LTV-847S
LTV-847S
    LITE-ON(光宝)
    OC-16P_19.84X7.62MM_SM
    光电耦合器 VF=1.2V IF=50mA VISO=5KV
LTV-847S 数据手册
Photocoupler Product Data Sheet LTV-817/ 827/ 847 ( M, S, S-TA, S-TA1, S-TP ) Series Spec No.: DS-70-96-0016 Effective Date: 03/04/2010 Revision: K LITE-ON DCC RELEASE BNS-OD-FC001/A4 LITE-ON Technology Corp. / Optoelectronics No.90,Chien 1 Road, Chung Ho, New Taipei City 23585, Taiwan, R.O.C. Tel: 886-2-2222-6181 Fax: 886-2-2221-1948 / 886-2-2221-0660 http://www.liteon.com/opto LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only FEATURES * Current transfer ratio ( CTR : MIN. 50% at IF = 5mA, VCE = 5V ) * High input-output isolation voltage ( Viso = 5,000Vrms ) * Response time January 2010 ( tr : TYP. 4s at VCE = 2V, IC = 2mA, RL = 100 ) * Dual-in-line package : LTV-817 : 1-channel type LTV-827 : 2-channel type LTV-847 : 4-channel type * Wide lead spacing package : LTV-817M : 1-channel type LTV-827M : 2-channel type LTV-847M : 4-channel type * Surface mounting package : LTV-817S : 1-channel type LTV-827S : 2-channel type LTV-847S : 4-channel type * Tape and reel packaging : LTV-817S-TA : 1-channel type LTV-817S-TA1 : 1-channel type LTV-817S-TP : 1-channel type LTV-827S-TA1 : 2-channel type * Safety approval UL / CSA / FIMKO / NEMKO / DEMKO / SEMKO / VDE* approved *Required “V” ordering option * RoHS compliance * ◇ Critical characteristic * ○ Safety or compliance characteristic Part No. : LTV-817 / 827 / 847 (M, S, S-TA, S-TA1, S-TP) Series BNS-OD-C131/A4 Page : 1 of 15 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only OUTLINE DIMENSIONS LTV-817 : TYPE I (INK MARK) TYPE II (LASER MARK) LTV-827 : *1. Year date code. *2. 2-digit work week. *3. Factory identification mark shall be marked. (Z : Taiwan, Y : Thailand, X : China-TJ, W : China-CZ) *4. Rank shall be or shall not be marked. Part No. : LTV-817 / 827 / 847 (M, S, S-TA, S-TA1, S-TP) Series BNS-OD-C131/A4 Page : 2 of 15 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only OUTLINE DIMENSIONS LTV-847 : LTV-817M : TYPE I (INK MARK) TYPE II (LASER MARK) *1. Year date code. *2. 2-digit work week. *3. Factory identification mark shall be marked. (Z : Taiwan, Y : Thailand, X : China-TJ, W : China-CZ) *4. Rank shall be or shall not be marked. Part No. : LTV-817 / 827 / 847 (M, S, S-TA, S-TA1, S-TP) Series BNS-OD-C131/A4 Page : 3 of 15 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only OUTLINE DIMENSIONS LTV-827M : LTV-847M : *1. Year date code. *2. 2-digit work week. *3. Factory identification mark shall be marked. (Z : Taiwan, Y : Thailand, X : China-TJ, W : China-CZ) *4. Rank shall be or shall not be marked. Part No. : LTV-817 / 827 / 847 (M, S, S-TA, S-TA1, S-TP) Series BNS-OD-C131/A4 Page : 4 of 15 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only OUTLINE DIMENSIONS LTV-817S : TYPE I (INK MARK) TYPE II (LASER MARK) LTV-827S : *1. Year date code. *2. 2-digit work week. *3. Factory identification mark shall be marked. (Z : Taiwan, Y : Thailand, X : China-TJ, W : China-CZ) *4. Rank shall be or shall not be marked. Part No. : LTV-817 / 827 / 847 (M, S, S-TA, S-TA1, S-TP) Series BNS-OD-C131/A4 Page : 5 of 15 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only OUTLINE DIMENSIONS LTV-847S : *1. Year date code. *2. 2-digit work week. *3. Factory identification mark shall be marked. (Z : Taiwan, Y : Thailand, X : China-TJ, W : China-CZ) *4. Rank shall be or shall not be marked. Part No. : LTV-817 / 827 / 847 (M, S, S-TA, S-TA1, S-TP) Series BNS-OD-C131/A4 Page : 6 of 15 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only TAPING DIMENSIONS LTV-817S-TA1 : LTV-827S-TA1 : Description Tape wide Pitch of sprocket holes Distance of compartment Distance of compartment to compartment Symbol W P0 F P2 P1 Part No. : LTV-817 / 827 / 847 (M, S, S-TA, S-TA1, S-TP) Series BNS-OD-C131/A4 Dimensions in mm ( inches ) 16  0.3 ( .63 ) 4  0.1 ( .15 ) 7.5  0.1 ( .295 ) 2  0.1 ( .079 ) 12  0.1 ( .472 ) Page : 7 of 15 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only TAPING DIMENSIONS LTV-817S-TA : LTV-817S-TP : Description Tape wide Pitch of sprocket holes Distance of compartment Distance of compartment to compartment Symbol W P0 F P2 P1 Part No. : LTV-817 / 827 / 847 (M, S, S-TA, S-TA1, S-TP) Series BNS-OD-C131/A4 Dimensions in mm ( inches ) 16  0.3 ( .63 ) 4  0.1 ( .15 ) 7.5  0.1 ( .295 ) 2  0.1 ( .079 ) 12  0.1 ( .472 ) Page : 8 of 15 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only ABSOLUTE MAXIMUM RATING ( Ta = 25C ) PARAMETER SYMBOL RATING UNIT Forward Current IF 50 mA Reverse Voltage VR 6 V Power Dissipation P 70 mW Collector - Emitter Voltage VCEO 35 V Emitter - Collector Voltage VECO 6 V Collector Current IC 50 mA Collector Power Dissipation PC 150 mW Ptot 200 mW Viso 5,000 Vrms Operating Temperature(LTV- 827 / 847) Topr -30 ~ +110 C Operating Temperature (LTV-817) Topr -30 ~ +110 C Storage Temperature Tstg -55 ~ +125 C Tsol 260 C INPUT OUTPUT Total Power Dissipation *1 Isolation Voltage ○ *2 Soldering Temperature *1. AC For 1 Minute, R.H. = 40 ~ 60% Isolation voltage shall be measured using the following method. (1) Short between anode and cathode on the primary side and between collector and emitter on the secondary side. (2) The isolation voltage tester with zero-cross circuit shall be used. (3) The waveform of applied voltage shall be a sine wave. *2. For 10 Seconds Part No. : LTV-817 / 827 / 847 (M, S, S-TA, S-TA1, S-TP) Series BNS-OD-C131/A4 Page : 9 of 15 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only ELECTRICAL - OPTICAL CHARACTERISTICS ( Ta = 25C ) PARAMETER INPUT OUTPUT VF — 1.2 1.4 V IF=20mA Reverse Current IR — — 10 A VR=4V Terminal Capacitance Ct — 30 250 pF V=0, f=1KHz Collector Dark Current ICEO — — 100 nA VCE=20V, IF=0 Collector-Emitter Breakdown Voltage BVCEO 35 — — V IC=0.1mA IF=0 Emitter-Collector Breakdown Voltage BVECO 6 — — V IE=10A IF=0 IC 2.5 — 30 mA CTR 50 — 600 % Collector-Emitter Saturation Voltage VCE(sat) — 0.1 0.2 V IF=20mA IC=1mA Isolation Resistance Riso —  DC500V 40 ~ 60% R.H. Floating Capacitance Cf — 0.6 1 pF V=0, f=1MHz Cut-Off Frequency fc — 80 — kHz Response Time (Rise) tr — 4 18 s Response Time (Fall) tf — 3 18 s *1 Current Transfer Ratio ◇ *1 CTR  IC 51010 11011 IF=5mA VCE=5V VCE=5V, IC=2mA RL=100, -3dB VCE=2V, IC=2mA RL=100  100% IF Part No. : LTV-817 / 827 / 847 (M, S, S-TA, S-TA1, S-TP) Series BNS-OD-C131/A4 CONDITIONS Forward Voltage Collector Current TRANSFER CHARACTERISTICS SYMBOL MIN. TYP. MAX. UNIT Page : 10 of 15 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only RANK TABLE OF CURRENT TRANSFER RATIO CTR MODEL NO. RANK MARK CTR ( % ) L 50 ~ 100 A 80 ~ 160 B 130 ~ 260 C 200 ~ 400 D 300 ~ 600 L or A or B or C or D 50 ~ 600 No Bin 50~600 B 130 ~ 260 C 200 ~ 400 BC 130~400 CD 200~600 No Bin 50~600 BC 130~400 CD 200~600 LTV-817 LTV-827 LTV-847 IF = 5 mA CONDITIONS VCE = 5 V Ta = 25 C Part No. : LTV-817 / 827 / 847 (M, S, S-TA, S-TA1, S-TP) Series BNS-OD-C131/A4 Page : 11 of 15 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only CHARACTERISTICS CURVES F ig .1 F o rw o rd C u rre n t F ig .2 C o lle cto r P o w e r D is sip tio n v s . A m b ie n t T e m p e ra tu te v s . A m b ie n t T e m p e ra tu re C o llec to r Po w er d issip atio n Pc (m W) 60 Fo rw ard c urrent I F (m A) 50 40 30 20 10 0 -30 0 25 50 75 100 200 150 100 50 0 -30 125 0 25 50 75 100 o Am b ient tem p erature Ta ( C ) F ig .3 C o lle c to r-e m itte r S a tu ra tio n F ig .4 F o rw a rd C u rre n t v s. F o rw a rd V o lta g e 500 O Ta= 25 C o Fo rw ard c urrent I F (m A) 5m A 7m A 3m A Ic = 0.5m A C o llec o tr-em itter saturatio n vo ltag e VC E (sat) (V) 5 1m A V o lta g e v s . F o rw a rd C u rre n t 6 4 3 2 Ta= 75 C 50 C o 200 o 100 o 50 20 10 5 2 1 0 5 10 15 0 1.0 0.5 1.5 2.0 2.5 3.0 Fo rw ard vo ltag e VF (V) Fo rw ard c urrent IF (m A) F ig .5 C u rre n t T ra n s fe r R a tio vs. F ig .6 C o lle cto r C u rre n t vs. F o rw a rd C u rre n t C o lle cto r-e m itte r V o lta g e 200 30 V C E = 5V 180 I F = 30m A o Ta= 25 C o Ta= 25 C C o llec to r c urrent Ic (m A) C urrent transfer ratio C TR (%) o 25 C 0 C -25 C 1 0 160 140 120 100 80 60 40 20m A 25 Pc (M AX.) 20 15 10m A 10 5m A 5 20 0 0 1 2 5 10 20 50 0 Fo rw ard c urrent I F (m A) Part No. : LTV-817 / 827 / 847 (M, S, S-TA, S-TA1, S-TP) Series BNS-OD-C131/A4 125 o Am b ient tem p erature Ta ( C ) 1 2 3 4 5 6 7 8 9 C o llec to r-em itter vo ltag e VC E (V) Page : 12 of 15 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only CHARACTERISTICS CURVES F ig .7 R e la tive C u rre n t T ra n sfe r R a tio F ig .8 C o lle cto r-e m itte r S a tu ra tio n V o lta g e vs. A m b ie n t T e m p e ra tu re vs. A m b ie n t T e m p e ra tu re 0.16 I F = 5m A C o llec to r-em itter saturatio n vo ltag e VC E (sat) (V) Relative c urrent transfer ratio (%) 150 V C E = 5V 100 50 0 -30 0 25 50 75 100 I F = 20m A 0.14 Ic = 1m A 0.12 0.10 0.08 0.06 0.04 0.02 0 -25 125 0 Am b ient tem p erature Ta ( C ) 75 100 125 F ig .1 0 R e sp o n se T im e vs. L o a d A m b ie n t T e m p e ra tu re R e sista n ce -5 500 V C E = 20V 200 -6 10 100 Resp o nse tim e ( s) C o llec to r d ark c urrent I C EO (A) 50 Am b ient tem p erature Ta ( C ) F ig .9 C o lle cto r D a rk C u rre n t vs. 10 25 o o -7 10 -8 10 -9 10 VC E = 2V Ic = 2m A o Ta= 25 C 50 tr 20 tf 10 td 5 ts 2 1 -10 10 0.5 -11 10 -25 0 25 50 75 100 o 0.2 0.05 0.1 0.2 0.5 1 2 Lo ad resistanc e R L (k Am b ient tem p erature Ta ( C ) 5 10 ) T e st C ircu it fo r R e sp o n se T im e F ig .1 1 F re q u e n cy R e sp o n se Vo ltag e g ain Av (d B ) 125 VC E = 2V Ic = 2m A o Ta= 25 C 0 10 R L= 10k 1k 100 T e st C ircu it fo r F re q u e n cy R e sp o n se 20 0.5 1 2 5 10 20 50 100 500 Freq uenc y f (kH z) Part No. : LTV-817 / 827 / 847 (M, S, S-TA, S-TA1, S-TP) Series BNS-OD-C131/A4 Page : 13 of 15 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only RECOMMENDED FOOT PRINT PATTERNS (MOUNT PAD) Unit : mm 4 PIN 8 PIN 16 PIN Part No. : LTV-817 / 827 / 847 (M, S, S-TA, S-TA1, S-TP) Series BNS-OD-C131/A4 Page : 14 of 15 LITE - O N TECH NO LO G Y CO RP O RATIO N Property of LITE-ON Only Notes: - Lite-On is continually improving the quality, reliability, function or design and Lite-On reserves the right to make changes without further notices. - The products shown in this publication are designed for the general use in electronic applications such as office automation equipment, communications devices, audio/visual equipment, electrical application and instrumentation. - For equipment/devices where high reliability or safety is required, such as space applications, nuclear power control equipment, medical equipment, etc, please contact our sales representatives. - When requiring a device for any ”specific” application, please contact our sales in advice. - If there are any questions about the contents of this publication, please contact us at your convenience. - The contents described herein are subject to change without prior notice. Part No. : LTV-817 / 827 / 847 (M, S, S-TA, S-TA1, S-TP) Series BNS-OD-C131/A4 Page : 15 of 15
LTV-847S 价格&库存
很抱歉,暂时无法提供与“LTV-847S”相匹配的价格&库存,您可以联系我们找货
LTV-847S
  • 5+2.48950
  • 50+1.87460
  • 150+1.64020
  • 400+1.28210
  • 2400+1.15920
  • 4800+1.08520
库存:31793
LTV-847S
  • 1+1.41231
  • 30+1.36361
  • 100+1.26621
  • 500+1.16880
  • 1000+1.12010
库存:400
LTV-847S
  • 25+3.2835825+0.41070
  • 125+3.19483125+0.39960
  • 625+3.06172625+0.38295
  • 1875+3.017341875+0.37740
  • 5000+2.928605000+0.36630
库存:224236
