
• Non-Inductive Design.
• Terminals are constructed for Kelvin connections to the circuit board.
• Compact footprint.
Max.
Power Rating at
70°C
Voltage Rating
Terminal Material
SR10
0.008 Ω
1.00 Ω
1.0 Watt
Power Limited
Solderable
SR20
0.005 Ω
1.00 Ω
2.0 Watts
Power Limited
Solderable
SR10 PACKAGE DIMENSIONS
Side view
Front view
Back view
.090 (2.29)
MAX.
.365 ±.020
(9.27 ±.51)
SR10
0.025Ω
1%
.370 ±.015
(9.40 ±.38)
.125 ±.020
(3.18 ±.51)
.045 (1.14)
.032 ±.007
(.81 ±.18)
.025 (.64)
SR20 PACKAGE DIMENSIONS
.565 ±.020
(14.35 ±.51)
SR20
0.050Ω
1%
.400 ±.015
(10.16 ±.38)
.125 ±.020
(3.18 ±.51)
.032 ±.007
(.81 ±.18)
.025 (.64)
DIMENSIONS IN INCHES AND (MILLIMETERS)
CIRCUIT BOARD LAYOUT NOTES
SR20
SR10
A
A
Scale:
actual size
C
C S S C
.045 (1.14)
.025 (.64)
.045 (1.14)
.025 (.64)
Section AA
B
B
.100 (2.54)
.100 (2.54)
.100 (2.54)
.200 (5.08)
.100 (2.54)
.200 (5.08)
S S
C
.045 (1.14)
.025 (.64)
.045 (1.14)
Section BB
.025 (.64)
Measurement note: For purposes of these specifications, resistance measurement shall
be made using Kelvin connections (four wire) with appropriate current and sense connections to the device terminals.
C = Current connection
S = Sense connection
Circuit Board Layout: The circuit board traces connecting to the current terminals must
be sized appropriately for the current flowing through the trace. For example; 0.005Ω
operated at 2.0 Watts would have 20 amps flowing through the circuit board traces into
the current terminals.
ELECTRONICS, INC.
e-mail: caddock@caddock.com • web: www.caddock.com
For Caddock Distributors listed by country see caddock.com/contact/dist.html
© 2003-2017 Caddock Electronics, Inc.
0.008
0.010
0.012
0.015
Ω
Ω
Ω
Ω
0.020
0.025
0.030
0.033
0.040 Ω
0.050 Ω
0.075 Ω
0.10 Ω
Ω
Ω
Ω
Ω
0.15
0.20
0.25
0.30
Ω
Ω
Ω
Ω
0.40
0.50
0.75
1.00
Ω
Ω
Ω
Ω
SR20 Standard Resistance Values:
0.040 Ω 0.15 Ω 0.40 Ω
0.005 Ω 0.020 Ω
0.050 Ω 0.20 Ω 0.50 Ω
0.008 Ω 0.025 Ω
0.075 Ω 0.25 Ω 0.75 Ω
0.010 Ω 0.030 Ω
0.10 Ω
0.015 Ω 0.033 Ω
0.30 Ω 1.00 Ω
Custom resistance values can be manufactured for
high quantity applications. Please contact Caddock
Applications Engineering.
Specifications:
.090 MAX.
(2.29 MAX.)
.045 (1.14)
SR10 Standard Resistance Values:
Resistance Tolerance: ±1.0%
Temperature Coefficient: TC referenced to
+25°C, ∆R taken at -15°C and +105°C.
0.081 to 1.00 ohm
-50 to +100 ppm/°C
0.025 to 0.080 ohm
0 to +150 ppm/°C
0.008 to 0.024 ohm
0 to +200 ppm/°C
0.005 to 0.007 ohm
0 to +300 ppm/°C
Load Life: 1000 hours at rated power at +70°C,
∆R ±(0.2 percent + 0.00001 ohm) max.
Thermal Shock: Mil-Std-202, Method 107, Cond. A,
Moisture Resistance: Mil-Std-202, Method 106,
Encapsulation: Polymer over resistance element.
Power Derating Curve:
100
80
* Power rating:
The power rating
60
40
should be limited as
shown by the derating
curve based upon the
25
70
100
150
TEMPERATURE, °C
maximum ambient
temperature. The derating curve is based on still
air with natural convection around the resistor.
RATED LOAD, %
Resistance
Min.
Model No.
Ordering Information:
Model Number:
Resistor Value:
SR10 - 0.050 - 1%
Tolerance
Sales and Applications Engineering
17271 North Umpqua Hwy.
Roseburg, Oregon 97470-9422
Phone: (541) 496-0700
Fax: (541) 496-0408
28_IL126.01717
很抱歉,暂时无法提供与“SR10-0.020-1%”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 250+38.41764250+4.95896
- 500+35.84834500+4.62732
- 750+34.52881750+4.45699
- 1250+33.036251250+4.26433
- 1750+32.147181750+4.14957
- 2500+31.278512500+4.03744
- 国内价格 香港价格
- 1+83.790251+10.81567
- 10+57.7508410+7.45450
- 25+50.6933225+6.54351
- 50+46.2788150+5.97368
- 100+42.52612100+5.48929
